Smith Audi A5 T8 2.0TDI 2012
Mr_Smith
Belgium
H11-037290 (2nd hand?)
Dear audi lovers
I am new to this forum, drive an audi A5 T8 2.0TDI Quattro which is a super car
Lately the engine starts to shake at idle and when the engine is still cold. Warm engine is better but still not 100%
I coud take the car to the dealer where is the fun of it ?
I decided to invest in HEX V2 cable from Ross Tech and installed the VCDS software
All is running fine and I am ready to diagnose..
I could use some help here step by step.. There's a lot of information out here, I know.
Just want to do it step by step and understand with the manual what I am doing
Mr_Smith
Belgium
Dimanche,06,Septembre,2020,16:15:46:63919
VCDS -- Logiciel d'émulation de VAG/VAS sous Windows 10 x64
Version VCDS: FRM 19.6.2.1  HEX-V2 CB: 0.4508.4
Version données: 20190930 DS308.0
[url]www.rosstech.fr[/url]
VIN: WAUZZZ8T3AA056944   Plaque d'immat.:
Type chassis: 8T-AU48 (8T0)
Scanner: 01 03 05 08 09 0E 10 15 16 17 19 42 46 47 52 53 55 56 5F 62
          6C 72
VIN: WAUZZZ8T3AA056944   Kilométrage: 189350km
01-Moteur -- Etat: Défaut 0010
03-Freins ABS -- Etat: OK 0000
04-Angle de direction -- Etat: OK 0000
05-Autor. démarrage -- Etat: Défaut 0010
08-Climatronic -- Etat: OK 0000
09-Centrale Elec. -- Etat: OK 0000
0E-Lect. multiméd. 1 -- Etat: OK 0000
10-Assistance stationnt -- Etat: OK 0000
15-Airbags -- Etat: OK 0000
16-Volant multifonct. -- Etat: OK 0000
17-Instruments -- Etat: OK 0000
19-Gateway CAN -- Etat: OK 0000
42-Porte conducteur -- Etat: OK 0000
46-Module confort -- Etat: OK 0000
47-Sonorisation -- Etat: OK 0000
52-Porte passager -- Etat: OK 0000
53-Frein de stationnt -- Etat: OK 0000
55-Portée des feux -- Etat: Défaut 0010
56-Radio -- Etat: OK 0000
5F-Electr. d'informat. -- Etat: Défaut 0010
62-Porte AR gauche -- Etat: OK 0000
6C-Caméra recul -- Etat: Défaut 0010
72-Porte AR droite -- Etat: OK 0000
Adresse 01: Moteur (J623-CAHA)       Labels:. 03L-906-019-CAG.clb
   No. pièce Log: 03L 906 022 RM    Mat: 03L 906 019 AL
   Pièce: R4 2,0L EDC   H22 8422
   Révision: 25H22---
   Codage: 1A194012232603080000
   No. Atelier: WSC 42749 133 86274
   Jeu de données ASAM: EV_ECM20TDI03L906022RM A02005
   ROD: EV_ECM20TDI03L906022NP.rod
   VCID: 015F80A1A18690FFC68-8054
1 Code défaut trouvé:
5175 - Régulation de pression de cabrurant Différence de régulation
          P1065 00 [109] - -
          Confirmé - Testé depuis RàZ mémoire
             Capture:
                    Etat du défaut: 00000001
                    Priorité du défaut: 2
                    Fréquence du défaut: 3
                    Kilométrage: 187893 km
                    Date: 2020.07.31
                    Temps: 09:52:52
                    Régime moteur: 1607.50 /min
                    Valeur de charge normée: 58.8 %
                    Vitesse du véhicule: 25 km/h
                    Température du liquide de refroidissem.: 58 °C
                    Température air d'admission: 36 °C
                    Pression de l'air ambiant: 1010 mbar
                    Tension borne 30: 12.900 V
                    Compteur de désapprentissage selon OBD: 40
                    Co Eng st: COENG_RUNNING
                    Co Eng st-Test_Program_Co Eng st COMPU VERB UBYTE: 3
Tests passés: 0 0 0 0 0
Adresse 03: Freins ABS (J104)       Labels:. 8K0-907-379-V1.clb
   No. pièce Log: 8K0 907 379 BE    Mat: 8K0 907 379 BE
   Pièce: ESP8 quattro  H04 0030
   Révision: --------    No. de série: --------------
   Codage: 180D0C
   No. Atelier: WSC 06325 000 00000
   VCID: 7DA7FC51DDFEF41FA20-8028
Aucun code défaut trouvé.
