2008 Audi S8 Air Suspension Issues
glabate
C?ID=416440
I have a 2007 Audi S8 with 64K miles . The yellow and green air suspension lights come on and blink. Research on the internet indicates it's either the relay, air compressor and/or leaks in the shocks/solenoid/lines. I did the auto scan and results are below. Here is what I am thinking I should do:
1. Clear the DTCs and see if the compressor comes to life
2. If not, replace the relay behind the driver's dash and check fuse. See if the compressor starts.
3. if yes, look for leaks on all struts and solenoid. Also check air lines.
4. Possibly rebuild compressor
5. Replace any struts, lines, or solenoid if leaks found
Just wondering if the above will work especially if I clear the DTCs. Thanks for any help in advance.
Gregg
Monday,31,August,2020,16:50:23:26778
VIN: WAUPN44E77N007082   License Plate:
Chassis Type: 4E (4L0)
Scan: 01 02 03 05 06 07 08 09 0E 0F 11 31 15 16 17 19 28 34 36 37
          38 42 46 47 4F 52 53 55 56 61 62 65 67 6C 72 76 77
VIN: WAUPN44E77N007082   Mileage: 104210km-64753miles
38-Roof Electronics -- Status: OK 0000
   Part No SW: 4E0 910 552 A    HW: 4E0 907 552
   Component: 5.2L V10/4V FSI    ª0040
   Revision: 5AH11---    Serial number: AUX3Z0F7704139
   Coding: 01060009190F0160
   Shop #: WSC 08353 444 54433
   VCID: 2019E406B6C56AAB723-8074
005703 - Check Coding of ECUs on Powertrain Data Bus
               P1647 - 001 -  - Intermittent
                    Fault Status: 00100001
                    Mileage: 104127 km
                    Date: 2020.08.18
                    Time: 07:34:29
                    Temperature: 24.0°C
                    Temperature: 27.0°C
                    Absolute Pres.: 790.0 mbar
                    Voltage: 11.430 V
Address 02: Auto Trans        Labels: 09E-927-156.lbl
   Part No SW: 4E1 910 156 K    HW: 09E 927 156 B
   Component: AG6 09E 5,2 FSI USA 0020
   Revision: --H01---    Serial number:        0090739
   Coding: 0000002
   Shop #: WSC 02313 785 00200
   VCID: 2B03032ACF03B9F3D71-807E
Address 03: ABS Brakes        Labels: 4E0-910-517.lbl
   Part No SW: 4E0 910 517 D    HW: 4E0 614 517 AB
   Component: ESP 5.7 allrad  H46 0500
   Coding: 0001627
   Shop #: WSC 02313 000 00000
   VCID: 2411E816A2DD768B16B-8070
Address 05: Acc/Start Auth.        Labels: 4E0-910-131.lbl
   Part No SW: 4E0 910 131     HW: 4E0 909 131 L
   Component:     FBS AUDID3  H10 0190
   Revision: 01904910    Serial number: AUX3Z0F7704139
   Coding: 0410624
   Shop #: WSC 02311 785 00200
   VCID: 58E98CE6AE15E26B4A3-800C
   Subsystem 1 - Part No: 4E0 905 852 E
   Component: ELV                 1940
00956 - Key 2
                    Reset counter: 77
                    Mileage: 103440 km
                    Date: 2020.06.27
                    Time: 09:53:26
00955 - Key 1
                    Fault Frequency: 0
                    Reset counter: 48
                    Mileage: 103520 km
                    Date: 2020.07.06
                    Time: 16:00:44
Address 06: Seat Mem. Pass        Labels: None
   Part No SW: 4E0 910 760 D    HW: 4E0 959 760 B
   Component: Sitzmemory BFS H02  0010
   Revision: 00000000    Serial number: 5DS 008 795-03
   Coding: 4071520
Address 07: Control Head        Labels: 4E0-910-7xx-07.clb
   Part No SW: 4E0 910 732 T    HW: 4E0 035 729 A
   Component: Interfacebox    H43 4610
