2004 Mk5 VW Golf wont start PRNDS flashing
croozir
New Zealand
C?ID=376022
Hi This is my first post daughters VW golf has issues I checked the ECU relay it appears to be serviceable copy of scan result attached I suspect it could be a transmission problem any assistance is greatly appreciated many thanks
Monday,07,September,2020,16:10:28:18660
VIN: WVWZZZ1KZ4W120792   License Plate: BZE463
Mileage: 285230km-177233mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 7D
VIN: WVWZZZ1KZ4W120792   Mileage: 285230km-177233miles
00-Steering Angle Sensor -- Status: Sporadic communication error 1000
01-Engine -- Status: Cannot be reached 1100
02-Auto Trans -- Status: Malfunction 1010
46-Central Conv. -- Status: Malfunction 1010
56-Radio -- Status: Sporadic communication error 1000
Address 01: Engine
   Part No SW: 02E 300 041 K    HW: 02E 927 770 L
   Component: GSG DSG             0702
   Revision: 02904010    Serial number: 00000403010172
   Shop #: WSC 05200 824 57105
   VCID: 1A6DD21BF09B379BBC7-804E
18258 - Powertrain Data Bus
            P1850 - 000 - Missing Message from ECU
18148 - Clutch Temperature Monitoring
            P1740 - 012 -
18259 - Powertrain Data Bus
            P1851 - 000 - Missing Message from ABS Controller - Intermittent
   Part No: 1K0 907 379 K
   Component: ESP FRONT MK60      0103
   Coding: 0023170
   Shop #: WSC 00010 824 05318
   VCID: 3A2D329B505B179B5C7-806E
   Part No: 1K0 907 044 BA
   Component: ClimatronicPQ35 066 0606
   VCID: 678BBBEF73695A73F39-8032
Address 09: Cent. Elect.
   Part No SW: 1K0 909 605 A    HW: 1K0 909 605 A
   Component: 0M AIRBAG VW8   022 0500
   Revision: 04022000    Serial number: 0033FD0A78U3
   Coding: 0012365
   Shop #: WSC 01268 785 00200
   VCID: 2A0D02DBA0FBA71B2C7-807E
   Subsystem 1 - Serial number: 6332MSME560B4502
   Subsystem 2 - Serial number: 6342MSME27494702
   Subsystem 3 - Serial number: 6351HSME63036E01
   Subsystem 4 - Serial number: 6361HSME5F046C01
   Part No SW: 1K0 953 549 A    HW: 1K0 953 549 A
   Component: Lenksäulenmodul 012 0030
   Coding: 0010012
   Shop #: WSC 01279 785 00200
   VCID: 303910B38627DDCBE23-8064
00002 - Transmission Control Unit
   Part No: 1K0 920 860 LX
   Component: KOMBIINSTRUMENT VDD 3354
   Coding: 0002101
   Shop #: WSC 05200 824 15413
   VCID: 094F9D57453DCC0305D-805C
   Part No SW: 1K0 907 530 C    HW: 1K0 907 951
   Component: Gateway         H08 0080
   Revision: 08          Serial number: 260010430207CF
   Coding: 3F3F0B40070003
   VCID: 270BFBEFB3E99A73339-8072
9 Faults Found:
                    Fault Frequency: 16
                    Reset counter: 199
                    Mileage: 285210 km
                    Time: 14:59:40
                    Reset counter: 238
                    Mileage: 285210 km
                    Time: 15:03:17
                    Reset counter: 238
                    Mileage: 285210 km
                    Time: 15:03:49
01304 - Radio
                    Reset counter: 238
                    Mileage: 285210 km
                    Time: 15:03:51
                    Fault Status: 00101110
                    Fault Frequency: 92
                    Reset counter: 239
                    Time Indication: 15
                    Reset counter: 238
                    Mileage: 285211 km
                    Time: 00:00:21
                    Reset counter: 238
                    Mileage: 285211 km
                    Time: 00:00:59
                    Reset counter: 238
                    Mileage: 285211 km
                    Time: 00:01:25
                    Reset counter: 239
                    Mileage: 285233 km
   Component: IMMO                3354
   Shop #: WSC 05200 824 94533
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN1.lbl
   Part No: 1K0 959 701 E
   Component: Tuersteuergeraet 09 0116
   Coding: 0000052
   Part No: 1K2 909 144 F
   Component: EPS_ZFLS Kl.3       1301
   VCID: 2F3B13CF9B19C233FB9-807A
                    Mileage: 5200 km
                    Temperature: 16.0°C
                    Voltage: 12.00 V
