AC Problem 2010 Jetta
grant@gendan
Hi all,
I am posting this on behalf of a customer. They are fighting to get the AC working on their Jetta. Thanks in advance for any help you can offer:
About 4 weeks ago we charged the AC system and as of yesterday we checked and it was holding the gas (17.5 barg). When we turned on the AC nothing. Run the VCDS and checked the error coding it came up with a code 3. HP pressure sender reading low pressure? The error codes for the compressor cleared as we now have a brand new compressor and it is connected. Took the connector off the HP sender and simulated the 12v pulsed signal down the signal line to try and clear the lock out 3 code, the fans on the radiator bank kicked up and the expansion valve opened, but alas no compressor current.
Saturday,29,August,2020,14:41:09:57294
VCDS Version: 20.4.2.0 (x64)
VIN: WVWZZZ1KZ8M1411xx   License Plate:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 76
VIN: WVWZZZ1KZ8M1411xx   Mileage: 155460km-96598miles
Address 01: Engine        Labels: 03G-906-016-BKD.clb
   Part No SW: 03G 906 021 PP    HW: 03G 906 021 AN
   Component: R4 2,0L EDC G000SG  4661
   Revision: --H07---    Serial number: VWX7Z0H124C0IK
   Coding: 0000072
   Shop #: WSC 00194 210 88212
   VCID: 7CF784593F34A9664F-8028
   Revision: 00H11001
   Coding: 0006786
   Shop #: WSC 00066 000 00000
   VCID: 73E5AF65126AE61E1E-8026
   Part No SW: 1K0 820 047 HB    HW: 1K0 820 047 HB
   Component: Climatic PQ35   141 1010
   Revision: 00141028    Serial number: 00000000000000
   VCID: 6BD5B7054A5A3EDED6-803E
00229 - Refrigerant Pressure
            002 - Lower Limit Exceeded
   Part No SW: 3C0 937 049 AH    HW: 3C0 937 049 AH
   Revision: 00H54000    Serial number: 00000000869731
   Coding: E4010E2700041500470A00000F000000000859035C000100000000000000
   VCID: 6FEDA3157E42C2FEFA-803A
   Component: Wischer 210208 021  0501
   Coding: 00038805
   Shop #: WSC 00066
   Component: RLS     100108 046  0204
   Coding: 00208933
   Shop #: WSC 00066
   Component: 2K AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD1PND4T
   Coding: 0012875
   VCID: 3D71495D64AE606E38-8068
   Subsystem 1 - Serial number: 6332MSME2C406259B
   Subsystem 2 - Serial number: 6342MSME29556A47K
   Subsystem 3 - Serial number: 6351HSME13122B32Z
   Subsystem 4 - Serial number: 6361HSME127D64001
   Part No SW: 1K0 953 549 BF    HW: 1K0 953 549 BF
   Component: J0527           051 0100
   Coding: 0000041
   VCID: 77FD9B7506128A3E22-8022
   Part No SW: 1K0 920 964 B    HW: 1K0 920 964 B
   Component: KOMBIINSTRUMENT 3HL 1212
   Revision: V0002000    Serial number: VWX7Z0H124C0IK
   Coding: 0019403
   Shop #: WSC 15634 000 1048576
   VCID: 2C5774198FD4F9E69F-8078
   Revision:   H07 01    Serial number: 070108F2001366
   Coding: E9807F0E0002021003
   VCID: 306F6069A3FC9D06A3-8064
   Component: IMMO            3HL 1212
   Shop #: WSC 00194 210 71434
   Part No SW: 1K0 959 701 Q    HW: 1K0 959 793 M
   Component: J386  TUER-SG FT    1134
   Revision: 31008001    Serial number: 00000516188125
   Coding: 0000692
   VCID: 3C7744597FB469660F-8068
   Part No: 1K2 909 144 M
   Component: EPS_ZFLS Kl.070 H08 1901
   Shop #: WSC 02069 000 90108
   VCID: 366356714198B336F9-8062
   Coding: 81900A0001060C7F2D0484057008DFC690FCA0
   VCID: 0305FFA542CAD69E0E-8056
   Subsystem 2 - Component:       NGS No Answer
   Subsystem 3 - Component:      IRUE No Answer
                    Reset counter: 79
                    Mileage: 155465 km
                    Time: 13:25:55
00323 - Vehicle Inclination Sensor (G384)
                    Reset counter: 79
                    Mileage: 155465 km
                    Time: 13:25:55
                    Reset counter: 79
                    Mileage: 155465 km
                    Time: 13:25:55
   Part No SW: 1K0 959 702 Q    HW: 1K0 959 792 M
   Component: J387  TUER-SG BT    1134
   Revision: 31008001    Serial number: 00000157288127
   Coding: 0000948
Address 56: Radio
   Part No SW: 1K0 959 703 P    HW: 1K0 959 795 G
   Component: J388   TUER-SG HL   1120
   Revision: 11006001    Serial number: 00000002766315
   Coding: 0000144
   Part No SW: 1K0 959 704 P    HW: 1K0 959 794 G
   Component: J389   TUER-SG HR   1120
   Revision: 11006001    Serial number: 00000002774086
   Coding: 0000144
   VCID: 3E734E5169A87B7621-806A
Address 76: Park Assist        Labels: 1K0-919-283.lbl
   Part No: 1K0 919 283 A
   Component: 12 Einparkhilfe     0101
   VCID: 2D51791DB4CEF0EE88-8078
End-------------------------(Elapsed Time: 01:45)--------------------------
DrPeter
16.4905° S, 151.7375° W
Hello Grant,
Thanks for the post! The VIN makes this vehicle look like a 2008 'Campanella White' VW Jetta :) [If I had to guess the production date is "03/2008" ??]