   Revision: 00000000    Serial number: 348HT067505074
   Coding: 0000003
   VCID: 33331B4A1733E1339F1-8066
   Subsystem 1 - Part No: 4E0 910 611
   Component: E0380 BedienteilH03 0040
   Subsystem 2 - Serial number: 00000000018821
   Subsystem 3 - Serial number: 0109.08.060000000100010220ÿ
   Subsystem 4 - Serial number: 010220ÿ
   Part No SW: 4E0 910 043 B    HW: 4E0 820 043 G
   Component: KLIMAAUTOMAT    017 0450
   Revision: 00000032    Serial number: 00000000104043
   Coding: 0106833
   VCID: 1C61D0F69AAD4E4BAEB-8048
00066 - Rear Right Footwell Heater (Z43)
                    Fault Status: 01101100
                    Reset counter: 37
                    Mileage: 102216 km
                    Date: 2019.08.14
                    Time: 19:01:19
                    Voltage: 13.00 V
00657 - Positioning Motor for Central Vents (V102)
                    Fault Status: 00100011
                    Reset counter: 61
                    Mileage: 104024 km
                    Date: 2020.07.30
                    Time: 08:55:44
                    Voltage: 13.70 V
                    Temperature: 24.0°C
                    (no units): 193.0
                    (no units): 192.0
                    Temperature: 22.0°C
Address 09: Cent. Elect.        Labels: 4E0-910-279.clb
   Part No SW: 4E0 910 279 Q    HW: 4E0 907 279 Q
   Component: ILM Fahrer      H15 0230
   Coding: 0133123
   VCID: 3635225E0441F41BB8F-8062
   Subsystem 1 - Part No: 4E1 910 113 C
   Component: Wischer WWS D3  H60 0420
   Coding: 00000035
   Shop #: WSC 02313
   Subsystem 2 - Part No: 4E0 910 557 A  Labels: 8K0-955-559.CLB
   Component: REGENLICHTSENSORH13 0090
   Coding: 00139548
   Shop #: WSC 02313
Address 0E: Media Player 1
Address 0F: Digital Radio
Address 11: Engine II
Address 15: Airbags        Labels: 4E0-910-655-94.lbl
   Part No SW: 4E0 910 655 C    HW: 4E0 959 655 J
   Component:    Airbag 9.41  H12 4030
   Revision: 91H12400    Serial number: 0037Q0007LU8
   Coding: 0532707
   VCID: 2615F21ED4E1849B08F-8072
   Subsystem 1 - Part No: 4E0 910 339
   Component: BF-Gewichtsens. H01 0030
   Subsystem 2 - Serial number: 36LN6
   Subsystem 3 - Serial number: 0001.01.0000H0100000000000ÿ†63
   Subsystem 4 - Serial number: 000000ÿ†63328RB401752D36Fÿ†63
   Subsystem 5 - Serial number: 52D36Fÿ†63428RB401752E43Fÿ†63
   Subsystem 6 - Serial number: 52E43Fÿ†63528RB401752DB9Sÿ†63
   Subsystem 7 - Serial number: 52DB9Sÿ†63628RB4017533112ÿ†63
   Subsystem 8 - Serial number: 533112ÿ†63729RB4017CD83B ÿ†63
   Subsystem 9 - Serial number: CD83B ÿ†63829RB4017CD3B6.ÿ
   Subsystem 10 - Serial number: CD3B6.ÿ
Address 16: Steering wheel        Labels: 4E0-910-549.lbl
   Part No SW: 4E0 910 549     HW: 4E0 953 549
   Component: Lenksäulenmodul H14 0040
   Coding: 0012141
   VCID: 6597B512E9674F83C15-8030
   Component: Lenkradmodul    H07 0090
Address 17: Instruments        Labels: 4E0-910-xxx-17.lbl
   Part No SW: 4E0 910 951 F    HW: 4E0 920 951 F
   Component: KOMBIINSTR. VDO H82 0520
   Revision: D03         Serial number: AUDID3F7000150
   Coding: 0032203
   Shop #: WSC 00001 001 00001
   VCID: 2809FC26DEF592EB3A3-807C
Address 19: CAN Gateway        Labels:. 4L0-910-468.clb
   Part No SW: 4L0 910 468     HW: 4L0 907 468
   Component: J533__Gateway   H06 0040
   Revision: 00H06000    Serial number: 0900B0680781A8
   Coding: F5F5DFFF307A0E
