2012 Passat SEL Premium Backup Camera
CFlow
C?ID=415194
Hello all,
Need some help. I have connected a Highline RVC using the Eurozone Tuning Harness. All is connected however, I cannot seem to program the backup camera. I get the Backup Camera not available.
I was able to go into 6c and calibrate the camera, however when I go into 6c Coding, I do not get the Coding helper to program it properly. The only place to put a code is in the Software coding section, still I get Coding Rejected, error 31: Request out of Range. When I run a fault code i get Malfunction 0010.
Link to videos of my process
https://www.dropbox.com/sh/xgmbfjjqnpzfejj/AAAhQsvAuSSTcOf-x05yccx-a?dl=0
 Sunday,06,September,2020,11:03:41:28871
VIN: 1VWCM7A30CC013494   License Plate: 12345
Mileage: 356750km-221674mi   Repair Order:
Chassis Type: A3-VW41 (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 36 37 42 44 46 47 4F
          52 56 62 6C 72 77
VIN: 1VWCM7A30CC013494   Mileage: 356750km-221674miles
37-Navigation -- Status: Malfunction 1010
6C-Back-up Cam. -- Status: Malfunction 1010
Address 01: Engine (0-32-CDVB)       Labels:. 03H-907-309-V1.clb
   Part No SW: 03H 906 023 E    HW: 03H 907 309 A
   Component: 3,6 FSI ULEV2 H04 3013
   Revision: MFH04---    Serial number:
   Coding: 001D0012242400008000
   Shop #: WSC 25106 444 104901
   ASAM Dataset: EV_ECM36FSI01103H906023E 001011
   ROD: EV_ECM36FSI01103H906023E.rod
   VCID: 2411E8CD7E5CF35B16B-8070
8221 - Unknown Error Code
          U3501 00 [032] - -
                    Mileage: 356704 km
                    Date: 2020.09.05
                    Time: 23:20:02
                    Engine speed: 0.00 /min
                    Coolant temperature: 27 °C
                    Intake air temperature: 38 °C
                    Voltage terminal 30: 8.669 V
                    Generator: load signal: 0.00 %
                    Torque request: sum of auxiliary aggregate: 0.0 Nm
4714 - Steering Column Control Module
          U0212 00 [032] - No Communications
                    Mileage: 356704 km
                    Date: 2020.09.06
                    Time: 02:12:02
                    Coolant temperature: 29 °C
                    Intake air temperature: 41 °C
                    Voltage terminal 30: 11.497 V
5649 - Throttle Control
          P3078 00 [104] - Airflow at Idle too Low
                    Mileage: 356611 km
                    Date: 2020.08.19
                    Time: 18:10:05
                    Engine speed: 1358.00 /min
                    Normed load value: 17.3 %
                    Vehicle speed: 28 km/h
                    Coolant temperature: 88 °C
                    Intake air temperature: 55 °C
                    Voltage terminal 30: 12.816 V
                    Height correction: 0.97308
                    Accelerator pedal: sensor voltage 1: 742.2 mV
                    Accelerator pedal: sensor voltage 2: 380.8 mV
                    Coolant temperature: -40 °C
                    Intake air temperature: -40 °C
                    Ambient air pressure: 0 mbar
                    Voltage terminal 30: 0.000 V
4511 - Camshaft Position Sensor B Bank 1 (G300)
          P0366 00 [096] - Implausible Signal
                    Mileage: 356704 km
                    Date: 2020.09.04
                    Time: 20:47:38
                    Engine speed: 249.50 /min
                    Normed load value: 92.9 %
                    Intake air temperature: 28 °C
                    Voltage terminal 30: 9.706 V
                    Camshaft adjustment intake bank 1: specified value: 25.000 °
                    Camshaft adjustment intake bank 1: actual value: 25.000 °
                    Coolant temperature at engine start: 27.8 °C
                    Engine oil temperature: 26.2 °C
                    Camshaft adaptation intake bank 1: phase position: 0.00 °
4261 - Unknown Error Code
          U3501 00 [096] - -
                    Mileage: 356704 km
