2006 Tansporter T5 AXD engine, intermittent starting problem
rainbm
H,
I have a 2006 VW T5 Transporter 2.5 TDi 130ps with 70k miles on it which I've owned from new.
VIN: WV1ZZZ7H6H049228
Engine No: AXD 126513
I have been living with an intermittent starting problem for about 6 weeks and recently it has become more frequent. Until recently, once it had started in the morning, the fault would disappear on subsequent starts until the next day or a few days hence. Now, it usually reappears on the next attempt to start it
Symptoms
The engine spins but will not start.
When it won't start, the ASR warning light (Anticlockwise circular arrow inside a triangle) comes on, goes out briefly and then comes back on. The glowplug light does not light at all. I've just noticed there is an ABS warning light also and this does not appear to be part of the issue
When it does start, the glowplug light comes on very briefly (It's quite warm currently), the ATC light comes on briefly (along with most of the warning lights) and then goes out and stays out. You can also hear the fuel pump "squelch" as it primes.
If I turn the ignition switch off and on again several times, eventually the glowplug light flashes on, the TCS/ABS light goes out and doesn't come back on, you hear the fuel pump start and the engine starts when you turn the key the rest of the way to the start position.
I have removed and tested the "109" relay.
A friend of mine has a VCDS reader and has read the error codes. I have included two log files. SCAN1 is the first read of the ECU. He then cleared the errors and carried out a scan that showed no errors, although we couldn't print the log file. SCAN2 is the log file after we had recreated the fault once.
I'm going to paste the auto-scan file in here because I can't find a way to attach them as files to the post!
Has anyone seen this before or have any suggestions for trying to diagnose the fault?
Any suggestions very gratefully received!
Mark
SCAN2
  	 		 		 	 	 		 			 				[FONT=&quot]VCDS [/FONT]
 			 			 				 					[FONT=&quot]Windows Based VAG/VAS Emulator Running on Windows 10 x64 [/FONT]
 			 			 				 					[FONT=&quot]VCDS Version: Release 20.4.2(x64) Data version: 20200730 DS317.0 [/FONT]
 			 			 				 					[FONT=&quot][URL="http://www.Ross-Tech.com"]www.Ross-Tech.com[/URL] [/FONT]
 			 			 				 					[FONT=&quot]Dealer/Shop Name: [/FONT]
 			 			 				 					[FONT=&quot]Workshop Code: 000 00000 000000 [/FONT]
 			 			 				 					[FONT=&quot]Self-Diagnosis Log [/FONT]
 			 			 				 					[FONT=&quot]Thursday,20,August,2020,13:23:<wbr>32:11020 [/FONT]
 			[TABLE]
 				<tbody>[TR]
 					[TD="bgcolor: #FFFFFF"] 						 							 								[FONT=&quot]VIN: WV1ZZZ7HZ6H049228 License Plate: [/FONT]
 					[/TD]
 				[/TR]
 				[TR]
 					[TD="bgcolor: #FFFFFF"] 						 							 								[FONT=&quot]Mileage: 114820km-71345mi Repair Order: [/FONT]
 					[/TD]
 				[/TR]
 			</tbody>[/TABLE]
 			 			 				 					[FONT=&quot]Chassis Type: 7H (7H - VW Transporter/Multivan (2003 > 2010)) [/FONT]
 			 			 				 					[FONT=&quot]Scan: 01 02 03 08 09 0B 0D 15 16 17 18 19 1C 22 2D 37 45 46 47 56 [/FONT]
