2010 Golf - New gateway and need codes
18ME
C?ID=401654
Hi,
Total and absolute newbie here but trying to understand how it all works and need some help please.
I bought a 2010 mk6 Golf which needed a few bits and bobs doing and tidying but was generally pretty good but one day wouldn’t start. Anyway, long story short this was to do with the gateway corroded so wasn’t communicating with anything. I took it to a guy who spent quite a long time trying to sort the issues out, he changed the gateway module and the parking sensor module which had also corroded. I’ve now got the car back which is running but he’s disconnected the parking sensors as it was constantly bleeping. I’ve also got no sound from the head unit as I replaced this (due to the original one not working at all) prior to the issues but believe this is because the car that it was previously in had dynaudio.
Basically, he couldn’t code anything due to the gateway knackered and not being able to get the original codes for anything. I bought the VCDS HEX NET a few months ago as thought I could code the new replacement head unit and it would come in handy as have many VAG cars and probably will do in the future. This is the first time I've used it so hopefully after watching a few vids I've done it correctly.
Friday,28,August,2020,21:52:36:34784
VCDS Version: 20.4.2.0 (x64)  HEX-NET CB: 0.4513.4
VIN: WVWZZZ1KZBW077109   License Plate: LS60MBU
Mileage: 209600km-130239mi   Repair Order:
Chassis Type: 1K-VW36 (7N0)
Scan: 01 03 08 09 15 16 17 19 25 2E 37 42 44 46 4F 52 53 56 61 62
          72 77
VIN: WVWZZZ1KZBW077109   Mileage: 209600km-130239miles
25-Immobilizer -- Status: Cannot be reached 1100
37-Navigation -- Status: Not registered 0011
53-Parking Brake -- Status: Cannot be reached 1100
   Part No SW: 03L 906 018     HW: 03L 907 309 R
   Component: R4 2.0l TDI   H22 9978
   Revision: 42H22---    Serial number: 00000000000000
   Coding: 00190012042500080000
   Shop #: WSC 55695 001 1048576
   ASAM Dataset: EV_ECM20TDI01103L906018 003014
   ROD: EV_ECM20TDI01103L906018_003_VW36.rod
   VCID: 679E93F19EEA34BEB2-8032
4638 - Engine Oil Temp. Sensor (G8)
          P0196 00 [040] - Implausible Signal
                    Mileage: 209599 km
                    Date: 2020.08.19
                    Time: 16:16:49
                    Engine speed: 780.50 /min
                    Normed load value: 41.2 %
                    Coolant temperature: 29 °C
                    Intake air temperature: 21 °C
                    Voltage terminal 30: 13.800 V
                    Fuel consumption: 1.03 l/h
                    Engine oil temperature: 100.0 °C
                    Oil warning threshold: 27.724 mm
                    Control Module temperature: 19.8 °C
                    Oil fill level: 0.000 mm
                    Outside air temperature: 21.0 °C
                    Fuel temperature: 21.5 °C
   Part No SW: 1K0 907 379 AT    HW: 1K0 907 379 AT
   Component: ESP MK60EC1   H30 0105
   Revision: 00H30001
   Coding: 163B400D09290001680C02E490220082310000
   VCID: 0444A47D879CFFA637-8050
   Part No SW: 3C8 907 336 AB    HW: 3C8 907 336 AB
   Revision: 00009001
   Coding: 0000000002
   ROD: EV_ClimaBasis_VW36.rod
   VCID: 6D92E1D9BC161EEEC8-8038
          U1111 00 [008] - -
          [Motorsteuergerät - kein Signal/Kommunikation]
                    Reset counter: 91
13701392 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Bremsensteuergerät - kein Signal/Kommunikation]
                    Reset counter: 91
13701408 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Diagnoseinterface für Datenbus - kein Signal/Kommunikation]
                    Fault Frequency: 117
                    Reset counter: 196
13701456 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Steuergerät im Schalttafeleinsatz - kein Signal/Kommunikation]
                    Fault Frequency: 116
                    Reset counter: 196
9481748 - High Pressure Sensor
          B10AE 14 [008] - Open or Short to Ground
                    Reset counter: 197
                    Mileage: 209599 km
                    Date: 2020.08.19
                    Time: 16:15:37
   Part No SW: 1K0 937 084 D    HW: 1K0 937 084 D
   Component: BCM PQ35  B   103 0615
   Revision: 00103 AD
   Coding: 48180A3A8825F1C040080080340000E443510088536D8160648000200040
   VCID: 2F2E3BD17E9AACFEBA-807A
   Subsystem 1 - Part No: 1K2 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer 12081  26  0512