   VCID: 6C81C0360A8D7ECB9EB-8038
   Part No SW: 4E0 910 158     HW: 4E0 919 158 D
   Component: KLIMA-STG. FOND 017 0230
   Revision: 00000019    Serial number: 00000000045071
   Coding: 0000000
   VCID: 619FA102FD4F23A33DD-8034
Address 34: Level Control        Labels: 4E0-910-553.clb
   Part No SW: 4E0 910 553 J    HW: 4E0 907 553 F
   Component: LUFTFDR.-CDC    H06 6310
   Coding: 0015510
   VCID: 2A0D062EC0F9A0FB2C7-807E
01577 - Turn-Off due to Over-Temp
                    Fault Frequency: 9
                    Reset counter: 72
                    Mileage: 103176 km
                    Date: 2020.06.11
                    Time: 16:12:08
01772 - Signal from Level Control Pressure Sensor (G291)
                    Fault Frequency: 64
                    Reset counter: 76
                    Mileage: 102817 km
                    Date: 2019.12.27
                    Time: 13:39:22
01583 - Leak in System Detected
                    Fault Status: 11100000
                    Fault Frequency: 8
                    Reset counter: 37
                    Mileage: 104077 km
                    Date: 2020.07.30
                    Time: 21:18:19
01400 - Suspension Level Control
                    Reset counter: 77
                    Mileage: 104195 km
                    Date: 2020.08.22
                    Time: 16:43:20
   Component: Sitzmemory FS  H02  0010
   Coding: 4071530
   Part No SW: 4E0 910 888 M    HW: 4E0 919 887 D
   Component: MNS US          H48 1100
   Revision: 00000000    Serial number: 381GK067504232
   VCID: 38292C660E55026BAA3-806C
Address 38: Roof Electronics        Labels: 4E0-910-135.lbl
   Part No SW: 4E0 910 135 A    HW: 4E0 907 135
   Component: Dachknoten D3   H05 0090
   Serial number: 00000620200037
   Coding: 0003477
   VCID: 1D67DDF281B74743595-8048
Address 42: Door Elect, Driver        Labels: 4E1-910-802-42.lbl
   Part No SW: 4E1 910 802 B    HW: 4E1 959 801 B
   Component: Türsteuer.FS BRM003 0100
   Coding: 0032364
Address 46: Central Conv.        Labels:. 4E0-910-289.lbl
   Part No SW: 4E0 910 289 D    HW: 4E0 907 289 D
   Component: Komfortgeraet   H07 0010
   Revision: 00100007    Serial number:  W040608140103
   Coding: 0048702
   Subsystem 1 - Part No: 4E0 910 853
   Component: Heckdeckel   P14H06 0070
   Subsystem 2 - Part No: 4E0 907 719
   Component: Neigungssensor  H05 0020
Address 47: Sound System        Labels: None
   Part No SW: 4E0 910 466 D    HW: 4E0 035 466
   Component: BO_D3           H06 0320
   Revision: 20S00002    Serial number: 00808060004575
   Coding: 0000026
   VCID: 270BFF1AD3EB9D93339-8072
   Subsystem 1 - Part No: 4E0 910 465 B
   Component: BO_D3_SLAVE     H31 0310
   Subsystem 2 - Serial number: 02808060002507
   Subsystem 3 - Serial number: 0228.08.060000000100030012ÿ
   Subsystem 4 - Serial number: 030012ÿ
                    Fault Status: 00101011
                    Reset counter: 37
                    Mileage: 104195 km
                    Date: 2020.08.22
                    Time: 16:40:11
                    Voltage: 11.90 V
                    Temperature: 30.0°C
                    Bin. Bits: 00000100
                    Voltage: 11.50 V
                    Temperature: 29.0°C
03017 - Motor for Left Front Treble Speaker (V344)
                    Reset counter: 74
                    Mileage: 103520 km
