2012 Q7 Foglights as Cornering Lights
Chrisfast44
Colorado, USA
C?ID=25945
Been using Ross-Tech for a long time, but this is my first post. I am looking to actually do 2 things if possible. I picked up a 2012 Q7 last year and would like to make the Fog Lights act as cornering lights. I went to module 09 Central Electronics, but there isn't an option for Coding Helper where I have changed that in the past on other vehicles.
I also would like to code out the Adaptive Headlights if possible. I am getting random faults that they are defective. The fault is for the left light swivel motor. I would just assume code it to believe it doesn't have Adaptive Lights if possible. Especially if I can get the fog lights to work as cornering lights, then I could care less about the cornering light in the headlight assembly. Any help is greatly appreciated. Auto Scan below. Thank you!!!!
Wednesday,26,August,2020,07:15:12:56786
VCDS Version: 20.4.2.0 (x64)
VIN: WA1WMAFE8CD003551   License Plate:
Chassis Type: FE-AU56 (4F0)
Scan: 01 02 03 05 08 09 15 16 17 19 28 36 3C 42 46 47 4C 4F 52 55
          56 5F 62 69 6C 6D 6F 72 76
VIN: WA1WMAFE8CD003551   Mileage: 130760km-81250miles
Address 01: Engine (J623-CATA)       Labels:. 059-907-401-V2.clb
   Part No SW: 4L2 910 401     HW: 4L0 907 401 D
   Component: 3.0TDI FSA    H18 0009
   Revision: 54H18---    Serial number:
   Coding: 2A2A4012252600050000
   Shop #: WSC 07128 003 1048576
   ASAM Dataset: EV_ECM30TDI0114L2910401 002008
   ROD: EV_ECM30TDI0114L2910401_002.rod
   VCID: 61C3DD847094788E7C-8034
Readiness: 0 0 0 1 1
   Part No SW: 0C8 927 750 S    HW: 0C8 927 750 S
   Component: AL1000 AISIN  001 3408
   Coding: 001178
   Shop #: WSC 01409 004 1048576
   ROD: EV_TCMAL991031_002.rod
   VCID: 3C7D4CF0B7B675660F-8068
   Part No SW: 4L0 910 517 M    HW: 4L0 614 517 L
   Revision: 00H02001
   Coding: 0099473
   Shop #: WSC 31414 790 00001
   VCID: 346D64D057E6BD26C7-8060
   Part No SW: 4F0 910 852 B    HW: 4F0 905 852 F
   Component: FBSAUDIC6 ELV   H05 0130
   Revision: 00H05000    Serial number: 10603401901443
   Coding: 0000135
   VCID: 254B8994EC3CD4AE40-8070
   Subsystem 1 - Part No: 4F0 910 132 L
   Component: FBSAUDIC6 EZS   H03 0020
   Component: FBSAUDIC6 KSG   H03 0020
   Part No SW: 4L0 910 043 D    HW: 4L0 820 043 AJ
   Revision: 00---026    Serial number: 00000000295876
   Coding: 0002A036
   VCID: 254B89942C3CD4AE40-8070
   Subsystem 1 - Part No SW: 8K0 959 772 D    HW: 8K0 959 772
   Component: SLR-B8  H05 0006
   Serial number:           0013152246
   Coding: 070000
   Part No SW: 4F0 910 279 AG    HW: 4F0 907 279 C
   Component: ILM Fahrer      H31 0400
   Coding: 0133123
   VCID: 6ED9B6B8794AD7F6F1-803A
   Subsystem 1 - Part No: 4L1 910 113   Labels: 1KX-955-119.CLB
   Component: Wischer AU716   H18 0110
   Coding: 00022806
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
   Part No SW: 4L0 910 655 A    HW: 4L0 959 655 B
   Component: 73 AIRBAG AUDI8RH43 0230
   Revision: 07H43000    Serial number: 0038QD09VT6$
   Coding: 0014131
   VCID: 2B5F7FAC8AD8E2DE96-807E
   Subsystem 1 - Part No: 4L0 910 339 A
   Component: BF-Gewichtsens. H03 0030
   Subsystem 2 - Serial number: 6332QSME5B5E2654R
