GOLF VII to VII FL
kamil1555
PL
C?ID=210479
Hi! Sorry for my english. I changed the front lights to full led and the rear lights to dynamic led and BCM module to FL. I also changed the front radar to the facelift in the vw badge. Please help with the correct coding of the BCM (admap from GOLF VII GTD FL with sunroof) module and the ABS. Please also check the compatibility of modules with each other.
Address 01: Engine (J623-CUNA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 EP    HW: 04L 907 309 A
   Component: R4 2,0L EDC   H22 8359
   Revision: 81H22---
   Coding: 01190032036405082000
   Shop #: WSC 15555 155 155555
   ASAM Dataset: EV_ECM20TDI01104L906021EP 002011
   ROD: EV_ECM20TDI01104L906021AE.rod
   VCID: 77BEE716CE87F03E22-8022
17156 - Databus
          U1123 00 [039] - Received Error Message
                    Mileage: 73696 km
                    Date: 2020.09.05
                    Time: 11:14:01
                    Engine speed: 0.00 /min
                    Coolant temperature: 34 °C
                    Intake air temperature: 33 °C
                    Voltage terminal 30: 12.180 V
                    Drivetrain coordinator: brake fault status-Bits 0-7: 0
                    Drivetrain coordinator: brake function status-Bits 0-7: 4
                    Acceleration: 0.000 m/s²
17158 - Databus
                    Mileage: 73696 km
                    Date: 2020.09.05
                    Time: 11:14:01
                    Drivetrain coordinator: brake fault status-Bits 0-7: 19
   Part No SW: 3Q0 907 379 AF    HW: 3Q0 907 379 F
   Component: ESC           H42 0625
   Revision: 00000000    Serial number: 63024000001317
   Coding: 01FA62A1342609730780060541C32980462C90E0608294F514605078C009
   VCID: 7EB0F232E1BDC17661-802A
8314 - Check Coding of ECUs on Powertrain Data Bus
          P1647 00 [009] - -
          [FCAN: Coding of ESP and TSK does not fit together]
                    Reset counter: 228
                    Mileage: 73696 km
                    Date: 2020.09.05
                    Time: 11:12:11
   Part No SW: 5G0 907 044 BD    HW: 5G0 907 044 BD
   Revision: 00001K08
   Coding: 00020114202100011105000000101000
   VCID: 6A98CE628D355DD6AD-803E
   Air quality sensor:
459018 - Databus
          [Steuergerät für Schiebe/Aufstelldach - kein Signal/Kommunikation]
                    Reset counter: 228
                    Mileage: 73696 km
                    Date: 2020.09.05
                    Time: 11:12:37
   Part No SW: 5Q0 937 084 CF    HW: 5Q0 937 084 CF
   Component: BCM MQBAB M+  H34 0236
   Serial number: 02001707600358
   Coding: 00100E46C24122FB4BE44000001C07281000000000000000000000000000
   ROD: EV_BCMBOSCH_017.rod
   Component: WWS    141009  043 0551
   Serial number:         141024082207
   Component: RLHS  037 0059
   Serial number: S4Y14M11D06H09M30S58
   Coding: 03A8DD
263442 - Siren / Alarm Horn for Anti-Theft Alarm System
          B131D F7 [009] - No Release by Immobilizer
                    Reset counter: 228
                    Mileage: 73696 km
                    Date: 2020.09.05
                    Time: 11:14:02
          U1101 00 [009] - Active
                    Reset counter: 228
                    Mileage: 73696 km
                    Date: 2020.09.05
                    Time: 11:12:41
   Part No SW: 5QA 919 298 D    HW: 5QA 919 298 A
   Component: PLA 3.0 12KH07 0050
   Serial number: 000308417618267
   Coding: 0271067841
   ASAM Dataset: EV_EPHVA2CAU3700000 009041
   VCID: 51EA798E00A38E0ECC-8004
   Part No SW: 5Q0 907 572 P    HW: 3QF 907 572 A
   Coding: 2B0007C159FFC728949C810580400600000000000000000004
   VCID: 44C440DACFD16BA677-8010
8 Faults Found:
1238 - Databus
          [FAULT_CHK_BV1_POSITION]
                    Reset counter: 228
                    Mileage: 73696 km
                    Date: 2020.09.05
                    Time: 11:12:50
                    Voltage terminal 15: 12.1 V
          [FAULT_THP_EC_INVALID_IKA]
                    Reset counter: 228
                    Mileage: 73696 km
                    Date: 2020.09.05
                    Time: 11:12:50
0940 - Databus
          [FAULT_TIMEOUT_ESP_24]
                    Reset counter: 228
                    Mileage: 73696 km
                    Date: 2020.09.05
                    Time: 11:12:50
1127 - Databus
          [FAULT_TIMEOUT_PSD_04]
                    Reset counter: 228
                    Mileage: 73696 km
                    Date: 2020.09.05
                    Time: 11:12:50
1218 - Databus
          [FAULT_TIMEOUT_PSD_05]
                    Reset counter: 228
                    Mileage: 73696 km
                    Date: 2020.09.05
                    Time: 11:12:50
1219 - Databus
          [FAULT_TIMEOUT_PSD_06]
                    Reset counter: 228
                    Mileage: 73696 km
                    Date: 2020.09.05
                    Time: 11:12:50
2068 - Databus
          [FAULT_TSK_IRREV_FAIL]
                    Reset counter: 228
                    Mileage: 73696 km
                    Date: 2020.09.05
                    Time: 11:12:50
1232 - Databus
          [FAULT_VIDEO_SIGNAL_LIST]
                    Reset counter: 228
                    Mileage: 73696 km
                    Date: 2020.09.05
                    Time: 11:12:50
   Part No SW: 5Q0 959 655 AA    HW: 5Q0 959 655 AA
   Component: AirbagVW20    014 0386
   Serial number: 003MLR09VS9L
   VCID: 7F4E0F36E6B7C87E6A-802A
   Belt Pretensioner left:
   Serial number: 34169667E04111740681
   Coding: 333135
   Belt Pretensioner right:
   Serial number: 34169668B04111471616
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 001 511 17
   Serial number: 357670000003F6A8192$
   Subsystem 4 - Part No SW: -----------    HW: 480 002 910 14
   Serial number: 3586700000076D15711R
   Subsystem 5 - Part No SW: -----------    HW: 480 402 310 14
   Serial number: 3516502BD1860BA40358
   Subsystem 6 - Part No SW: -----------    HW: 480 402 710 14
   Serial number: 3526502B71811BA35241
   Subsystem 7 - Part No SW: -----------    HW: 480 402 810 14
   Serial number: 3556502A11811BA49185
9440283 - Driver side knee airbag igniter
          B100C 1B [137] - Resistance Too High
                    Mileage: 73696 km
                    Date: 2020.09.05
                    Time: 11:13:00
   Part No SW: 5Q0 953 507 DD    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 04111404220027
   Coding: 0C00
   VCID: 7BB6FB26F2AFD45E46-802E
   Part No SW: 5G1 920 757     HW: 5G1 920 757
   Component: KOMBI         301 4270
   Coding: 07AD09006F9C000807887E0B1400000000000000
   Shop #: WSC 15555 155 15549
   VCID: 6B96CB6682CF44DED6-803E
          U1014 00 [009] - -
                    Reset counter: 228
                    Mileage: 73696 km
                    Date: 2020.09.05
                    Time: 11:11:40
16776980 - Databus
          [PLA_Status_01 keine Kommunikation]
                    Reset counter: 228
                    Mileage: 73696 km
                    Date: 2020.09.05
                    Time: 11:11:40
   Part No SW: 5Q0 907 530 AC    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1204
   Revision: --------    Serial number: 0002623084
   Coding: 030100040F087300FF00027E080F00010001050000000000000000000000
   ASAM Dataset: EV_GatewLear 011020
   ROD: EV_GatewLear_011.rod
   VCID: 72A8D602A5E5951615-8026
   Subsystem 2 - Part No SW: 5G0 959 442 N    HW: 5G0 959 442 N  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H10 0038
   Serial number: 29140002283060034433
   Coding: 2CFFFF
   Serial number: 0811884703
66304 - Databus
          U1124 00 [009] - Additional Installations Detected
          [Mehrverbau CAN]
                    Reset counter: 228
                    Mileage: 73696 km
                    Date: 2020.09.05
                    Time: 11:11:59
                    Supply voltage: Terminal 30: 12.2 V
                    Terminal 15: On
                    Reset counter: 228
                    Mileage: 73696 km
                    Date: 2020.09.05
                    Time: 11:11:59
                    Terminal 15: On
Address 29: Left Light (J1018)       Labels: 8V0-907-399.clb
   Part No SW: 8V0 907 399 D    HW: 8V0 907 399 D
   Component: LCM_MLBevoH08 0014
   VCID: 47DE57D6FEE740BE92-8012
Address 39: Right Light (J1023)       Labels: 8V0-907-399.clb
   Serial number: 0403491669
   Coding: 02011103
   Shop #: WSC 00028 028 00066
   ROD: EV_HREntryHella_VW37.rod
   VCID: 3C34383AB72113660F-8068
   Lane Change Assistant 2:
   Serial number: 0402730710
   Coding: 020111
   Serial number: 0000289132166
   Coding: 003B0320D000020000001000
   Shop #: WSC 00028 028 00067
   Serial number: 00000000000004303158
   Part No SW: 3Q0 909 144 H    HW: 3Q0 909 144 H
   Component: EPS_MQB_ZFLS  505 5061
   Coding: 9303
   VCID: 373E27168E07303EE2-8062
Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V1.clb
   Component: FCM MQB Low   001 0285
   Serial number: 07041610800816
   Coding: 000000050100164A07100F01020000000000000000000000000000000000
13705473 - Databus
          U1121 00 [137] - Missing Message
          [Fahrwerk_01 data bus missing message]
                    Reset counter: 228
                    Mileage: 73696 km
                    Date: 2020.09.05
                    Time: 11:13:24
13705489 - Databus
          [PSD_04 data bus missing message]
                    Reset counter: 228
                    Mileage: 73696 km
                    Date: 2020.09.05
                    Time: 11:13:24
0032 - Headlight
          C107E 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 228
                    Mileage: 73696 km
                    Date: 2020.09.05
                    Time: 11:13:24
   Serial number: 30101402081862
   Coding: 003F0120DE00048000801000
   VCID: 41CA49CED0C37E8E5C-8014
   Serial number: 00000000000004411546
   Coding: 190000
   Part No SW: 5G0 035 846 A    HW: 5G0 035 846 A
   Component: MU-S-N-ER     041 0430
   Serial number: V1F00111143684
   Coding: 02730001FF00000021110001000800001F0202040100010045
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 271EF7565EA7A0BE72-8072
   Subsystem 1 - Part No SW: 5G0 919 605 D    HW: 5G0 919 605 D
   Component: ABT_Std_Nav  H60 0030
   Serial number: VWZ8Z9PS404UYS
   Subsystem 2 - Part No SW: 5G0 919 866 AB    HW: -----------
   Component:  ECE 2015/16  --- 0051
   Part No SW: 5Q0 980 653 F    HW: 5Q0 980 653
   Component: MQB_MFK       H06 0052
   Serial number: 10000160488
   Coding: 0101040001020304000501010100000100
   ROD: EV_MFKBoschAU370.rod
   VCID: 3B363B26B22F145E06-806E
2359296 - Databus
          [LWR_AFS_02_TO_FAILURE]
                    Reset counter: 228
                    Mileage: 73696 km
                    Date: 2020.09.05
                    Time: 11:13:39
                    Control Module temperature: 42 °C
                    Outside air temperature: 18.0 °C
                    Vehicle speed: 0.00 km/h
                    Terminal 15 on: 609.5 s
   Component: SAS-GEN 2     H06 0014
   Serial number: 140527200333
   Part No SW: 7P5 941 572 A    HW: 7P5 941 572 A
   Component: LED1L         H06 0002
   ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
   ROD: EV_LEDMinMaxL_KEBODAVW481.rod
   VCID: 393A212EB813264E14-806C
   Component: LED1R         H06 0002
   ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
   ROD: EV_LEDMinMaxRKEBODVW481.rod
End----------(Elapsed Time: 01:50, VBatt start/end: 12.3V/12.3V)-----------
myounus
Northwest UK
C?ID=321059
hi there
Before you embark on coding I’d recommend you get component protection removed from the modules. If you know someone who has access to ODIS, it’s a quick job.
I have to be pedantic here: Just having ODIS isn't sufficient. The person must also have the appropriate credentials to access the mothership's FAZIT servers.
