Passat b7 coding abs
bonzo
Romania
C?ID=334156
hy all i have a passat b7 and the car came to me with the 2 errors on abs ,i have changed the 2 rear sensor...same error,checked the wires the wire are ok...i think its from coding,i have made a scan,im waiting answer please,thank you ps if i disconect one of the sensors i have short to ground error
Sunday,23,August,2020,22:36:53:28383
VCDS Version: 20.4.0.1  HEX-V2 CB: 0.4508.4
VIN: WVWZZZ3CZBE405571   License Plate: TM88VPP
Mileage: 188420km-117078mi   Repair Order:
Chassis Type: 3C-VW46 (7N0)
Scan: 01 03 08 09 10 13 15 16 17 19 25 37 42 44 46 4F 52 53 56 61
          62 72 77
VIN: WVWZZZ3CZBE405571   Mileage: 188420km-117078miles
62-Door, Rear Left -- Status: Cannot be reached 1100
   Part No SW: 03L 906 018 BF    HW: 03L 907 309 N
   Component: R4 2,0L EDC   H24 7852
   Revision: 47H24---    Serial number: 00000000000000
   Coding: 00190012044401080000
   Shop #: WSC 00015 115 00000
   ASAM Dataset: EV_ECM20TDI01103L906018BF 003005
   ROD: EV_ECM20TDI01103L906018BE.rod
   VCID: 6FBB2F92571BE183BA8-803A
4327 - Function Restriction due to Faults in Other Modules
          U1113 00 [039] - -
                    Mileage: 188428 km
                    Date: 2020.08.23
                    Time: 22:35:34
                    Engine speed: 0.00 /min
                    Coolant temperature: 27 °C
                    Intake air temperature: 29 °C
                    Voltage terminal 30: 11.140 V
                    ACC target acceleration: 0.000 m/s²
                    ACC control module received status-Bits 0-7: 7
                    Status of ACC/CCS acceleration interface-Bits 0-7: 3
                    Acceleration: 0.000 m/s²
                    Engine status: COENG_READY
4330 - Function Restriction due to Faults in Other Modules
          U1113 00 [038] - -
                    Mileage: 188428 km
                    Date: 2020.08.23
                    Time: 22:35:33
                    Coolant temperature: 28 °C
   Part No SW: 3AA 614 109 P    HW: 3AA 614 109 P
   Component: J104   C2 450M V5CE 0011
   Revision: --H07---    Serial number: 00000003940239
   Coding: 0084400
   Shop #: WSC 05311 000 00000
   VCID: 3A2DCEC65059742B5D6-806E
03841 - RPM Sensor Rear Left: Incorrect Signal
                    Reset counter: 206
                    Mileage: 188428 km
                    Date: 2020.08.23
                    Time: 22:35:31
                    Hex Value: 0x0000
                    Bin. Bits: 00000000 00000000
                    Voltage: 11.00 V
                    Bin. Bits: 00011111
                    Count: 156
                    Hex Value: 0x0000
03842 - RPM Sensor Rear Right: Incorrect Signal
                    Reset counter: 206
                    Mileage: 188428 km
                    Date: 2020.08.23
                    Time: 22:35:31
                    Hex Value: 0x0000
                    Voltage: 11.00 V
                    Bin. Bits: 00011111
                    Count: 157
                    Hex Value: 0x0000
   Part No SW: 5K0 907 044 ED    HW: 5K0 907 044 ED
   Component: Climatronic   H17 1010
   Revision: 00001003
   Coding: 0000000003
   VCID: 71BF29EA412FF773ACC-8024
13701520 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Türsteuergerät hinten links - kein Signal/Kommunikation]
                    Reset counter: 206
                    Mileage: 188428 km
                    Date: 2020.08.23
                    Time: 22:35:31
Address 09: Cent. Elect. (J519)       Labels:. 3AA-937-087.clb
   Part No SW: 3AA 937 087 A    HW: 3AA 937 087 A
   Component: BCM PQ47 H    413 0452
   Revision: BB413001
   Coding: 000000000000000000180080540081E443510088426D87606480C7200041