   Coding: 009795
   Component: RLS 230810 05  54  0403
   Coding: 0330AD
   Component: LIN BACKUP HO  H11 9004
                    Reset counter: 157
                    Mileage: 209583 km
                    Date: 2020.07.01
                    Time: 03:51:45
                    Voltage: 11.65 V
                        Term 50 Off
00153 - Windshield Wiper Motor;  Driver Side (V216)
                    Reset counter: 196
                    Mileage: 209583 km
                    Date: 2020.07.01
                    Time: 03:51:45
                    Voltage: 11.65 V
                        Term 50 Off
                    Reset counter: 156
                    Mileage: 209583 km
                    Date: 2020.07.01
                    Time: 03:53:52
                        Term 15 Off
                    Voltage: 11.70 V
                        Term 50 Off
   Part No SW: 5K0 959 655 D    HW: 5K0 959 655 D
   Component: AirbagVW10    037 0606
   Serial number: 003FKRABV693
   Coding: 00003133
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 3B361F81B2E2405E06-806E
   Serial number: 3572MSME2C504555ZZZV
   Serial number: 3582MSME466F7556ZZZ5
   Serial number: 3512QSME180D6B6EZZZ7
   Serial number: 3522QSME08266A17ZZZW
   Part No SW: 5K0 953 507 BC    HW: 5K0 953 549 E
   Component: Lenks.Modul   007 0080
   Revision: --------    Serial number:  90440JHC000AU
   Coding: 108A140000
   ROD: EV_SMLSNGKUDS_A05.rod
   VCID: 72A8F2A5A528C11615-8026
   Serial number: 50000000000000202462
   Coding: E20000
332564 - Databus
                    Fault Frequency: 53
                    Reset counter: 0
                    Mileage: 208253 km
                    Date: 2021.11.18
                    Time: 11:51:24
332580 - Databus
                    Fault Frequency: 21
                    Reset counter: 51
                    Mileage: 208253 km
                    Date: 2021.11.18
                    Time: 11:51:24
332596 - Databus
                    Fault Frequency: 8
                    Reset counter: 51
                    Mileage: 208253 km
                    Date: 2021.11.18
                    Time: 11:51:24
   Part No SW: 5K0 920 971 A    HW: 5K0 920 971 A
   Component: KOMBI         H03 0406
   Coding: 470B00
   VCID: 2D1221D97C96DEEE88-8078
11 Faults Found:
9453842 - Oil Level Thermal Sensor
          B1041 35 [008] - Signal high time > maximum
                    Reset counter: 197
                    Mileage: 209599 km
                    Date: 2020.08.19
                    Time: 16:16:44
12604928 - Combination / Chassis CAN Bus (SAE Bus D)
          U0056 00 [008] - Performance
          [Datenbus Kombi/Fahrwerk: keine Kommunikation]
                    Fault Frequency: 17
                    Reset counter: 196
12648448 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Steuergerät für Motor: keine Kommunikation]
                    Reset counter: 91
12656896 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Steuergerät für Bremse: keine Kommunikation]
                    Reset counter: 91
12664832 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Steuergerät für BCM / Bordnetz / el. ZE: keine Kommunikation]
                    Fault Frequency: 64
                    Reset counter: 196
12669184 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Steuergerät für Airbag: keine Kommunikation]
                    Reset counter: 91
13638912 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Steuergerät für Lenkhilfe: keine Kommunikation]
                    Reset counter: 91
12718592 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Steuergerät für Lenksäulenelektronik: keine Kommunikation]
                    Fault Frequency: 19
                    Reset counter: 196
12658688 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Steuergerät für elektrische Parkbremse: keine Kommunikation]
                    Reset counter: 156
                    Mileage: 209583 km
                    Date: 2020.07.01
                    Time: 00:00:23
12666368 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Steuergerät für Diagnose Interface: keine Kommunikation]
                    Fault Frequency: 31
                    Reset counter: 196
13631488 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Steuergerät für Komfortsysteme: keine Kommunikation]
                    Fault Frequency: 16