 			 			 				 					[FONT=&quot]57 6E 76 77 78 7D [/FONT]
 			 			 				 					[FONT=&quot]VIN: WV1ZZZ7HZ6H049228 Mileage: 114820km-71345miles [/FONT]
 			 			 				 					[FONT=&quot]------------------------------<wbr>------------------------------<wbr>------------------- [/FONT]
 			 			 				 					[FONT=&quot]Address 01: Engine Labels: 070-906-016-AXD.clb [/FONT]
 			 			 				 					[FONT=&quot]Part No SW: 070 906 016 AJ HW: 028 101 156 8 [/FONT]
 			 			 				 					[FONT=&quot]Component: R5 2,5L EDC 7002 [/FONT]
 			 			 				 					[FONT=&quot]Shop #: WSC 02756 785 00200 [/FONT]
 			 			 				 					[FONT=&quot]VCID: 58BFB2BBE83867460B-5122 [/FONT]
 			 			 				 					[FONT=&quot]No Faults Found [/FONT]
 			 			 				 					[FONT=&quot]or DTCs not supported by controller [/FONT]
 			 			 				 					[FONT=&quot]or a communication error occurred [/FONT]
 			 			 				 					[FONT=&quot]Address 03: ABS Brakes Labels: 7H0-907-37x-ASR-F.lbl [/FONT]
 			 			 				 					[FONT=&quot]Part No: 7H0 907 379 G [/FONT]
 			 			 				 					[FONT=&quot]Component: ASR FRONT MK25 0103 [/FONT]
 			 			 				 					[FONT=&quot]Coding: 0007206 [/FONT]
 			 			 				 					[FONT=&quot]VCID: 3979173F73729E4E14-5104 [/FONT]
 			 			 				 					[FONT=&quot]1 Fault Found: [/FONT]
 			 			 				 					[FONT=&quot]01314 - Engine Control Module [/FONT]
 			 			 				 					[FONT=&quot]004 - No Signal/Communication [/FONT]
 			 			 				 					[FONT=&quot]Address 08: Auto HVAC Labels: Redir Fail! [/FONT]
 			 			 				 					[FONT=&quot]Part No: 7H0 820 045 AC [/FONT]
 			 			 				 					[FONT=&quot]Component: CLIMA/AC 0303 [/FONT]
 			 			 				 					[FONT=&quot]Shop #: WSC 00000 000 00000 [/FONT]
 			 			 				 					[FONT=&quot]VCID: 66C38C43524CC1B689-5104 [/FONT]
 			 			 				 					[FONT=&quot]01299 - Diagnostic Interface for Data Bus (J533) [/FONT]
 			 			 				 					[FONT=&quot]013 - Check DTC Memory [/FONT]
 		 			 				 					[FONT=&quot]VCID: 3F8D79276D56B07E2A-5122 [/FONT]
 			 			 				 					[FONT=&quot]Thursday,20,August,2020,13:23:<wbr>34:11020 [/FONT]
 			 			 				 					[FONT=&quot]Page 2 [/FONT]
 			 			 				 					[FONT=&quot]Address 09: Cent. Elect. Labels:. 7H0-937-049.lbl [/FONT]
 			 			 				 					[FONT=&quot]Part No: 7H0 937 049 P [/FONT]
 			 			 				 					[FONT=&quot]Component: BORDNETZ SGVER 1.0 1901 [/FONT]
 			 			 				 					[FONT=&quot]Coding: 0000100 [/FONT]
 			 			 				 					[FONT=&quot]Shop #: WSC 02737 785 00200 [/FONT]
 			 			 			 				 					[FONT=&quot]2 Faults Found: [/FONT]
 			 			 				 					[FONT=&quot]01341 - Control Module in Instrument Panel On Comfort CAN (J285) [/FONT]
 			 			 				 					[FONT=&quot]008 - Implausible Signal [/FONT]
 			 			 				 					[FONT=&quot]Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl [/FONT]
 			 			 				 					[FONT=&quot]Part No: 1C0 909 605 A [/FONT]
 			 			 				 					[FONT=&quot]Component: 3B AIRBAG VW51 0008 [/FONT]
 			 			 				 					[FONT=&quot]Coding: 13122 [/FONT]
 			 			 				 					[FONT=&quot]Shop #: WSC 02756 [/FONT]
 			 			 				 					[FONT=&quot]VCID: 224BD053AEE4FD9625-5104 [/FONT]
 			 				 					[FONT=&quot]No fault code found. [/FONT]