                    Voltage: 11.80 V
00625 - Vehicle Speed Signal
                    Mileage: 5200 km
                    Temperature: 16.0°C
                    Voltage: 12.10 V
                    Voltage: 11.90 V
   Part No: 1K0 959 433 T
   Component: 0W KSG              0560
   Coding: 80E802087F2D8505485FC61000
   VCID: 41DF45773D8D44431DD-8014
   Subsystem 1 - Part No: 1K0 951 605 A
   Component: LIN BACKUP HORN H01 1201
   Subsystem 2 - Part No: 1K0 907 719
   Component: Neigungssensor  003 0003
   Subsystem 3 - Part No: 1K0 951 177
   Component: Innenraumueberw.004 0101
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN1.lbl
   Part No: 1K0 959 702 E
   Coding: 0000052
   VCID: 313F15B78D2DD4C3EDD-8064
01553 - Motor for Central Locking; Passenger Door (V57); Lock
   Part No: 1K0 035 186 J
   Component: Radio BNO           0016
   Coding: 0040400
   VCID: 2D0709C79115B023C95-8078
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN1.lbl
   Part No: 1K0 959 703 C
   Component: Tuersteuergeraet 06 0202
   Coding: 0000016
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN1.lbl
   Part No: 1K0 959 704 C
   Coding: 0000016
Address 7D: Aux. Heat        Labels: 1K0-963-235.lbl
   Part No SW: 1K0 963 235 D    HW: 1K0 963 235 D
   Component: PTC-Element         0404
   Revision: 00700000    Serial number:
   VCID: 2C0104C3AA0FB92BDEB-8078
End----------(Elapsed Time: 01:23, VBatt start/end: 12.2V/12.2V)-----------
Monday,07,September,2020,16:12:56:18660
Address 01: Engine
            P1740 - 012 -
   Coding: 0023170
   Coding: 0012365
   Coding: 0010012
   Coding: 0002101
9 Faults Found:
                    Fault Frequency: 16
                    Reset counter: 199
                    Mileage: 285210 km
                    Time: 14:59:40
                    Reset counter: 238
                    Mileage: 285210 km
                    Time: 15:03:17
                    Reset counter: 238
                    Mileage: 285210 km
                    Time: 15:03:49
01304 - Radio
                    Reset counter: 238
                    Mileage: 285210 km
                    Time: 15:03:51
                    Fault Frequency: 92
                    Reset counter: 239
                    Time Indication: 15
                    Reset counter: 238
                    Mileage: 285211 km
                    Time: 00:00:21
                    Reset counter: 238
                    Mileage: 285211 km
                    Time: 00:00:59
                    Reset counter: 238
                    Mileage: 285211 km
                    Time: 00:01:25
                    Reset counter: 239
                    Mileage: 285233 km
   Coding: 0000052
                    Mileage: 5200 km
                    Temperature: 16.0°C
                    Voltage: 12.00 V
                    Voltage: 11.80 V
                    Mileage: 5200 km
                    Temperature: 16.0°C
                    Voltage: 12.10 V
                    Voltage: 11.90 V
   Coding: 0000052
   Coding: 0040400
   Coding: 0000016
   Coding: 0000016
End----------(Elapsed Time: 01:19, VBatt start/end: 12.1V/12.1V)-----------
Address 01: Engine
            P1740 - 012 -
   Coding: 0023170
   Coding: 0012365
   Coding: 0010012
   Coding: 0002101
9 Faults Found:
                    Fault Frequency: 16
                    Reset counter: 199
                    Mileage: 285210 km
                    Time: 14:59:40
                    Reset counter: 238
                    Mileage: 285210 km
                    Time: 15:03:17
                    Reset counter: 238
                    Mileage: 285210 km
                    Time: 15:03:49
01304 - Radio
                    Reset counter: 238
                    Mileage: 285210 km
                    Time: 15:03:51
                    Fault Frequency: 92
                    Reset counter: 239
                    Time Indication: 15
                    Reset counter: 238
                    Mileage: 285211 km
                    Time: 00:00:21