                    Reset counter: 91
   Part No SW: 7N0 907 530 P    HW: 1K0 907 951
   Component: J533  Gateway H40 1623
   Revision:   H40       Serial number: 041211F6000926
   Coding: 462007
   Shop #: WSC 05314 000 00000
   VCID: 3D321199A4F64E6E38-8068
                    Reset counter: 197
                    Mileage: 209598 km
                    Date: 2020.08.10
                    Time: 09:39:57
                    Reset counter: 157
                    Mileage: 209583 km
                    Date: 2020.07.01
                    Time: 17:19:51
                    Fault Frequency: 191
                    Mileage: 209583 km
                    Date: 2020.07.01
                    Time: 17:19:51
                    Reset counter: 157
                    Mileage: 209583 km
                    Date: 2020.07.01
                    Time: 17:19:51
03406 - Control Module for Battery Monitoring
                    Reset counter: 157
                    Mileage: 209583 km
                    Date: 2020.07.01
                    Time: 17:20:50
   Component: IMMO          H03 0406
   VCID: 6A98EAC58DF809D6AD-803E
   Part No SW: 5N0 035 342 C    HW: 5N0 035 342 C
   Revision: A1001003    Serial number: 7668505564
   VCID: 271ED3F1566AF4BE72-8072
                    Fault Frequency: 8
                    Reset counter: 196
                    Reset counter: 91
   Part No SW: 1T0 035 680 C    HW: 1T0 035 680 C
   Component: RNS-MID       H41 2720
   Revision: AB001001    Serial number: VWZ6Z7K4187106
   Coding: 060700020100009000
   Shop #: WSC 00020 790 00000
   VCID: 2E1026D57990A5F6B1-807A
00857 - CD Changer Unit (R41)
                    Fault Frequency: 137
                    Reset counter: 157
                    Mileage: 209576 km
   Part No SW: 5K0 959 701 B    HW: 5K0 959 701 B
   Component: Tuer-SG         009 2120
   Coding: 0000692
   VCID: 312A3DA9A8AEBA0EAC-8064
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 70     3001
   Revision: 00H17000
                    Fault Frequency: 11
                    Reset counter: 196
                    Voltage: 13.75 V
                        DU
                    Temperature: 29.0°C
                    RPM: 781 /min
                    Voltage: 11.63 V
                        DU
                    Temperature: 23.0°C
                    RPM: 1498 /min
   Component: EZE_2         H40 1623
   Coding: 00000008
   VCID: 6FAEFBD1BE1AECFEFA-803A
02174 - Analog/Digital clock
                    Reset counter: 156
                    Mileage: 209583 km
                    Date: 2020.07.01
                    Time: 00:00:25
   Part No SW: 5K0 959 702 E    HW: 5K0 959 702 E
   Component: Tuer-SG         009 2152
   Coding: 0000948
   VCID: 352209B95CC6962EF0-8060
Address 53: Parking Brake
                    Reset counter: 157
                    Mileage: 209576 km
   Component: Batt.regelung H40 1623
   Coding: 030F185A
   VCID: 71AAFDA9A82EFA0EEC-8024
00458 - Control Module for Battery Monitoring (J367)
                    Reset counter: 156
                    Mileage: 209583 km
                    Date: 2020.07.01
                    Time: 00:02:19
02252 - Generator
                    Reset counter: 156
                    Mileage: 209583 km
                    Date: 2020.07.01
                    Time: 00:02:19
   Coding: 0000144
   Shop #: WSC 01357 011 1012552
   Coding: 0000144
   VCID: 36200EB541C09D36F9-8062
   Part No SW: 7P6 035 730 B    HW: 7P6 035 730 B
   Component: TELEFON       H05 0440
   Revision: 1B001001    Serial number: 00007668483647
   Coding: 0A01000000010101
   ASAM Dataset: UHVNA A01007
   ROD: UHVNA.rod
   VCID: 312A3DA960AEBA0EAC-8064
9455635 - Telephone Microphone
          B1048 13 [008] - Open Circuit
                    Reset counter: 65
                    Mileage: 208366 km
                    Date: 2021.11.28
                    Time: 11:38:51
12664832 - Body Control Module (Central Electric)
          U0140 00 [008] - No Communications
                    Reset counter: 91
13633792 - No Communication with Diagnostic Gateway
          U0146 00 [008] - -
          [Gateway: keine Kommunikation]
                    Reset counter: 91
                    Mileage: 209582 km
                    Date: 2022.01.30
                    Time: 16:53:17
End----(Elapsed Time: 01:38, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
18ME
C?ID=401654
Thank you for such a quick response.
