Audi A6 2012, high beam assist adaption
LN-TAL
Norway
C?ID=13729
Hi there,
Audi A6, 2012. I think the high beam assistant is a bit slow in turning on high beam lights again. It takes too long time after we have passed the other car berfor it switches on the high beam again. Is it possible to adjust this somewhere with VCDS ?
Also, when driving in drifting snow in norway, it refuses to turn on high beam. Probably due to reflection in the snow. But I think the sensitivity is a bit high.
Monday,23,February,2015,19:12:51:41099
VCDS Version: 15.2.0.0
Data version: 20150130
VIN: WAUZZZ4GXCN05XXXX   License Plate: AUDI A6
Mileage: 77556km-48191mi   Repair Order:
Chassis Type: 4G (4G0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 18 19 20 28 34 3B 3C 42 44
          46 47 52 53 55 56 5F 62 69 72 82 85 8B 8E 8F 90
VIN: WAUZZZ4GXCN05XXXX   Mileage: 77556km-48191miles
Address 01: Engine (J623-CDUC)       Labels: Redir Fail!
   Part No SW: 4G0 907 401 F    HW: 4G0 907 401
   Component: 3.0TDI EDC17  H37 0004
   Revision: 53H37---
   Coding: 1225401A057601020000
   Shop #: WSC 09667 001 1048576
   ASAM Dataset: EV_ECM30TDI0114G0907401F 001004
   ROD: EV_ECM30TDI0114G0907401F.rod
   VCID: A600BC07D9470608B9-80F3
Address 02: Auto Trans (J217)       Labels: 0B5-927-156.clb
   Part No SW: 4G1 927 156 B    HW: 0B5 927 156 F
   Component: 0B5 30 TDIRdW H10 0001
   Revision: --H10---    Serial number: 0000000313
   Shop #: WSC 02311 785 00200
   ASAM Dataset: EV_TCMDL501 A02087
   ROD: EV_TCMDL501.rod
   VCID: AC144E2FC7AB3C586F-80F9
Address 03: ABS Brakes (J104)       Labels: 4G0-907-379.clb
   Part No SW: 4G0 907 379 G    HW: 4G0 907 379 G
   Component: ESP PREMIUM   H09 0250
   Coding: 27A6C701E465E380EB00
   ASAM Dataset: EV_ESPPremiAU57X 004017
   ROD: EV_ESPPremiAU57X_AU57.rod
   VCID: B5226B4B14E17D9000-80E0
   Part No SW: 4H0 907 064 BN    HW: 4H0 907 064 BN
   Component: BCM2 2.0      H31 0330
   Coding: 01A93006000000000000
   Shop #: WSC 02391 785 00200
   VCID: F6A0AC4741673688C9-80A3
   Part No SW: 4G0 820 043 K    HW: 4G0 820 043 K
   Component: KLIMA 4 ZONEN H11 0062
   Serial number: 15091100040250
   Coding: 361200783C
   ASAM Dataset: EV_AirCondiComfoUDS 002033
   ROD: EV_AirCondiComfoUDS.rod
   VCID: A71EB103DE4D1F0082-80F2
Address 09: Cent. Elect. (J519)       Labels: 4H0-907-063.clb
   Part No SW: 4H0 907 063 BG    HW: 4H0 907 063
   Component: BCM1 2.0      H12 0100
   Revision: 11012002    Serial number: 00000001213626
   Coding: 0907201009749FE28981008300001800CF9CE7082E080101000108542F01
   VCID: EE90842739370E4801-80BB
   Subsystem 1 - Part No SW: 4G1 955 119     HW: 4G8 955 119
   Component: WWS57X 110830  H35 0051
   Coding: 0045F7
   Component: RLS  H04 0003
   Coding: 02512B
   Subsystem 3 - Part No SW: 4G0 941 531 G    HW: 4G0 941 531 G
   Component: E1 - LDS  H07 0044
   Subsystem 4 - Part No SW: 4H0 907 472 B    HW: 4H0 907 472 B
   Component: A31 LED Mod1L  H03 0006
   Coding: 110000
   Subsystem 5 - Part No SW: 4H0 907 472 B    HW: 4H0 907 472 B
   Component: A27 LED Mod1R  H03 0006
   Coding: 110000
   Subsystem 6 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Component: AQ_Hum_Sensor  H02 0002
Address 10: Park/Steer Assist (J791)       Labels: 4H0-919-475-7X5.clb
   Part No SW: 4H0 919 475 P    HW: 4H0 919 475 E
   Component: PARKHILFE PLA H06 0030
   Revision: --------    Serial number: 56261122100635
   Coding: 992B08
   ASAM Dataset: EV_EPHVA2CAU57X0000 002008
   ROD: EV_EPHVA2CAU57X0000.rod
   VCID: BFCE096326DDB7C0DA-80EA
Address 13: Auto Dist. Reg (J428)       Labels: 4H0-907-561.clb
   Part No SW: 4G0 907 561     HW: 4G0 907 561
   Component: ACC3          H15 0160
   Coding: 3F04010202
   ASAM Dataset: EV_AdaptCruisContrAU57X 001003
   ROD: EV_AdaptCruisContrAU57X.rod
   VCID: E79EF1031ECDDF0042-80B2
Address 15: Airbags (J234)       Labels: 4H0-959-655.clb
   Part No SW: 4H0 959 655 C    HW: 4H0 959 655 C
   Component: Airbag10.43   H40 0040
   Revision: --------    Serial number: 003JG0046NF0
   Coding: 30323436313330303339554A304C34473053
   ROD: EV_AirbaAU10BPAAU64X_AU57.rod
   VCID: B6206C4709E7768809-80E3
   Serial number: 3575HRB405T0OPMG6G6D
   Serial number: 3585HRB40650Q3SKG1AN
   Serial number: 3515JRB40690NHDIDHO0
   Serial number: 3525JRB40530NHDGFHBO
   Serial number: 3554VRB405D0NI3IC0DN
   Serial number: 3564VRB405D0NI3I4HH.