@kamil1555: did you make a adaptation channel map of the old BCM before the retrofit?
kamil1555
PL
C?ID=210479
Yes, but the number of adaptations is different than in the new module. I have a problem with ambient light in the doors, sill and adaptation of the central locking remote control. CP from 09 is now ok.
^^^^clear ALL DTC and re-post a new auto-scan (please)
kamil1555
PL
C?ID=210479
Autoscan:
   Revision: 81H22---
17158 - Databus
                    Mileage: 76376 km
                    Date: 2020.09.20
                    Time: 08:51:50
                    Coolant temperature: 18 °C
                    Intake air temperature: 19 °C
                    Voltage terminal 30: 12.020 V
                    Acceleration: 0.000 m/s˛
          P1647 00 [009] - -
                    Reset counter: 22
                    Date: 2020.09.20
                    Time: 08:50:02
   Revision: 00001K08
   Air quality sensor:
   Coding: 03A8DD
   Sun Roof:
   Subsystem 3 - Part No SW: 8V3 959 591     HW: 8V3 959 591
   Component: J245 PS73.013  H02 0007
   Serial number:     WOO2323115Y
   Coding: 181801
   Coding: 0271067841
10 Faults Found:
1238 - Databus
                    Reset counter: 22
                    Mileage: 76376 km
                    Date: 2020.09.20
                    Time: 08:50:44
                    Control Module temperature: 22 °C
                    Longitudinal_acceleration_vehicle_reference: 0.00 m/s˛
201217 - Control Module Incorrectly Coded
          U1014 00 [009] - -
          [FAULT_CODING2SWAP_GRP_ACC_TYPE]
                    Reset counter: 22
                    Mileage: 76376 km
                    Date: 2020.09.20
                    Time: 08:50:44
201219 - Control Module Incorrectly Coded
          U1014 00 [009] - -
          [FAULT_CODING2SWAP_GRP_AWV_TYPE]
                    Reset counter: 22
                    Mileage: 76376 km
                    Date: 2020.09.20
                    Time: 08:50:44
201225 - No Enable Indentifications Active
          B2032 00 [009] - -
          [FAULT_SWAP_NO_FAS_FUNCTION]
                    Reset counter: 22
                    Mileage: 76376 km
                    Date: 2020.09.20
                    Time: 08:50:44
0940 - Databus
                    Reset counter: 22
                    Mileage: 76376 km
                    Date: 2020.09.20
                    Time: 08:50:44
1127 - Databus
                    Reset counter: 22
                    Mileage: 76376 km
                    Date: 2020.09.20
                    Time: 08:50:44
1218 - Databus
                    Reset counter: 22
                    Mileage: 76376 km
                    Date: 2020.09.20
                    Time: 08:50:44
1219 - Databus
                    Reset counter: 22
                    Mileage: 76376 km
                    Date: 2020.09.20
                    Time: 08:50:44
2068 - Databus
                    Reset counter: 22
                    Mileage: 76376 km
                    Date: 2020.09.20
                    Time: 08:50:44
1232 - Databus
                    Reset counter: 22
                    Mileage: 76376 km
                    Date: 2020.09.20
                    Time: 08:50:44
   Coding: 333135
   Coding: 333135
                    Mileage: 76376 km
                    Date: 2020.09.20
                    Time: 08:50:54
   Coding: 0C00
   Coding: 07AD09006F8C000807887E0B1400000000000000
          U1014 00 [009] - -
                    Reset counter: 22
                    Mileage: 76376 km
                    Date: 2020.09.20
                    Time: 08:49:33
   Coding: 2CFFFF
66304 - Databus
          [Mehrverbau CAN]
                    Reset counter: 22
                    Mileage: 76376 km
                    Date: 2020.09.20
                    Time: 08:49:52
                    Terminal 15: On
   Coding: 02011103
   Coding: 020111
   Coding: 003B0320D400020000001001
589827 - Window Regulator; Rear Driver Side
          B131F 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 22
                    Mileage: 76376 km
                    Date: 2020.09.20
                    Time: 08:51:48
   Coding: 9303
   Coding: 000000050100164A03101F00020000000000000000000000000000000000
0032 - Headlight
                    Reset counter: 22
                    Mileage: 76376 km
                    Date: 2020.09.20
                    Time: 08:51:19
   Coding: 001F0120DE00048000801001
   Coding: 190000
   Coding: 0101010001020304000501010100000100
Admap 09 Central Electronic:
;SW:5Q0-937-084-CF   HW:5Q0-937-084-CF ---  Cent. Elect. --- SA: 31347
;Component:BCM MQBAB M+  H34 0236
IDE01550-Service position,170.494336 °,2
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking,Decelerate ,10
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn,short ,10
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen,active ,10
IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen,not active ,8
IDE02711-ENG133397-Rear Window Wiper-Einzelansteuerung Heckintervallwischen,not active ,8
IDE02711-ENG133395-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 1,8 s,8
IDE02711-ENG133396-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 2,30 s,8
IDE02711-ENG112304-Rear Window Wiper-Heckwischer,logikgesteuert ,8
IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1,5 s,8
IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2,3 s,8
IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik,7 s,8
IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall,7 s,8
IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW,active ,8
IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck,active ,8
IDE02711-ENG154831-Rear Window Wiper-Zeit_wasch_min_heck,0 ms,8
IDE03638-IDE04231-static AFS light-Steering wheel angle: offset,0.3 °,16
IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit,50.0 %/s,16
IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt,both sides ,16
IDE03638-ENG116675-static AFS light-Lower speed threshold,0.0 km/h,16
IDE03638-ENG116682-static AFS light-Maximaltemperatur,100.0 °C,16
IDE03638-ENG116679-static AFS light-obere Grenztemperatur,95.0 °C,16
IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel,120 °,16
IDE03638-ENG116680-static AFS light-untere Grenztemperatur,80.0 °C,16
IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel,80 °,16
IDE03638-ENG116676-static AFS light-Upper speed threshold,40.0 km/h,16
IDE03638-ENG116674-static AFS light-Vorschrift,ECE R119 ,16
IDE03638-ENG115830-static AFS light-Zeitwert Einschaltzeit Abbiegelicht,15 min,16
IDE04927-IDE01446-Window heater-Running time of heated front window,600 s,11
IDE04927-ENG126845-Window heater-FSH Automatik,not active ,11
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert,320 s,11
IDE04927-ENG141955-Window heater-heizbare Heckscheibe,not installed ,11
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH,not active ,11
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH,not active ,11
IDE04927-ENG141962-Window heater-Waschduesenheizung,not installed ,11
IDE04928-MAS01577-Anti-theft device-Parking heater,not installed ,8
IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn,not active ,8
IDE04928-ENG115864-Anti-theft device-Alarmsignal,discontinuous ,8
IDE04928-ENG141960-Anti-theft device-Anti-theft alarm system,not active ,8
IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung,not active ,8
IDE04928-ENG115812-Anti-theft device-DWA Camper Modus,not active ,8
IDE04928-ENG142007-Anti-theft device-DWA_Einfachhorn_oder_Sounder,not installed ,8
IDE04928-ENG141961-Anti-theft device-Heckscheibenbruchsensor,not installed ,8
IDE04928-ENG142006-Anti-theft device-IRUE_NGS_Deaktivierungstaster_direkt_am BCM_verdrahtet,No ,8
IDE04928-ENG142249-Anti-theft device-OBD Alarm,not_active ,8
IDE04928-ENG142009-Anti-theft device-Schliesszylinder in_Richtung Oeffnen_aktiv (Thatcham inaktiv),No ,8
IDE04928-ENG142010-Anti-theft device-Sensor_fuer_Innenraumueberwachung,No ,8
IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl,1 Alarm ,8
IDE04928-ENG142008-Anti-theft device-tilt_sensor,No ,8
IDE04928-ENG126842-Anti-theft device-Ueberwachung Innenentriegelungshebel,not active ,8
IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm,keine verzoegerung ,8
IDE05145-Light configuration,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 36 00 1A 0B 0F 7F 00 00 00 00 00 00 00 00 00 05 40 00 1B 0C 0F 7F 00 00 00 00 00 00 00 00 00 05 44 00 4B 46 00 7F 08 0A 7F 00 00 00 00 00 00 05 3A 00 49 46 00 7F 08 09 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0A 38 00 22 12 00 64 00 00 00 00 00 00 00 00 00 0A 42 00 23 13 00 64 00 00 00 00 00 00 00 00 00 ,224
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss,1 s,30
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle,22.50 °C,30
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle,21.50 °C,30
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle,22.50 °C,30
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle,21.50 °C,30
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle,36.00 °C,30
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle,35.00 °C,30
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle,36.00 °C,30
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle,35.00 °C,30
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle,53.50 °C,30
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle,52.50 °C,30
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle,53.50 °C,30
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle,52.50 °C,30
IDE06089-ENG141977-Seat heater level current consumption allocation-Sitzheizungsfreigabe,unvernetztes_Heizmodul_verbunden ,30
IDE06507-MAS13132-Button in center console-Function of button 3,Driving program ,8
IDE07007-ENG142253-A/C heater function via remote control-Abbruch_d_Warnblinker_moeglich,active ,8
IDE07007-ENG142252-A/C heater function via remote control-Abbruch_Hupen_RSt,not active ,8
IDE07007-ENG142255-A/C heater function via remote control-Aktivierung_Drehzahlanzeige,active ,8
IDE07007-ENG142254-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Akustik,active ,8
IDE07007-ENG128461-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Uebernahme_RSt,active ,8
IDE07007-ENG115720-A/C heater function via remote control-Remote Start,not installed ,8
IDE07007-ENG128460-A/C heater function via remote control-Rueckmeldung_bei_Aktivierung,active ,8
IDE07356-Position during interval mode,31.494474 °,2
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs,abschalten ueber Abschaltstufen des Energiemanagements oder nach der Nachlaufzeit ,6
IDE07470-ENG126843-After-run for park light-ZV verriegeln bei Klemme 15 Ein,active ,6
IDE08786-ENG124476-Assistance light functions-Sunlight Sensor,not installed ,9
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit,0.10 s,19
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1,2 ,19
IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2,3 ,19
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3,1 ,19
IDE09731-ENG125018-Int. light: 2nd generation-Cockpitbeleuchtung mehrfarbig,active ,19
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach,80 %,19
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe,0 ,19
IDE09731-ENG115822-Int. light: 2nd generation-Defaultwert Ambienteprofil Fussraum,10 %,19
IDE09731-ENG116685-Int. light: 2nd generation-Defaultwert Ambienteprofil Tuer,50 %,19
IDE09731-ENG115823-Int. light: 2nd generation-Defaultwert Ambienteprofil Vorn,50 %,19
IDE09731-ENG125644-Int. light: 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen,not active ,19
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen,active ,19
IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen,not active ,19
IDE09731-ENG142233-Int. light: 2nd generation-Helligkeit_Tuertafelbeleuchtung_nicht_berechnen,active ,19
IDE09731-ENG116596-Int. light: 2nd generation-Innenlicht bei offenem Heckdeckel einschalten,active ,19
IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig,active ,19
IDE09731-ENG116597-Int. light: 2nd generation-KL30G ohne PWM,active ,19
IDE09731-ENG125019-Int. light: 2nd generation-Lautsprecherbeleuchtung mehrfarbig,active ,19
IDE09731-ENG125020-Int. light: 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig,active ,19
IDE09731-ENG125023-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren,active ,19
IDE09731-ENG125022-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig,active ,19
IDE09731-ENG116687-Int. light: 2nd generation-Tuerinnengriff mit Tuertafel,installed ,19
IDE09731-ENG116686-Int. light: 2nd generation-Tuerinnengriffbeleuchtung mit I-Tafel,installed ,19
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig,active ,19
IDE09731-ENG142184-Int. light: 2nd generation-Weckfaehigkeit_klemme_30G,installed ,19
IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel,active ,19
IDE09732-ENG133384-Interior light: light configuration-Ambient_Farbliste_HMI,active ,5
IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprecher,installed ,5
IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen,not active ,5
IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus,not active ,5
IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung,installed ,5
IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtung,installed ,5
IDE09732-ENG125651-Interior light: light configuration-Farbwahl ueber Fahrprofil,installed ,5
IDE09732-ENG125650-Interior light: light configuration-Farbwahl ueber HMI,installed ,5
IDE09732-ENG114629-Interior light: light configuration-Foot well lighting,installed ,5
IDE09732-ENG133385-Interior light: light configuration-Frei_Farbwahl_ueber_HMI,active ,5
IDE09732-ENG126834-Interior light: light configuration-LIN-Dachkonsole lokal aktivierbar,active ,5
IDE09732-ENG125647-Interior light: light configuration-Mittelkonsolenbeleuchtung,installed ,5
IDE09732-ENG125649-Interior light: light configuration-Panoramaschiebedachbeleuchtung,installed ,5
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz,25 %,17
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz,25 %,17
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne,58 %,17
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz,53 %,17
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne,58 %,17
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz,53 %,17
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne,85 %,17
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz,80 %,17
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne,85 %,17
IDE09761-ENG142183-Seat fan charac. curve-Sitzlueftung_reduzierbar,not installed ,17
IDE10298-Alternating park position 1,7.494498 °,2
IDE10299-Alternating park position 2,29.494476 °,2
IDE11477-ENG128619-Interior lighting: parameter-p_adaption_kundenwunsch_dach,1.00 ,256
IDE11477-ENG128539-Interior lighting: parameter-p_adaption_kundenwunsch_fussraum,0.00 ,256
IDE11477-ENG128571-Interior lighting: parameter-p_adaption_kundenwunsch_itafel,1.00 ,256
IDE11477-ENG128523-Interior lighting: parameter-p_adaption_kundenwunsch_tuer,0.60 ,256
IDE11477-ENG128659-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI,00000000  ,256
IDE11477-ENG128660-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_2,00000000  ,256
IDE11477-ENG128656-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_2,00000000  ,256
IDE11477-ENG128628-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_dach,100 %,256
IDE11477-ENG128548-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_fussraum,0 %,256
IDE11477-ENG128580-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_itafel,100 %,256
IDE11477-ENG128532-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_tueren,96 %,256
IDE11477-ENG128625-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_dach,100 %,256
IDE11477-ENG128577-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_itafel,100 %,256
IDE11477-ENG128529-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_tueren,96 %,256
IDE11477-ENG128627-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_dach,100 %,256
IDE11477-ENG128579-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_itafel,100 %,256
IDE11477-ENG128531-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_tueren,96 %,256
IDE11477-ENG128624-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_dach,100 %,256
IDE11477-ENG128576-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_itafel,100 %,256
IDE11477-ENG128528-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_tueren,96 %,256
IDE11477-ENG128629-Interior lighting: parameter-p_helligkeit_einausstieg_dach,100 %,256
IDE11477-ENG128581-Interior lighting: parameter-p_helligkeit_einausstieg_itafel,100 %,256
IDE11477-ENG128533-Interior lighting: parameter-p_helligkeit_einausstieg_tueren,96 %,256
IDE11477-ENG128620-Interior lighting: parameter-p_helligkeit_entriegelt_dach,100 %,256
IDE11477-ENG128540-Interior lighting: parameter-p_helligkeit_entriegelt_fussraum,100 %,256
IDE11477-ENG128572-Interior lighting: parameter-p_helligkeit_entriegelt_itafel,100 %,256
IDE11477-ENG128524-Interior lighting: parameter-p_helligkeit_entriegelt_tueren,0 %,256
IDE11477-ENG128634-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_dach,100 %,256
IDE11477-ENG128554-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum,100 %,256
IDE11477-ENG128586-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_itafel,100 %,256
IDE11477-ENG128538-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren,96 %,256
IDE11477-ENG128630-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_dach,100 %,256
IDE11477-ENG128550-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_fussraum,100 %,256
IDE11477-ENG128582-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_itafel,100 %,256
IDE11477-ENG128626-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_dach,126 %,256
IDE11477-ENG128623-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_dach,100 %,256
IDE11477-ENG128543-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_fussraum,100 %,256
IDE11477-ENG128575-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_itafel,100 %,256
IDE11477-ENG128622-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_dach,100 %,256
IDE11477-ENG128542-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum,100 %,256
IDE11477-ENG128574-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_itafel,100 %,256
IDE11477-ENG128526-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_tueren,126 %,256
IDE11477-ENG128621-Interior lighting: parameter-p_helligkeit_max_dach,100 %,256
IDE11477-ENG128573-Interior lighting: parameter-p_helligkeit_max_itafel,100 %,256
IDE11477-ENG128525-Interior lighting: parameter-p_helligkeit_max_tueren,96 %,256
IDE11477-ENG128631-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_dach,100 %,256
IDE11477-ENG128551-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum,100 %,256
IDE11477-ENG128583-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_itafel,100 %,256
IDE11477-ENG128535-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren,96 %,256
IDE11477-ENG128632-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_dach,100 %,256
IDE11477-ENG128552-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum,100 %,256
IDE11477-ENG128584-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_itafel,100 %,256
IDE11477-ENG128536-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren,96 %,256
IDE11477-ENG128633-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_dach,100 %,256
IDE11477-ENG128553-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum,100 %,256
IDE11477-ENG128585-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_itafel,100 %,256
IDE11477-ENG128537-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren,96 %,256
IDE11477-ENG128480-Interior lighting: parameter-p_t_verzoegerung_einstieg_fussraum,0.0 s,256
IDE11477-ENG128473-Interior lighting: parameter-p_t_verzoegerung_einstieg_tueren,0.5 s,256
IDE11714-ENG126827-Ambient light color list-Blauwert Farbe 1,0 ,30
IDE11714-ENG133432-Ambient light color list-Blauwert Farbe 10,0 ,30
IDE11714-ENG126830-Ambient light color list-Blauwert Farbe 2,0 ,30
IDE11714-ENG126833-Ambient light color list-Blauwert Farbe 3,0 ,30
IDE11714-ENG133414-Ambient light color list-Blauwert Farbe 4,0 ,30
IDE11714-ENG133417-Ambient light color list-Blauwert Farbe 5,0 ,30
IDE11714-ENG133420-Ambient light color list-Blauwert Farbe 6,0 ,30
IDE11714-ENG133426-Ambient light color list-Blauwert Farbe 8,0 ,30
IDE11714-ENG126826-Ambient light color list-Gruenwert Farbe 1,0 ,30
IDE11714-ENG133431-Ambient light color list-Gruenwert Farbe 10,0 ,30
IDE11714-ENG126829-Ambient light color list-Gruenwert Farbe 2,0 ,30
IDE11714-ENG126832-Ambient light color list-Gruenwert Farbe 3,0 ,30
IDE11714-ENG133416-Ambient light color list-Gruenwert Farbe 5,0 ,30
IDE11714-ENG133419-Ambient light color list-Gruenwert Farbe 6,0 ,30
IDE11714-ENG133422-Ambient light color list-Gruenwert Farbe 7,0 ,30
IDE11714-ENG133425-Ambient light color list-Gruenwert Farbe 8,0 ,30
IDE11714-ENG133428-Ambient light color list-Gruenwert Farbe 9,0 ,30
IDE11714-ENG126825-Ambient light color list-Rotwert Farbe 1,0 ,30
IDE11714-ENG133430-Ambient light color list-Rotwert Farbe 10,0 ,30
IDE11714-ENG126828-Ambient light color list-Rotwert Farbe 2,0 ,30
IDE11714-ENG126831-Ambient light color list-Rotwert Farbe 3,0 ,30
IDE11714-ENG133412-Ambient light color list-Rotwert Farbe 4,0 ,30
IDE11714-ENG133415-Ambient light color list-Rotwert Farbe 5,0 ,30
IDE11714-ENG133418-Ambient light color list-Rotwert Farbe 6,0 ,30
IDE11714-ENG133424-Ambient light color list-Rotwert Farbe 8,0 ,30
IDE11944-ENG142014-Keyless access and start authorization-Elektische_Lenkradverriegelung,not installed ,3
IDE11944-ENG141948-Keyless access and start authorization-Kessy,not installed ,3
IDE11944-ENG116654-Keyless access and start authorization-Kessy Komfort schliessen,not active ,3
IDE11944-ENG116626-Keyless access and start authorization-Oeffnung Heckdeckel bei Wiederentriegelung,active ,3
IDE12412-ENG154557-LIN Ambient light color list-Blauwert_Farbe_3_lin,0 ,30
IDE12412-ENG154560-LIN Ambient light color list-Blauwert_Farbe_4_lin,0 ,30
IDE12412-ENG154561-LIN Ambient light color list-Blauwert_Farbe_5_lin,0 ,30
IDE12412-ENG154562-LIN Ambient light color list-Blauwert_Farbe_6_lin,0 ,30
IDE12412-ENG154656-LIN Ambient light color list-Gruenwert_Farbe_2_lin,0 ,30
IDE12412-ENG154676-LIN Ambient light color list-Gruenwert_Farbe_3_lin,0 ,30
IDE12412-ENG154679-LIN Ambient light color list-Gruenwert_Farbe_4_lin,0 ,30
IDE12412-ENG154680-LIN Ambient light color list-Gruenwert_Farbe_5_lin,0 ,30
IDE12412-ENG154681-LIN Ambient light color list-Gruenwert_Farbe_6_lin,0 ,30
IDE12412-ENG154682-LIN Ambient light color list-Gruenwert_Farbe_7_lin,0 ,30
IDE12412-ENG154683-LIN Ambient light color list-Gruenwert_Farbe_8_lin,0 ,30
IDE12412-ENG154733-LIN Ambient light color list-Rotwert_Farbe_1_lin,0 ,30
IDE12412-ENG154744-LIN Ambient light color list-Rotwert_Farbe_2_lin,0 ,30
IDE12412-ENG154767-LIN Ambient light color list-Rotwert_Farbe_4_lin,0 ,30
IDE12412-ENG154768-LIN Ambient light color list-Rotwert_Farbe_5_lin,0 ,30
IDE12412-ENG154769-LIN Ambient light color list-Rotwert_Farbe_6_lin,0 ,30
IDE12412-ENG154771-LIN Ambient light color list-Rotwert_Farbe_8_lin,0 ,30
MAS05055-lower turn position,31.494474 °,2
MAS05056-upper turn position,170.494336 °,2
MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle,0 lx,24
MAS08228-ENG133445-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red,00 00 ,24
MAS08228-ENG133436-Light sensor-Helligkeitsgrenze_sehr_hell,2000 lx,24
MAS08228-ENG133442-Light sensor-Maximale_Ausgangsspannung,0 mV,24
MAS08228-ENG133440-Light sensor-Maximale_Beleuchtungsstaerke,0 lx,24
MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung,0 mV,24
ENG141683-ENG116672-Allwetterlicht_Spoiler-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren,active ,4
ENG141683-ENG116671-Allwetterlicht_Spoiler-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT,active ,4
ENG126649-ENG126872-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_1,single-color ,30
ENG126649-ENG126899-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_10,single-color ,30
ENG126649-ENG126902-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_11,single-color ,30
ENG126649-ENG126905-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_12,single-color ,30
ENG126649-ENG126908-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_13,single-color ,30
ENG126649-ENG126911-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_14,single-color ,30
ENG126649-ENG126914-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_15,single-color ,30
ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2,single-color ,30
ENG126649-ENG126878-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_3,single-color ,30
ENG126649-ENG126881-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_4,single-color ,30
ENG126649-ENG126884-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_5,single-color ,30
ENG126649-ENG126887-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_6,single-color ,30
ENG126649-ENG126890-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_7,single-color ,30
ENG126649-ENG126893-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_8,single-color ,30
ENG126649-ENG126896-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_9,single-color ,30
ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1,00 ,60
ENG141649-ENG142194-Außenlicht_Blinker-dynamisch_blinken_10,active ,10
ENG141649-ENG121967-Außenlicht_Blinker-Panic flashing,active ,10
ENG141649-ENG122211-Außenlicht_Blinker-Richtungs_blinken_links,active ,10
ENG141649-ENG122210-Außenlicht_Blinker-Richtungs_blinken_rechts,active ,10
ENG141649-ENG122201-Außenlicht_Blinker-Schluessel_Anlern_Blinken,active ,10
ENG141649-ENG122202-Außenlicht_Blinker-UGDO_ Anlern_Blinken,active ,10
ENG141649-ENG122214-Außenlicht_Blinker-Warnblinken_Zuendung_AUS,active ,10
ENG141649-ENG122213-Außenlicht_Blinker-Warnblinken_Zuendung_EIN,active ,10
ENG141649-ENG122204-Außenlicht_Blinker-ZV_Blinken_auf,active ,10
ENG141649-ENG122203-Außenlicht_Blinker-ZV_Blinken_zu,active ,10
ENG141647-ENG115861-Außenlicht_Front-Lichthupe bei Zuendung aus moeglich,active ,9
ENG141648-ENG115782-Aussenlicht_Heck-Nebelschlusslicht Warngeschwindigkeit,0 km/h,5
ENG141656-ENG142020-Außenlicht_uebergreifend-All-weather lights,not installed ,18
ENG141656-ENG116601-Außenlicht_uebergreifend-Coming Home Verbaustatus,manual ,18
ENG141656-ENG130581-Außenlicht_uebergreifend-Fahrlicht_Hinweis_mehrfach,active ,18
ENG141656-ENG133382-Außenlicht_uebergreifend-Faktor fuer Verfügbarkeitstimer,Faktor fuer x5 Minuten ,18
ENG141656-ENG116608-Außenlicht_uebergreifend-Helligkeitsschwelle Forward-Messung,46400 lx,18
ENG141656-ENG116603-Außenlicht_uebergreifend-Menueeinstellung Cominghome,10 seconds ,18
ENG141656-ENG116607-Außenlicht_uebergreifend-Menueeinstellung Leaving-home Zeit per BAP,10 seconds ,18
ENG122934-erase_error_table,55 00 00 ,3
ENG122933-error_mask,0 bit,2
ENG141650-ENG141973-Fernlicht_assistent-Erweiterte_Fernlichtsteuerung,AFS: FLA: Fernlicht (GLW:MDF) ,6
ENG141650-ENG116637-Fernlicht_assistent-Menuesteuerung Fernlichtassistent,present ,6
ENG141682-ENG115835-Front_wiper-Adaptives Nachwischen bei SRA,active ,6
ENG141682-ENG115770-Front_wiper-Variable Regensensoraktivierung,not active ,6
ENG141660-ENG115658-Kennlinie_sLWR_Soll-x0,-100.00 %,30
ENG141660-ENG101574-Kennlinie_sLWR_Soll-X1,-100.00 %,30
ENG141660-ENG99557-Kennlinie_sLWR_Soll-X2,-100.00 %,30
ENG141660-ENG102140-Kennlinie_sLWR_Soll-X3,-100.00 %,30
ENG141660-ENG102936-Kennlinie_sLWR_Soll-X4,-100.00 %,30
ENG141660-ENG103548-Kennlinie_sLWR_Soll-X5,-100.00 %,30
ENG141660-ENG113992-Kennlinie_sLWR_Soll-X6,-100.00 %,30
ENG141660-ENG115661-Kennlinie_sLWR_Soll-x7,-100.00 ,30
ENG141660-ENG115662-Kennlinie_sLWR_Soll-x8,-100.00 %,30
ENG141660-ENG115663-Kennlinie_sLWR_Soll-x9,-100.00 %,30
ENG141660-ENG115659-Kennlinie_sLWR_Soll-y0,100.0 %,30
ENG141660-ENG99777-Kennlinie_sLWR_Soll-Y1,90.0 %,30
ENG141660-ENG100480-Kennlinie_sLWR_Soll-Y2,80.0 %,30
ENG141660-ENG100773-Kennlinie_sLWR_Soll-Y3,70.0 %,30
ENG141660-ENG100631-Kennlinie_sLWR_Soll-Y4,60.0 %,30
ENG141660-ENG102174-Kennlinie_sLWR_Soll-Y5,50.0 %,30
ENG141660-ENG113993-Kennlinie_sLWR_Soll-Y6,40.0 %,30
ENG141660-ENG115665-Kennlinie_sLWR_Soll-y7,30.0 %,30
ENG141660-ENG115666-Kennlinie_sLWR_Soll-y8,15.0 %,30
ENG141660-ENG115667-Kennlinie_sLWR_Soll-y9,0.0 %,30
ENG141657-ENG116159-Leuchte 35 LED Warnblinktaster C48-Fehlerort mittleres Byte DTC-DFCC 15,63 ,16
ENG141657-ENG116160-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion A 15,Unknown (76),16
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12,10 - allgemeine Scheinwerfer ,16
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13,10 - allgemeine Scheinwerfer ,16
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16,16 ,16
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16,08 ,16
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16,38 - LED Blinkleuchten ,16
ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16,only_if_closed ,16
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16,Blinken links Hellphase ,16
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17,127 ,16
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17,18 ,16
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17,18 ,16
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17,38 - LED Blinkleuchten ,16
ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17,only_if_closed ,16
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17,Blinken rechts Hellphase ,16
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18,127 ,16
ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18,41 ,16
ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 18,00 ,16
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18,38 - LED Blinkleuchten ,16
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19,127 ,16
ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19,42 ,16
ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 19,00 ,16
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19,38 - LED Blinkleuchten ,16
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1,0 ,16
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1,00 ,16
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1,not active ,16
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1,not active ,16
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20,127 ,16
ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20,39 ,16
ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20,10 ,16
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20,43 - allgemeine LED ,16
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20,Brake light ,16
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21,127 ,16
ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21,3A ,16
ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21,20 ,16
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21,43 - allgemeine LED ,16
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21,Brake light ,16
ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22,127 ,16
ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22,Quittierungsfunktion 1 ,16
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23,127 ,16
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23,127 ,16
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23,43 - allgemeine LED ,16
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23,Rear lid open ,16
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23,Daytime running lights ,16
ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24,127 ,16
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24,43 - allgemeine LED ,16
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24,Rear lid open ,16
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24,Daytime running lights ,16
ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24,Parking light right ,16
ENG116961-ENG116347-Leuchte25KZL HA59-Lasttyp 25,25 - allgemeine Glühlampe Innen- oder Außenlicht ,16
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26,127 ,16
ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26,2F ,16
ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26,1C ,16
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26,43 - allgemeine LED ,16
ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26,only_if_closed ,16
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26,Nebelschlusslicht wenn kein Anhaenger gesteckt und Rechtsverkehr ,16
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27,127 ,16
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27,47 ,16
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27,00 ,16
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27,36 - LED Kleinleistung ,16
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27,Versorgungsbedarf der LCM Module ,16
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28,43 - allgemeine LED ,16
ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28,only_if_closed ,16
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29,127 ,16
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29,43 - allgemeine LED ,16
ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29,only_if_closed ,16
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2,0 ,16
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2,not active ,16
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2,not active ,16
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30,36 - LED Kleinleistung ,16
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3,0 ,16
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3,not active ,16
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3,not active ,16
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4,0 ,16
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4,not active ,16
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4,not active ,16
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5,0 ,16
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5,not active ,16
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5,not active ,16
ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6,0 ,16
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6,Lichthupe generell ,16
ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6,not active ,16
ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7,0 ,16
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7,Lichthupe generell ,16
ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7,not active ,16
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8,4B ,16
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8,44 ,16
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8,5 - LED Abblendlicht ,16
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8,Parking light right ,16
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9,49 ,16
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9,3A ,16