I've not used the VCDS before other than doing this auto scan. Do I simply go to the radio section and enter that six digit number?
Any idea what I need to make the parking sensors correctly and would I need to reconnect the parking sensor wiring before doing anything?
No, in the Gateway:
[Select]
[19-CAN Gateway]
[Coding]
- Enter the suggested value in the New Coding field:
[Do It!]
You can also look at the details with [Long Coding Helper]
Let's get the gateway configured properly first. It's currently configured for a different platform entirely, which can cause plenty of confusion in other modules.
Post up a fresh Auto-Scan after you recode the Gateway and then clear all fault codes.
18ME
C?ID=401654
Thank you for the detailed guide. Ive entered the code into the new coding field and a pop up has come up. Do I click yes, no or cancel?
It says.
This appears to be an uninitiated control module; valid WSC/Importer/Equipment data may be required.
Click yes for VCDS to use default values of 12345/123/12345.
Click no for VCDS To try the values currently in the module.
Click cancel to go back and manually edit the values.
I suggest [No] to try the current values first.
If that doesn't work, try [Yes].
If that doesn't work, then try entering more random values such as:
WSC: 07147
Importer: (Not sure what's "correct" for the UK, try something like 321)
Equipment Number: 26926
18ME
C?ID=401654
I've now coded the gateway and cleared the fault codes although its still giving faults in the gateway.
Here is the auto scan.
Monday,31,August,2020,08:18:05:34784
          72 77
                    Mileage: 209599 km
                    Date: 2001.14.18
                    Time: 16:16:49
10095 - Engine Control Unit Incorrectly Coded
          P0610 00 [167] - -
                    Mileage: 209605 km
                    Date: 2001.14.30
                    Time: 08:10:33
                    Engine speed: 0.00 /min
                    Coolant temperature: 14 °C
                    Intake air temperature: 15 °C
                    Voltage terminal 30: 11.560 V
                    Zähler der Regenerationszeit des Partikelfilters: 0.00 s
                    Particle filter: kilometers since last regeneration: 158636 m
                    Particle filter: soot mass measured: 11.25 g
                    Particle filter: soot mass calculated: 19.66 g
                    Particle filter: differential pressure: dynamic offset: 0 hPa
   Revision: 00H30001
                    Reset counter: 157
                    Mileage: 209605 km
                    Date: 2001.14.30
                    Time: 08:10:32
                    Count: 2
                    Count: 20480
                    Count: 8192
                    Count: 41728
                    Count: 255
   Revision: 00009001
   Coding: 0000000002
          U1111 00 [008] - -
                    Reset counter: 91
          U1111 00 [008] - -
                    Reset counter: 91
          U1111 00 [008] - -
                    Reset counter: 196
          U1111 00 [008] - -
                    Reset counter: 196
                    Reset counter: 197
                    Mileage: 209599 km
                    Date: 2001.14.18
                    Time: 16:15:37
   Revision: 00103 AD
   Coding: 009795
   Coding: 0330AD
                    Reset counter: 157
                    Mileage: 209605 km
                    Date: 2001.14.30
                    Time: 08:05:50
                    Voltage: 11.40 V
                        Term 50 Off
                    Reset counter: 157
                    Mileage: 209583 km
                    Date: 2000.14.01
                    Time: 03:51:45
                    Voltage: 11.65 V
                        Term 50 Off
                    Reset counter: 196
                    Mileage: 209583 km
                    Date: 2000.14.01