                    Date: 2020.09.06
                    Time: 00:03:01
                    Intake air temperature: 37 °C
                    Voltage terminal 30: 6.596 V
   Part No SW: 02E 300 057 G    HW: 02E 927 770 AL
   Component: GSG DSG AG6     511 2701
   Revision: 05351113    Serial number: 00001105141495
   Shop #: WSC 09003 957 00200
   VCID: 1D67DD2951B6C293595-8048
18275 - Powertrain Data Bus
            P1867 - 000 - Missing Message from Steering Wheel (J527) - Intermittent
                    Fault Frequency: 255
                    Reset counter: 38
                    Mileage: 356704 km
                    Date: 2015.01.28
                    Time: 02:12:04
   Revision: 00H31001
   Coding: C54BC0F5492300FDA30F03ED921D0041A70000
   VCID: 7BA3F3B1A3E26CA3071-802E
                    Reset counter: 230
                    Mileage: 356532 km
                    Date: 2015.01.08
                    Time: 15:52:35
                    Count: 12
                    Count: 29184
                    Count: 16390
                    Count: 48384
                    Count: 64768
                    Reset counter: 230
                    Mileage: 356704 km
                    Date: 2015.01.27
                    Time: 23:39:58
                    Count: 7
                    Count: 13
                    Count: 28672
                    Count: 128
                    Count: 28928
                    Count: 7168
                    Count: 254
   Part No SW: 5K0 959 434 B    HW: 5K0 959 434 A
   Component: VWKESSYPQ35GP 085 0902
   Revision: 00085000    Serial number: 0143271823
   Coding: 130C0C
   ASAM Dataset: EV_KESSYPQ35G A02014
   VCID: 3431188DCEBC63DB86B-8060
65813 - Supply voltage
                    Reset counter: 229
                    Mileage: 356704 km
                    Date: 2020.09.05
                    Time: 23:20:26
   Part No SW: 561 907 044 D    HW: 561 907 044 D
   Component: Climatronic   H01 0102
   Revision: 00001001
   Coding: 0010001012
   VCID: 1869CC3DB214A7BB8A3-804C
13635840 - Supply voltage
          [Versorgungsspannung - unterer Grenzwert unterschritten]
                    Reset counter: 229
                    Mileage: 356704 km
                    Date: 2020.09.05
                    Time: 23:21:43
   Part No SW: 5K0 937 087 Q    HW: 5K0 937 087 Q
   Component: BCM PQ35 H+   111 0147
   Revision: BL111001
   Coding: 6F200E1B982B08D408880201360085480071008645A00DF064806000BC70
   VCID: 43D34B519B92D4630F1-8016
   Component: RLS 080911 05  54  0403
   Coding: 22300A
                    Reset counter: 229
                    Mileage: 356704 km
                    Date: 2015.01.27
                    Time: 23:17:37
                    Voltage: 8.90 V
                    Reset counter: 229
                    Mileage: 356704 km
                    Date: 2015.01.28
                    Time: 02:12:03
                    Voltage: 11.40 V
                    Reset counter: 229
                    Mileage: 356704 km
                    Date: 2015.01.27
                    Time: 23:21:01
                    Voltage: 8.30 V
                    Fault Status: 00101010
                    Reset counter: 229
                    Mileage: 356704 km
                    Date: 2015.01.27
                    Time: 03:25:40
                    Voltage: 11.65 V
02742 - Bulb for Brake/Turn Signal Light; Left
                    Reset counter: 229
                    Mileage: 356704 km
                    Date: 2015.01.24
                    Time: 05:56:21
                    Voltage: 13.55 V
02743 - Bulb for Brake/Turn Signal Light; Right
                    Reset counter: 229
                    Mileage: 356704 km
                    Date: 2015.01.24
                    Time: 05:56:21
                    Voltage: 13.55 V
   Part No SW: 5C0 959 655     HW: 5C0 959 655
   Component: AirbagVW10G   013 0809
   Serial number: 003END09B16.