                    Reset counter: 238
                    Mileage: 285211 km
                    Time: 00:00:59
                    Reset counter: 238
                    Mileage: 285211 km
                    Time: 00:01:25
                    Reset counter: 239
                    Mileage: 285233 km
   Coding: 0000052
                    Mileage: 5200 km
                    Temperature: 16.0°C
                    Voltage: 12.00 V
                    Voltage: 11.80 V
                    Mileage: 5200 km
                    Temperature: 16.0°C
                    Voltage: 12.10 V
                    Voltage: 11.90 V
   Coding: 0000052
   Coding: 0040400
   Coding: 0000016
   Coding: 0000016
Address 01: Engine
            P1740 - 012 -
   Coding: 0023170
   Coding: 0012365
   Coding: 0010012
   Coding: 0002101
9 Faults Found:
                    Fault Frequency: 16
                    Reset counter: 199
                    Mileage: 285210 km
                    Time: 14:59:40
                    Reset counter: 238
                    Mileage: 285210 km
                    Time: 15:03:17
                    Reset counter: 238
                    Mileage: 285210 km
                    Time: 15:03:49
01304 - Radio
                    Reset counter: 238
                    Mileage: 285210 km
                    Time: 15:03:51
                    Fault Frequency: 92
                    Reset counter: 239
                    Time Indication: 15
                    Reset counter: 238
                    Mileage: 285211 km
                    Time: 00:00:21
                    Reset counter: 238
                    Mileage: 285211 km
                    Time: 00:00:59
                    Reset counter: 238
                    Mileage: 285211 km
                    Time: 00:01:25
                    Reset counter: 239
                    Mileage: 285233 km
   Coding: 0000052
                    Mileage: 5200 km
                    Temperature: 16.0°C
                    Voltage: 12.00 V
                    Voltage: 11.80 V
                    Mileage: 5200 km
                    Temperature: 16.0°C
                    Voltage: 12.10 V
                    Voltage: 11.90 V
   Coding: 0000052
   Coding: 0040400
   Coding: 0000016
   Coding: 0000016
Address 01: Engine
            P1740 - 012 -
   Coding: 0023170
   Coding: 0012365
   Coding: 0010012
   Coding: 0002101
9 Faults Found:
                    Fault Frequency: 16
                    Reset counter: 199
                    Mileage: 285210 km
                    Time: 14:59:40
                    Reset counter: 238
                    Mileage: 285210 km
                    Time: 15:03:17
                    Reset counter: 238
                    Mileage: 285210 km
                    Time: 15:03:49
01304 - Radio
                    Reset counter: 238
                    Mileage: 285210 km
                    Time: 15:03:51
                    Fault Frequency: 92
                    Reset counter: 239
                    Time Indication: 15
                    Reset counter: 238
                    Mileage: 285211 km
                    Time: 00:00:21
                    Reset counter: 238
                    Mileage: 285211 km
                    Time: 00:00:59
                    Reset counter: 238
                    Mileage: 285211 km
                    Time: 00:01:25
                    Reset counter: 239
                    Mileage: 285233 km
   Coding: 0000052
                    Mileage: 5200 km
                    Temperature: 16.0°C
                    Voltage: 12.00 V
                    Voltage: 11.80 V
                    Mileage: 5200 km
                    Temperature: 16.0°C
                    Voltage: 12.10 V
                    Voltage: 11.90 V
   Coding: 0000052
   Coding: 0040400
   Coding: 0000016
   Coding: 0000016
Address 01: Engine
            P1740 - 012 -
   Coding: 0023170
   Coding: 0012365
   Coding: 0010012
   Coding: 0002101
9 Faults Found:
                    Fault Frequency: 16