 			 			 				 					[FONT=&quot]Address 17: Instruments Labels: 7Hx-920-xxx-17.lbl [/FONT]
 			 			 				 					[FONT=&quot]Part No: 7H0 920 951 G [/FONT]
 			 			 				 					[FONT=&quot]Component: KOMBI+WEGFAHRSP VDO V03 [/FONT]
 			 			 				 					[FONT=&quot]Coding: 01412 [/FONT]
 			 			 				 					[FONT=&quot]Shop #: WSC 59003 [/FONT]
 			 			 				 					[FONT=&quot]VCID: 306F2A1BF0085F06A3-5122 [/FONT]
 			 			 				 					[FONT=&quot]WV1ZZZ7HZ6H049228 VWZ7Z0E2876295 [/FONT]
 			 			 				 					[FONT=&quot]49-00 - No Communications [/FONT]
 			 			 				 					[FONT=&quot]Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl [/FONT]
 			 			 				 					[FONT=&quot]Part No: 6N0 909 901 [/FONT]
 			 			 				 					[FONT=&quot]Component: Gateway K<->CAN 0001 [/FONT]
 			 			 				 					[FONT=&quot]Coding: 00006 [/FONT]
 			 			 				 					[FONT=&quot]Shop #: WSC 02737 [/FONT]
 			 			 				 					[FONT=&quot]VCID: 70EFEA1B30881F06E3-5104 [/FONT]
 			 			 				 					[FONT=&quot]Page 3 [/FONT]
 			 			 				 					[FONT=&quot]Address 46: Central Conv. Labels: 7H0-959-433.lbl [/FONT]
 			 			 				 					[FONT=&quot]Part No: 7H0 959 433 B [/FONT]
 			 			 				 					[FONT=&quot]Component: C2B Komfortgerát 0004 [/FONT]
 			 			 				 					[FONT=&quot]Coding: 00069 [/FONT]
 			 			 				 					[FONT=&quot]VCID: 326B2013FE046D16D5-4AE4 [/FONT]
 			 			 				 					[FONT=&quot]Subsystem 1 - Part No: 7H2959802 [/FONT]
 			 			 				 					[FONT=&quot]Component: Tõrsteuer.FS KLO 0203 [/FONT]
 			 			 				 					[FONT=&quot]Subsystem 2 - Part No: 7H2959801 [/FONT]
 			 			 				 					[FONT=&quot]Component: Tõrsteuer.BF KLO 0203 [/FONT]
End-------------------------(<wbr>Elapsed Time: 06:12)------------------------<wbr>-- [/FONT]
SCAN1
  	 		 		 	 	 		 			 				 					[FONT=&quot]Thursday,20,August,2020,12:54:<wbr>45:11020
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64 [/FONT]
 			 				 					[FONT=&quot]VCDS Version: 20.4.2.0 Data version: 20200730 [URL="http://www.Ross-Tech.com"]www.Ross-Tech.com[/URL] [/FONT]
 					[FONT=&quot]------------------------------<wbr>------------------------------<wbr>-------------------- [/FONT]
 					[FONT=&quot]Chassis Type: 7H (7H - VW Transporter/Multivan (2003 > 2010)) Scan: 01 02 03 08 09 0B 0D 15 16 17 18 19 1C 22 2D 37 45 46 47 56 [/FONT]
 					[FONT=&quot]          57 6E 76 77 78 7D
[/FONT] 					[FONT=&quot]VIN: WV1ZZZ7HZ6H049228 Mileage: 114820km-71345miles ------------------------------<wbr>------------------------------<wbr>------------------- Address 01: Engine Labels: 070-906-016-AXD.clb [/FONT]
 					[FONT=&quot]   Part No SW: 070 906 016 AJ    HW: 028 101 156 8
   Component: R5 2,5L EDC 0000SG  7002
   Revision: 12345678    Serial number: VWZ7Z0E2876295
   Coding: 0001072
[/FONT] 					[FONT=&quot]Shop #: WSC 02756 785 00200 VCID: 58BFB2BBE83867460B-5122 [/FONT]
 					[FONT=&quot]No fault code found. Readiness: 0 0 X X X [/FONT]
 					[FONT=&quot]Address 03: ABS Brakes Labels: 7H0-907-37x-ASR-F.lbl Part No: 7H0 907 379 G [/FONT]
 			 				 					[FONT=&quot]Component: ASR FRONT MK25 Coding: 0007206
Shop #: WSC 02756 785 00200 VCID: 3979173F73729E4E14-5104 [/FONT]
