B6 Parking Brake Issues
norfolk-boy
C?ID=201631
I have an issue with a B6 3C Passat EPB, I wanted to change a seized motor on the right rear. I had issues with opening the rear parking brake 53 - PB - Group 007 acivate presed on and it just sat there with no ok left it 20mins and then came out and tried again. Battery charger hooked up all the time as per video and write up. The pads open 007 was not available after this. I then stripped and manually wound the calipers back I have seen this online to replaced the motor and pads (needed doing) and plugged it all up and tried to do a close parking brake 53 - PB - Group 006. It came up with ERROR Group 6 not available. I tried to open them again group 07, also error not available. I then tried the EPB and it made a attempt to close but it was still flashing, the motors went for about 20-30 seconds and then stopped. I have an autoscan from 24/08 that I took but is not sure if this is before or after the change (I know cardinal sin I thought i saved the first one)! I have been through everything and I am stumped. The current situation is the following all with battery charger connected:
EPB flashing (P) with a line through lit
2 faults on the PB 53
02427 - Brake Disk Rear Right; Not Reached
02432 - Supply Voltage for Left Parking Brake Motor (V282) - Checked fuses connector and swopped the motors over, fault stayed the same so not motors. Could the motors not be making contact to the caliper?
03 ABS brakes
01309 - Power Steering Control Module (J500)- not investigated this i believe it was there before the issue.
I have observed and tried the following that I have read on previous threads with these sort of issues. The closest one to mine is here:
https://forums.ross-tech.com/showth...8-Parking-Brake-Module-broken-or-wrong-coding
I am getting problem with Lateral Acceleration Sensor (G200) being "Not available" at basic setting. Brake Electronics, Measuring Blocks 008, Group 004 show right values in field 2 as is in the manual and values change, when car is moving. So sensors should be ok. The fix for that
Longitudinal Acceleration Sensor (G251) Basic Setting is also "Not available" as is Longitudinal Acceleration Sensor (G202), but there is no error message about that in Auto-Scan.
removed battery 2 hours reconnected. No change
reset to sensors in basic settings 04 as per ROSS Tech site and the above thread. The only way some aspects of the brake to work is if I
clear codes.
PB 53
basic settings 04
Group 20 ok, says error
press EPB button it moves for 1 second but brake is not coming on right (left is dead as no voltage) when pressed again runs for 30 seconds then stops.like it is not engaged or something!
Both calipers wind in and out correctly with motors off. The parking controller I guess is going to be suspect but if i cannot do the basic settings now how will i recode it to the car? As the right caliper was the original issue with a seized stuck on brake I have ordered a new caliper. Any help appreciated as to next steps after that as all basic settings appear unavailable in parking brake 53.
First Autoscan 24/08 followed by last Autoscan today 06/09
Monday,24,August,2020,19:57:01:04560
VCDS Version: 20.4.1.0 (x64)
VIN: WVWZZZ3CZ8E089155   License Plate: PASS
Mileage: 170940km-106217mi   Repair Order:
Chassis Type: 3C (3C0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 53 56 62 72
VIN: WVWZZZ3CZ8E089155   Mileage: 170940km-106217miles
Address 01: Engine        Labels: 03G-906-018-BKP.clb
   Part No SW: 03G 906 018 FG    HW: 03G 906 018 FG
   Component: R4 2.0l PPD1.5 G    0907
   Revision: --H45---    Serial number: VWZCZ000000000
   Coding: 0000072
   Shop #: WSC 05314 000 00000
   VCID: 6FED2CC67E8CDCFEE2-803A
009489 - SAE - ECM/PCM Power Relay Sense Circuit
               P2511 - 008 - Intermittent - Intermittent
                    Reset counter: 5
                    Mileage: 170118 km
                    Time: 17:07:10
                    RPM: 1152 /min
                    Torque: 112.0 Nm
                    Speed: 30.0 km/h
                        35.10 %