                    Date: 2020.07.04
                    Time: 11:04:45
                    Voltage: 12.40 V
                    Temperature: 55.0°C
                    Bin. Bits: 00000100
                    Voltage: 12.50 V
                    Temperature: 52.0°C
Address 4F: Centr. Electr. II        Labels: None
   Part No SW: 4E0 910 280 A    HW: 4E0 907 280 B
   Component: ILM Beifahrer   H11 0070
   Revision:             Serial number: 00000000001298
   Coding: 0010111
   VCID: 1E65DAFE8CB15C5B40F-804A
   Subsystem 1 - Part No: 4E0 910 511 A
   Component: UGDO HL US      H04 0050
   Subsystem 2 - Serial number: 0253440T16T705
Address 52: Door Elect, Pass.        Labels: 4E1-910-802-52.lbl
   Part No SW: 4E1 910 802 B    HW: 4E1 959 802 B
   Component: Türsteuer.BF BRM003 0100
   Coding: 0032364
Address 53: Parking Brake        Labels: 4E0-910-801.clb
   Part No SW: 4E0 910 801 C    HW: 4E0 907 801 A
   Component: EPB  A32C0220   H02 0220
   Revision: A32C0220
   Coding: 0000732
   Shop #: WSC 04664 002 1048576
   VCID: 1F1BE7FA8BBB55534B9-804A
   Part No SW: 4F0 910 357 F    HW: 4F0 907 357 F
   Coding: 0000018
   VCID: 290FF922C5FFABE325D-807C
   Subsystem 1 - Part No: 4F0 941 329 B
   Component: AFS-Modul links H02 0020
   Subsystem 2 - Part No: 4F0 941 329 B
   Component: AFS-Modul rechtsH02 0020
   Part No SW: 4E0 910 541 T    HW: 4E0 035 541 P
   Component: TUNER EU/US/RDW H42 0630
   Revision: 00000000    Serial number: 396H1067544758
   Coding: 0000002
   VCID: 313F1142ED2FD323EDD-8064
Address 61: Battery Regul.        Labels: 4E0-910-181.lbl
   Part No SW: 4E0 910 181 C    HW: 4E0 915 181 C
   Component: J0644 BEM       H12 0550
   Revision: 00000000    Serial number: 00000000016057
   Shop #: WSC 08353 444 54109
   Subsystem 1 - Part No: 4E0 915 105 A
   Component: von VA0  000915105D
   Coding: 344530393135313035412056413030303039313531303544
   Shop #: WSC 46514 003 1048576
02274 - Quiescent Current Stage 3
                    Fault Frequency: 15
                    Mileage: 102814 km
                    Date: 2019.12.24
                    Time: 19:48:36
02272 - Quiescent Current Stage 1
                    Fault Frequency: 25
                    Mileage: 102703 km
                    Date: 2019.11.18
                    Time: 09:15:29
02273 - Quiescent Current Stage 2
                    Fault Frequency: 18
                    Mileage: 102804 km
                    Date: 2019.12.02
                    Time: 22:15:37
02276 - Quiescent Current Stage 5
                    Fault Frequency: 17
                    Mileage: 102804 km
                    Date: 2019.12.02
                    Time: 22:51:29
02256 - Quiescent Current
                    Fault Frequency: 17
                    Reset counter: 72
                    Mileage: 103275 km
                    Date: 2020.06.18
                    Time: 00:19:39
Address 62: Door, Rear Left        Labels: 4E0-910-802.lbl
   Part No SW: 4E0 910 802 A    HW: 4E0 959 801 C
   Component: Türsteuer.HL BRM003 0100
   Coding: 0032364
Address 65: Tire Pressure        Labels: 4E0-910-273.lbl
   Part No SW: 4E0 910 273 A    HW: 4F0 907 273 A
   Component: Reifendruck 3   H05
   Revision: 00050340    Serial number: 00000900046778
   Coding: 0202428
   Shop #: WSC 08353 444 58704
01477 - System Switched Off
                    Fault Frequency: 253