Adresse 05: Autor. démarrage (J393)       Labels:. 8K0-907-064-05.clb
   No. pièce Log: 8K0 907 064 DQ    Mat: 8K0 907 064 DQ
   Pièce: BCM2 1.1      H02 0327
   Révision: 00002001
   Codage: 072400
   VCID: 025D8FADA4008BE7DF2-8056
   Sous-système 1 - No. pièce Log: 8K0 905 852 D    Mat: 8K0 905 852 D
   Pièce: J764 ELV MLB  H37 0042
   No. de série: 0210000005952013
03285 - Capteur d'effleurement de poignée extérieure de porte AV G
            011 - Coupure
             Capture:
                    Etat du défaut: 01101011
                    Fréquence du défaut: 1
                    Compteur de RAZ: 76
                    Kilométrage: 187857 km
                    Heure: 0
                    Date: 2020.07.30
                    Temps: 16:31:55
Adresse 08: Climatronic (J255)       Labels:. 8Tx-820-043-3Z.clb
   No. pièce Log: 8T1 820 043 AK    Mat: 8T1 820 043 AK
   Pièce: KLIMA 3 ZONEN H08 0171
   Révision: C1000000    No. de série: 01030220100551
   Codage: 34300000
   VCID: 7AADF74DCCD0C327872-802E
Adresse 09: Centrale Elec. (J519)       Labels:. 8K0-907-063.clb
   No. pièce Log: 8K0 907 063 P    Mat: 8K0 907 063 P
   Pièce: BCM1 1.0      H25 0380
   Révision: 10025001    No. de série: 00000000576114
   Codage: 260050914034AF010009000300005D5D0F1C030804010161000000
   VCID: 3C21315586643D17D5E-8068
   Sous-système 1 - No. pièce Log: 8T1 955 119 D    Mat: 8J1 955 119   Labels: 1KX-955-119.CLB
   Pièce: WWS 280110  H14 0070
   No. de série: SWF10010285488
   Codage: 00FD11
   Sous-système 2 - No. pièce Log: 8K0 955 559     Mat: 8K0 955 559   Labels: 8K0-955-559.CLB
   Pièce: RLS  H04 0003
   No. de série: 10762994
   Codage: 02532C
   Sous-système 3 - No. pièce Log: 8K0 941 531 AL    Mat: 8K0 941 531 AL
   Pièce: E1 - LDS  H08 0090
   No. de série: 00000000002901100854
   Sous-système 4 - No. pièce Log: 8K0 907 410     Mat: 8K0 907 410
   Pièce: EHL205.06.02K  H02 0010
Adresse 0E: Lect. multiméd. 1 (R41)       Labels: 4E0-910-111.lbl
   No. pièce Log: 4E0 910 110 L    Mat: 4E0 035 110 A
   Pièce: CDC-MP3-Pana  H49 0050
   Révision: 00000015
   VCID: 211FE02101C670FFE68-8074
Adresse 10: Assistance stationnt (J446)       Labels:. 8K0-919-475.clb
   No. pièce Log: 8K0 919 475 R    Mat: 8K0 919 475 A
   Pièce: PARKHILFE 8K  H06 0070
   Révision: 11001001    No. de série: 50941003400130
   Codage: 30020F
   VCID: 48C95D85C2BC61B7416-801C
Adresse 15: Airbags (J234)       Labels:* 8K0-959-655.clb
   No. pièce Log: 8K0 959 655 G    Mat: 8K0 959 655 G
   Pièce: AirbagVW-AU10 H39 0560
   No. de série: 003EFD0BH5D5
   Codage: 30353438363030303030554A304C38543053
   Jeu de données ASAM: EV_AirbaECUVWAUDI010 003010
   VCID: 41DF40A1E10650FF868-8014
   Capteur de collision du sac gonflable latéral: côté conducteur:
   No. de série: 6334MSME50041637%
   Capteur de collision de sac gonflable latéral: côté passager:
   No. de série: 6344MSME4F250C36L
   Capteur de collision du sac gonflable latéral AR: côté cond.:
   No. de série: 6352QSME354D4804I
   Capteur de collision du sac gonflable latéral AR: côté pass.:
   No. de série: 6362QSME574D4036K
   Capteur de collision du sac gonflable frontal: côté conducteur:
   No. de série: 63732SME284E362C7
   Capteur de collision du sac gonflable frontal: côté passager AV:
   No. de série: 63832SME284E2614+