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9,5 - LED Abblendlicht ,16
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG141661-Leuchtenkonfiguration_Aussenlich_Heck,26 00 00 41 02 00 7F 00 00 00 00 00 00 00 00 00 26 00 00 42 04 00 7F 00 00 00 00 00 00 00 00 00 2B 10 00 39 18 00 7F 00 00 00 00 00 00 00 00 00 2B 20 00 3A 18 00 7F 00 00 00 00 00 00 00 00 00 2A 29 00 2C 18 24 7F 00 00 00 00 00 00 00 00 00 2B 0A 00 29 08 21 7F 15 09 7F 00 00 00 00 00 00 2B 1A 00 2A 08 21 7F 15 0A 7F 00 00 00 00 00 00 19 28 00 30 08 00 7F 00 00 00 00 00 00 00 00 00 2B 1C 00 2F 1B 00 FF 00 00 00 00 00 00 00 00 00 24 00 00 47 46 00 7F 00 00 00 00 00 00 00 00 00 2B 0B 00 31 19 00 FF 00 00 00 00 00 00 00 00 00 2B 1B 00 32 19 00 FF 00 00 00 00 00 00 00 00 00 ,192
ENG141662-Leuchtenkonfiguration_Sonstiges,26 08 00 16 02 00 FF 00 00 00 00 00 00 00 00 00 26 18 00 18 04 00 FF 00 00 00 00 00 00 00 00 00 24 00 00 02 2B 00 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 29 00 00 63 4C 00 64 00 00 00 00 00 00 00 00 00 ,128
ENG141658-ENG142219-Leuchtweitenregulierung-Achsabstand_des_Fahrzeuges,0 mm,62
ENG141658-ENG142218-Leuchtweitenregulierung-Achssensor_PWM_Wert_Einfederung_Sensor_H4,-8.00 mm/%,62
ENG141658-ENG142217-Leuchtweitenregulierung-Achssensor_PWM_Wert_Einfederung_Sensor_vorn,-8.00 mm/%,62
ENG141658-ENG142211-Leuchtweitenregulierung-Ansteuerung_obere_grenze,90.0 %,62
ENG141658-ENG142210-Leuchtweitenregulierung-Ansteuerung_untere_grenze,10.0 %,62
ENG141658-ENG142214-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_1,-8.00 mm/%,62
ENG141658-ENG142216-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_2,-8.00 mm/%,62
ENG141658-ENG142213-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_1,-8.00 mm/%,62
ENG141658-ENG142215-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_2,-8.00 mm/%,62
ENG141658-ENG142198-Leuchtweitenregulierung-Fahrwerk_Variante,Verbundlenkerhinterachse ,62
ENG141658-ENG142204-Leuchtweitenregulierung-Fail_Safe_sLWR,0.0 %,62
ENG141658-ENG142223-Leuchtweitenregulierung-fFiltEinf,0.00 Hz,62
ENG141658-ENG142212-Leuchtweitenregulierung-Lineare_Abbildung,0 ,62
ENG141658-ENG142220-Leuchtweitenregulierung-lwr_lFzg_Sw_Abstand,0 mm,62
ENG141658-ENG142221-Leuchtweitenregulierung-lwr_lFzg_Sw_Hoehe,0 mm,62
ENG141658-ENG142225-Leuchtweitenregulierung-lwr_pwm_untere_schwelle,2.5 %,62
ENG141658-ENG142227-Leuchtweitenregulierung-max_v_slwr,0 km/h,62
ENG141658-ENG142224-Leuchtweitenregulierung-pa_fFiltSwNeigung,0.00 Hz,62
ENG141658-ENG142200-Leuchtweitenregulierung-Quelle_Hoehenwerte,CAN_Daempferregelung ,62
ENG141658-ENG142042-Leuchtweitenregulierung-sensor_headlight_range_control_installed,Rear ,62
ENG141658-ENG142199-Leuchtweitenregulierung-sLWR_bei_Abblendlicht,active ,62
ENG141658-ENG142208-Leuchtweitenregulierung-sLWR_Hysterese,20.0 %,62
ENG141658-ENG142207-Leuchtweitenregulierung-sLWR_SW_Grad,0.0 %/s,62
ENG141658-ENG142206-Leuchtweitenregulierung-sLWR_Touristenlicht,-100.0 %,62
ENG141659-ENG115658-lwr_ofs_RSw_Ah1S-x0,-5.00 %,20
ENG141659-ENG101574-lwr_ofs_RSw_Ah1S-X1,-5.00 %,20
ENG141659-ENG99557-lwr_ofs_RSw_Ah1S-X2,-5.00 %,20
ENG141659-ENG102140-lwr_ofs_RSw_Ah1S-X3,-5.00 %,20
ENG141659-ENG102936-lwr_ofs_RSw_Ah1S-X4,-5.00 %,20
ENG141659-ENG115659-lwr_ofs_RSw_Ah1S-y0,-5.00 ,20
ENG141659-ENG99777-lwr_ofs_RSw_Ah1S-Y1,-5.00 ,20
ENG141659-ENG100480-lwr_ofs_RSw_Ah1S-Y2,-5.00 ,20
ENG141659-ENG100773-lwr_ofs_RSw_Ah1S-Y3,-5.00 ,20
ENG141659-ENG100631-lwr_ofs_RSw_Ah1S-Y4,-5.00 ,20
ENG122979-ENG141953-Networking-Getriebesteuergeraet,not installed ,8
ENG124714-ENG142262-OCU-Remote HuF Hupfrequenz,3 ,8
ENG124714-ENG133392-OCU-Remote Lock Unlock Timer s3,20.0 ms,8
ENG124714-ENG125657-OCU-Remote_Unlock_Lock,Via ZV-Absicherung Light ,8
ENG98831-ENG126849-Personalization-Aktivierungsoption_im_HMI-Menue_sichtbar,active ,16
ENG98831-ENG133401-Personalization-Anzahl_Benutzerkonten,4 ,16
ENG98831-ENG126850-Personalization-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar,active ,16
ENG98831-ENG126848-Personalization-Personalisierung_aktiv,active ,16
ENG98831-ENG141994-Personalization-Personalisierung_Profilfunkion,profiles_active ,16
ENG98831-ENG126851-Personalization-Personalisierungsfunktionen_in_HMI-Menue_sichtbar,active ,16
ENG98831-ENG142030-Personalization-Profil_Variante,Konto (v. 1.x) ,16
ENG98831-ENG133404-Personalization-PSO_FSG_Setup2_Bit_1,active ,16
ENG98831-ENG133405-Personalization-PSO_FSG_Setup2_Bit_2,active ,16
ENG141646-MAS01065-Querschnitts_funktionen-Brand,VW ,5
ENG141646-ENG142187-Querschnitts_funktionen-Hardware_Eingang_Drucktankklappenstatus,Pin 31 ,5
ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn,200 lx,1
ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day,500 lx,1
ENG115729-ENG116609-Scheinwerferreinigung-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,10 ,10
ENG115729-ENG141949-Scheinwerferreinigung-Headlamp washer system,installed ,10
ENG115729-ENG115769-Scheinwerferreinigung-SRA bei Waschwassermangel,active ,10
ENG115729-ENG115767-Scheinwerferreinigung-SRA Einweichpausenzeit,2000 ms,10
ENG115729-ENG115768-Scheinwerferreinigung-SRA Nachwaschzeit,400 ms,10
ENG115729-ENG115766-Scheinwerferreinigung-SRA Waschzeit,400 ms,10
ENG141684-SFT271873-Slave_systems_identification-Control Unit For Wiper Motor,Not available ,6
ENG141684-SFT271874-Slave_systems_identification-Rain Light Recognition Sensor,Not available ,6
ENG141684-SFT271877-Slave_systems_identification-Garage Door Opener Operating Unit,Not available ,6
ENG141684-SFT271894-Slave_systems_identification-Sensor For Anti Theft Alarm System,Not available ,6
ENG141684-SFT271904-Slave_systems_identification-Sun Roof,Available ,6
ENG141684-SFT271910-Slave_systems_identification-Ceiling Light Module,Not available ,6
ENG141684-SFT271928-Slave_systems_identification-Roof Blind,Available ,6
ENG141684-SFT271947-Slave_systems_identification-Relative Air Humidity Interior Sender,Not available ,6
ENG141684-SFT271966-Slave_systems_identification-Neck Heating Left,Not available ,6
ENG141684-SFT271967-Slave_systems_identification-Neck Heating Right,Not available ,6
ENG141684-SFT272065-Slave_systems_identification-Seat Backrest Fan 1 Front Left,Not available ,6
ENG141684-SFT272067-Slave_systems_identification-Seat Cushion Fan 1 Front Left,Not available ,6
ENG141684-SFT272069-Slave_systems_identification-Seat Backrest Fan 1 Front Right,Not available ,6
ENG141684-SFT272071-Slave_systems_identification-Seat Cushion Fan 1 Front Right,Not available ,6
ENG141635-ENG116658-Spiegelverstellung-Funk Spiegelanklappen,not active ,5
ENG141635-ENG116665-Spiegelverstellung-Funk Spiegelanklappung Modus,by convenience operation via remote control key ,5
ENG141635-ENG116660-Spiegelverstellung-Menuesteuerung Funk Spiegel anklappen,not active ,5
ENG141635-ENG116659-Spiegelverstellung-Menuesteuerung synchrone Spiegelverstellung,active ,5
ENG141635-ENG126841-Spiegelverstellung-Profilfunktion fuer Anklappung der Aussenspiegel,active ,5
ENG141635-ENG133411-Spiegelverstellung-Spiegelanklappen_bei_Wiederverriegelung,not active ,5
ENG141635-ENG116656-Spiegelverstellung-Spiegelverstellung Synchron,active ,5
ENG141663-ENG142236-Suchbeleuchtung_allgemein-Daempfung Abdimmen KL 58xs PWM,0.00 s,21
ENG141663-ENG142238-Suchbeleuchtung_allgemein-Daempfung Abdimmen KL 58xt PWM,0.00 s,21
ENG141663-ENG142239-Suchbeleuchtung_allgemein-Daempfung Aufdimmen KL 58xd PWM,0.00 s,21
ENG141663-ENG142237-Suchbeleuchtung_allgemein-Daempfung Aufdimmen KL 58xt PWM,0.00 s,21
ENG141663-ENG142242-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Abdimmen,20.0 s,21
ENG141663-ENG142241-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Aufdimmen,3.0 s,21
ENG141663-ENG142243-Suchbeleuchtung_allgemein-pa_Hysterese_RLS,2 ,21
ENG141663-ENG142235-Suchbeleuchtung_allgemein-PWM Daempfung Aufdimmen KL58xs PWM,0.00 s,21
ENG141663-ENG115820-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Grundwert,6.0 %,21
ENG141668-ENG102140-Suchbeleuchtung_KL 58xs min-X3,510 lx,8
ENG141672-ENG101574-Suchbeleuchtung_KL_58xd_min-X1,50 lx,10
ENG141672-ENG99777-Suchbeleuchtung_KL_58xd_min-Y1,16.0 ,10
ENG141672-ENG100480-Suchbeleuchtung_KL_58xd_min-Y2,25.0 ,10
ENG141672-ENG100773-Suchbeleuchtung_KL_58xd_min-Y3,30.0 ,10
ENG141672-ENG100631-Suchbeleuchtung_KL_58xd_min-Y4,50.0 ,10
ENG141677-ENG99557-Suchbeleuchtung_KL_58xd_PWM-X2,50 ,12
ENG141677-ENG102140-Suchbeleuchtung_KL_58xd_PWM-X3,100 ,12
ENG141677-ENG115659-Suchbeleuchtung_KL_58xd_PWM-y0,2.0 %,12
ENG141677-ENG99777-Suchbeleuchtung_KL_58xd_PWM-Y1,2.0 %,12
ENG141677-ENG100480-Suchbeleuchtung_KL_58xd_PWM-Y2,6.0 %,12
ENG141677-ENG100773-Suchbeleuchtung_KL_58xd_PWM-Y3,10.0 %,12
ENG141677-ENG100631-Suchbeleuchtung_KL_58xd_PWM-Y4,80.0 %,12
ENG141680-ENG101574-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X1,10 lx,12
ENG141680-ENG99557-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X2,100 lx,12
ENG141680-ENG102140-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X3,500 lx,12
ENG141680-ENG99777-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y1,20 ,12
ENG141680-ENG100480-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y2,80 ,12
ENG141680-ENG100773-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y3,180 ,12
ENG141680-ENG100631-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y4,300 ,12
ENG141632-ENG116647-Sunroof-SAD Komfort oeffnen,active ,4
ENG141632-ENG116646-Sunroof-SAD Komfort schliessen,active ,4
ENG141632-ENG141970-Sunroof-Schiebedachmodul_MD_1,installed ,4
ENG141632-ENG141971-Sunroof-Schiebedachmodul_MD_3,installed ,4
ENG141634-ENG122192-Verdecksteuergeraet-Verdeck oeffnen via Kessy,not active ,9
ENG141634-ENG116715-Verdecksteuergeraet-Verdeck schließen via Kessy,not active ,9
ENG141634-ENG142258-Verdecksteuergeraet-Virtuelles_Pedal_HMI_einstellba,not active ,9
ENG116832-ENG126852-Wischgeschwindigkeiten-Dauerwischen Stufe_1 Zyklen pro Minute,40 ,3
ENG116832-ENG126853-Wischgeschwindigkeiten-Dauerwischen Stufe_2 Zyklen pro Minute,60 ,3
ENG141651-ENG125653-ZV allgemein-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster,not active ,7
ENG141651-ENG133389-ZV allgemein-Nutzfahrzeug_Schliessung,active ,7
ENG141651-ENG141957-ZV allgemein-Radio freq.,433.92MHz ,7
ENG141651-ENG141996-ZV allgemein-ZV_ohne_Safe_Funktion,installed ,7
ENG141654-ENG115756-ZV Autolock-automatisches Verriegeln bei Geschwindigkeit,not active ,3
ENG141655-ENG116661-ZV Crash-SAD PreCrash Konturschliessen,active ,4
ENG141653-ENG142016-ZV Heck-Heckdeckelentriegelung_HDF_Innentaster,not installed ,7
ENG141653-ENG141995-ZV Heck-Heckschloss_Steuerung,Contact control ,7
ENG141681-IDE02022-ZV Komfort-Comfort opening,active ,8
ENG141681-ENG116664-ZV Komfort-Fahrertuerbedienung Fensterheber schliessen,active ,8
ENG141681-ENG116643-ZV Komfort-Schliesszylinder Komfort oeffnen,not active ,8
ENG141681-ENG116644-ZV Komfort-Schliesszylinder Komfort schliessen,not active ,8
ENG141652-ENG142000-ZV Türkonfiguration-Schlosstyp_NAR,No ,5
downtime
Finland
C?ID=280813
Use notepad++ and get the compare plugin to it. Open the old BCM adaptation channels as first to compare and then the new BCM adaptation map as the second one. This way it is much easier to check what channels are correct and matching the old one and what are not.
Then the ACC radar. You need mothership connection to that as well to return the FeC codes to it.
kamil1555
PL
C?ID=210479
Ok. Thank's. BCM work ok now, all channels is ok with old bcm, but seat heating, heated rear window, electric driver's seat and massage are not working.
downtime
Finland
C?ID=280813
Check my BCM adaptations. I have the same CF BCM module that you have swapped to. I see some differences in window heater and seat heating settings.
;SW:5Q0-937-084-CF   HW:5Q0-937-084-CF ---  Cent. Elect.
