Automatic parking brake - Auto engage
UWSCSI
Norway
C?ID=134408
Hello
My 2019 Audi e-tron occasionally activate the automatic parking brake when i park.
I guess it has something to do with the inclination of the car when i park and/or shut down the engine.
I would prefer that the automatic parking brake were engaged every time i park.
Any suggestions on what to code?
Best regards from Norway!
In 03-ABS, there should be an Adaptation Channel named:
IDE08134 -- Automatic parking brake
What is currently in that channel?
UWSCSI
Norway
C?ID=134408
The IDE08134 -- Automatic parking brake was not activated.
When I change it to "activated" I get the following message that makes me wonder if I should proceed or not...
Have you looked at the bottom of the Adaptation page in the VCDS product manual?
https://www.ross-tech.com/vcds/tour/adaptation_screen.php
I would try [No] for current values first.
If that doesn't work, try again with [Yes] for the defaults in VCDS.
If that doesn't work, then you're going to have to enter some more random values, like:
- Workshop Code: 05310
- Importer Number: I'm not sure what it is for Norway. Pick a 3-digit number.
- Equipment Number: 33953
UWSCSI
Norway
C?ID=134408
Sorry that I did not read the product manual... I am naturally born lazy...
Anyhow, I had to enter the security code (40168) for the ABS-module and choose [Yes] to store the new adaption.The APB now engages like I prefer it to do.
Thank you for your support and for VCDS, it is great!
rocamet
Rancho Cucamonga, CA, USA
C?ID=419570
@Uwe For my 2020 Atlas Cross Sport, do you know if the following channel is the same as the one you mention above? I do not have IDE08134. It is asking the same questions as the OP stated above, I'm just a little weary to change it since the title is not the same. thank you in advance.
IDE04645-Electromechanical parking brake
