Audi A4 B6 3.0 Timing Belt HELP
Justinking
Bay Area, CA, USA
Recently did the timing belt on my car.
The car now misfires rather bad, I used the camshaft tools. Could I have messed up the timing?
To check timing all you do is put the crank at TDC (matching the arrows) then the camshaft tool should sit perfect right?
Also could it be a air leak? I also took the throttle body off and manifold to clean it.
Some weird things I hear are the PCV whining a good amount. I took brake cleaner and sprayed it around the PCV valve then it made the car run somewhat better. Any ideas or opinions help.
Only codes are misfire 1.2.3.4,5,6
Also short term fuel is at 24% for both banks.
Jef
HQ
It would seem you are pointed in the right direction in regards to the PCV.