   Coding: 0000354A
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01024
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 6FBBD7E1E71A0003BB9-803A
   Subsystem 1 - Part No SW: 5C6 959 339     HW: 5C6 959 339
   Component: BF-Gewichtss.  H10 0027
   Serial number: 6940000Y1100006R5108
   Coding: 303252
   Serial number: 3572MSME2727455DZZZ
   Serial number: 3582MSME2C336260ZZZS
   Serial number: 3516KSME075A4B11ZZZS
   Serial number: 3526KSME07234511ZZZD
   Serial number: 3556LSME76621712ZZZQ
   Serial number: 3566LSME59441712ZZZS
9442836 - Front Passenger's Airbag Disabled Indicator Lamp
          B1016 14 [136] - Open or Short to Ground
                    Mileage: 356704 km
                    Date: 2020.09.04
                    Time: 20:48:56
          [Powersupply  lower threshold fall short of]
                    Reset counter: 229
                    Mileage: 356704 km
                    Date: 2020.09.05
                    Time: 23:16:02
          B10B4 00 [008] - Function Restriction due to Undervoltage
                    Reset counter: 229
                    Mileage: 356704 km
                    Date: 2020.09.05
                    Time: 23:15:18
          B10B3 00 [008] - Function Restriction due to Implausible Message(s)
                    Reset counter: 229
                    Mileage: 356704 km
                    Date: 2020.09.05
                    Time: 23:14:47
   Part No SW: 1K5 953 521 AR    HW: 5K0 953 569 E
   Revision: FF010040    Serial number: 20110723300996
   Coding: 001A140000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 7DA7FDA9BD766293395-8028
   Component: E221__MFL-YVJ  H06 0022
   Coding: E30000
114178 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
                    Reset counter: 229
136194 - Supply voltage
                    Reset counter: 229
                    Mileage: 356704 km
                    Date: 2020.09.05
                    Time: 23:35:47
   Part No SW: 561 920 970 B    HW: 561 920 970 B
   Component: KOMBI         H07 0507
   Coding: 231E01
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04093
   ROD: EV_Kombi_UDS_VDD_RM09_004_VW41.rod
   VCID: 196FC939491EBEB3B5D-804C
12718592 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Steuergerät für Lenksäulenelektronik: keine Kommunikation]
                    Reset counter: 229
                    Mileage: 356704 km
                    Date: 2020.09.06
                    Time: 02:12:02
          [Supply voltage too low]
                    Reset counter: 229
                    Mileage: 356704 km
                    Date: 2020.09.05
                    Time: 23:20:27
   Part No SW: 7N0 907 530 K    HW: 1K0 907 951
   Component: J533  Gateway H40 1620
   Revision:   H40       Serial number: 15081101291219
   Coding: 466000
   VCID: 38292CBDD25487BBAA3-806C
7 Faults Found:
                    Fault Status: 00110100
                    Reset counter: 229
                    Mileage: 356704 km
                    Date: 2015.01.28
                    Time: 02:12:04
00469 - Infotainment Databus in Single Wire Operation
                    Fault Status: 00101011
                    Reset counter: 229
                    Mileage: 356704 km
                    Date: 2015.01.27
                    Time: 03:14:12
                    Reset counter: 229
                    Mileage: 356704 km
                    Date: 2015.01.27
                    Time: 03:14:16
01304 - Radio
                    Reset counter: 229
                    Mileage: 356704 km
                    Date: 2015.01.27
                    Time: 03:14:16
                    Fault Frequency: 13
                    Mileage: 356704 km
                    Date: 2015.01.27
                    Time: 03:14:12
                    Reset counter: 229
                    Mileage: 356704 km
                    Date: 2015.01.27
                    Time: 23:21:17
                    Reset counter: 229
                    Mileage: 356704 km
                    Date: 2015.01.27
                    Time: 05:00:26
   Component: IMMO          H07 0507
   Coding: 000007
   VCID: 6A8DC6F5DCF8E52BEC7-803E
   Part No SW: 5K0 905 861 A    HW: 5K0 905 861 A
   Component: ELV-PQ35      H20 0230
   Revision: 00000000    Serial number: 11000110773001
   Coding: 4900000000000000
   ROD: EV_ELVMarquMPVW36X_VW01.rod
   VCID: 2E050AE52090490BF0F-807A
          [Under voltage (continued)]
                    Reset counter: 229
                    Mileage: 356704 km
                    Date: 2020.09.05
                    Time: 23:19:37
                    ELV State: 0C
                    Information Clamps: 77 60
                    CoCo State: B0 01