                    Time: 03:51:45
                    Voltage: 11.65 V
                        Term 50 Off
                    Reset counter: 156
                    Mileage: 209583 km
                    Date: 2000.14.01
                    Time: 03:53:52
                        Term 15 Off
                    Voltage: 11.70 V
                        Term 50 Off
   Coding: 00003133
   Coding: 108A140000
   Coding: E20000
332564 - Databus
                    Fault Frequency: 53
                    Reset counter: 0
                    Mileage: 208253 km
                    Date: 2015.14.26
                    Time: 11:51:24
332580 - Databus
                    Fault Frequency: 21
                    Reset counter: 51
                    Mileage: 208253 km
                    Date: 2015.14.26
                    Time: 11:51:24
332596 - Databus
                    Fault Frequency: 8
                    Reset counter: 51
                    Mileage: 208253 km
                    Date: 2015.14.26
                    Time: 11:51:24
   Coding: 352002
                    Mileage: 209605 km
                    Date: 2001.14.30
                    Time: 08:12:08
                    Reset counter: 157
                    Mileage: 209605 km
                    Date: 2001.14.30
                    Time: 08:12:08
                    Reset counter: 157
                    Mileage: 209605 km
                    Date: 2001.14.30
                    Time: 08:13:08
                    Fault Frequency: 8
                    Reset counter: 196
                    Reset counter: 91
                    Fault Frequency: 141
                    Reset counter: 157
                    Mileage: 209576 km
   Coding: 0000692
   Revision: 00H17000
                    Fault Frequency: 11
                    Reset counter: 196
                    Voltage: 13.75 V
                        DU
                    Temperature: 29.0°C
                    RPM: 781 /min
                    Voltage: 11.63 V
                        DU
                    Temperature: 23.0°C
                    RPM: 1498 /min
   Coding: 00000008
                    Reset counter: 156
                    Mileage: 209583 km
                    Date: 2000.14.01
                    Time: 00:00:25
   Coding: 0000948
                    Reset counter: 157
                    Mileage: 209576 km
   Coding: 030F185A
                    Reset counter: 156
                    Mileage: 209583 km
                    Date: 2000.14.01
                    Time: 00:02:19
02252 - Generator
                    Reset counter: 156
                    Mileage: 209583 km
                    Date: 2000.14.01
                    Time: 00:02:19
   Coding: 0000144
   Coding: 0000144
   ROD: UHVNA.rod
                    Reset counter: 65
                    Mileage: 208366 km
                    Date: 2016.14.04
                    Time: 11:38:51
                    Reset counter: 91
          U0146 00 [008] - -
                    Reset counter: 91
                    Mileage: 209582 km
                    Date: 2018.14.03
                    Time: 16:53:17
End----(Elapsed Time: 01:51, VBatt start/end: 11.6V/11.6V. VIgn 11.6V)-----
NEtech
Denmark
C?ID=56995
Try this for an start.
CAN Gateway coding: 350003
Change Coding for [61] from 030F185A to 00000000
Remove [53] + [61] in CAN Gateway Installation list
Add [37]
18ME
C?ID=401654
Add [37]
Thank you, I'll try this when I get home.
18ME
C?ID=401654
Add [37]
Just done the above so hopefully this sorts the gateway out.
How do I code the radio so that I have sound? I changed the headunit as the original was knackered and all is well with sat nav etc but have no sound. When turning the headunit on it comes up with powered by Dynaudio or similar. My car doesn't have Dynaudio so could this be the issue?