Address 16: Steering wheel (J527)       Labels: 4H0-953-568.clb
   Revision: --------    Serial number: 90372KIG0017A
   Coding: 0000FD
   VCID: B73E614306ED8F8012-80E2
   Subsystem 1 - Part No SW: 4G0 951 528 A    HW: 4G0 951 528 A
   Component: E221 - MFL  H08 0009
Address 17: Instruments (J285)       Labels: 4H0-920-xxx-17.clb
   Part No SW: 4G8 920 931 J    HW: 4G8 920 931 J
   Component: TDieRdwAcc    H79 0375
   Revision: 26181120    Serial number: 658200911593034
   Coding: 138611001F150008000000
   ASAM Dataset: EV_RBD4K 004040
   ROD: EV_RBD4K.rod
Address 18: Aux. Heat (J364)       Labels: 8R0-265-105.clb
   Part No SW: 4H0 265 105 E    HW: 4H0 265 105 E
   Component: Standheizung  H24 0250
   Revision: 66006006    Serial number: 20110804225306
   Coding: 5D3B00
   VCID: A404A60FA77BF418A7-80F1
   Part No SW: 4G0 907 468 E    HW: 4G0 907 468 A
   Component: J533--Gateway H08 0213
   Revision: --------    Serial number: 00000000244812
   Coding: 00CD077D00
   ROD: EV_GatewUDS_AU57.rod
   VCID: B2285057E58F6AA825-80E7
   Subsystem 1 - Part No SW: 8X0 915 181     HW: 8X0 915 181
   Component: J367-BDM  H07 0140
   Serial number: 00000000005650457450
   Voltage stabilizer:
Address 20: High Beam Assist. (J844)       Labels: 8K0-857-511.clb
   Part No SW: 8K0 857 511 E    HW: 8K0 857 511 A
   Component: FLA           H04 0004
   Revision: AA001002
   Coding: 04018264747464545425363E
   VCID: B3265553129563A02E-80E6
Address 28: HVAC, Rear (E265)       Labels: 4G0-919-158.clb
   Part No SW: 4G0 919 158 C    HW: 4G0 919 158 C
   Component: KLIMA FOND    H07 0062
   Serial number: 13091100040404
   Coding: 01
   ASAM Dataset: EV_ClimaContrUnitRearUDS 002015
   ROD: EV_ClimaContrUnitRearUDS.rod
   VCID: AF2E5923F6BD47404A-80FA
Address 34: Level Control (J197)       Labels: None
   Part No SW: 4G0 907 553 C    HW: 4G0 907 553
   Component: LUFE-DAEMPFER H17 0779
   Coding: 008003
   ASAM Dataset: EV_AirSuspe 003022
   ROD: EV_AirSuspe_AU57.rod
   VCID: AB164D33C2A53B6066-80FE
   Part No SW: 4G0 907 637 B    HW: 4G0 907 637 B
   Component: SARA 6D       H02 0004
   Revision: --------    Serial number: EJ1BPA42021N8Y0
   ASAM Dataset: EV_SARA 006014
   ROD: EV_SARA.rod
   VCID: AD12432BFCB1355078-80F8
   Part No SW: 4G0 907 566 D    HW: 4G0 907 566
   Component: J769  SWA MasterH02 0020
   Revision: 00H02000    Serial number: 6PZ 010 287-03
   Coding: 0010102
   VCID: B02C5A5F238358B853-80E5
   Subsystem 1 - Part No: 4G0 907 568 D
   Component: J770  SWA Slave H01 0020
   Subsystem 2 - Serial number: 6PZ 010 287-23
   Subsystem 3 - Serial number: 5F21.09.1100H010003CF20338ˇ
   Subsystem 4 - Serial number: F20338ˇ
   Part No SW: 4G8 959 793 D    HW: 4G8 959 793
   Component: TSG FA        H05 0212
   Coding: 011F16205000628002080013
   Shop #: WSC 02312 785 00200
   VCID: C1CA0F9B5829C130AC-8094
Address 44: Steering Assist (J500)       Labels: 8K0-909-144.clb
   Component: RCEPS         H35 0010
   Revision: 00001000    Serial number: 0006160872
   Coding: 101101010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS.rod
Address 46: Central Conv. (J393)       Labels: 4H0-907-064-46.clb
   Revision: 00002001    Serial number: 0159077062
   Coding: 0100062020B90494832009042E0104000000000000000000000000000000
   Subsystem 1 - Part No SW: 4G9 959 591     HW: 8V3 959 591
   Component: J245 PS20.006  H02 0007
   Coding: 001F00
   Subsystem 2 - Part No SW: 4G9 959 591     HW: 8V3 959 591
   Component: J394 PS20.006  H02 0007
   Coding: 180800