                    WFS State: 67 1A
                    Vehicle speed: 0.00 km/h
                    Voltage: 4A
          U1400 00 [008] - -
          [Under voltage (temporary)]
                    Reset counter: 229
                    Mileage: 356704 km
                    Date: 2020.09.05
                    Time: 23:17:14
                    ELV State: 0C
                    CoCo State: B0 01
                    WFS State: 67 1A
                    Voltage: 4C
   Revision: A1001003    Serial number: 7660671120
   VCID: 290FF9F919FE2E3325D-807C
01304 - Radio
                    Reset counter: 229
                    Mileage: 356704 km
                    Date: 2015.01.27
                    Time: 03:25:19
                    Reset counter: 229
                    Mileage: 356704 km
                    Date: 2015.01.27
                    Time: 23:17:03
                    Reset counter: 229
                    Mileage: 356704 km
                    Date: 2015.01.27
                    Time: 23:20:22
   Part No SW: 561 959 760     HW: 561 959 760
   Component: MEM-FS        H04 0181
   Revision: AA000000    Serial number: 00000011397868
   Coding: 00581B0000000000000021010100202020202120202020
   VCID: 6099A4DD2A44AF7B323-8034
                    Reset counter: 229
                    Mileage: 356699 km
                    Date: 2015.01.17
                    Time: 04:27:47
01882 - Lumbar Support Fore / Aft Adjustment Button (E336); Forward
                    Fault Status: 00100011
                    Reset counter: 228
                    Mileage: 356704 km
                    Date: 2015.01.25
                    Time: 01:38:11
                    Reset counter: 229
                    Mileage: 356704 km
                    Date: 2015.01.27
                    Time: 23:21:24
   Part No SW: 3C8 035 684 E    HW: 3C0 035 684 E
   Component: RNS-MID       H59 3690
   Revision: AB001001    Serial number: VWZ6Z7L7220009
   Coding: 0409000001000094000B
   VCID: 2D070DE92D163213C95-8078
                    Reset counter: 191
                    Mileage: 356712 km
                    Reset counter: 230
                    Mileage: 356712 km
   Part No SW: 561 959 701 A    HW: 3C0 959 793 C
   Revision: 12110009    Serial number: 0002922307
   Coding: 0405FD
   ROD: EV_TSGFPQ25BRFVW46X.rod
   VCID: 1C61D02D462CCB9BAEB-8048
   Slave Driver:
   Subsystem 1 - Part No SW: 561 959 811     HW: 561 959 811   Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG_HL  004 4472
   Coding: 800000
          B11EC 54 [008] - Missing Calibration / Basic Setting
                    Reset counter: 227
66304 - Switch for Drivers Side Window Regulator
          B11F0 29 [008] - Signal Implausible
                    Reset counter: 222
                    Mileage: 356596 km
                    Date: 2020.08.19
                    Time: 17:08:40
65793 - Supply voltage
          [Front DCU undervoltage]
                    Reset counter: 229
                    Mileage: 356704 km
                    Date: 2020.09.05
                    Time: 23:20:26
131584 - Motor for Rear Window Regulator
          B11EE 54 [008] - Missing Calibration / Basic Setting
                    Reset counter: 228
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 290    3201
   Revision: 00H20000
   VCID: 3431188DC23C63DB86B-8060
   Part No SW: 3T0 035 456 B    HW: 3T0 035 456 B
   Component: KonzernAmp10K H06 0362
   Revision: --------    Serial number: BP225309710766
   ROD: EV_AudioVerst10KanalSTT3_VW41.rod
   VCID: 3039149D3AA45FFBE23-8064
   Component: EZE_2         H40 1620
   Coding: 01030108
   VCID: 6FBBD7E1E79A0003BB9-803A
   Serial number: 53388786011106801244
   Coding: 181100
   Component: Analoguhr  008 0002
   Part No SW: 561 959 702 A    HW: 3C0 959 792 C
   Revision: 14110009    Serial number: 0002686286
   Coding: 0405FC
   ROD: EV_TSGBPQ25BRFVW46X.rod
   VCID: 1D67DD295D36C293595-8048
   Slave Passenger:
   Subsystem 1 - Part No SW: 561 959 812     HW: 561 959 812   Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG_HR  004 4472
   Coding: 800000
                    Reset counter: 229
                    Mileage: 356704 km
                    Date: 2020.09.05
                    Time: 23:20:29
                    Reset counter: 228
                    Mileage: 356532 km
                    Date: 2020.08.17
                    Time: 15:52:33
                    Reset counter: 191
                    Mileage: 356712 km
                    Reset counter: 230
                    Mileage: 356712 km
   Part No SW: 3C0 907 441     HW: 3C0 907 441
   Component: J772__Rearview      0042
   Revision: 00H05000    Serial number:    PA8 J980240
   Coding: 8388607