Monday,31,August,2020,20:48:55:34784
Mileage: 209620km-130251mi   Repair Order:
Scan: 01 03 08 09 15 16 17 19 25 2E 37 42 44 46 4F 52 56 62 72 77
VIN: WVWZZZ1KZBW077109   Mileage: 209620km-130251miles
                    Mileage: 209599 km
                    Date: 2020.08.19
                    Time: 16:16:49
          P0610 00 [040] - -
                    Fault Frequency: 8
                    Mileage: 209605 km
                    Date: 2020.08.31
                    Time: 08:10:33
   Revision: 00H30001
                    Reset counter: 157
                    Mileage: 209605 km
                    Date: 2020.08.31
                    Time: 08:10:32
                    Count: 2
                    Count: 20480
                    Count: 8192
                    Count: 41728
                    Count: 255
   Revision: 00009001
   Coding: 0000000002
          U1111 00 [008] - -
                    Reset counter: 91
          U1111 00 [008] - -
                    Reset counter: 91
          U1111 00 [008] - -
                    Reset counter: 196
          U1111 00 [008] - -
                    Reset counter: 196
                    Reset counter: 197
                    Mileage: 209599 km
                    Date: 2020.08.19
                    Time: 16:15:37
   Revision: 00103 AD
   Coding: 009795
   Coding: 0330AD
                    Reset counter: 157
                    Mileage: 209583 km
                    Date: 2020.07.01
                    Time: 03:51:45
                    Voltage: 11.65 V
                        Term 50 Off
                    Reset counter: 196
                    Mileage: 209583 km
                    Date: 2020.07.01
                    Time: 03:51:45
                    Voltage: 11.65 V
                        Term 50 Off
                    Reset counter: 156
                    Mileage: 209583 km
                    Date: 2020.07.01
                    Time: 03:53:52
                        Term 15 Off
                    Voltage: 11.70 V
                        Term 50 Off
                    Reset counter: 198
                    Mileage: 209605 km
                    Date: 2020.08.31
                    Time: 08:51:11
                        Term 15 Off
                    Voltage: 11.70 V
                        Term 50 Off
                    Fault Frequency: 159
                    Reset counter: 198
                    Mileage: 209605 km
                    Date: 2020.08.31
                    Time: 08:51:12
                        Term 15 Off
                    Voltage: 11.70 V
                        Term 50 Off
   Coding: 00003133
   Coding: 108A140000
   Coding: E20000
332564 - Databus
                    Fault Frequency: 53
                    Reset counter: 0
                    Mileage: 208253 km
                    Date: 2021.11.18
                    Time: 11:51:24
332580 - Databus
                    Fault Frequency: 21
                    Reset counter: 51
                    Mileage: 208253 km
                    Date: 2021.11.18
                    Time: 11:51:24
332596 - Databus
                    Fault Frequency: 8
                    Reset counter: 51
                    Mileage: 208253 km
                    Date: 2021.11.18
                    Time: 11:51:24
   Coding: 470B00
10 Faults Found:
                    Reset counter: 197
                    Mileage: 209599 km
                    Date: 2020.08.19
                    Time: 16:16:44
                    Fault Frequency: 17
                    Reset counter: 196
          U1111 00 [008] - -
                    Reset counter: 91
          U1111 00 [008] - -
                    Reset counter: 91
          U1111 00 [008] - -
                    Fault Frequency: 64
                    Reset counter: 196
          U1111 00 [008] - -
                    Reset counter: 91
          U1111 00 [008] - -
                    Reset counter: 91
          U1111 00 [008] - -
                    Fault Frequency: 19
                    Reset counter: 196
          U1111 00 [008] - -
                    Fault Frequency: 31
                    Reset counter: 196
          U1111 00 [008] - -
                    Fault Frequency: 16
                    Reset counter: 91
   Coding: 350003
                    Fault Frequency: 8
                    Reset counter: 196
                    Reset counter: 91
                    Fault Frequency: 170
                    Reset counter: 159
                    Mileage: 209576 km
   Coding: 0000692
   Revision: 00H17000
                    Fault Frequency: 11
                    Reset counter: 196
                    Voltage: 13.75 V
                        DU
                    Temperature: 29.0°C
                    RPM: 781 /min
                    Voltage: 11.63 V
                        DU
                    Temperature: 23.0°C
                    RPM: 1498 /min
   Coding: 00000008
                    Reset counter: 156
                    Mileage: 209583 km
                    Date: 2020.07.01
                    Time: 00:00:25
   Coding: 0000948
                    Reset counter: 159
                    Mileage: 209576 km
   Coding: 0000144
   Coding: 0000144
   ROD: UHVNA.rod
                    Reset counter: 65
                    Mileage: 208366 km
                    Date: 2021.11.28
                    Time: 11:38:51
                    Reset counter: 91
          U0146 00 [008] - -
                    Reset counter: 91
                    Mileage: 209582 km
                    Date: 2022.01.30
                    Time: 16:53:17
End----------(Elapsed Time: 01:25, VBatt start/end: 12.2V/12.1V)-----------
[Select]
[56-Radio]
[Coding]
Look at Byte 1 (the second byte, since the first byte is "Byte 0").
