Vw Polo and new used ecu problem
V3lmu
Oulu, Finland
C?ID=229426
Hey!
That would be one problem I need help with. The car is a Volkswagen Polo, the model year is 2005. The engine runs out and the fault is located in a local car repair shop in the engine control unit. The car repair shop bought a similar control unit from the car dismantling workshop, but this new used engine control unit cannot be adapted to the car according to Ross-Tech's instructions.
- DTCs have been read from the car many times.
- The secret key code of the car has been determined with the vag-tacho program.
- The RIGHT EFFICIENT battery charger has been attached to the car during programming. The voltage has always been over 13 volts
- The car has an old and a new engine control unit in place. Both engine control units give the same Immo code. So does this car have an immobilizer in the instrument cluster?
- The car is able to adjust the engine control unit, after which the keys are adjusted. This also works, but once the keys have been adjusted and the car is turned off, the car will forget the aforementioned adjustments. :mad:
Original ECU, Round 1
Tuesday,01,September,2020,18:57:01:00464
Dealer/Shop Name: J.P - V3lmu
VIN: WVWZZZ9NZ6D035649   License Plate: VW POLO
Mileage: 171120km-106329mi   Repair Order: vanha ecu - uusin
Chassis Type: 9N (9N - VW Polo (2002 > 2010))
Scan: 01 02 03 08 09 15 17 19 25 37 44 45 46 56 76
VIN: WVWZZZ9NZ6D035649   Mileage: 171120km-106329miles
Address 01: Engine        Labels: 036-906-034-APE.lbl
   Part No: 036 906 034 AK
   Component:  MARELLI 4MV        5955
   Coding: 00071
   Shop #: WSC 31000
   VCID: 5BE3977B6A359DD3671-4B5C
   WVWZZZ9NZ6D035649     VWZ7Z0E1808797
Readiness: 1010 0101
Address 03: ABS Brakes        Labels: 6R0-907-37x-ABS80.clb
   Part No SW: 6Q0 907 379 AF    HW: 6Q0 907 379 AF
   Component: ABS 8.0 front   H04 0002
   Shop #: WSC 31414 790 00001
   VCID: 015F8513AD1917035DD-50D0
No Faults Found
Address 08: Auto HVAC        Labels: 6Q0-820-045.lbl
   Part No: 6Q0 820 045
   Component: Klimaanlage        X0840
   VCID: 6A8DC2BFB56FF45BEC7-50D0
            79-00 - Please Check Fault Codes
Address 09: Cent. Elect.        Labels:. 6Qx-937-049-C.lbl
   Part No: 6Q1 937 049 D
   Component: 00AF BN-SG.         1S34
   Coding: 26046
   Shop #: WSC 31414
   VCID: 3C2134E78F7BBAEB4EB-50D0
   Part No: 1C0 909 605 K
   Component: 19 AIRBAG VW51 0P   0008
   Coding: 12601
   Shop #: WSC 31414
   VCID: 2C0104A77F1B2A6BDEB-50D0
Address 17: Instruments        Labels: 6Q0-920-xxx-17.lbl
   Part No: 6Q0 920 803 B
   Coding: 01141
   Shop #: WSC 00050
   VCID: 2F3B13AB4E0D5173FB9-50D0
   Part No: 6N0 909 901
   Component: 0B7L GATEWAY CAN    1S34
   Coding: 00014
   Shop #: WSC 31414
   VCID: 70B9D0D793B30E8BA23-50D0
   Part No: 6Q0 423 156 AE
   Component: LenkhilfeKYO        V957
   Coding: 10140
   Shop #: WSC 31414
   VCID: 72BDDADF9DBF3C9B547-50D0
Address 46: Central Conv.        Labels:. 6Q0-959-433.clb
   Part No: 6Q0 959 433 E
   Component: 3F Komfortgerát     0002
   Coding: 00019
   Shop #: WSC 31414
   VCID: 3D2739E39461B3E3795-4B3C
End----(Elapsed Time: 03:14, VBatt start/end: 16.5V/13.9V. VIgn 0.0V)------
Then I reset the DTCs and rescanned original ECU
Tuesday,01,September,2020,19:01:02:00464
Mileage: 171120km-106329mi   Repair Order: vanha ecu - uusin 2. kierros
   Coding: 00071
   Shop #: WSC 31000
Readiness: 1110 0101
   Coding: 0002172
   Coding: 26046
   Shop #: WSC 31414
   Coding: 12601
   Shop #: WSC 31414
   Coding: 01141
   Shop #: WSC 00050
   Coding: 00014
   Shop #: WSC 31414
   Coding: 10140
   Shop #: WSC 31414
   Coding: 00019
   Shop #: WSC 31414
End----(Elapsed Time: 03:09, VBatt start/end: 13.9V/13.8V. VIgn 0.0V)------
New used engine control unit
Tuesday,01,September,2020,19:20:05:00464
Mileage: 171120km-106329mi   Repair Order: uusi käytetty ecu 1. kierros
   Component:  MARELLI 4MV       4562
   Coding: 00071
   Shop #: WSC 00788
   WVWZZZ9NZ3Y113150     VWZ7Z0B5727871
17978 - Engine Start Blocked by Immobilizer
            P1570 - 35-00 -
   Coding: 0002172
   Coding: 26046
   Shop #: WSC 31414
   Coding: 12601
   Shop #: WSC 31414
   Coding: 01141
   Shop #: WSC 00050
01177 - Engine Control Unit
            65-10 - Unauthorized - Intermittent
   Coding: 00014
   Shop #: WSC 31414
   Coding: 10140
   Shop #: WSC 31414
   Coding: 00019
   Shop #: WSC 31414
End----(Elapsed Time: 03:11, VBatt start/end: 13.6V/13.8V. VIgn 0.0V)------
I then reset the DTCs and rescanned new used engine control unit
Tuesday,01,September,2020,19:23:59:00464
Mileage: 171120km-106329mi   Repair Order: uusi käytetty ecu 2. kierros
   Coding: 00071
   Shop #: WSC 00788
   VCID: 55F781430C014BA3515-FFFE
   Coding: 26046
   Shop #: WSC 31414
   Coding: 12601
   Shop #: WSC 31414
   Coding: 01141
   Shop #: WSC 00050
   Coding: 00014
   Shop #: WSC 31414
   Coding: 10140
   Shop #: WSC 31414
   Coding: 00019
   Shop #: WSC 31414
End----(Elapsed Time: 03:05, VBatt start/end: 14.0V/14.0V. VIgn 0.0V)------
The engine control unit with black tape is the original of the car.
https://ibb.co/Z6zBp1x
What to try next? :confused:
Since the two ECUs still have different VINs and Immo-IDs stored in them, the chances of them really having the same PIN code is about 1 in 10,000. ;)
V3lmu
Oulu, Finland
C?ID=229426
Okay, this is now a misunderstanding of this thing. ECU and immobilizer have their own codes. Is there any tool that can be used to examine ECU pin code? Or is there always a VAG (OEM) workshop trip ahead?
It depends on the ECU. I'm not aware of any tool that can read PINs from all ECUs (or even all instrument cluster or immobilizer modules).
MartinsX
Riga, Latvia
C?ID=268515
In situation only ECU is replaced, You need to get both PIN codes: original for this car and from donor ECU (can not be done with VCDS). Next step is to match/pair/adapt donor ECU to Your car like described here (use VCDS for this operation). No need and do not touch key-immo pairing or You will screw up everything...