 				 					[FONT=&quot]0103 [/FONT]
 			 				 					[FONT=&quot](x64) DS317.0 [/FONT]
 			 				 					[FONT=&quot]License Plate:
[/FONT]
 			 				 					[FONT=&quot]013 - Check DTC Memory - Intermittent 01314 - Engine Control Module [/FONT]
 					[FONT=&quot]004 - No Signal/Communication - Intermittent [/FONT]
[/FONT]
Shop #: WSC 00000 000 00000 VCID: 66C38C43524CC1B689-5104 [/FONT]
 				 					[FONT=&quot]0303 [/FONT]
 					[FONT=&quot]013 - Check DTC Memory - Intermittent [/FONT]
 					[FONT=&quot]Address 09: Cent. Elect. Labels:. 7H0-937-049.lbl Part No: 7H0 937 049 P
 					[FONT=&quot]Shop #: WSC 02737 785 00200 VCID: 3F8D79276D56B07E2A-5104 [/FONT]
 					[FONT=&quot]6 Faults Found:
01598 - Drive Battery Voltage [/FONT]
 					[FONT=&quot]002 - Lower Limit Exceeded 00538 - Reference Voltage [/FONT]
 					[FONT=&quot]014 - Defective 00991 - Interior Lights [/FONT]
 					[FONT=&quot]012 - Electrical Fault in Circuit - Intermittent 01341 - Control Module in Instrument Panel On Comfort CAN (J285) [/FONT]
 			 				 					[FONT=&quot]008 - Implausible 01598 - Drive Battery Voltage 001 - Upper Limit 01117 - Generator Terminal DF 008 - Implausible [/FONT]
 				 					[FONT=&quot]Signal - Intermittent [/FONT]
 					[FONT=&quot]Exceeded
Load Signal
Signal
[/FONT]
 					[FONT=&quot]Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl Part No: 1C0 909 605 A
00532 - Supply Voltage B+ [/FONT]
 					[FONT=&quot]07-10 - Signal too Low - Intermittent [/FONT]
 					[FONT=&quot]Address 17: Instruments Labels: 7Hx-920-xxx-17.lbl Part No: 7H0 920 951 G
VCID: 306F2A1BF0085F06A3-5104 WV1ZZZ7HZ6H049228 VWZ7Z0E2876295 [/FONT]
 					[FONT=&quot]49-10 - No Communications - Intermittent [/FONT]
 					[FONT=&quot]Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl Part No: 6N0 909 901 [/FONT]
 		 			 				 					[FONT=&quot]Component: Gateway K<->CAN 0001 Coding: 00006
Shop #: WSC 02737
 					[FONT=&quot]49-10 - No Communications - Intermittent ------------------------------<wbr>------------------------------<wbr>------------------- [/FONT]
Part No: 7H0 959 433 B Component: C2B Komfortgerát Coding: 00069 [/FONT]
 				 					[FONT=&quot]Labels: 7H0-959-433.lbl 0004 [/FONT]
 			 				 					[FONT=&quot]Subsystem 1 - Part No: 7H2959802 Component: Tõrsteuer.FS KLO 0203 [/FONT]
 					[FONT=&quot]Subsystem 2 - Part No: 7H2959801 Component: Tõrsteuer.BF KLO 0203 [/FONT]
 					[FONT=&quot]End-------------------------(<wbr>Elapsed Time: 06:16)------------------------<wbr>-- [/FONT]
 					[FONT=&quot]Address 01: DTCs cleared ------------------------------<wbr>------------------------------<wbr>-------------------- ------------------------------<wbr>------------------------------<wbr>-------------------- [/FONT]
 					[FONT=&quot]Address 03: DTCs cleared ------------------------------<wbr>------------------------------<wbr>-------------------- ------------------------------<wbr>------------------------------<wbr>-------------------- [/FONT]
 					[FONT=&quot]Address 08: DTCs cleared ------------------------------<wbr>------------------------------<wbr>-------------------- ------------------------------<wbr>------------------------------<wbr>-------------------- [/FONT]