;Component:BCM MQBAB M+  H34 0236, Coding:000000000000000000000000000000000000000000000000000000000000
;EV_BCMMQB,017001,EV_BCMBOSCH_017.rod
;Saturday,08,February,2020,17:16:45:18875
;VCDS Version: Release 19.6.2 (x64)  Data version: 20190930 DS308.0
;VCID: 7EA5FEEB8073EE47BBB-802A
IDE01550-Service position,178.999822 °,2
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking,Decelerate ,10
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn,active ,10
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn,short ,10
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen,active ,10
IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen,not active ,8
IDE02711-ENG133397-Rear Window Wiper-Einzelansteuerung Heckintervallwischen,not active ,8
IDE02711-ENG133395-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 1,8 s,8
IDE02711-ENG133396-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 2,30 s,8
IDE02711-ENG112304-Rear Window Wiper-Heckwischer,logikgesteuert ,8
IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1,5 s,8
IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2,3 s,8
IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik,7 s,8
IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall,7 s,8
IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW,active ,8
IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck,active ,8
IDE02711-ENG154831-Rear Window Wiper-Zeit_wasch_min_heck,0 ms,8
IDE03638-IDE04231-static AFS light-Steering wheel angle: offset,0.3 °,16
IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit,50.0 %/s,16
IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt,both sides ,16
IDE03638-ENG116675-static AFS light-Lower speed threshold,0.0 km/h,16
IDE03638-ENG116682-static AFS light-Maximaltemperatur,100.0 °C,16
IDE03638-ENG116679-static AFS light-obere Grenztemperatur,95.0 °C,16
IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel,120 °,16
IDE03638-ENG116680-static AFS light-untere Grenztemperatur,80.0 °C,16
IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel,80 °,16
IDE03638-ENG116676-static AFS light-Upper speed threshold,40.0 km/h,16
IDE03638-ENG116674-static AFS light-Vorschrift,ECE R119 ,16
IDE03638-ENG115830-static AFS light-Zeitwert Einschaltzeit Abbiegelicht,15 min,16
IDE04927-IDE01446-Window heater-Running time of heated front window,240 s,11
IDE04927-ENG126845-Window heater-FSH Automatik,active ,11
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert,320 s,11
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH,active ,11
IDE04927-ENG154810-Window heater-window heating front activation time pause,0 s,11
IDE04928-MAS01577-Anti-theft device-Parking heater,installed ,8
IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn,not active ,8
IDE04928-ENG115864-Anti-theft device-Alarmsignal,frequency modulated ,8
IDE04928-ENG141960-Anti-theft device-Anti-theft alarm system,not active ,8
IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung,not active ,8
IDE04928-ENG115812-Anti-theft device-DWA Camper Modus,not active ,8
IDE04928-ENG142007-Anti-theft device-DWA_Einfachhorn_oder_Sounder,not installed ,8
IDE04928-ENG141961-Anti-theft device-Heckscheibenbruchsensor,not installed ,8
IDE04928-ENG142006-Anti-theft device-IRUE_NGS_Deaktivierungstaster_direkt_am BCM_verdrahtet,No ,8
IDE04928-ENG142249-Anti-theft device-OBD Alarm,not_active ,8
IDE04928-ENG142009-Anti-theft device-Schliesszylinder in_Richtung Oeffnen_aktiv (Thatcham inaktiv),No ,8
IDE04928-ENG142010-Anti-theft device-Sensor_fuer_Innenraumueberwachung,No ,8
IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl,10 Alarme ,8
IDE04928-ENG142008-Anti-theft device-tilt_sensor,No ,8
IDE04928-ENG126842-Anti-theft device-Ueberwachung Innenentriegelungshebel,not active ,8
IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm,2 sekunden verzoegerung ,8
IDE05145-Light configuration,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 36 00 1A 0B 0F 7F 00 00 00 00 00 00 00 00 00 05 40 00 1B 0C 0F 7F 00 00 00 00 00 00 00 00 00 05 44 00 4A 46 00 7F 08 0A 7F 00 00 00 00 00 00 05 3A 00 49 46 00 7F 08 09 7F 00 00 00 00 00 00 29 45 00 63 46 00 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0A 38 00 22 12 00 64 00 00 00 00 00 00 00 00 00 0A 42 00 23 13 00 64 00 00 00 00 00 00 00 00 00 ,224
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss,1 s,30
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle,21.00 °C,30
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle,20.00 °C,30
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle,21.00 °C,30
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle,20.00 °C,30
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle,38.00 °C,30
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle,37.00 °C,30
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle,38.00 °C,30
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle,37.00 °C,30
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle,56.00 °C,30
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle,55.00 °C,30
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle,56.00 °C,30
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle,55.00 °C,30
IDE06507-MAS13132-Button in center console-Function of button 3,Driving program ,8
IDE07007-ENG142253-A/C heater function via remote control-Abbruch_d_Warnblinker_moeglich,active ,8
IDE07007-ENG142252-A/C heater function via remote control-Abbruch_Hupen_RSt,not active ,8
IDE07007-ENG142255-A/C heater function via remote control-Aktivierung_Drehzahlanzeige,active ,8
IDE07007-ENG142254-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Akustik,active ,8
IDE07007-ENG128461-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Uebernahme_RSt,active ,8
IDE07007-ENG115720-A/C heater function via remote control-Remote Start,not installed ,8
IDE07007-ENG128460-A/C heater function via remote control-Rueckmeldung_bei_Aktivierung,active ,8
IDE07356-Position during interval mode,40.999959 °,2
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs,not active ,6
IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit,255 min,6
IDE07470-ENG126843-After-run for park light-ZV verriegeln bei Klemme 15 Ein,active ,6
IDE08786-ENG124476-Assistance light functions-Sunlight Sensor,not installed ,9
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit,0.10 s,19
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1,0 ,19
IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2,0 ,19
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3,0 ,19
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach,0 %,19
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe,0 ,19
IDE09731-ENG115822-Int. light: 2nd generation-Defaultwert Ambienteprofil Fussraum,30 %,19
IDE09731-ENG116685-Int. light: 2nd generation-Defaultwert Ambienteprofil Tuer,30 %,19
IDE09731-ENG115823-Int. light: 2nd generation-Defaultwert Ambienteprofil Vorn,10 %,19
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen,active ,19
IDE09731-ENG116596-Int. light: 2nd generation-Innenlicht bei offenem Heckdeckel einschalten,active ,19
IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig,active ,19
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig,not active ,19
IDE09731-ENG142184-Int. light: 2nd generation-Weckfaehigkeit_klemme_30G,installed ,19
IDE09732-ENG133384-Interior light: light configuration-Ambient_Farbliste_HMI,active ,5
IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus,not active ,5
IDE09732-ENG114629-Interior light: light configuration-Foot well lighting,installed ,5
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz,30 %,17
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz,30 %,17
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne,50 %,17
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz,50 %,17
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne,50 %,17
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz,50 %,17
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne,75 %,17
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz,75 %,17
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne,80 %,17
IDE09761-ENG142183-Seat fan charac. curve-Sitzlueftung_reduzierbar,not installed ,17
IDE10298-Alternating park position 1,19.999980 °,2
IDE10299-Alternating park position 2,34.999965 °,2
IDE11477-ENG128619-Interior lighting: parameter-p_adaption_kundenwunsch_dach,1.00 ,256
IDE11477-ENG128539-Interior lighting: parameter-p_adaption_kundenwunsch_fussraum,0.20 ,256
IDE11477-ENG128571-Interior lighting: parameter-p_adaption_kundenwunsch_itafel,1.00 ,256
IDE11477-ENG128635-Interior lighting: parameter-p_adaption_kundenwunsch_psd,0.00 ,256
IDE11477-ENG128523-Interior lighting: parameter-p_adaption_kundenwunsch_tuer,0.60 ,256
IDE11477-ENG128659-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI,00000001  ,256
IDE11477-ENG128660-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_2,00110000  ,256
IDE11477-ENG128656-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_2,00000000  ,256
IDE11477-ENG128628-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_dach,100 %,256
IDE11477-ENG128548-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_fussraum,70 %,256
IDE11477-ENG128580-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_itafel,100 %,256
IDE11477-ENG128644-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_psd,0 %,256
IDE11477-ENG128532-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_tueren,96 %,256
IDE11477-ENG128625-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_dach,100 %,256
IDE11477-ENG128545-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_fussraum,70 %,256
IDE11477-ENG128577-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_itafel,100 %,256
IDE11477-ENG128641-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_psd,0 %,256
IDE11477-ENG128529-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_tueren,96 %,256
IDE11477-ENG128627-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_dach,100 %,256
IDE11477-ENG128547-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_fussraum,70 %,256
IDE11477-ENG128579-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_itafel,100 %,256
IDE11477-ENG128643-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_psd,0 %,256
IDE11477-ENG128531-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_tueren,96 %,256
IDE11477-ENG128624-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_dach,100 %,256
IDE11477-ENG128544-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_fussraum,70 %,256
IDE11477-ENG128576-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_itafel,100 %,256
IDE11477-ENG128640-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_psd,0 %,256
IDE11477-ENG128528-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_tueren,96 %,256
IDE11477-ENG128629-Interior lighting: parameter-p_helligkeit_einausstieg_dach,100 %,256
IDE11477-ENG128549-Interior lighting: parameter-p_helligkeit_einausstieg_fussraum,70 %,256
IDE11477-ENG128581-Interior lighting: parameter-p_helligkeit_einausstieg_itafel,100 %,256
IDE11477-ENG128645-Interior lighting: parameter-p_helligkeit_einausstieg_psd,0 %,256
IDE11477-ENG128533-Interior lighting: parameter-p_helligkeit_einausstieg_tueren,96 %,256
IDE11477-ENG128620-Interior lighting: parameter-p_helligkeit_entriegelt_dach,100 %,256
IDE11477-ENG128572-Interior lighting: parameter-p_helligkeit_entriegelt_itafel,100 %,256
IDE11477-ENG128636-Interior lighting: parameter-p_helligkeit_entriegelt_psd,0 %,256
IDE11477-ENG128524-Interior lighting: parameter-p_helligkeit_entriegelt_tueren,0 %,256
IDE11477-ENG128634-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_dach,100 %,256
IDE11477-ENG128554-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum,70 %,256
IDE11477-ENG128586-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_itafel,100 %,256
IDE11477-ENG128650-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_psd,0 %,256
IDE11477-ENG128538-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren,96 %,256
IDE11477-ENG128630-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_dach,100 %,256
IDE11477-ENG128582-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_itafel,100 %,256
IDE11477-ENG128646-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_psd,0 %,256
IDE11477-ENG128626-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_dach,126 %,256
IDE11477-ENG128642-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_psd,0 %,256
IDE11477-ENG128623-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_dach,100 %,256
IDE11477-ENG128575-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_itafel,100 %,256
IDE11477-ENG128639-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_psd,0 %,256
IDE11477-ENG128622-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_dach,100 %,256
IDE11477-ENG128542-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum,126 %,256
IDE11477-ENG128574-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_itafel,100 %,256
IDE11477-ENG128638-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_psd,0 %,256
IDE11477-ENG128526-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_tueren,126 %,256
IDE11477-ENG128621-Interior lighting: parameter-p_helligkeit_max_dach,100 %,256
IDE11477-ENG128541-Interior lighting: parameter-p_helligkeit_max_fussraum,70 %,256
IDE11477-ENG128573-Interior lighting: parameter-p_helligkeit_max_itafel,100 %,256
IDE11477-ENG128637-Interior lighting: parameter-p_helligkeit_max_psd,0 %,256