   VCID: 3829D4CE6255663BAB2-806C
   Subsystem 1 - Part No SW: 3AB 955 419     HW: 3AB 955 419   Labels: 1KX-955-119.CLB
   Component: Wischer 27041  10  0603
   Coding: 00B795
   Component: RLS 200511 05  54  0403
   Coding: 033028
                    Reset counter: 206
                    Mileage: 188428 km
                    Date: 2020.08.23
                    Time: 22:35:31
                    Voltage: 11.10 V
Address 10: Park/Steer Assist (J446)       Labels:| 3AE-919-475.clb
   Part No SW: 3AE 919 475     HW: 7N0 919 475
   Component: PARKHILFE 8K  H04 0009
   Revision: --------    Serial number: 77631113107207
   Coding: 108002
   ASAM Dataset: EV_EPHVA18VW47X0000 001003
   ROD: EV_EPHVA18VW47X0000.rod
   VCID: 7CA108DE166D8A1B0FA-8028
Address 13: Auto Dist. Reg        Labels: 3AA-907-567.clb
   Part No SW: 3AA 907 567     HW: 3AA 907 567
   Component: AC201  RDW M    036 0143
   Revision: 00036000    Serial number: 00000000100478
   Coding: 0010100
   Shop #: WSC 65793 128 08224
   VCID: 77AB17F223CBA943628-8022
00234 - Sensor for Automatic Distance Regulation Misadjusted
            003 - Mechanical Failure
                    Fault Status: 01100011
                    Reset counter: 206
                    Mileage: 188428 km
                    Date: 2020.08.23
                    Time: 22:35:30
                    Count: 110
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 206
                    Mileage: 188428 km
                    Date: 2020.08.23
                    Time: 22:35:30
                    Count: 4
                    Reset counter: 206
                    Mileage: 188428 km
                    Date: 2020.08.23
                    Time: 22:35:31
                    Count: 4
                    Reset counter: 206
                    Mileage: 188428 km
                    Date: 2020.08.23
                    Time: 22:35:31
                    Count: 8
   Part No SW: 5N0 959 655 R    HW: 5N0 959 655 R
   Component: J234__101 VW10 HI   1918
   Revision: 22014000    Serial number: 003K0P9HE0TV
   Coding: 0012337
   VCID: 4CC1981E0ACDFA9BFFA-8018
   Subsystem 1 - Serial number: 00000000000000000
   Subsystem 2 - Serial number: 6342MTS676671141
   Subsystem 3 - Serial number: 6351HTS6H8CF3AKJ
   Subsystem 4 - Serial number: 6361HTS65J8A1AKJ
01221 - Crash Sensor Side Airbag; Driver Side (G179)
            008 - Implausible Signal - MIL ON
                    Fault Status: 11101000
                    Mileage: 188428 km
                    Date: 2020.08.23
                    Time: 22:35:31
Address 16: Steering wheel (J527)       Labels:| 3C0-953-569.clb
   Part No SW: 3C9 953 501 BM    HW: 5K0 953 569 T
   Revision: FF010040    Serial number: 20110511200766
   Coding: 318AA50000
   VCID: 75B71DFA3547DB53704-8020
   Coding: E20000
   Part No SW: 3AA 920 870 A    HW: 3AA 920 870 A
   Coding: 161F00
   Shop #: WSC 05314 115 00000
   VCID: 3039ECEE8AA5BE7BE32-8064
   Part No SW: 7N0 907 530 G    HW: 1K0 907 951
   Component: J533  Gateway H41 1614
   Revision:   H41       Serial number: 100511F1003725
   Coding: 462006
   Shop #: WSC 05314 000 00000
   VCID: 3431E0FE7E3D825B87A-8060
                    Reset counter: 206
                    Mileage: 188428 km
                    Date: 2020.08.23
                    Time: 22:35:31
   Part No SW: 3AA 959 433     HW: 3AA 959 433
   Component:    IMMO         043 0399
   Revision: 00043000    Serial number: VWZCZ000000000
   VCID: 76B51AF624C1D04B79E-8022
   Part No SW: 1T0 035 680 L    HW: 3T0 035 680 B
   Component: RNS-MID       H06 5274
   Revision: AB001001    Serial number: SKZ6Z7L6131060
   Coding: 00000000000000000000
   VCID: 372BD7F26F4B6943A28-8062