You should have a drop-down that tells you what kind of sound system your radio is configured for.
You can choose a different one, or "Sound System Not Installed".
18ME
C?ID=401654
[Select]
[56-Radio]
[Coding]
Perfect, works a treat now with radio, nav and phone.
Just need to get the parking sensors working now. The guy who replaced the gateway module also replaced the parking sensor module because it too was corroded but after installing it the sensors were constantly bleeping so he disconnected the wiring to the back so it didn't drive me mad. Do I need to reconnect the wiring before attempting any coding? And any suggestions on coding these? The car has front and rear sensors if this makes a difference.
Yes, I think you will have to connect it in order to code it. :)
After you connect it, please make and post a current scan so we can see what's what.
18ME
C?ID=401654
Ok. just gone to try and reconnect the wiring but thought it would be an easy thing to do through the boot courtesy light but can't see where the guy disconnected it so looks like I'll have to try and get the whole trim off to access it. Don't suppose anyone knows how this trim comes off? as I can't see any screws at all and pulling at it seems fruitless as it seems truely fixed in place.
18ME
C?ID=401654
Managed to get the trim away to connect the wiring to the PDC buzzer. As soon as I turn the ignition on the buzzer bleeps very fast and constant. I did have a look to see if I could find the parking sensor module but the ones I tried (10-Park/Steer Assist & 76-Park Assist) say no response from controller.
Here is the scan with it connected.
Sunday,06,September,2020,16:02:25:34784
Mileage: 209660km-130276mi   Repair Order:
VIN: WVWZZZ1KZBW077109   Mileage: 209660km-130276miles
                    Mileage: 209599 km
                    Date: 2020.08.19
                    Time: 16:16:49
                    Unlearning counter according OBD: 34
          P0610 00 [040] - -
                    Fault Frequency: 8
                    Mileage: 209605 km
                    Date: 2020.08.31
                    Time: 08:10:33
                    Unlearning counter according OBD: 37
   Revision: 00H30001
                    Reset counter: 199
                    Mileage: 209605 km
                    Date: 2020.08.31
                    Time: 08:10:32
                    Count: 2
                    Count: 20480
                    Count: 8192
                    Count: 41728
                    Count: 255
   Revision: 00009001
   Coding: 0000000002
          U1111 00 [008] - -
                    Reset counter: 91
          U1111 00 [008] - -
                    Reset counter: 91
          U1111 00 [008] - -
                    Reset counter: 196
          U1111 00 [008] - -
                    Reset counter: 196
                    Reset counter: 197
                    Mileage: 209599 km
                    Date: 2020.08.19
                    Time: 16:15:37
   Revision: 00103 AD
   Coding: 009795
   Coding: 0330AD
                    Reset counter: 157
                    Mileage: 209583 km
                    Date: 2020.07.01
                    Time: 03:51:45
                    Voltage: 11.65 V
                        Term 50 Off
                    Reset counter: 196
                    Mileage: 209583 km
                    Date: 2020.07.01
                    Time: 03:51:45
                    Voltage: 11.65 V
                        Term 50 Off
                    Reset counter: 156
                    Mileage: 209583 km
                    Date: 2020.07.01
                    Time: 03:53:52
                        Term 15 Off
                    Voltage: 11.70 V
                        Term 50 Off
                    Reset counter: 198
                    Mileage: 209605 km
                    Date: 2020.08.31
                    Time: 08:51:11
                        Term 15 Off
                    Voltage: 11.70 V
                        Term 50 Off