Question, how and when did you determine the system's charge pressure? I ask, because 17.5 bar, at rest is way to high!
If the HVAC was in operation then the value could be plausible.
Depending on ambient temperature the static pressure should read as indicated below:
G65 Pressure vs. Temperature chart
(When key is on, engine is off, static system pressure)
15C - 59F - 4.0 bar
20C - 68F - 5.0 bar
25C - 77F - 6.0 bar
30C - 86F - 7.0 bar
35C - 95F - 8.0 bar
40C - 104F - 9.0 bar
Source: Ross-Tech forum post Tis’ the HVAC Season
The G65-High Pressure Sensor for this HVAC system uses a 12V power source on Pin3 and a ground on Pin1. If you were to check the potential between Pins 1 & 3, you should be able to light up a 20-watt light bulb with minimal voltage loss.
Any voltage drop will affect the voltage to the J255-HVAC Controller via Pin2 of the G65.
Have you tried a new G65-High Pressure Sensor? These part numbers have been superseded several times from a [1K0 959 126 A] to [1K0 959 126 D] to [1K0 959 126 E] and then finally to the [5K0 959 126]. !Check with the local parts department for the correct part number by VIN!
The link above for the Tis’ the HVAC Season is full of useful information and so are the Official Factory Repair manuals.
Hope this helps,
drpeter
grant@gendan
Hi DrPeter,
Thanks for your reply and help!
I should have mentioned the correct car details :facepalm: It is a 2008 VW Jetta.
I did query the pressure reading as I thought it was high. My customer has compared this pressure reading against another 2009 Jetta and a Polo (both with working AC) and the readings are all similar....
Good idea on trying a new G65 sensor.
Do you need to run a basic setting on the AC after regassing and changing the sensor to get the compressor to start working?
Best regards,
DrPeter
Hello again,
I should have mentioned the car details It is a 2008 VW Jetta.
No worries, we are part time detectives here and you gave us enough clues to solve the puzzle! :)
It maybe a good idea to properly evacuate the HVAC system and charge it by weight, not pressure so as to insure the proper operation of the system.
So if they replace the G65, they would not have to worry about any Basic Settings or Adaptations.
There only one Basic Settings for this HVAC controller and that is for the "Potentiometer & Flap Alignment", (used when any vent flaps/motors are replaced/re-worked).
Also, when replacing the G65-High Pressure Sensor, there should be no need to evacuate the refrigerant from the HVAC system. Most, if not all of these systems use a schrader valve on the fitting under the G65 and when the G65 is removed this valve should close off the path of refrigerant. I believe it is a 17mm open end wrench is all that is needed.**
** Still recommend to the customer to observe ALL the safety precautions when working with refrigerant systems!
Stay cool...
drpeter
grant@gendan
Thanks again for your help!
A reply from my customer below:
"Was getting around to changing the sensor. So seems the logical place to start
We have 12v on pins 1and 3 and when we simulate the signal on 2 everything else fires up fans kick in and the expansion valve opens.
We checked the recirc flap and that is stroking nicely as detected by the VCDS.
The pressure is from the Halfords pressure gauge on the recharge rig green zone is 25 to 40 psi or 1.7 barg to 2.72 barg I was reading the Kpa scale and got a 0 in the wrong place when converting (I hate SI units) so the LP side is charged with 525 grams of refrigerant which is what is stated on the bonnet sticker and the pressure on the LP side is 30 psi just over 2 barg in the green zone of the gauge.
So looks like a G65 sensor required."