                    Voltage: 14.01 V
                        46.41 %
                    Temperature: 88.0�C
Readiness: N/A
Address 03: ABS Brakes        Labels:. 3C0-614-109-C4.clb
   Part No SW: 3C0 614 109 C    HW: 3C0 614 109 C
   Component: J104    C4 440 V1   0003
   Revision: --020---    Serial number: 00000776027482
   Coding: 0001291
   Shop #: WSC 05311 000 00000
   VCID: 1E332102C9A6057619-804A
                    Fault Status: 01101000
                    Reset counter: 189
                    Mileage: 118755 km
                    Time: 13:50:44
                    Hex Value: 0x0002
                    Voltage: 14.00 V
                    Bin. Bits: 00011110
                    Count: 221
   Part No SW: 1K0 820 047 FT    HW: 1K0 820 047 FT
   Component: Climatic PQ35   141 0909
   Revision: 00141027    Serial number: 00000000000000
   VCID: 7BF508963AF4B05E5E-802E
   Part No SW: 3C0 937 049 AH    HW: 3C0 937 049 AH
   Revision: 00H54000    Serial number: 01000007594827
   Coding: 00800F0700041A00470A00000F000000000859435C000100000000000000
   Shop #: WSC 05124 000 00000
   Subsystem 1 - Part No: 3C2 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer 080102 022  0601
   Coding: 00046997
   Shop #: WSC 05124
   Part No SW: 3C0 909 605 M    HW: 3C0 909 605 M
   Component: 0C AIRBAG VW8   032 2522
   Revision: 12032000    Serial number: 003B1PJJ7N7T
   Coding: 0012355
   VCID: 306FEFBAA3328306BB-8064
   Subsystem 1 - Serial number: 6332MSME170A7932
   Subsystem 2 - Serial number: 6342MSME1617111B
   Subsystem 3 - Serial number: 6351HTS6L4I09AH6
   Subsystem 4 - Serial number: 6361HTS6L4I8CRK6
   Part No SW: 3C0 953 549 L    HW: 3C0 953 549 L
   Component: Lenks�ulenmodul 006 0010
   Revision: 00006000    Serial number: 3C5953507BK
   Coding: 0000013
   VCID: 3561DEAE5C50A62EE8-8060
   Part No SW: 3C0 920 960 N    HW: 3C0 920 960 N
   Component: KOMBIINSTRUMENT VD1 1216
   Revision: V0002000    Serial number: 00000000000000
   Coding: 0007405
   Shop #: WSC 14557 067 57207
   VCID: 2E53F1C2B90695F6A9-807A
Address 19: CAN Gateway        Labels:. 3C0-907-530-V2.clb
   Part No SW: 3C0 907 530 E    HW: 3C0 907 951
   Component: J533__Gateway   H10 0080
   Revision:   H10       Serial number: 1200P0792700B4
   Coding: F9807F060002021003
   VCID: 234510F6E2C4289E36-8076
   Part No SW: 3C0 959 433 R    HW: 3C0 959 433 R
   Component:    IMMO         042 0383
   VCID: 3979D29E7048424E0C-806C
   Component:    ELV          027 0380
   3C0905861G     ELV          027 0380
   Component: J386  TUER-SG FT    1132
   Revision: 32008001    Serial number: 00000025878922
   Coding: 0000693
   VCID: 3B75C8967A74705E1E-806E
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 000    3001
   Revision: 00H17000
   VCID: 3169EABEA8388A0EB4-8064
   Component:    KSG PQ46 ELV 042 0472
   Coding: 01910A0001860E763004941570085FCE107CA0
   Component: LIN BACKUP HORN H07 9001
   Component: Neigungssensor  004 0611
   Component: J387  TUER-SG BT    1132
   Revision: 32008001    Serial number: 00000026978831
   Coding: 0000692
   VCID: 3C77CB8A7F7A776617-8068
                    Fault Status: 00101100
                    Reset counter: 87
                    Mileage: 156792 km
   Part No SW: 3C0 907 801 J    HW: 3C0 907 801 J
   Component: J540 EPB3  VW-09393 0009
   Revision:   008       Serial number: 00000000182530
   Coding: 0000056
   VCID: 295902DE80E8F2CE7C-807C
            000 - - - MIL ON
                    Fault Status: 11110000
                    Reset counter: 76
                    Mileage: 170915 km
                    Voltage: 12.80 V
                    Count: 1
                    Hex Value: 0x1271
                    Hex Value: 0x0002
                    Hex Value: 0x0108
02429 - Right Parking Brake Motor (V283) Clamping Force Not Reached
            000 - - - MIL ON
                    Reset counter: 76
                    Mileage: 170915 km
                    Voltage: 14.00 V
                    Count: 3
                    Hex Value: 0x12E1
                    Hex Value: 0x0001
                    Hex Value: 0x1008