   Revision: CJ007000    Serial number: 00000000023539
   Coding: 030000
   Shop #: WSC 09670 001 1048576
   VCID: 9D7293EB8411C5D0E8-80C8
   Part No SW: 4G8 959 792 E    HW: 4G8 959 792 A
   Component: TSG BF        H05 0212
   Coding: 011F16205000628002080002
   Part No SW: 4H0 907 801 E    HW: 4H0 907 801 A
   Component: EPB-4         H03 0012
   Revision: --------    Serial number: 00000000141261
   ROD: EV_ParkiBrake_AU48.rod
   VCID: AA184837CD5F22689D-80FF
Address 55: Headlight Range (J431)       Labels: None
   Part No SW: 4H0 907 357 A    HW: 4H0 907 357 A
   Component: ....LWR12.... H02 0013
   Serial number: 110927-0002-072
   Coding: 11226F601002A300
   ROD: EV_HeadlRegulBasic.rod
   Part No SW: 4G1 035 053 E    HW: 4G1 035 053
   Component: Radio U Basic H41 0093
   Revision: AB001007    Serial number: 049IY0BB023405
   Coding: 010003010000000001
   VCID: A10AAF1BB869E130CC-80F4
   Part No SW: 4G0 035 666 G    HW: 4G0 035 666
   Component: H-BN-EU       H47 0484
   Revision: --------    Serial number: 426I00B7613577
   Coding: 050100010003FFED3D30EB3E00000003E80101020000000000
   VCID: AC144E2FCFAB3C586F-80F9
   Subsystem 1 - Part No: 8R0 060 884 N
   Component: EUR 2011  1205
   Subsystem 2 - Part No SW: 4G0 919 605 A    HW: 4G0 919 605 A
   Component: DU8 C7 SV  H42 0021
   Subsystem 3 - Part No SW: 4G1 919 610 C    HW: 4G1 919 610 A
   Component: E380 BDT C7  H08 0204
   Component: CD-Database  3371
   Part No SW: 4G8 959 795 E    HW: 4G8 959 795 A
   Component: TSG HL        H04 0212
   Coding: 010F14204000628002080002
   VCID: C4C4068F473BD41887-8091
Address 69: Trailer (J345)       Labels: None
   Part No SW: 4G8 907 383     HW: 4G8 907 383
   Component: Anhaenger     H07 0072
   Revision: 5G001002    Serial number: 00000133243781
   Coding: 0109080000000000
   VCID: F1AA9F5B280911B01C-80A4
   Component: TSG HR        H04 0212
Address 82: Heads Up Display (J898)       Labels: 4G0-919-604.clb
   Part No SW: 4G0 919 604 G    HW: 4G0 919 604 G
   Component: HeadUpDisplay 005 0106
   Coding: 470000
   ASAM Dataset: EV_HUDContiC7 001020
   ROD: EV_HUDContiC7.rod
Address 85: On Board Cam. (J852)       Labels: None
   Part No SW: 4G0 907 217     HW: 4H0 907 217 A
   Component: DPC-SG        H24 0036
   Coding: EA060000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: E582FB0BE4C1CD1070-80B0
Address 8B: Adaptive Cruise 2 (J428)       Labels: 4H0-907-561.clb
   Part No SW: 4G0 907 541     HW: 4G0 907 541
   Coding: 3F04010202
   ASAM Dataset: EV_AdaptCruisContr2AU57X 001002
   ROD: EV_AdaptCruisContr2AU57X.rod
Address 8E: Image Processing (J851)       Labels: 4G0-907-107.clb
   Part No SW: 4G0 907 107 B    HW: 4H0 907 107
   Component: BV-SG         H29 0034
   Serial number: 000040182408117
   Coding: 04C0BB1C1111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7_AU57.rod
   VCID: A502BB0BA4410D10B0-80F0
   Part No SW: 4H0 980 945 B    HW: 4H0 980 945 B
   Coding: 0066E608031F037E070308014240C2010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: B12A5F5BE08951B05C-80E4
   Part No SW: 4H0 980 946 B    HW: 4H0 980 946 B
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
End-------------------------(Elapsed Time: 04:14)--------------------------
LN-TAL
Norway
C?ID=13729
Anybody knows something about this ? I have only found the "speed adaption". I adjusted it down to 40km/h, but still the time from we have passed a meeting car is a bit long before the assistant switch on the high beam again.