                    Reset counter: 198
                    Mileage: 209605 km
                    Date: 2020.08.31
                    Time: 08:51:12
                        Term 15 Off
                    Voltage: 11.70 V
                        Term 50 Off
   Coding: 00003133
   Coding: 108A140000
   Coding: E20000
332564 - Databus
                    Fault Frequency: 53
                    Reset counter: 0
                    Mileage: 208253 km
                    Date: 2021.11.18
                    Time: 11:51:24
332580 - Databus
                    Fault Frequency: 21
                    Reset counter: 51
                    Mileage: 208253 km
                    Date: 2021.11.18
                    Time: 11:51:24
332596 - Databus
                    Fault Frequency: 8
                    Reset counter: 51
                    Mileage: 208253 km
                    Date: 2021.11.18
                    Time: 11:51:24
   Coding: 470B00
10 Faults Found:
                    Reset counter: 197
                    Mileage: 209599 km
                    Date: 2020.08.19
                    Time: 16:16:44
                    Fault Frequency: 17
                    Reset counter: 196
          U1111 00 [008] - -
                    Reset counter: 91
          U1111 00 [008] - -
                    Reset counter: 91
          U1111 00 [008] - -
                    Fault Frequency: 64
                    Reset counter: 196
          U1111 00 [008] - -
                    Reset counter: 91
          U1111 00 [008] - -
                    Reset counter: 91
          U1111 00 [008] - -
                    Fault Frequency: 19
                    Reset counter: 196
          U1111 00 [008] - -
                    Fault Frequency: 31
                    Reset counter: 196
          U1111 00 [008] - -
                    Fault Frequency: 16
                    Reset counter: 91
   Coding: 350003
                    Fault Frequency: 8
                    Reset counter: 196
                    Reset counter: 91
   Coding: 060100020100009000
                    Fault Frequency: 28
                    Reset counter: 163
                    Mileage: 209624 km
   Coding: 0000692
   Revision: 00H17000
                    Fault Frequency: 11
                    Reset counter: 196
                    Voltage: 13.75 V
                        DU
                    Temperature: 29.0°C
                    RPM: 781 /min
                    Voltage: 11.63 V
                        DU
                    Temperature: 23.0°C
                    RPM: 1498 /min
   Coding: 00000008
                    Reset counter: 156
                    Mileage: 209583 km
                    Date: 2020.07.01
                    Time: 00:00:25
   Coding: 0000948
                    Fault Frequency: 29
                    Reset counter: 163
                    Mileage: 209624 km
   Coding: 0000144
   Coding: 0000144
   ROD: UHVNA.rod
                    Reset counter: 65
                    Mileage: 208366 km
                    Date: 2021.11.28
                    Time: 11:38:51
                    Reset counter: 91
          U0146 00 [008] - -
                    Reset counter: 91
                    Mileage: 209582 km
                    Date: 2022.01.30
                    Time: 16:53:17
End----------(Elapsed Time: 01:29, VBatt start/end: 12.2V/12.2V)-----------
South Molton, UK
That scan shows that you have many modules that are not communicating with each other (BTW there's no point trying to connect to modules that don't appear in the Installation List!), looks like you need to do some basic fault finding - get a WD and checking fuses would be the first thing I would suggest.
18ME
C?ID=401654
Thanks.
Sorry, I am a complete novice with VCDS. What’s a WD?
18ME
C?ID=401654
Would the cause of modules not communicating with each other have something to do with the gateway module being replaced?
18ME
C?ID=401654
I’ll have to try that tomorrow on the laptop as nothing happens on iPad.