 					[FONT=&quot]Address 09: DTCs cleared ------------------------------<wbr>------------------------------<wbr>-------------------- ------------------------------<wbr>------------------------------<wbr>-------------------- [/FONT]
 					[FONT=&quot]Address 15: DTCs cleared ------------------------------<wbr>------------------------------<wbr>-------------------- ------------------------------<wbr>------------------------------<wbr>-------------------- [/FONT]
 		 			 				 					[FONT=&quot]Address 17: DTCs cleared ------------------------------<wbr>------------------------------<wbr>-------------------- ------------------------------<wbr>------------------------------<wbr>-------------------- [/FONT]
 					[FONT=&quot]Address 19: DTCs cleared ------------------------------<wbr>------------------------------<wbr>-------------------- ------------------------------<wbr>------------------------------<wbr>-------------------- [/FONT]
 					[FONT=&quot]Address 46: DTCs cleared ------------------------------<wbr>------------------------------<wbr>-------------------- ------------------------------<wbr>------------------------------<wbr>-------------------- [/FONT]
   Coding: 0001072
[/FONT]
 			 				 					[FONT=&quot]No fault code found. ------------------------------<wbr>------------------------------<wbr>------------------- [/FONT]
 			 				 					[FONT=&quot]Component: Gateway K<->CAN Coding: 00006
Shop #: WSC 02737
VCID: 70EFEA1B30881F06E3-5122 [/FONT]
 				 					[FONT=&quot]0001 [/FONT]
 			 				 					[FONT=&quot]End-------------------------(<wbr>Elapsed Time: 06:24)------------------------<wbr>-- [/FONT]
 					[FONT=&quot]Part No SW: 070 906 016 AJ HW: 028 101 156 8 Component: R5 2,5L EDC 7002
[/FONT] 					[FONT=&quot]------------------------------<wbr>------------------------------<wbr>------------------- [/FONT]
[/FONT]
 					[FONT=&quot]Shop #: WSC 02737 785 00200 VCID: 3F8D79276D56B07E2A-5122 [/FONT]
VCID: 306F2A1BF0085F06A3-5122 WV1ZZZ7HZ6H049228 VWZ7Z0E2876295 [/FONT]
Shop #: WSC 02737
 			 				 					[FONT=&quot]49-00 - No Communications ------------------------------<wbr>------------------------------<wbr>------------------- [/FONT]
I have no idea what software you ran the above data through to produce all those tags, but the formatting is a hot mess. Please post the plain text that VCDS produces.
rainbm
Hi Uwe,
I've just cut and pasted the text from the dumped files...
This is the second scan after clearing all the codes and then reproducing the fault:
 Dealer/Shop Name:
 Self-Diagnosis Log
 Thursday,20,August,2020,13:23:32:11020
 57 6E 76 77 78 7D
 No Faults Found
 Coding: 0007206
 Self-Diagnosis Log
 Thursday,20,August,2020,13:23:34:11020
 Page 2
 Coding: 0000100
 Coding: 13122
 Shop #: WSC 02756
 Coding: 01412
 Shop #: WSC 59003
 Coding: 00006
 Shop #: WSC 02737
 Self-Diagnosis Log
 Page 3
 Coding: 00069
 Shop #: WSC 02756
End-------------------------(Elapsed Time: 06:12)--------------------------
rainbm
Here is the 1st scan before clearing all the codes that were stored for many months...