Adresse 16: Volant multifonct. (J527)       Labels:. 8K0-953-568.clb
   No. pièce Log: 8K0 953 568 F    Mat: 8K0 953 568 F
   Pièce: Lenks.Modul   H16 0014
   Révision: --------    No. de série: 90319JAR000LI
   Codage: 000016
   VCID: 3D273C519D7E341FE20-8068
   Pièce: E221 - MFL  H02 0003
Adresse 17: Instruments (J285)       Labels:. 8T0-920-xxx-17.clb
   No. pièce Log: 8T0 920 931 D    Mat: 8T0 920 931 D
   Pièce: KOMBIINSTR.   H36 0255
   Révision: 00000000    No. de série: CSF50F22A
   Codage: 0F0531000B000008010101
   No. Atelier: WSC 06325 123 12345
   VCID: 38292D45B25C1137316-806C
Adresse 19: Gateway CAN (J533)       Labels:. 8T0-907-468.clb
   No. pièce Log: 8T0 907 468 T    Mat: 8T0 907 468 K
   Pièce: GW-BEM 4CAN-M H09 0105
   Révision: EB800053    No. de série: 5300E101210495
   Codage: 00CF07
   VCID: 52FD7FED34E0DB672F2-8006
   Sous-système 1 - No. pièce Log: 8X0 915 181     Mat: 8X0 915 181
   Pièce: J367-BDM  H07 0125
   No. de série: 00000000002790957363
   Sous-système 2 - No. pièce Log: 8K0 959 663 B    Mat: 8K0 959 663 B
   Pièce: J532_DCDCStab  H04 0003
   No. de série: 10031000037011200410
Adresse 42: Porte conducteur (J386)       Labels:. 8K0-959-793.clb
   No. pièce Log: 8T0 959 793 J    Mat: 8T0 959 793 D
   Pièce: TSG FA        H07 1201
   Codage: 011C12625000450005
   VCID: 50F975E53AECA977196-8004
Adresse 46: Module confort (J393)       Labels:. 8K0-907-064-46.clb
   Révision: 00002001    No. de série: 0126472037
   Codage: 01000E20203944C50120043680000000
   Sous-système 1 - No. pièce Log: 8K0 959 719     Mat: 8K0 959 719
   Pièce: GTO BF  H06 0050
   No. de série: 00000000000000215466
   Sous-système 2 - No. pièce Log: 8K0 959 591 A    Mat: 8K0 959 591
   Pièce: J245 PS037  H06 0041
Adresse 47: Sonorisation (J525)       Labels:. 8T0-035-223-BOM.clb
   No. pièce Log: 8T0 035 223 AN    Mat: 8T0 035 223 AK
   Pièce: DSP Prem      H10 0190
   Révision: 00010001    No. de série: 34882001196701
Adresse 52: Porte passager (J387)       Labels:. 8K0-959-792.clb
   No. pièce Log: 8T0 959 792 J    Mat: 8T0 959 792 D
   Pièce: TSG BF        H07 1201
   Codage: 011C12225000450005
   VCID: 4FFB769927D2B68F00C-801A
Adresse 53: Frein de stationnt (J540)       Labels: 8K0-907-801-V1.clb
   No. pièce Log: 8K0 907 801 H    Mat: 8K0 907 801 H
   Pièce: EPB Audi B8   H09 0100
   Révision: 00000003    No. de série: 10000000421328
   No. Atelier: WSC 00000 000 00000
   VCID: 34311975AE34F5571DE-8060
Adresse 55: Portée des feux        Labels: 8T0-907-357.clb
   No. pièce Log: 8H0 907 357 B    Mat: 8H0 907 357 B
   Pièce: AFS 1           H01 0030
   Révision: 00000001    No. de série:
   Codage: 0000017
   No. Atelier: WSC 06324 000 00000
   VCID: 313F10615D26C07F768-8064
   Sous-système 1 - No. pièce: 7L6 941 329 C
   Pièce: AFS-Modul links H01 0004
   Sous-système 2 - No. pièce: 7L6 941 329 C
   Pièce: AFS-Modul rechtsH07 0004
02988 - Commutation circulation à droite/circulation à gauche active
            000 - - - Témoin allumé
             Capture:
                    Etat du défaut: 11100000
                    Priorité du défaut: 7
                    Compteur de RAZ: 134
                    Kilométrage: 189351 km
                    Heure: 0
                    Date: 2020.09.06
                    Temps: 14:16:23
Adresse 56: Radio (R)       Labels: Echec redir!
