[RS4 B8] Suspension Electronics Fault - (14) Security Access
Szogun
Poland
C?ID=403301
Hi,
I have problem with RS4 8 lift (2014).
Error 02646 has appeared - it returns after deleting and suspension adjustment does not work.
I tried to adapt but it is not available.
What is the security code (I tried 20103 and 02000).
And why the coding in suspension electronics is 00000? It should be?
I don't have a previous autoscan to check it.
VIN: WUAZZZ8KXEA901520   License Plate:
Chassis Type: 8K-AU48 (8R0)
Scan: 01 02 03 05 08 09 0E 13 14 15 16 17 19 1B 22 30 42 44 46 47
          52 53 56 5C 5F 62 6C 72
VIN: WUAZZZ8KXEA901520   Mileage: 199070km-123696miles
5C-Lane Maintain. -- Status: OK 0000
Address 01: Engine (------CFSA)       Labels:. 079-907-560-CFS.clb
   Part No SW: 8T2 907 560 E    HW: 8T1 907 560
   Component: 4.2l V8HDZ /  X04 0003
   Revision: NAX04---
   Coding: 1225003225C6080A3000
   Shop #: WSC 92521 052 00000
   ASAM Dataset: EV_ECM42FSI0118T2907560E 001002
   ROD: EV_ECM42FSI0118T2907560E.rod
   VCID: 3E253BD570F3BADB60F-806A
Readiness: 1110 1001
   Part No SW: 8T0 927 156 J    HW: 0B5 927 156 K
   Component: 0B5 42 FSIRdW H02 0003
   Revision: --H02---
   Shop #: WSC 06325 000 00000
   ASAM Dataset: EV_TCMDL501021 001015
   ROD: EV_TCMDL501021.rod
   VCID: 44D1493D1E1FD00B36B-8010
   Part No SW: 8T0 907 379 F    HW: 8T0 907 379 F
   Component: ESP8 quattro  H09 0100
   Coding: 386D6A
   VCID: 45D7543915A5E903215-8010
   Part No SW: 8K0 907 064 JF    HW: 8K0 907 064 JF
   Component: BCM2 2.0      H14 0650
   Coding: 05824000000000000000
   VCID: 7DA7FCD93DF561C3395-8028
   Subsystem 1 - Part No SW: 8K0 959 754 CD    HW: 8K0 959 754 CD
   Serial number: 0514000023960001
Address 08: Auto HVAC (J255)       Labels:. 8Kx-820-043-3Z.clb
   Part No SW: 8K1 820 043 T    HW: 8K1 820 043 T
   Revision: C1000000    Serial number: 01280220141141
   Coding: 4800000000
   VCID: 392F28C9695D9DE355D-806C
   Part No SW: 8K0 907 063 DL    HW: 8K0 907 063 DL
   Component: BCM1 1.0      H22 0103
   Revision: 1002208S    Serial number: 00002176448502
   Coding: 0600001000349FF23D8140C3000019090F9CC70A22090201000008004401010200020034000000
   Shop #: WSC 23658 001 1048576
   VCID: 7CA1F1DD26EF68CB0EB-8028
   Subsystem 1 - Part No SW: 8K1 955 119 B    HW: 8K1 955 119 B  Labels: 1KX-955-119.CLB
   Component: MITSUBA130214  H18 0461
   Serial number: 1402120702926
   Coding: 004577
   Serial number: 22318471
   Coding: 02005D
   Subsystem 3 - Part No SW: 8K0 941 531 AQ    HW: 8K0 941 531 AQ
   Component: E1 - LDS  H03 0031
   Serial number: 00000000001002140113
   Subsystem 4 - Part No SW: 8K5 941 329     HW: 8K5 941 329
H01 0031
   Subsystem 5 - Part No SW: 8K5 941 329     HW: 8K5 941 329
H01 0031
   Subsystem 6 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Serial number: 3E684417000000000001
Address 0E: Media Player 1 (R41)       Labels: Redir Fail!