   Subsystem 1 - Part No: 1T0 919 859 C
   Component: EU East V13  8286
                    Reset counter: 206
                    Mileage: 188424 km
   Component: J386  TUER-SG FT    1123
   Revision: 32008001    Serial number: 00000534388227
   Coding: 0000053
   Shop #: WSC 77101 662 370085
   VCID: 3B23CBC25F634D23460-806E
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Reset counter: 206
                    Mileage: 188428 km
                    Fault Status: 01100101
                    Reset counter: 206
                    Mileage: 188428 km
   Part No SW: 5N1 909 144 L    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.309 0802
   Revision: 1AH03729    Serial number: 00111240243301
   Coding: 0000258
                    Fault Status: 11101101
                    Reset counter: 206
                    Mileage: 188428 km
                    Date: 2020.08.23
                    Time: 22:35:31
                    (no units): 4.0
                    Voltage: 11.10 V
   Component:    KSG PQ47 ELV 043 0631
   Coding: 0091020052830E76300494157C084F0B607C01
   Component: EZE_2         H41 1614
   Coding: 00000008
   VCID: 6FBB2F92579BE183BA8-803A
   Subsystem 1 - Part No SW: 3AA 919 204 A    HW: 3AA 919 204 A
   Component: Analoguhr  004 0003
   Part No SW: 3AA 959 702 A    HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0533
   Revision: 14110009    Serial number: 0002870101
   Coding: 0200B6
   Shop #: WSC 05311 115 00000
   VCID: 3635DAF668C1904BB9E-8062
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C0 959 704     HW: 3C0 959 794   Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  004 0407
   Serial number: 00000002172929
   Coding: 000090
          B11EC 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 206
                    Mileage: 188428 km
                    Date: 2020.08.23
                    Time: 22:35:31
   Part No SW: 3AA 907 801 E    HW: 3AA 907 801 E
   Component: J540 EPB4  VW-55183 0007
   Revision:   H18       Serial number: 00000000354060
   Coding: 0022067
   VCID: 3333E3E2773385639E0-8066
                    Reset counter: 206
                    Mileage: 188428 km
                    Date: 2020.08.23
                    Time: 22:35:31
                    Voltage: 11.10 V
                    Count: 104
                    Hex Value: 0x1260
                    Hex Value: 0x0001
                    Hex Value: 0x0101
                    Reset counter: 206
                    Mileage: 188424 km
   Component: Batt.regelung H41 1614
   Coding: 030B185A
   VCID: 71BF29EA41AFF773ACC-8024
   Subsystem 1 - Part No SW: 1K0 915 181 F    HW: 1K0 915 181 A
   Component: J367-BDM  H07 0150
   Serial number: 00000000009370471454
Address 77: Telephone (J412)       Labels:| 3C8-035-730-A.clb
   Part No SW: 5N0 035 730 D    HW: 5N0 035 730 D
   Component: Telefon       009 0511
   Revision: --------    Serial number: 35909603160931
   Coding: 020000000000001000000000
   Shop #: WSC 00015 115 08193
   ASAM Dataset: EV_UHVPremi A01005
   ROD: EV_UHVPremi_A01.rod
   VCID: 290F018AA97FCFB324C-807C
End----(Elapsed Time: 01:37, VBatt start/end: 11.1V/11.1V. VIgn 11.1V)-----
South Molton, UK
Are you 100% sure the rear sensors are the correct part, and that they are genuine (not CRAP)?
On many models the rear sensors have different part numbers depending on the options (such as Park Assist) - so worth checking the correct part numbers for your specific VIN not just generic parts for your model.
South Molton, UK
Passat B7 has only one possibility for rear sensors, suitable for with and without Park Assist.
Still leaves the possibility of (Chinese Replacement Auto Parts)?
The disconnect test done by OP IMHO means the wiring is OK.