                    Fault Status: 00111100
                    Reset counter: 106
                    Mileage: 170638 km
                    Voltage: 13.70 V
                    Count: 10
                    Hex Value: 0x12E1
                    Hex Value: 0x0001
                    Hex Value: 0x1010
02433 - Supply Voltage for Right Parking Brake Motor (V283)
            011 - Open Circuit - MIL ON
                    Fault Status: 11101011
                    Fault Frequency: 18
                    Reset counter: 79
                    Mileage: 170915 km
                    Voltage: 12.10 V
                    Count: 31
                    Hex Value: 0x1170
                    Hex Value: 0x0008
                    Hex Value: 0x0104
                    Reset counter: 116
                    Mileage: 170915 km
                    Voltage: 11.50 V
                    Count: 52
                    Hex Value: 0x12F0
                    Hex Value: 0x0001
                    Hex Value: 0x0104
   Part No: 1K0 035 186 AD
   Component: Radio GR0       034 0033
   Revision: 0003404S    Serial number: VWZ2Z2G3362495
   Coding: 0040402
   Shop #: WSC 00218 210 186736
   VCID: 68DF47DA5B620BC6A3-803C
   Part No SW: 1K0 959 703 P    HW: 1K0 959 795 G
   Component: J388   TUER-SG HL   1118
   Revision: 11006001    Serial number: 00000002372439
   Coding: 0000144
   VCID: 3D71C68E64607E6E20-8068
   Part No SW: 1K0 959 704 P    HW: 1K0 959 794 G
   Component: J389   TUER-SG HR   1118
   Revision: 11006001    Serial number: 00000002383725
   Coding: 0000144
   VCID: 3E73C1826966657639-806A
End-------------------------(Elapsed Time: 01:44)--------------------------
Last Auto scan today 06/05/2020
Sunday,06,September,2020,17:26:24:04560
VCDS Version: 20.4.2.0 (x64)
VIN: WVWZZZ3CZ8E089155   License Plate: PASS15
   Coding: 0000072
   VCID: 6FED2CC67E8CDCFEFA-803A
Readiness: N/A
   Coding: 0001291
   VCID: 1E332102C9A6057601-804A
                    Reset counter: 79
                    Mileage: 170947 km
                    Time: 19:34:24
                    Hex Value: 0x0000
                    Voltage: 14.25 V
                    Bin. Bits: 00011111
                    Count: 221
   VCID: 7BF508963AF4B05E46-802E
   Coding: 00046997
   Shop #: WSC 05124
   Coding: 0012355
   VCID: 306FEFBAA3328306A3-8064
   Coding: 0000013
   VCID: 3561DEAE5C50A62EF0-8060
   Coding: 0007405
   VCID: 2E53F1C2B90695F6B1-807A
   VCID: 234510F6E2C4289E2E-8076
   VCID: 3979D29E7048424E14-806C
   Coding: 0000693
   VCID: 3B75C8967A74705E06-806E
   Revision: 00H17000
   VCID: 3169EABEA8388A0EAC-8064
   Coding: 0000692
   VCID: 3C77CB8A7F7A77660F-8068
   Coding: 0000056
   VCID: 295902DE80E8F2CE64-807C
            000 - - - MIL ON
                    Reset counter: 79
                    Mileage: 170947 km
                    Voltage: 14.20 V
                    Count: 1
                    Hex Value: 0x1271
                    Hex Value: 0x0001
                    Hex Value: 0x0408
                    Fault Status: 11101100
                    Reset counter: 79
                    Mileage: 170947 km
                    Voltage: 12.60 V
                    Count: 22
                    Hex Value: 0x12E0
                    Hex Value: 0x0021
                    Hex Value: 0x0202
   Coding: 0040402
   VCID: 68DF47DA5B620BC6BB-803C
   Coding: 0000144
   VCID: 3D71C68E64607E6E38-8068
   Coding: 0000144
   VCID: 3E73C1826966657621-806A
End-------------------------(Elapsed Time: 01:41)--------------------------
Mark G
C?ID=37801
ive seen simalur b4, i usually fit new caliber ,bleed, road test, while braking i hit the h.b button on and of quickly, (obv youll not be speedin at this stage) then it allows me to reset all
norfolk-boy
C?ID=201631
Many thanks for the reply. I fitted the new caliper bled and also removed the left hand calipher motor wound it back 1 full turn and refitted as the brake was hard on with no current flow. After this hit parking brake a few times and reset everything. All working thank god for that. These units are so fickle. Hope this helps someone.