   Subsystem 3 - Serial number: 6342QSME5B5E3840Q
   Subsystem 4 - Serial number: 6352QSME5D5E3446V
   Subsystem 5 - Serial number: 6362QSME52601C5AJ
   Subsystem 6 - Serial number: 63734SME27613C683
   Subsystem 7 - Serial number: 63834SME27614068-
   Part No SW: 4F0 910 549 B    HW: 4F0 953 549 E
   Component: J0527               0830
   Revision: 00H07000    Serial number: 90025112160078
   Coding: 0012142
   VCID: 285580A09B2EC9C67B-807C
   Component: E0221           H03 0030
Address 17: Instruments (J285)       Labels:. 4L0-920-xxx-17.clb
   Part No SW: 4L0 920 984 R    HW: 4L0 920 984 R
   Component: KOMBIINSTR.   H22 0411
   Revision: 00000000    Serial number: LMZ20LP9C
   Coding: 8BDF64040900CF05020205
   VCID: 42813208DD52039645-8016
   Part No SW: 4F0 907 468 Q    HW: 4F0 907 468 G
   Component: GW-BEM 5CAN-M H06 0047
   Revision: MB300033    Serial number: 3300M1190900AD
   Coding: 00C303
   VCID: 3D7B41F4A4AC7C6E38-8068
   Component: J367-BDM  H07 0125
   Serial number: 00000000002790453381
02256 - Quiescent Current
            001 - Upper Limit Exceeded
                    Fault Status: 01100001
                    Fault Frequency: 51
                    Reset counter: 174
                    Mileage: 128433 km
                    Date: 2020.07.07
                    Time: 18:45:00
                    Fault Frequency: 57
                    Reset counter: 214
                    Mileage: 128433 km
                    Date: 2020.07.07
                    Time: 21:45:00
                    Bin. Bits:    00000
                    Voltage: 12.30 V
                    Count: 18
   Part No SW: 4L0 910 158     HW: 4L0 919 158 AA
   Revision: 00---010    Serial number: 00000030211207
   Coding: 0000006
   VCID: 68D5C0A05BAE09C6BB-803C
   Part No SW: 4F0 959 760 D    HW: 4F0 959 760 D
   Component: MEM-FS        H08 0064
   Revision: AA000000    Serial number: 00000013889581
   Coding: 00581B00000011110000
   VCID: 326162C86DF2B316D5-8066
   Part No SW: 4L0 910 566 C    HW: 4L0 907 566 B
   Revision: 00H01000    Serial number: 6PZ 009 014-10
   Coding: 0000001
   VCID: 2E5976B8B9CA97F6B1-807A
   Subsystem 3 - Serial number: 5F03.09.1100H010003C910866ÿ
   Subsystem 4 - Serial number: 910866ÿ
   Part No SW: 4F0 959 793 T    HW: 8K0 959 793 M
   Component: TSG FA        H12 0362
   Revision:             Serial number: 0000013663119
   Coding: 011F57205E40440004
   VCID: 48952020FB6E29C69B-801C
   Part No SW: 4L0 910 289 K    HW: 4L0 907 289 K
   Component: Komfortgeraet   H11 0120
   Revision: 0120 ---    Serial number: 01570346230000
   Coding: 3569821
   VCID: 387550E04B8E5946EB-806C
                    Fault Status: 01101100
                    Reset counter: 174
                    Mileage: 119676 km
                    Date: 2011.08.24
                    Time: 23:00:59
   Part No SW: 4L0 035 223 H    HW: 4L0 035 223 G
   Component: BOSE G3 Q7    H03 0130
   Revision: CH003000    Serial number: 00000000016761
   Coding: 030000
   VCID: 2757839C5630C6BE72-8072
Address 4C: Tire Pressure II        Labels: 4F0-910-274.clb
   Part No SW: 4F0 910 274 B    HW: 4F0 907 274
   Component: J793  RKA+      H04 0110