IDE11477-ENG128525-Interior lighting: parameter-p_helligkeit_max_tueren,96 %,256
IDE11477-ENG128631-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_dach,100 %,256
IDE11477-ENG128551-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum,70 %,256
IDE11477-ENG128583-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_itafel,100 %,256
IDE11477-ENG128647-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_psd,0 %,256
IDE11477-ENG128535-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren,96 %,256
IDE11477-ENG128632-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_dach,100 %,256
IDE11477-ENG128552-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum,70 %,256
IDE11477-ENG128584-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_itafel,100 %,256
IDE11477-ENG128648-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_psd,0 %,256
IDE11477-ENG128536-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren,96 %,256
IDE11477-ENG128633-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_dach,100 %,256
IDE11477-ENG128553-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum,70 %,256
IDE11477-ENG128585-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_itafel,100 %,256
IDE11477-ENG128649-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_psd,0 %,256
IDE11477-ENG128537-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren,96 %,256
IDE11477-ENG128480-Interior lighting: parameter-p_t_verzoegerung_einstieg_fussraum,2.0 s,256
IDE11477-ENG128473-Interior lighting: parameter-p_t_verzoegerung_einstieg_tueren,0.5 s,256
IDE11714-ENG126827-Ambient light color list-Blauwert Farbe 1,235 ,30
IDE11714-ENG133432-Ambient light color list-Blauwert Farbe 10,57 ,30
IDE11714-ENG126830-Ambient light color list-Blauwert Farbe 2,169 ,30
IDE11714-ENG126833-Ambient light color list-Blauwert Farbe 3,55 ,30
IDE11714-ENG133414-Ambient light color list-Blauwert Farbe 4,40 ,30
IDE11714-ENG133417-Ambient light color list-Blauwert Farbe 5,240 ,30
IDE11714-ENG133420-Ambient light color list-Blauwert Farbe 6,190 ,30
IDE11714-ENG133423-Ambient light color list-Blauwert Farbe 7,255 ,30
IDE11714-ENG133426-Ambient light color list-Blauwert Farbe 8,255 ,30
IDE11714-ENG126826-Ambient light color list-Gruenwert Farbe 1,221 ,30
IDE11714-ENG133431-Ambient light color list-Gruenwert Farbe 10,255 ,30
IDE11714-ENG126829-Ambient light color list-Gruenwert Farbe 2,169 ,30
IDE11714-ENG126832-Ambient light color list-Gruenwert Farbe 3,108 ,30
IDE11714-ENG133416-Ambient light color list-Gruenwert Farbe 5,88 ,30
IDE11714-ENG133419-Ambient light color list-Gruenwert Farbe 6,63 ,30
IDE11714-ENG133422-Ambient light color list-Gruenwert Farbe 7,102 ,30
IDE11714-ENG133425-Ambient light color list-Gruenwert Farbe 8,204 ,30
IDE11714-ENG133428-Ambient light color list-Gruenwert Farbe 9,204 ,30
IDE11714-ENG126825-Ambient light color list-Rotwert Farbe 1,217 ,30
IDE11714-ENG133430-Ambient light color list-Rotwert Farbe 10,136 ,30
IDE11714-ENG126828-Ambient light color list-Rotwert Farbe 2,169 ,30
IDE11714-ENG126831-Ambient light color list-Rotwert Farbe 3,253 ,30
IDE11714-ENG133412-Ambient light color list-Rotwert Farbe 4,242 ,30
IDE11714-ENG133415-Ambient light color list-Rotwert Farbe 5,254 ,30
IDE11714-ENG133418-Ambient light color list-Rotwert Farbe 6,124 ,30
IDE11714-ENG133424-Ambient light color list-Rotwert Farbe 8,0 ,30
IDE11944-ENG142014-Keyless access and start authorization-Elektische_Lenkradverriegelung,not installed ,3
IDE11944-ENG141948-Keyless access and start authorization-Kessy,not installed ,3
IDE11944-ENG116626-Keyless access and start authorization-Oeffnung Heckdeckel bei Wiederentriegelung,not active ,3
IDE12412-ENG154557-LIN Ambient light color list-Blauwert_Farbe_3_lin,0 ,30
IDE12412-ENG154560-LIN Ambient light color list-Blauwert_Farbe_4_lin,0 ,30
IDE12412-ENG154561-LIN Ambient light color list-Blauwert_Farbe_5_lin,0 ,30
IDE12412-ENG154562-LIN Ambient light color list-Blauwert_Farbe_6_lin,0 ,30
IDE12412-ENG154656-LIN Ambient light color list-Gruenwert_Farbe_2_lin,0 ,30
IDE12412-ENG154676-LIN Ambient light color list-Gruenwert_Farbe_3_lin,0 ,30
IDE12412-ENG154679-LIN Ambient light color list-Gruenwert_Farbe_4_lin,0 ,30
IDE12412-ENG154680-LIN Ambient light color list-Gruenwert_Farbe_5_lin,0 ,30
IDE12412-ENG154681-LIN Ambient light color list-Gruenwert_Farbe_6_lin,0 ,30
IDE12412-ENG154682-LIN Ambient light color list-Gruenwert_Farbe_7_lin,0 ,30
IDE12412-ENG154683-LIN Ambient light color list-Gruenwert_Farbe_8_lin,0 ,30
IDE12412-ENG154733-LIN Ambient light color list-Rotwert_Farbe_1_lin,0 ,30
IDE12412-ENG154744-LIN Ambient light color list-Rotwert_Farbe_2_lin,0 ,30
IDE12412-ENG154767-LIN Ambient light color list-Rotwert_Farbe_4_lin,0 ,30
IDE12412-ENG154768-LIN Ambient light color list-Rotwert_Farbe_5_lin,0 ,30
IDE12412-ENG154769-LIN Ambient light color list-Rotwert_Farbe_6_lin,0 ,30
IDE12412-ENG154771-LIN Ambient light color list-Rotwert_Farbe_8_lin,0 ,30
MAS05055-lower turn position,42.999957 °,2
MAS05056-upper turn position,178.999822 °,2
MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle,0 lx,24
MAS08228-ENG133445-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red,00 00 ,24
MAS08228-ENG133436-Light sensor-Helligkeitsgrenze_sehr_hell,2000 lx,24
MAS08228-ENG133442-Light sensor-Maximale_Ausgangsspannung,0 mV,24
MAS08228-ENG133440-Light sensor-Maximale_Beleuchtungsstaerke,0 lx,24
MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung,0 mV,24
ENG141683-ENG116672-Allwetterlicht_Spoiler-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren,not active ,4
ENG141683-ENG116671-Allwetterlicht_Spoiler-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT,not active ,4
ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1,00 ,60
ENG141649-ENG122211-Außenlicht_Blinker-Richtungs_blinken_links,not active ,10
ENG141649-ENG122210-Außenlicht_Blinker-Richtungs_blinken_rechts,not active ,10
ENG141649-ENG142029-Außenlicht_Blinker-Warnblinken_durch_Fahrerassistenz,active ,10
ENG141649-ENG122214-Außenlicht_Blinker-Warnblinken_Zuendung_AUS,not active ,10
ENG141649-ENG122213-Außenlicht_Blinker-Warnblinken_Zuendung_EIN,not active ,10
ENG141647-ENG115861-Außenlicht_Front-Lichthupe bei Zuendung aus moeglich,active ,9
ENG141648-ENG115782-Aussenlicht_Heck-Nebelschlusslicht Warngeschwindigkeit,0 km/h,5
ENG141648-ENG115831-Aussenlicht_Heck-Schlusslicht mit Bremslichtfunktion,active ,5
ENG141656-ENG142020-Außenlicht_uebergreifend-All-weather lights,not installed ,18
ENG141656-ENG115656-Außenlicht_uebergreifend-Coming Home Leuchten,Fog light ,18
ENG141656-ENG116604-Außenlicht_uebergreifend-Coming-home Einschaltereignis,ignition ,18
ENG141656-ENG130581-Außenlicht_uebergreifend-Fahrlicht_Hinweis_mehrfach,active ,18
ENG141656-ENG133382-Außenlicht_uebergreifend-Faktor fuer Verfügbarkeitstimer,Faktor fuer x5 Minuten ,18
ENG141656-ENG116608-Außenlicht_uebergreifend-Helligkeitsschwelle Forward-Messung,46400 lx,18
ENG141656-ENG116603-Außenlicht_uebergreifend-Menueeinstellung Cominghome,10 seconds ,18
ENG141656-ENG116607-Außenlicht_uebergreifend-Menueeinstellung Leaving-home Zeit per BAP,10 seconds ,18
ENG122934-erase_error_table,00 00 00 ,3
ENG141650-ENG141973-Fernlicht_assistent-Erweiterte_Fernlichtsteuerung,AFS: FLA: Fernlicht (GLW:MDF) ,6
ENG141650-ENG116637-Fernlicht_assistent-Menuesteuerung Fernlichtassistent,present ,6
ENG141682-ENG115835-Front_wiper-Adaptives Nachwischen bei SRA,active ,6
ENG141682-ENG115770-Front_wiper-Variable Regensensoraktivierung,not active ,6
ENG141660-ENG115658-Kennlinie_sLWR_Soll-x0,-100.00 %,30
ENG141660-ENG101574-Kennlinie_sLWR_Soll-X1,-100.00 %,30
ENG141660-ENG99557-Kennlinie_sLWR_Soll-X2,-100.00 %,30
ENG141660-ENG102140-Kennlinie_sLWR_Soll-X3,-100.00 %,30
ENG141660-ENG102936-Kennlinie_sLWR_Soll-X4,-100.00 %,30
ENG141660-ENG103548-Kennlinie_sLWR_Soll-X5,-100.00 %,30
ENG141660-ENG113992-Kennlinie_sLWR_Soll-X6,-100.00 %,30
ENG141660-ENG115661-Kennlinie_sLWR_Soll-x7,-100.00 ,30
ENG141660-ENG115662-Kennlinie_sLWR_Soll-x8,-100.00 %,30
ENG141660-ENG115663-Kennlinie_sLWR_Soll-x9,-100.00 %,30
ENG141660-ENG115659-Kennlinie_sLWR_Soll-y0,100.0 %,30
ENG141660-ENG99777-Kennlinie_sLWR_Soll-Y1,90.0 %,30
ENG141660-ENG100480-Kennlinie_sLWR_Soll-Y2,80.0 %,30
ENG141660-ENG100773-Kennlinie_sLWR_Soll-Y3,70.0 %,30
ENG141660-ENG100631-Kennlinie_sLWR_Soll-Y4,60.0 %,30
ENG141660-ENG102174-Kennlinie_sLWR_Soll-Y5,50.0 %,30
ENG141660-ENG113993-Kennlinie_sLWR_Soll-Y6,40.0 %,30
ENG141660-ENG115665-Kennlinie_sLWR_Soll-y7,30.0 %,30
ENG141660-ENG115666-Kennlinie_sLWR_Soll-y8,15.0 %,30
ENG141660-ENG115667-Kennlinie_sLWR_Soll-y9,0.0 %,30
ENG141657-ENG116159-Leuchte 35 LED Warnblinktaster C48-Fehlerort mittleres Byte DTC-DFCC 15,06 ,16
ENG141657-ENG116160-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion A 15,Unknown (76),16
ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10,127 ,16
ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10,63 ,16
ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10,45 ,16
ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10,41 - LED Kleinleistung ,16
ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10,Versorgungsbedarf der LCM Module ,16
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12,10 - allgemeine Scheinwerfer ,16
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13,10 - allgemeine Scheinwerfer ,16
ENG116952-ENG116185-Leuchte16BLK SLB35BLK SL KC9-Dimmwert CD 16,127 ,16
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16,2A ,16
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16,1A ,16
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16,37 - allgemeine LED bis 12W ,16
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16,Parking light right ,16
ENG116952-ENG116184-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion D 16,Daytime running lights ,16
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17,127 ,16
ENG116953-ENG116204-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert CD 17,127 ,16
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17,29 ,16
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17,0A ,16
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17,37 - allgemeine LED bis 12W ,16
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116953-ENG116203-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion D 17,Daytime running lights ,16
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18,127 ,16
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18,38 - LED Blinkleuchten ,16
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19,127 ,16
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19,38 - LED Blinkleuchten ,16
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1,0 ,16
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1,00 ,16
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1,not active ,16
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1,not active ,16
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20,127 ,16
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20,34 - LED Bremsleuchten ,16
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20,Brake light ,16
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21,127 ,16
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21,34 - LED Bremsleuchten ,16
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21,Brake light ,16
ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22,127 ,16
ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22,Quittierungsfunktion 1 ,16
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23,127 ,16
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23,127 ,16
ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23,35 ,16
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23,32 - allgemeine LED bis 12W ,16
ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23,only_if_closed ,16
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23,not active ,16
ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23,Daytime running lights ,16
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24,127 ,16
ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24,36 ,16
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24,32 - allgemeine LED bis 12W ,16
ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24,only_if_closed ,16
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24,Parking light right ,16
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24,not active ,16
ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24,Daytime running lights ,16
ENG116961-ENG116356-Leuchte25KZL HA59-Dimmwert CD 25,127 ,16
ENG116961-ENG116355-Leuchte25KZL HA59-Lichtfunktion D 25,Daytime running lights ,16
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26,127 ,16
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26,43 - allgemeine LED ,16
ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26,only_if_closed ,16
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26,Nebelschlusslicht wenn kein Anhaenger gesteckt und Rechtsverkehr ,16
ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27,minimize ,16
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27,127 ,16
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27,36 ,16
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27,1A ,16
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27,32 - allgemeine LED bis 12W ,16
ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27,only_if_closed ,16
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27,Brake light ,16
ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27,Nebelschlusslicht wenn kein Anhaenger gesteckt und Rechtsverkehr ,16
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28,32 - allgemeine LED bis 12W ,16
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29,127 ,16
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29,32 - allgemeine LED bis 12W ,16
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2,0 ,16
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2,not active ,16
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2,not active ,16
ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30,89 ,16
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30,36 - LED Kleinleistung ,16
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3,0 ,16
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3,not active ,16
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3,not active ,16
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4,0 ,16
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4,not active ,16
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4,not active ,16
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5,0 ,16
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5,not active ,16
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5,not active ,16
ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6,0 ,16
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6,Lichthupe generell ,16
ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6,not active ,16
ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7,0 ,16
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7,Lichthupe generell ,16
ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7,not active ,16
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8,4A ,16
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8,44 ,16
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8,5 - LED Abblendlicht ,16
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8,Parking light right ,16
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9,49 ,16
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9,3A ,16
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9,5 - LED Abblendlicht ,16
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG141661-Leuchtenkonfiguration_Aussenlich_Heck,26 08 00 16 02 00 7F 00 00 00 00 00 00 00 00 00 26 18 00 18 04 00 7F 00 00 00 00 00 00 00 00 00 22 09 00 2B 18 00 7F 00 00 00 00 00 00 00 00 00 22 19 00 2D 18 00 7F 00 00 00 00 00 00 00 00 00 2A 29 00 2C 18 24 7F 00 00 00 00 00 00 00 00 00 20 0A 00 35 08 09 FF 00 14 7F 00 00 00 00 00 00 20 1A 00 36 08 0A FF 00 14 7F 00 00 00 00 00 00 2B 28 00 30 08 00 7F 00 14 7F 00 00 00 00 00 00 2B 0C 00 2E 1B 00 FF 00 00 00 00 00 00 00 00 00 20 1A 00 36 18 00 FF 1B 00 80 00 00 00 00 00 00 20 0B 00 31 19 00 7F 00 00 00 00 00 00 00 00 00 20 1B 00 32 19 00 7F 00 00 00 00 00 00 00 00 00 ,192
ENG141662-Leuchtenkonfiguration_Sonstiges,25 1A 00 2A 08 0A 7F 00 14 7F 00 00 00 00 00 00 25 0A 00 29 08 09 7F 00 14 7F 00 00 00 00 00 00 24 00 00 02 2B 00 59 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 29 00 00 06 4C 00 64 00 00 00 00 00 00 00 00 00 ,128
ENG141658-ENG142219-Leuchtweitenregulierung-Achsabstand_des_Fahrzeuges,0 mm,62
ENG141658-ENG142218-Leuchtweitenregulierung-Achssensor_PWM_Wert_Einfederung_Sensor_H4,-8.00 mm/%,62
ENG141658-ENG142217-Leuchtweitenregulierung-Achssensor_PWM_Wert_Einfederung_Sensor_vorn,-8.00 mm/%,62
ENG141658-ENG142211-Leuchtweitenregulierung-Ansteuerung_obere_grenze,90.0 %,62
ENG141658-ENG142210-Leuchtweitenregulierung-Ansteuerung_untere_grenze,10.0 %,62
ENG141658-ENG142214-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_1,-8.00 mm/%,62
ENG141658-ENG142216-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_2,-8.00 mm/%,62
ENG141658-ENG142213-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_1,-8.00 mm/%,62
ENG141658-ENG142215-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_2,-8.00 mm/%,62
ENG141658-ENG142198-Leuchtweitenregulierung-Fahrwerk_Variante,Verbundlenkerhinterachse ,62
ENG141658-ENG142204-Leuchtweitenregulierung-Fail_Safe_sLWR,0.0 %,62
ENG141658-ENG142223-Leuchtweitenregulierung-fFiltEinf,0.00 Hz,62
ENG141658-ENG142212-Leuchtweitenregulierung-Lineare_Abbildung,0 ,62
ENG141658-ENG142220-Leuchtweitenregulierung-lwr_lFzg_Sw_Abstand,0 mm,62
ENG141658-ENG142221-Leuchtweitenregulierung-lwr_lFzg_Sw_Hoehe,0 mm,62
ENG141658-ENG142226-Leuchtweitenregulierung-lwr_pwm_obere_schwelle,87.5 %,62
ENG141658-ENG142225-Leuchtweitenregulierung-lwr_pwm_untere_schwelle,12.5 %,62
ENG141658-ENG142227-Leuchtweitenregulierung-max_v_slwr,0 km/h,62
ENG141658-ENG142224-Leuchtweitenregulierung-pa_fFiltSwNeigung,0.00 Hz,62
ENG141658-ENG142200-Leuchtweitenregulierung-Quelle_Hoehenwerte,CAN_Daempferregelung ,62
ENG141658-ENG142042-Leuchtweitenregulierung-sensor_headlight_range_control_installed,not installed ,62
ENG141658-ENG142199-Leuchtweitenregulierung-sLWR_bei_Abblendlicht,active ,62
ENG141658-ENG142208-Leuchtweitenregulierung-sLWR_Hysterese,20.0 %,62
ENG141658-ENG142207-Leuchtweitenregulierung-sLWR_SW_Grad,0.0 %/s,62
ENG141658-ENG142206-Leuchtweitenregulierung-sLWR_Touristenlicht,-100.0 %,62
ENG141659-ENG115658-lwr_ofs_RSw_Ah1S-x0,-5.00 %,20
ENG141659-ENG101574-lwr_ofs_RSw_Ah1S-X1,-5.00 %,20
ENG141659-ENG99557-lwr_ofs_RSw_Ah1S-X2,-5.00 %,20
ENG141659-ENG102140-lwr_ofs_RSw_Ah1S-X3,-5.00 %,20
ENG141659-ENG102936-lwr_ofs_RSw_Ah1S-X4,-5.00 %,20
ENG141659-ENG115659-lwr_ofs_RSw_Ah1S-y0,-5.00 ,20
ENG141659-ENG99777-lwr_ofs_RSw_Ah1S-Y1,-5.00 ,20
ENG141659-ENG100480-lwr_ofs_RSw_Ah1S-Y2,-5.00 ,20
ENG141659-ENG100773-lwr_ofs_RSw_Ah1S-Y3,-5.00 ,20
ENG141659-ENG100631-lwr_ofs_RSw_Ah1S-Y4,-5.00 ,20
ENG122979-ENG141968-Networking-Anhaengeranschlussgeraet,installed ,8
ENG124714-ENG142260-OCU-Honk DWA_Ausgabe_Fanfare,active ,8
ENG124714-ENG142262-OCU-Remote HuF Hupfrequenz,3 ,8
ENG124714-ENG133392-OCU-Remote Lock Unlock Timer s3,20.0 ms,8
ENG98831-ENG126849-Personalization-Aktivierungsoption_im_HMI-Menue_sichtbar,active ,16
ENG98831-ENG133401-Personalization-Anzahl_Benutzerkonten,4 ,16
ENG98831-ENG126850-Personalization-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar,active ,16
ENG98831-ENG126848-Personalization-Personalisierung_aktiv,active ,16
ENG98831-ENG141994-Personalization-Personalisierung_Profilfunkion,profiles_active ,16
ENG98831-ENG126851-Personalization-Personalisierungsfunktionen_in_HMI-Menue_sichtbar,active ,16
ENG98831-ENG142030-Personalization-Profil_Variante,Konto (v. 1.x) ,16
ENG98831-ENG133404-Personalization-PSO_FSG_Setup2_Bit_1,active ,16
ENG98831-ENG133405-Personalization-PSO_FSG_Setup2_Bit_2,active ,16
ENG141646-MAS01065-Querschnitts_funktionen-Brand,VW ,5
ENG141646-ENG116624-Querschnitts_funktionen-CAN Wecken bei Softtouchbetaetigung,not active ,5
ENG141646-ENG142187-Querschnitts_funktionen-Hardware_Eingang_Drucktankklappenstatus,Pin 31 ,5
ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn,200 lx,1
ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day,500 lx,1
ENG115729-ENG116609-Scheinwerferreinigung-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,10 ,10
ENG115729-ENG141949-Scheinwerferreinigung-Headlamp washer system,installed ,10
ENG115729-ENG115767-Scheinwerferreinigung-SRA Einweichpausenzeit,2000 ms,10
ENG115729-ENG115768-Scheinwerferreinigung-SRA Nachwaschzeit,800 ms,10
ENG115729-ENG115766-Scheinwerferreinigung-SRA Waschzeit,800 ms,10
ENG141684-SFT271873-Slave_systems_identification-Control Unit For Wiper Motor,Not available ,6
ENG141684-SFT271874-Slave_systems_identification-Rain Light Recognition Sensor,Not available ,6
ENG141684-SFT271877-Slave_systems_identification-Garage Door Opener Operating Unit,Not available ,6
ENG141684-SFT271894-Slave_systems_identification-Sensor For Anti Theft Alarm System,Not available ,6
ENG141684-SFT271904-Slave_systems_identification-Sun Roof,Not available ,6
ENG141684-SFT271910-Slave_systems_identification-Ceiling Light Module,Not available ,6
ENG141684-SFT271928-Slave_systems_identification-Roof Blind,Not available ,6
ENG141684-SFT271947-Slave_systems_identification-Relative Air Humidity Interior Sender,Not available ,6
ENG141684-SFT271966-Slave_systems_identification-Neck Heating Left,Not available ,6
ENG141684-SFT271967-Slave_systems_identification-Neck Heating Right,Not available ,6
ENG141684-SFT272065-Slave_systems_identification-Seat Backrest Fan 1 Front Left,Not available ,6
ENG141684-SFT272067-Slave_systems_identification-Seat Cushion Fan 1 Front Left,Not available ,6
ENG141684-SFT272069-Slave_systems_identification-Seat Backrest Fan 1 Front Right,Not available ,6
ENG141684-SFT272071-Slave_systems_identification-Seat Cushion Fan 1 Front Right,Not available ,6
ENG116588-ENG116589-Sonderfunktionen-Signalprioritaet fuer Blinker,MFG ,4
ENG141635-ENG116659-Spiegelverstellung-Menuesteuerung synchrone Spiegelverstellung,active ,5
ENG141635-ENG126841-Spiegelverstellung-Profilfunktion fuer Anklappung der Aussenspiegel,active ,5
ENG141635-ENG116656-Spiegelverstellung-Spiegelverstellung Synchron,active ,5
ENG141663-ENG142236-Suchbeleuchtung_allgemein-Daempfung Abdimmen KL 58xs PWM,0.00 s,21
ENG141663-ENG142238-Suchbeleuchtung_allgemein-Daempfung Abdimmen KL 58xt PWM,0.00 s,21
ENG141663-ENG142239-Suchbeleuchtung_allgemein-Daempfung Aufdimmen KL 58xd PWM,0.00 s,21
ENG141663-ENG142237-Suchbeleuchtung_allgemein-Daempfung Aufdimmen KL 58xt PWM,0.00 s,21
ENG141663-ENG142242-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Abdimmen,20.0 s,21
ENG141663-ENG142241-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Aufdimmen,3.0 s,21
ENG141663-ENG142243-Suchbeleuchtung_allgemein-pa_Hysterese_RLS,2 ,21
ENG141663-ENG142235-Suchbeleuchtung_allgemein-PWM Daempfung Aufdimmen KL58xs PWM,0.00 s,21
ENG141663-ENG115631-Suchbeleuchtung_allgemein-Suchbeleuchtung Festwert,50 %,21
ENG141663-ENG115820-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Grundwert,10.0 %,21
ENG141672-ENG101574-Suchbeleuchtung_KL_58xd_min-X1,50 lx,10
ENG141672-ENG99777-Suchbeleuchtung_KL_58xd_min-Y1,16.0 ,10
ENG141672-ENG100480-Suchbeleuchtung_KL_58xd_min-Y2,25.0 ,10
ENG141672-ENG100773-Suchbeleuchtung_KL_58xd_min-Y3,30.0 ,10
ENG141672-ENG100631-Suchbeleuchtung_KL_58xd_min-Y4,50.0 ,10
ENG141677-ENG99557-Suchbeleuchtung_KL_58xd_PWM-X2,50 ,12
ENG141677-ENG102140-Suchbeleuchtung_KL_58xd_PWM-X3,100 ,12
ENG141677-ENG115659-Suchbeleuchtung_KL_58xd_PWM-y0,2.0 %,12
ENG141677-ENG99777-Suchbeleuchtung_KL_58xd_PWM-Y1,2.0 %,12
ENG141677-ENG100480-Suchbeleuchtung_KL_58xd_PWM-Y2,6.0 %,12
ENG141677-ENG100773-Suchbeleuchtung_KL_58xd_PWM-Y3,10.0 %,12
ENG141677-ENG100631-Suchbeleuchtung_KL_58xd_PWM-Y4,80.0 %,12
ENG141680-ENG101574-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X1,10 lx,12
ENG141680-ENG99557-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X2,100 lx,12
ENG141680-ENG102140-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X3,500 lx,12
ENG141680-ENG99777-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y1,20 ,12
ENG141680-ENG100480-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y2,80 ,12
ENG141680-ENG100773-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y3,180 ,12
ENG141680-ENG100631-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y4,300 ,12
ENG141632-ENG116646-Sunroof-SAD Komfort schliessen,not active ,4
ENG141634-ENG125652-Verdecksteuergeraet-Servoheck Schlossansteuerung,nur wenn mind. 1 Raste zu ,9
ENG141634-ENG142011-Verdecksteuergeraet-trunk_lid_conrol_unit,installed ,9
ENG141634-ENG142258-Verdecksteuergeraet-Virtuelles_Pedal_HMI_einstellba,not active ,9
ENG124901-Wischer_Fehlermaske_Mitsuba_Entw,0 bit,4
ENG116832-ENG126852-Wischgeschwindigkeiten-Dauerwischen Stufe_1 Zyklen pro Minute,40 ,3
ENG116832-ENG126853-Wischgeschwindigkeiten-Dauerwischen Stufe_2 Zyklen pro Minute,60 ,3
ENG141651-ENG133390-ZV allgemein-Wiederverriegelung_Laderaum,ZV_Wiederveriegelung ,7
ENG141651-ENG141996-ZV allgemein-ZV_ohne_Safe_Funktion,installed ,7
ENG141654-ENG115756-ZV Autolock-automatisches Verriegeln bei Geschwindigkeit,not active ,3
ENG141655-ENG116661-ZV Crash-SAD PreCrash Konturschliessen,active ,4
ENG141653-ENG142016-ZV Heck-Heckdeckelentriegelung_HDF_Innentaster,via_CAN ,7
ENG141653-ENG141995-ZV Heck-Heckschloss_Steuerung,Kontaktsteuerung mit Mindestansteuerzeit ,7
ENG141681-IDE02022-ZV Komfort-Comfort opening,not active ,8
ENG141681-ENG116664-ZV Komfort-Fahrertuerbedienung Fensterheber schliessen,active ,8
ENG141681-ENG116643-ZV Komfort-Schliesszylinder Komfort oeffnen,not active ,8
ENG141681-ENG116644-ZV Komfort-Schliesszylinder Komfort schliessen,not active ,8
ENG141652-ENG141999-ZV Türkonfiguration-Fond_Schloss,Tuersteuergeraet im Fond verbaut oder keine Fondtuer ,5
Elapsed Time: 01:29
kamil1555
PL
C?ID=210479
Ok. Thank's. I check it.
kamil1555
PL
C?ID=210479
I've already dealt with the radar and the rest. There is only one problem left for me: the mirrors, windows and sunroof from the remote control do not work, although I have everything coded in the module. Oddly enough, the car responds only to two buttons on the remote control, open and close, and the car does not respond to the trunk button.
@kamil1555: Hi again
My apology, but I have to ask - I note that your admap has ENG141681-ENG122994-ZV Komfort-Menuesteuerung Komfortbedienung einstellbar set to "adjustable". This means that there is a mechanism in the MENU to turn-on/off the comfort opening facility. Is it set?
AINils
Germany (AIB)
He used cracked Radar Sensor, that`s why fault with IKA Key ist inside.
kamil1555
PL
C?ID=210479
Yes, turn on, but not working :(