                    Reset counter: 37
                    Mileage: 102216 km
                    Date: 2019.08.14
                    Time: 16:34:18
                    (no units): 0.0
                    Temperature: 28.0°C
                    Error Code: 0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                    Fault Status: 11100100
                    Reset counter: 166
                    Mileage: 102227 km
                    Date: 2019.08.14
                    Time: 21:41:21
                    (no units): 21.0
                    Temperature: 22.0°C
                    Error Code: 0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
   Part No SW: 4E0 910 754 Q    HW: 4E0 035 753 A
   Component: SDS 3501 US     H45 0630
   Revision: 00000000    Serial number: 00000607260139
   Shop #: WSC 12336 024 394758
   VCID: 34311856123DE60B86B-8060
Address 6C: Back-up Cam.        Labels: 4E0-910-441.clb
   Part No SW: 4E0 910 441     HW: 4L0 907 441 A
   Component: J772__Rearview      0050
   Revision: --H12---    Serial number: 525PA8-J6710D6
   Coding: 1121402
   VCID: 5CE190F6DA2D0E4B6EB-8008
Address 72: Door, Rear Right        Labels: 4E0-910-802.lbl
   Part No SW: 4E0 910 802 A    HW: 4E0 959 802 C
   Component: Türsteuer.HR BRM003 0100
   Coding: 0032364
Address 76: Park Assist        Labels: 4E0-910-283.lbl
   Part No SW: 4E0 910 283 C    HW: 4E0 919 283 C
   Component: Parkhilfe 8-Kan H12 0040
   Revision: 00H12000    Serial number: 08720621400879
   Coding: 0221208
   VCID: 2313EB0AA7D371B36F1-8076
   Part No SW: 4F0 910 336 H    HW: 4E0 862 335
   Component: Handyvorb2      H13 1130
   Revision: 00000000    Serial number: 00000007539681
   Coding: 0010900
End----------(Elapsed Time: 02:28, VBatt start/end: 13.8V/14.3V)-----------
The steps you've described sound reasonable given the DTCs in your suspension controller.
glabate
C?ID=416440
so I cleared the DTCs - no change. I then checked the fuse and it was fine. Replaced the relay and the compressor kicked in (yeah). No I'll get it up on a lift and check for leaks. Thanks!
NostraJackAss
Did you know you should also check sensor ranges are within spec too & as per RTFB or targets generated won't be reached and compressor goes to overheat and DTC to protect it too?
Jef
HQ
This being a +10 years old, I'd be shocked if the strut(s) didn't leak... and your DTCs could be due to holy struts. If the strut(s) are in fact leaking, trying to do the relearn might be a mix bag of failure. Some times strut(s) leak so bad, you can't get the relearn to work. But if just a minor leak, you can limp your way through the relearn... but park the car and 31.8 hours later it doesn't sit level anymore, and maybe the pump has to run longer than it was designed for thus the overheat shut down.
I would suggest to unplug the level sensors and make sure there isn't rot in there. Those things are kind of know for sucking up water and rotting apart inside.
glabate
C?ID=416440
Thanks, Jeff. I just set the Air Suspension to "Lift" and drove it around a bit. I parked in the garage and measured the fender to ground distance at each wheel (I know it should be center of each wheel but fender to ground was easier to mesure). The readings were:
LF: 760
LR: 750
RF: 762
RR: 755
I'll let the car sit 1.5 days and measure again. Thanks for the tips!