   Revision: 00000519    Serial number: 00005190118035
   Coding: 0758477
   VCID: 234F978CE2082A9E2E-8076
   Part No SW: 4F0 910 280     HW: 4F0 907 280 D
   Component: ILM Beifahrer   H14 0100
   Revision:             Serial number: 00000000095023
   Coding: 0012001
   VCID: 5EB9E67889EA477641-800A
   Part No SW: 4F0 959 792 T    HW: 8K0 959 792 M
   Component: TSG BF        H12 0362
   Revision:             Serial number: 0000014235580
   VCID: 4797231CF67026BE92-8012
   Part No SW: 4L0 910 357 B    HW: 4L0 907 357 B
   Coding: 0000031
   Part No SW: 4G0 035 082 B    HW: 4G0 035 082
   Component: Radio U SIRIU H53 0076
   Revision: AB001007    Serial number: 156I+0B7552653
   Coding: 020007010000000000
   VCID: 1F479B7C0E600E7E0A-804A
   Part No SW: 4L2 035 746 B    HW: 4L2 035 746
   Component: H-BNT-NA      H42 0422
   Revision: --------    Serial number: 097IW0B7504031
   Coding: 180200060004E3EF51000345EF632003140000000100000000
   VCID: 2D5B71B474CCECEE88-8078
   Component: NAR 2011  0505
   Subsystem 2 - Part No SW: 8R0 919 604     HW: 8R0 919 604
   Component: DU7 High  H41 0104
   Serial number: A130I60BS024645
   Subsystem 3 - Part No SW: 4L0 910 609     HW: 4L0 919 611 C
   Component: E0380 Bedient  H05 0060
   Serial number: 00000001762740
   Component: CD-Database  3371
   Part No SW: 4F0 959 795 P    HW: 4F0 959 795 P
   Component: TSG HL        H11 0362
   Revision:             Serial number: 0000014594302
   Coding: 010E57204040230004
   VCID: 46892E18F17A3FB669-8012
Address 69: Trailer (J345)       Labels:. 4E0-907-383.clb
   Part No SW: 4E0 907 383 J    HW: 4E0 907 383 J
   Revision: 2A001001    Serial number: 00000169363140
   Coding: 0200000000000000
   Shop #: WSC 07118 444 13417
   VCID: 31636DC468F4880EAC-8064
   Revision: --H05---    Serial number: 525PA8-J1840AL
   Coding: 1021201
   Part No SW: 4L0 910 945     HW: 4L0 827 851 E
   Revision: --H57001    Serial number: E5030000B
   Shop #: WSC 98765 666 38354
   VCID: 6CDDBCB04F5625E6DF-8038
   Subsystem 3 - Serial number: RD26.09.11--H57001001B0244ÿ
   Subsystem 4 - Serial number: 1B0244ÿ
   Component: ILM HINTEN 2    H07 0080
   Revision: AAH07080    Serial number: 119636433-----
   Coding: 0003595
   VCID: 26498E98913ADFB649-8072
   Component: J_245_EE16_SKB10H11 0220
   Component: J_394_EE16_SKB10H11 0220
   Component: J_392_EE16_SKB10H11 0220
   Component: TSG HR        H11 0362
   Revision:             Serial number: 0000014594305
   Part No SW: 4L0 910 283 E    HW: 4L0 919 283 E
   Component: Parkhilfe 8-Kan H03 0100
   Revision: 00H03000    Serial number: 37361124102094
   Coding: 0221266
   VCID: 2C5D7CB08FD6E5E69F-8078
End-------------------------(Elapsed Time: 03:49)--------------------------
Your Q7 uses "4F" CECM. That module was designed during the first half of the first decade of this century and first appeared in the 2005 A6. It doesn't have much flexibility in terms of lighting configuration.
Also, AFS headlight range controllers cannot be coded to believe that they are a "basic" module.
So I don't think either of these things can be done.
Chrisfast44
Colorado, USA
C?ID=25945
Ugh.... I was worried about that. Thank you for your reply. Really appreciate your help!