   Part No SW: 8X0 035 110 C    HW: 8X0 035 110
   Component: CDC-MP3-Pana  H41 0490
   Revision: 00000008
   VCID: 2D070C99AD153143C95-8078
Address 13: Auto Dist. Reg (J428)       Labels: None
   Part No SW: 8K0 907 561 C    HW: 8K0 907 561 C
   Component: ACC3          H11 0100
   Coding: 003370
   VCID: 323D1FE5B42B6EBB947-8066
Address 14: Susp. Elect.        Labels: None
   Part No SW: 8T0 907 376     HW: 8T0 907 376 A
   Component: J250 DRC FahrwerH01 0030
   Revision: 00000000    Serial number: 00875015534700
   Coding: 0000000
   Shop #: WSC 36884 001 1048576
   VCID: 7CA1F1DD2AEF68CB0EB-8028
02646 - Plausibility of Level Control System
            008 - Implausible Signal - MIL ON
                    Fault Status: 11101000
                    Reset counter: 227
                    Mileage: 199072 km
                    Date: 2020.09.04
                    Time: 13:36:51
   Part No SW: 8K0 959 655 N    HW: 8K0 959 655 N
   Component: AirbagVW-AU10 H48 0610
   Serial number: 003KFDC0243T
   Coding: 31354435363030303030554A304C384B3053
   Shop #: WSC 03078 001 1048576
   VCID: 48C95D0D2237F46BDA3-801C
   Serial number: 6334MSME413D337FM
   Serial number: 6344MSME413D317EK
   Serial number: 6352QSME6C3E5642T
   Serial number: 6362QSME154347529
   Serial number: 63732SME603C3E5CB
   Serial number: 63832SME603C3C4A7
   Part No SW: 8K0 953 568 M    HW: 8K0 953 568 M
   Revision: --------    Serial number: 90372NBS000OT
   Coding: 0000FF
   VCID: 44D1493D1E9FD00B36B-8010
   Part No SW: 8K0 920 931 S    HW: 8K0 920 931 S
   Component: KOMBIINSTR.   H35 0564
   Revision: 00200000    Serial number: ZCM53DH2F
   Coding: 13EF1100FF010008070000
   VCID: 3E253BD57073BADB60F-806A
   Part No SW: 8R0 907 468 P    HW: 8R0 907 468 D
   Component: GW-BEM 5CAN-M H11 0060
   Revision: 1Z120030    Serial number: 3041Z142170484
   Coding: 80E3031600
   VCID: 4CC1611D36CF184BFEB-8018
   Serial number: 2508612603
   Part No SW: 8K0 907 144 M    HW: 8K0 907 144 M
   Component: DYNAMIKLENK.  H06 0730
   Revision: 52001005    Serial number: --------------
   Coding: 030000
Address 22: AWD (J492)       Labels: 8K0-907-163.clb
   Part No SW: 8K0 907 163 B    HW: 8K0 907 163 A
   Component: 4 Wheel Drive H14 0100
   Serial number: 002602140001947
   VCID: 2F3B1691A7994353FB9-807A
Address 30: Special Function II (J843)       Labels: 8K0-907-440.clb
   Part No SW: 8K0 907 440 B    HW: 8K0 907 440
   Component: STS           H04 0020
   Revision: S0H04000    Serial number: 00000000098268
   Coding: 01010101000000000001000102
   Part No SW: 8T0 959 793 P    HW: 8T0 959 793 G
   Component: TSG FA        H09 0305
   Coding: 011C12205C20410001
   VCID: 56F58375F803529B58F-8002
   Part No SW: 8K0 909 144 G    HW: 8K0 909 144 B
   Component: RCEPS         H40 0508
   Revision: 00001000    Serial number: 0015312226
   Coding: 010001010001
   Shop #: WSC 06324 000 00000
   ASAM Dataset: EV_RCEPSAU48X 008015
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 353724F945C57983B15-8060
   Revision: 00002001    Serial number: 0328845853
   Coding: 013A0E20A0B908958330023280000000
   Subsystem 3 - Part No SW: 8K0 959 591 C    HW: 8K0 959 591
   Component: J245 PS151  H08 0043
   Subsystem 4 - Part No SW: 8K0 959 591 C    HW: 8K0 959 591
   Component: J394 PS240  H08 0043
   Revision: 00005001    Serial number: 94813026632204
   Part No SW: 8T0 959 792 P    HW: 8T0 959 792 G
   Component: TSG BF        H09 0305
   Coding: 011C12205E20410001
   VCID: 55F78479E5055983515-8000
   Component: EPB-4         H01 0005
   Revision: --------    Serial number: 00000001445419
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 3A2D37C56CDB96FB5C7-806E
   Part No SW: 4G1 035 053 J    HW: 4G1 035 053
   Component: Radio U Basic H41 0133
   Revision: AB001007    Serial number: 227C10E7885057
   Coding: 010003010000000001
   VCID: 2615F3B588E3021B08F-8072
Address 5C: Lane Maintain.        Labels: None
   Part No SW: 8T0 907 217 A    HW: 4E0 907 217 C
   Component: J759 HC             0040
   Revision: 00H08006    Serial number: 6002143030007E
   Coding: 0032001
   VCID: 372B2EF153498B93A39-8062
   Part No SW: 8R1 035 670 E    HW: 8R1 035 670 E
   Component: H-BNT-EU      H48 0793
   Revision: --------    Serial number: 207B40E7577776
   Coding: 120100010306A9EF2D80CB5E00000403040000000000000000
   VCID: 353724F945457983B15-8060
   Subsystem 1 - Part No: 8R0 060 884 BK
   Component: EUR 2014  1703
   Component: DU7 High  H42 0104
   Serial number: A130BN0E2954412
   Subsystem 3 - Part No SW: 8T0 919 611 N    HW: 8T0 919 611 J
   Serial number: 00000001761633
   Component: CD-Database  5571
   Part No SW: 8T0 959 795 Q    HW: 8T0 959 795 H
   Component: TSG HL        H07 0305
   Coding: 010C12204020210001
   VCID: 59EF8849891D7DE375D-800C
   Revision: --H09---    Serial number: 525PA8-J3Z91ZX
   Coding: 1021007
   VCID: 38292DCD5E5784EBAA3-806C
   Component: TSG HR        H07 0305
End----------(Elapsed Time: 02:10, VBatt start/end: 14.5V/14.5V)-----------
downtime
Finland
C?ID=280813
Have you visually checked the level sensors that they are not broken? Two at front both left and right side and one on the rear axle.
If the Audi level control electronics is anyway like in VW there’s no coding for the module 14, all settings are in adaptations.
akersgarage
C?ID=179893
Did you get to the bottom of the 02646 fault. We have same fault just now.
Szogun
Poland
C?ID=403301
Not exactly bottom of the fault, but I successfully erased the error.
The RS version has different suspension. Any clue for Audi A or S are in this case non usable.
I went to someone with ODIS - there is a guided function for this. Did You do this with VCDS?