Gregg
mattylondon
United Kingdom
C?ID=219022
I agree with Jef that's it's more than likely a leaking strut. I would also set the suspension in jack mode while it's parked. This will prevent the compressor from trying to level the car.
glabate
C?ID=416440
Thanks Matty. I wasn't sure if I should put it in jack mode or not. I didn't realize the compressor would kick in if parked. Good to know.
mattylondon
United Kingdom
C?ID=219022
The idea of leaving it in Jack Mode will prevent it from self levelling. If there is a leak the car would have a noticeable drop to the front left, front right or rear, and an indication of where to start looking for a leak. If all is good then maybe check the compressor of it can build pressure.
glabate
C?ID=416440
Thanks for the help!
glabate
C?ID=416440
so I created a story pole from a scrap piece of wood to measure each wheel fender from the ground to the fender. After ~20 hours with the car parked in garage and in "jack mode" the rear wheels are the same but the fronts have dropped ~2mm each. Guess I know which struts to look at first :(
glabate
C?ID=416440
so I saw I could get a pair of front struts for ~$600 from Rebuild Master Tech (RMT). Any experience with these folks (good or bad)?
glabate
C?ID=416440
UPDATE and Help!:
So I left the car in jack mode for a week without driving it. Checked the evel at each fender and the car did not lower at any corner. Drove it around for a few days and redid the scan (below). Not sure what to make of what it's saying. No leaks detected nor compressor overheating. Just the "01772 - Signal from Level Control Pressure Sensor (G291)" fault. What should I do next ?!?
Thursday,17,September,2020,13:23:13:26778
VIN: WAUPN44E77N007082 Mileage: 104270km-64790miles
Readiness: 0010 0001
Coding: 0000002
Coding: 0001627
Coding: 0410624
Component: ELV 1940
Coding: 4071520
Coding: 0000003
Coding: 0106833
Fault Status: 00101100
Reset counter: 81
Mileage: 104244 km
Date: 2020.09.05
Time: 13:47:59
Voltage: 14.10 V
00065 - Rear Left Footwell Heater (Z42)
Reset counter: 80
Mileage: 104244 km
Date: 2020.09.15
Time: 09:00:28
Voltage: 13.70 V
Part No SW: 4E0 910 279 Q HW: 4E1 955 113 C
Coding: 0133123
Coding: 00000035
Shop #: WSC 02313
Coding: 00139548
Shop #: WSC 02313
Address 0E: Media Player 1 Labels:
VCID: 55F785D2BC07DF03515-FFFE
Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
Part No SW: 4E0 910 593 D HW: 4E0 035 593
Component: SDAR SIRIUS H04 0670
Revision: 00000000 Serial number: AUZ4Z7F5031983
Reset counter: 41
Mileage: 104244 km
Date: 2020.09.05
Time: 13:48:16
Address 11: Engine II Labels: Redir Fail!
Coding: 0532707
Coding: 0012141
Coding: 0032203
Coding: 0000000
Coding: 0015510
Reset counter: 85
Mileage: 104246 km
Date: 2020.09.15
Time: 09:03:27
Coding: 4071530
Part No: 4E0 910 135 A
No Faults Found
Coding: 0032364
Coding: 0048702
Coding: 0000026
03016 - Motor for Front Right Treble Speaker (V345)
Reset counter: 85
Mileage: 104269 km
Date: 2020.09.16
Time: 08:40:03
Voltage: 12.30 V
Temperature: 29.0°C
Bin. Bits: 00000100
Voltage: 12.00 V
Temperature: 29.0°C
Coding: 0010111
Coding: 0032364
Revision: A32C0220
Coding: 0000732
Coding: 0000018
Coding: 0000002
Coding: 0032364
Coding: 0202428
Fault Frequency: 8
Reset counter: 45
Mileage: 104244 km
Date: 2020.09.05
Time: 13:49:49
(no units): 0.0
Temperature: 31.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Coding: 1121402
Coding: 0032364
Coding: 0221208
Coding: 0010900
End----------(Elapsed Time: 02:42, VBatt start/end: 13.5V/14.5V)-----------
mattylondon
United Kingdom
C?ID=219022
There are a few next steps. Can you recall what happened when the fault code was registered on Tuesday morning? Has the valve block gave an actual value that is out of spec what the module is expecting, hence the Implausible Signal. Or the wiring loom is damaged. The first task I would do is log measuring blocks with vcds to see if any appear out of range. Then next checking the wiring loom from the valve block, this is G291, to the level control module would be the next task. I'm guessing the fault is a failing valve block or the wiring.