                    Reset counter: 199
                    Mileage: 285210 km
                    Time: 14:59:40
                    Reset counter: 238
                    Mileage: 285210 km
                    Time: 15:03:17
                    Reset counter: 238
                    Mileage: 285210 km
                    Time: 15:03:49
01304 - Radio
                    Reset counter: 238
                    Mileage: 285210 km
                    Time: 15:03:51
                    Fault Frequency: 92
                    Reset counter: 239
                    Time Indication: 15
                    Reset counter: 238
                    Mileage: 285211 km
                    Time: 00:00:21
                    Reset counter: 238
                    Mileage: 285211 km
                    Time: 00:00:59
                    Reset counter: 238
                    Mileage: 285211 km
                    Time: 00:01:25
                    Reset counter: 239
                    Mileage: 285233 km
   Coding: 0000052
                    Mileage: 5200 km
                    Temperature: 16.0°C
                    Voltage: 12.00 V
                    Voltage: 11.80 V
                    Mileage: 5200 km
                    Temperature: 16.0°C
                    Voltage: 12.10 V
                    Voltage: 11.90 V
   Coding: 0000052
   Coding: 0040400
   Coding: 0000016
   Coding: 0000016
Jef
HQ
The trans isn't your main issue at this time.. it is the dead ECM. In order for any given control module to communicate, it must have the Holy Trinity:
You need to verify powers/grounds/data for the ECM are to factory design. This could be as simple as a blown fuse. Do a bit of digging into this, then ship over a few cases of L&P.... USPS has lost one of mine in Atlanta.
croozir
New Zealand
C?ID=376022
Many thanks Jef I will start chasing wires and power issues L&P Yeah can do with a few peanut slabs :)
croozir
New Zealand
C?ID=376022
HI Jef Just letting you know how I got on with this problem I did NOT have the small yellow engine caution light on the tacho (embedded on tacho face) when I turned on the ignition which was a clue. I pulled all the fuses under the bonnet "All good" tested with an multimeter I then pulled all the fuses in the interior fuse panel "All good" did not replace anything rechecked the ignition the yellow engine caution light was ON on the tacho face and PRNDS was Not flashing anymore engine started first crank and has had about 30 starts with no issues. So a bit of head scratching going on, I just thought I would post to let all users know the outcome might help someone cheers
15 year old car. Corrosion on electrical connections? Such a thing will often be cured temporarily by unplugging and re-plugging the connection, as you have apparently done with all those fuses.
croozir
New Zealand
C?ID=376022
Agreed Uwe I noted some discolouration/oxidation on some fuse blades
croozir
New Zealand
C?ID=376022
Finally got to the source of this intermittent problem car wouldn't start again with PRNDS flashing and no engine caution Icon on tachometer. I left the ignition on and moved one fuse side to side at a time on the interior fuse box whilst observing the caution and PRNDS light. When I moved fuse No20 it felt slightly loose (but not much more than normal to cause any suspicions) and I could hear a relay energising the light came back on and PRNDS stopped flashing. I pulled the fuse no corrosion and fuse tested OK. Replaced the fuse with same problem so fuse was not defective. I removed the fusebox out to check wiring at the back of the fusebox, wires found OK and secure. Next I inspected the fuse receptacle contacts they were found to be spread a little with not much tension to clasp the fuse blade. Tweaked the fuse receptacle contacts to provide more tension on the fuse blades ..Problem seems to be rectified hope this helps others....
iichel
Eindhoven, NB, NL
C?ID=284912
Great fix, the holy trinity did apply here. Power was missing, and intermittent errors are always SUPER annyoing.