   Shop #: WSC 06106 444 84665
   VCID: 5F9BA7211B3A90830B9-800A
                    Reset counter: 189
03006 - Back-up Camera System not calibrated
                    Reset counter: 189
02203 - Audio / Video Input 1
                    Fault Frequency: 8
                    Reset counter: 191
                    Mileage: 356704 km
                        Reverse OFF
                    Count: 3
02283 - Video Connection to Output [End Unit]
                    Reset counter: 231
                    Mileage: 356704 km
                        Reverse OFF
                    Count: 3
                    Reset counter: 229
                    Mileage: 356704 km
                        Reverse OFF
                    Count: 3
                    Reset counter: 230
                    Mileage: 356714 km
                        Reverse ON
                    Count: 3
   Part No SW: 7P6 035 730 F    HW: 7P6 035 730 F
   Component: TELEFON       H09 2902
   Revision: 1B001001    Serial number: 00007660470304
   Coding: 0A11040000010110
   ASAM Dataset: EV_UHVNA A01719
   ROD: UHVNA.rod
   VCID: 35372589C5C67AD3B15-8060
9455635 - Telephone Microphone
          B1048 13 [008] - Open Circuit
                    Reset counter: 229
                    Mileage: 356704 km
                    Date: 2020.09.05
                    Time: 03:25:12
12718592 - Steering Column Control Module
          U0212 00 [008] - No Communications
                    Reset counter: 229
                    Mileage: 356704 km
                    Date: 2020.09.06
                    Time: 02:12:02
          [Klemme 30: unterer Grenzwert unterschritten]
                    Reset counter: 229
                    Mileage: 356704 km
                    Date: 2020.09.05
                    Time: 23:28:10
0022 - Radio
          U1066 00 [008] - No Communication
          [Steuergerät Radio (RNS): kein Signal/Kommunikation]
                    Reset counter: 229
                    Mileage: 356704 km
                    Date: 2020.09.05
                    Time: 03:25:16
          U1400 00 [008] - -
                    Reset counter: 229
                    Mileage: 356704 km
                    Date: 2020.09.05
                    Time: 23:20:52
End----------(Elapsed Time: 01:31, VBatt start/end: 12.1V/12.1V)-----------
          52 56 62 6C 72 77
Readiness: 1110 0101
   Revision: 00H31001
   Coding: 130C0C
   Revision: 00001001
   Coding: 0010001012
   Revision: BL111001
   Coding: 22300A
   Coding: 0000354A
   Coding: 303252
   Coding: 001A140000
   Coding: E30000
   Coding: 231E01
   Coding: 466000
   Coding: 000007
   Coding: 0405FD
   Slave Driver:
   Coding: 800000
   Revision: 00H20000
   Coding: 01030108
   Coding: 181100
   Coding: 0405FC
   Slave Passenger:
   Coding: 800000
   Coding: 8388607
                    Reset counter: 191
                    Reset counter: 191
                    Fault Status: 01101000
                    Reset counter: 191
                    Mileage: 356750 km
                        Reverse OFF
                    Count: 3
                    Reset counter: 191
                    Mileage: 356750 km
                        Reverse OFF
                    Count: 3
   ROD: UHVNA.rod
End------(Elapsed Time: 01:20, VBatt start/end: 13.5V/13.5V, udsna)--------
CFlow
C?ID=415194
Can anyone help?
This camera module does not use long coding. It uses old-school short coding. You summarily dismissed the yellow balloon with the coding chart in one of your videos.
United States
After our phone conversation I was unable to locate a single A3 chassis NMS Passat scan with Component J772__Rearview in our scan collection. I don't believe that was an option in the US/Canada but I may be wrong. I suspect this was a retrofit: https://forums.ross-tech.com/index.php?threads/466/
I didn't go through each of them but VW has Archived press kits that date back to 2012 linked here which may help to see if a baseline scan would exist (or not).
In the meanwhile I would see if you can get 6C to accept the Coding of 0100006 or 0100007. If it won't accept you may need to see if the cause of 02203 - Audio / Video Input 1 - Open Circuit can be resolved to rule it out as a possible conflict.
CFlow
C?ID=415194
Dana,
My daughter came back this weekend and I have tried both code. Neither code was accepted. Yes this is a retrofit. My dropbox link has all items used in the installation.
United States
Thanks for the update. If both coding values were rejected entirely, and we know that the other retrofitted NMS was able to be coded to 0100007, I would resolve the 02203 - Audio / Video Input 1 - Open Circuit DTC to rule it out. Beyond that I don't have any other suggestions at this time.
