P0011 fault code, 1.8T mk4 AUM need Assistance Please!
Mk4kid
Pirate
South Africa
LP/IP
Hi guys
I have a mk4 1.8T aum (automatic)
Car milleage:174000
I am getting a fault code p0011 timing over advanced.
O2 sensor for bank 1 was replaced in the week.
I am experiencing power loss, high fuel usage and when the vehicle is cold on first startup it cranks up and starts on 2nd swings, it happens occasionally.
Took my car to a mechanical place and they advised I should replace the following :
Timing chain, timing chain tensioner, timing belt, oil pump
Please assist.
Is there any checks I can do with the vcds to be sure the timing chain and tensioner needs replacing.?
Mk4kid
Pirate
South Africa
LP/IP
VCDS Version: 18.9.0.2 (x64)
[b]Remainder removed.   Data from a clone/pirate copy of VCDS is not acceptable here.[/b]
South Molton, UK
i will update to latest then post it
Updating the VCDS software won't help you, the cable you have is an illegal clone (so the new version of VCDS probably won't work with it) - so you need to purchase a genuine Ross-Tech cable to get help here.