Thursday,20,August,2020,12:54:45:11020
VCDS Version: 20.4.2.0 Data version: 20200730 [url]www.Ross-Tech.com[/url]
          57 6E 76 77 78 7D
VIN: WV1ZZZ7HZ6H049228 Mileage: 114820km-71345miles ------------------------------------------------------------------------------- Address 01: Engine Labels: 070-906-016-AXD.clb
   Coding: 0001072
0103
(x64) DS317.0
License Plate:
Component: CLIMA/AC
0303
Coding: 0000100
Exceeded
Load Signal
Signal
Coding: 13122
Shop #: WSC 02756
Coding: 01412
Shop #: WSC 59003
Shop #: WSC 02737
49-10 - No Communications - Intermittent -------------------------------------------------------------------------------
Shop #: WSC 02756
End-------------------------(Elapsed Time: 06:16)--------------------------
Address 01: DTCs cleared -------------------------------------------------------------------------------- --------------------------------------------------------------------------------
Address 03: DTCs cleared -------------------------------------------------------------------------------- --------------------------------------------------------------------------------
Address 08: DTCs cleared -------------------------------------------------------------------------------- --------------------------------------------------------------------------------
Address 09: DTCs cleared -------------------------------------------------------------------------------- --------------------------------------------------------------------------------
Address 15: DTCs cleared -------------------------------------------------------------------------------- --------------------------------------------------------------------------------
Address 17: DTCs cleared -------------------------------------------------------------------------------- --------------------------------------------------------------------------------
Address 19: DTCs cleared -------------------------------------------------------------------------------- --------------------------------------------------------------------------------
Address 46: DTCs cleared -------------------------------------------------------------------------------- --------------------------------------------------------------------------------
          57 6E 76 77 78 7D
   Coding: 0001072
Component: CLIMA/AC
0303
No fault code found. -------------------------------------------------------------------------------
Coding: 0000100
Coding: 13122
Shop #: WSC 02756
Coding: 01412
Shop #: WSC 59003
Shop #: WSC 02737
0001
Shop #: WSC 02756
End-------------------------(Elapsed Time: 06:24)--------------------------
          57 6E 76 77 78 7D
No Faults Found
0103
Component: CLIMA/AC
0303
Coding: 0000100
Coding: 13122
Shop #: WSC 02756
Coding: 01412
Shop #: WSC 59003
Shop #: WSC 02737
0001
49-00 - No Communications -------------------------------------------------------------------------------
Shop #: WSC 02756
Looks like the ECU drops off-line intermittently. Since it's intermittent, that's going to be a bugger to track down.
PS: Please don't use the [Print] function in VCDS to post data here. Please post the native text that VCDS produces, either in the Logs sub-folder if you explicitly [Save] it, or in the Scans sub-folder if you don't.
rainbm
Hi Uwe, Many thanks for your reply.
Have you any suggestions for the best way to proceed with trying to find the fault? Someone has suggested sending the ECU off to ECUTesting for test/repair as a first step and at least ruling a faulty ECU out. They also suggested that the fault may well be caused by poor connections on one of the sensors connected to the ECU. I've also read that the cables for the glowplugs run through the rocker box cover are immersed exposed to engine oil and can be problematic.
Any suggestions at all for the best way proceed!? Or someone that that is good at this kind of fault finding that I can take the van to here in the UK?
Thnaks again,
Mark
South Molton, UK
First thing I would do is visually inspect all the cables going to and around the engine, and unmate all the connectors (one at a time!) to check for corrosion or liquid or loose/broken latches.
If that finds/fixes the problem then it's cost nothing but your time.
rainbm
SOLVED :)
Thanks for all your help everyone.
Just to follow up and say I've resolved this issue:
As suggested, I removed plugs to all sensors I could, one at a time. Nothing conclusive found. Obviously some induced new faults but I wasn't able to turn my intermittent failure into a permanent failure.
In the end, I plumped for removing the ECU and sending it off to EcuTesting to be tested and then repaired if they could find a fault. They did find faults "consistent with the symptoms I described" and I had the unit repaired. Total cost was £315.00 including shipping and VAT. If they had tested it and not been able to find a fault, I think they said they would have returned the unit to me for total cost of £85, including testing, collection and return shipping charges. Not 100% sure of that amount though.
I put the ECU back in and it started first time and although I haven't actually driven anywhere, it's started several times without any of the symptoms I was experiencing before. So I think it's a fix and hopefully not something external to the ECU that's induced the fault in it.
If the problem returns I will come back and report.
Thanks again for your help