Nicoleise
Denmark
C?ID=208110
Hi,
I would suggest, that you change the speed threshold back to 60 km/h, since this is one parameter that helps prevents the HBA from enabling inside city limits. Personally, I would set it to 70 km/h, but VW seems to feel 60 km/h is better.
It not wanting to engage in drifting snow is probably a "feature" not a "bug". For instance, it would not make sense that it engages high beam in dense fog, and drifting snow is basically often like stronger reflecting fog. :) The time from passing another car I believe is a safety feature, that prevents "flicker" both for other road users and yourself. I'm really not sure how many adaptation options the control unit contains, but generally speaking there is often reason behind the default parameters :) Also, these are obviously quite limited systems, all they use is a poor camera to try and access whether or not some lighting setup is applicable. Ideally for instance, it should track vehicle headlights (even if one bulb is out), but should also not make a "false alarm" on two road marker poles set up in a bend in the road.
I know that it is a general issue with both HBA and DLA, that these systems are in their infancy. I would personally never buy HBA for the very same reason, and DLA isn't much better and seems to differ very much from model to model - for instance in Audis with MatrixLED, it makes alot of errors like dimming down a zone because a marker pole or sign is there, and in Opel Insignias, it will some times even turn down the highbeam for nothing at all. It seems really nice in concept, but I haven't been fortunate enough to witness a system that can make it through even short night trips without making mistakes.
Many regards,
Nicolai
LN-TAL
Norway
C?ID=13729
Hi Nicolai,
there is no city around here. We are living at a small place with aprox. 300 people, and the rest is forrest. The roads are small, little traffic, sharp turns, and if the setting is at 68 km, like it was, then this function is completely useless. You are almost never up to this speed around here in the winter. And this is also the reason why I wanted to reverse the logic on the start/stop system. If you come to a complete stop in this area, it is just to let one car pass, and the stop will probably last for less than 5 sec. So again: the system is completely useless, and only wear out the starter motor and battery.
LasseTheDude
Norway
C?ID=247880
Hi. What type of headlights do u have? Led or bixenon? Because ur assist is coded for led lights. Xenon should be 02 in byte 00 ;)
I live in Norway too (Drammen) and have retrofitted HBA to my Superb 2 FL with very good results!
I have set the limit to turn the highbeam on at 25 km/h and off at 20 km/h.
Very happy. Bixenon with halogen and a rigid industries led bar :)
Hi Nicolai,
LN-TAL: Hello. I don't have your car, but I was able to "reverse the logic on the start/stop system" on my car recently by installing a simple electronic device onto the centre console switch. Not difficult to build and install (only needs rudimentary soldering skills).
Anyhow, if you are interested, you can find details HERE. If you have access to the WD for your car, the arrangement for the SS disabler switch might be similar to the mk7
PS: If you are interested and you aren't confident making the device, PM and I will send-up a completed switch
LN-TAL
Norway
C?ID=13729
My assist is coded with LED because I have led :)
LN-TAL
Norway
C?ID=13729
Hi. very interesting. But I found this procedure on another forum. Have not tested it yet, nut it should not hurt to test ?
Try with VCDS
09 - Central elektric
Login 20113
Adapt channel 34
-4 SS at ignition on off
+4 SS always off
+32 last status SS after ignition off
LN-TAL
Norway
C?ID=13729
I can confirm that the above mentioned procedure does work (at least for me). Remember that this is a system that the car is built with and approved with (VW and diesel engines are known to be very..., approved, he he) and this coding is only for testing purposes :)
