Hello, I changed my a4 b6 ecu and the new ecu has different drivetrain setup.
I need security access code in engine group to be able to change coding, i assume? I get error 31 coding rejected when trying to modify coding
Wednesday,02,September,2020,19:55:17:43954
VCDS Version: 20.4.2.0
VIN: WAUZZZ8E33A183181 License Plate:
Mileage: 435870km-270837mi Repair Order:
67 69 75 76 77
VIN: WAUZZZ8E33A183181 Mileage: 435870km-270837miles
Address 01: Engine Labels: 06B-906-018-AVJ.lbl
Part No: 8E0 909 518 AA
Component: 1.8L R4/5VT G 0004
Coding: 0011011
Shop #: WSC 87119 806 641192
VCID: 6FEC56417D36BEFEFA-5140
18020 - Engine Control Module Incorrectly Coded
P1612 - 004 -
Readiness: 0110 1101
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517 A
Component: ABS/ESP allrad 4529
Coding: 04475
VCID: 26427365C24CBFB649-50E8
18256 - Please check DTC Memory of Engine Controller
P1848 - 35-00 -
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 J
Component: A4 Klimaautomat 1016
Coding: 00000
Shop #: WSC 63351
VCID: 285E7D5DC858A9C67B-5140
00710 - Defroster Flap Positioning Motor (V107)
41-10 - Blocked or No Voltage - Intermittent
01841 - Potentiometer/Actuator for Temperature Flap; Left (G220)
00716 - Air recirculation Flap Positioning Motor (V113)
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 E
Component: int. Lastmodul NDL 0305
Coding: 00002
Shop #: WSC 63351
VCID: 3466992D0490DD26C7-4AFE
01494 - Bulb for Parking Lamps; Left (M1)
57-00 - Electric Circuit Failure
01800 - Light Switch (E1)
27-00 - Implausible Signal
Address 15: Airbags Labels: 8E0-959-655-84.lbl
Part No: 8E0 959 655 B
Component: Airbag 8.4EP 2000
Coding: 0011602
Shop #: WSC 63351 000 00000
VCID: 3662A32542ECCF36F9-5140
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 L
Component: Lenksáulenmodul 0308
Coding: 00022
Shop #: WSC 00425
VCID: 3C76B10D2CC015660F-4AE4
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 900 L
Component: KOMBI+WEGFAHRS. RB4 D35
Coding: 01100
Shop #: WSC 00186
VCID: 2D508C49E7BA8CEE88-5122
WAUZZZ8E33A183181 AUZ6Z0B0261919
29-00 - Short to Ground
Address 46: Central Conv. Labels:. 8E0-959-433-MIN.clb
Part No: 8E0 959 433 AR
Component: Komfortgerát T85 1310
Coding: 06976
Shop #: WSC 63351
VCID: 010800F90BA2B88E1C-4AFE
Subsystem 1 - Part No: 8E1959801B
Component: Tõrsteuer.FS BRM 0002
Subsystem 2 - Part No: 8E1959802B
Component: Tõrsteuer.BF BRM 0002
01562 - Rear right door
59-00 - Can't Unlock
61-00 - Won't De-Safe
End-------------------------(Elapsed Time: 05:46)--------------------------
