Caddy TPMS coding on a 1K0 907 379 BK ABS unit
Evoman
C?ID=412047
Hello all, my first post here!
Firstly, thank you Ross-Tech for producing such a valuable tool to us mere mortals!
Having changed most of the easy stuff with great success(Auto lock/unlock etc etc), I am having issues enabling the indirect TPMS via VCDS.
I have tried all I can find on the web plus some spurious coding I tried myself, and I get no dash light unless I add Gateway code 65 which I suspect is for direct.
I currently do not have the reset switch installed although I do have one ready to fit.
In ABS Basic settings I am missing the ability to reset the learned values from the unit.
I suspect The version of my ABS (BK) may not support it or obviously I have the incorrect coding.
I do hope someone with my version has this activated and maybe able to assist me.
Attached is my Auto-scan
Many thanks!
 Monday,31,August,2020,18:00:17:24089
VCDS Version: 20.4.2.0 (x64)  HEX-V2 CB: 0.4526.4
VIN: WV1ZZZ2KZDX061615   License Plate:
Mileage: 154540km-96026mi   Repair Order:
Chassis Type: 2K-VN35 (7N0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 4C 52 56
VIN: WV1ZZZ2KZDX061615   Mileage: 154540km-96026miles
Address 01: Engine (J623-CAYD)       Labels:. 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 TF    HW: 03L 907 425 C
   Component: R4 1.6l TDI   H43 9979
   Revision: --H43---    Serial number: 00000000000000
   Coding: 00114014030500080000
   Shop #: WSC 35110 790 50316
   ASAM Dataset: EV_ECM16TDI02103L906023TF 003003
   ROD: EV_ECM16TDI02103L997557M.rod
   VCID: 7DA7FDE1FD748F73395-8028
   Part No SW: 1K0 907 379 BK    HW: 1K0 907 379 BK
   Revision: 00H31001
   Coding: 433C400D092803FBC21102E5901EC081300400
   Shop #: WSC 35110 377 08192
   VCID: 7CA1F0E5E6EE867B0EB-8028
   Part No SW: 7N0 907 426 BG    HW: 7N0 907 426 BG
   Component: AC Manuell    H20 0505
   Revision: 00001018
   Coding: 0010004002
   VCID: 7AADF6FDEC5AB84B1C7-802E
   Part No SW: 5K0 937 085 R    HW: 5K0 937 085 R
   Component: BCM PQ35 B+   021 0068
   Revision: BB021001
   Coding: 471A583A8833186A088000839000006403017288524F8160648000000040
   VCID: 42DD4E1DC48A308B047-8016
   Subsystem 1 - Part No: 1T2 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer 28091  26  0512
   Coding: 009795
   Component: VW10Airbag02A H07 0013
   Revision: --------    Serial number: 003HL00E9A1W
   Coding: 000000000000000000000000000000003241
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 353725C185C49733B15-8060
   Part No SW: 5K0 953 507 AR    HW: 5K0 953 549 C
   Revision: --------    Serial number:  90422LJH0009O
   Coding: 1080060000
   ROD: EV_SMLSNGKUDS_A05.rod
   VCID: 005984158A86E29B523-8054
   Part No SW: 2K0 920 965 G    HW: 2K0 920 965 G
   Component: KOMBI         H05 0705
   Coding: 480001
   VCID: 33331BD98BB089039F1-8066
   Part No SW: 7N0 907 530 AF    HW: 7N0 907 530 AF
   Component: J533  Gateway H52 1634
   Revision:   H52       Serial number: 021012F2000661
   Coding: 357401
   VCID: 74B1D8C5CEBECE3B46B-8020
   Component: IMMO          H05 0705
   VCID: 6A8DC6BD9CFA08CBEC7-803E
   Part No SW: 1T0 959 701 T    HW: 1T0 959 701 T
   Component: Tuer-SG         009 2110
   Coding: 0000560
   VCID: 48C95C35EEB61ADBDA3-801C
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 140    3305
   Revision: 00H22000
   VCID: 372B2FC993486523A39-8062
   Part No SW: 1T0 959 702 R    HW: 1T0 959 702 R
   Coding: 0000816
   VCID: 47CB5F09E3A815A3D39-8012
Address 56: Radio
End----(Elapsed Time: 00:42, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
Evoman
C?ID=412047
Anyone have an idea?
Thinking about maybe splitting the Control module from the unit and using a BM suffix module. Some have had a good result with this unit it seems.
Any other units that support the TPMS indirect ability?