   No. pièce Log: 4F0 035 053 B    Mat: 4F0 035 053
   Pièce: Radio U Basic H45 0020
   Révision: AB001007    No. de série: 341BH0A7700350
   Codage: 010003010000000001
   VCID: 1C61D1D526A45D1735E-8048
Adresse 5F: Electr. d'informat. (J794)       Labels:. 4E0-035-6xx-5F.clb
   No. pièce Log: 8T1 035 670 E    Mat: 8T1 035 670 E
   Pièce: H-BNT-EU      H47 0047
   Révision: --------    No. de série: 491AT0A7532390
   Codage: 010100040106A1EF01000B1E000000030000
   VCID: 372B2E79BF421E4F38C-8062
   Sous-système 1 - No. pièce: 8R0 060 884 J
   Pièce: EUR 2010  1005
   Sous-système 2 - No. pièce Log: 4F0 919 604     Mat: 4F0 919 604
   Pièce: DU7 High  H43 0306
   No. de série: 9356BX0A1185557
   Sous-système 3 - No. pièce Log: 8T0 919 609 G    Mat: 8T0 919 609 G
   Pièce: E0380 Bedient  H08 0100
   No. de série: 00000000458487
   Sous-système 4 - No. pièce: 8R0 906 961 A
   Pièce:   CD-Database  1293
02244 - Bouton de l´organe de commande coincé
             Capture:
                    Etat du défaut: 00100000
                    Priorité du défaut: 5
                    Compteur de RAZ: 174
                    Heure: 0
                    Date: 2020.09.06
                    Temps: 14:24:13
             Capture:
                    Tension: 12.10 V
                    Bits: 10000000 00000000
                    Bits: 00000000 00000000
Adresse 62: Porte AR gauche (J388)       Labels:. 8K0-959-795.clb
   No. pièce Log: 8T0 959 795 J    Mat: 8T0 959 795 B
   Pièce: TSG HL        H05 1201
   Codage: 010C12224000450005
Adresse 6C: Caméra recul        Labels: 8T0-907-441.clb
   No. pièce Log: 8T0 907 441 C    Mat: 4L0 907 441 B
   Pièce: J772__Rearview      0040
   Révision: --H03---    No. de série: 525PA8-J9Z90GP
   Codage: 1020006
   VCID: 38292D45BE5C1137316-806C
02203 - Entrée audio/vidéo 1
            011 - Coupure - Intermittent
             Capture:
                    Etat du défaut: 00101011
                    Priorité du défaut: 4
                    Fréquence du défaut: 33
                    Compteur de RAZ: 170
                    Kilométrage: 187079 km
                    Heure: 0
                    Date: 2020.07.10
                    Temps: 09:36:18
             Capture:
                        Borne 15 ON
                        M.AR n.passée
                    Décompte: 3
Adresse 72: Porte AR droite (J389)       Labels:. 8K0-959-794.clb
   Pièce: TSG HR        H05 1201
Fin----(Temps écoulé: 01:46, VBatt début/fin: 11.9V/11.9V. VIgn 11.9V)-----
Hi,
Very few people on this forum speak (or read) French. Please post a scan from the standard English version of VCDS. You can download it from this page and it will happily coexist on your computer with the French translation you are currently using.
Mr_Smith
Belgium
Hi Uwe,
Ok, I will do so. Come back to you asap with english scna result
Mr_Smith
Belgium
Oooh boy. I installed the VCDS 20.4.2 ( english version ) on my Windows 10 pc. When I connect the HEX V2 interface ( blue led blinking ) , it is asking to update the interface firmware.. without success. The green led is blinking but the download is stuck.
When I use the the previous VCDS version 19.6.2, all is working fine
Yes, 20.4.2 does require higher firmware in the interface. However, I see no obvious reason for that at this time. Let me see if I can get @Shaun to take a look. This may not happen today since today is a holiday here in the USA.
Shaun
Hmm, that's a really rare one. It means the download is getting corrupted. What is your internet connection like? Do you have some kind of nannyware like firewall or antivirus? I would try disabling that and trying the update again. I would guess that this is either something to do with your internet connection or it is software like antivirus grabbing the download and trying to scan it and messing things up.
