2013 VW UP! No crank
Wout
C?ID=415581
It started a few months ago. Sometimes no crank after running a few minutes. Cold start always ok. Battery almost new. And when it cranks it runs like a charm. Both starter relays J906 and J907 dont move but have +12V. Checked all fuses and ground connections. Pretty desperate after a week. Thanks in advance!
Sunday,30,August,2020,11:30:01:15372
VIN: WVWZZZAAZED000505   License Plate:
Mileage: 131640km-81797mi   Repair Order: 30-08
Chassis Type: AA-VW12 (6N0)
Scan: 01 03 09 15 17 19 25 44 56 61
VIN: WVWZZZAAZED000505   Mileage: 131640km-81797miles
Address 01: Engine (------CHYB)       Labels:. 04C-906-020-CHY.clb
   Part No SW: 04C 906 020 AQ    HW: 04C 907 309 P
   Component: 1.0l R3 MPI   H23 5976
   Revision: UNH23---
   Coding: 00110012020401000000
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_ECM10MPI01104C906020AQ 001005
   ROD: EV_ECM10MPI01104C906020AP_VW12.rod
   VCID: 6A8C3D8F7CFC299BEC7-803E
Readiness: 1110 0001
Address 03: ABS Brakes (J104)       Labels: 1S0-614-517.clb
   Part No SW: 1S0 614 517 E    HW: 1S0 614 517 E
   Component: EBC 460 ESP   H08 0012
   Serial number: A00AVYG
   Coding: 12BF24718BAD02F148FF24F5D1AE4050590100
   ASAM Dataset: EV_Brake1ESPMP1TRWVW120 016035
   ROD: EV_Brake1ESPMP1TRWVW120.rod
   VCID: 313EEAE391AA9A43EDD-8064
Address 09: Cent. Elect. (J519)       Labels:. 1S0-937-09x-V1.clb
   Part No SW: 1S0 937 090 B    HW: 1S0 937 090 B
   Component: PQ25 BCM      H59 0563
   Revision: -8------    Serial number: --------------
   Coding: 64B8290000010000000009F46C28ACD07740426F7E820440200000420000
   Shop #: WSC 29120 004 1048576
   VCID: 323CE5EF942CA15B947-8066
   Part No SW: 1S0 959 655 B    HW: 1S0 959 655 B
   Component: VW10Airbag00J H02 0006
   Revision: --------    Serial number: 003MY002HC8C
   Coding: 00000000000000000000000000000000304A
   ASAM Dataset: EV_AirbaVW10BPAVW12X 001001
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 3D26C6D35DF26E23795-8068
   Serial number: 3575HRB405R20N96D0JB
   Serial number: 3585HRB400G50G0888JV
   Serial number: 3555NRB40164UP62B141
Address 17: Instruments (J285)       Labels:| 1Sx-920-xxx-17.clb-SRI1
   Part No SW: 1S0 920 860 M    HW: 1S0 920 860 M
   Component: KOMBI         H31 0205
   Revision: X0031012    Serial number: 00000000000000
   Coding: 114200
   ASAM Dataset: EV_KombiUDSMM9RM10 A04752
   ROD: EV_KombiUDSMM9RM10_A04_VW12.rod
   VCID: 3A2CCDCF4CDC591B5C7-806E
   Part No SW: 6N0 909 901     HW: 1S0 937 090 B
   Component: GW-K-CAN TP20 H59 0563
   Revision: -8------
   Coding: 001000
   VCID: 70B82FE75AA0D34BA23-8024
   Part No SW: 5K0 953 234     HW: 1S0 920 860 M
   Component: IMMO          H31 0205
   ASAM Dataset: EV_ImmoUDSMM9RM10 A01702
Address 44: Steering Assist (J792)       Labels:| 1Sx-909-144-44.clb
   Part No SW: 1S1 909 144 L    HW: 1S1 909 144 G
   Component: EPS_ECU       H35 1503
   Coding: 0001000101000000
   ASAM Dataset: EV_SteerAssisNSK 009004
   ROD: EV_SteerAssisNSK_009_VW12.rod
   VCID: 3C20CBD746E8672B4EB-8068
   Part No SW: 1S0 035 156     HW: 1S0 035 156
   Component: Radio         567 5541
   Revision: AA001001    Serial number: VWZ8Z1N4099465
   Coding: 0000020801
   VCID: 6888478762701B8BFA3-803C
00856 - Radio Antenna
                    Reset counter: 135
                    Mileage: 131644 km
                    Date: 2015.01.21
                    Time: 00:16:21
   Part No SW: 1S0 907 534     HW: 1S0 937 090 B
   Component: Batt-regelung H59 0563
   Coding: 032B7864
   Subsystem 1 - Part No SW: 1S0 915 181 B    HW: 1S0 915 181 B
   Component: J367-BDM  H08 0210
End----------(Elapsed Time: 00:35, VBatt start/end: 12.6V/12.6V)-----------
Hi and welcome. Got you Verified.
Given the lack of fault codes, the car itself doesn't know why it's not cranking. That means you'll have to trouble-shoot it the old-fashioned way, with wiring diagrams and a multimeter.
Wout
C?ID=415581
Thanks for verifying me Uwe. I have been measuring for a week already and found nothing wrong between J623 ECU relays and G467 (the clutchposition sensor). Strange thing is i cant measure the G467 somewhere in the VCDS blocks. Any help would be very appreciated.. Thanks.
