Why does my car feel more responsive after a fault code reset?
   #21
kpm
C?ID=342561
Hi, sorry for delay life got in the way as it often does. Here is full auto scan. I read about fuel trims, but I can't find them in advanced measuring values under 'fuel','obd','oxygen','lambda'. Are they in the engine module? What are they called?
Saturday,26,September,2020,17:37:52:42375
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 52 55 5F BB BC
VIN: WAUZZZ8V   Mileage: 208083km-129296miles
Address 01: Engine (J623-CUNA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 EP    HW: 04L 907 309 A
   Component: R4 2,0L EDC   H22 7539
   Revision: 81H22---
   Coding: 02190012032501082000
   Shop #: WSC 29392 003 1048576
   ASAM Dataset: EV_ECM20TDI01104L906021EP 002008
   ROD: EV_ECM20TDI01104L906021AE.rod
   VCID: 77ABE8D7FF471CC3639-8022
   Part No SW: 5Q0 907 379 L    HW: 5Q0 907 379 G
   Component: ESC           H31 0471
   Revision: 00000000    Serial number: 62004000002468
   Coding: 12F18AA234230A74017E060241CB2948512C5080608294F4026100788608
   ROD: EV_Brake1UDSContiMK100IPB_033.rod
   VCID: 45D7521FF52BBE53215-8010
   Component: AC Automat    H13 0052
   Revision: 20026000    Serial number: 00000000387850
   Coding: 03100104002000011000000000001100
   Shop #: WSC 06314 790 00021
   VCID: 33331CC7ABBF30E39F1-8066
   Serial number: 0319CD37000000000001
329988 - Motor for Defroster Flap
          B1090 71 [008] - Actuator stuck
                    Reset counter: 68
                    Mileage: 207069 km
                    Date: 2020.08.27
                    Time: 09:53:45
                    Voltage terminal 30: 11.7 V
                    Interior temperature: 15.4 °C
                    Outside air temperature: 17 °C
                    Defroster flap: specified value: 35
                    Defroster flap: actual value: 0
                    Defroster flap: actual value: 0.0 %
   Part No SW: 5Q0 937 084 AJ    HW: 5Q0 937 084 AJ
   Component: BCM MQBAB H   H18 0134
   Serial number: 01011419804312
   Coding: 07040A46C24322FD03844004B31C07A80000000000000000000000000000
   ROD: EV_BCMBOSCH_013.rod
   VCID: 0059830BAA895B7B523-8054
   Subsystem 1 - Part No SW: 8V2 955 119 A    HW: 8V2 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 140713  041 0580
   Serial number:         140716220904
   Coding: 0A47F7
   Serial number: 63282863
   Coding: 02006C
   Subsystem 3 - Part No SW: 8V0 941 531 AE    HW: 8V0 941 531 AE
   Serial number: 26 01 2016  00001031
   Serial number: 000000000ZY141681KG4
   Serial number: 00000000000030264090
Address 10: Park/Steer Assist (J791)       Labels:| 5Q0-919-283.clb
   Part No SW: 5Q0 919 283 E    HW: 5Q0 919 283
   Component: PARKHILFE 4K  H10 0051
   Revision: --------    Serial number: 39231420400990
   Coding: 0000050001
   ASAM Dataset: EV_EPHVA14AU3700000 002022
   VCID: 3B2334E783EFF8A3471-806E
   Part No SW: 5Q0 959 655 N    HW: 5Q0 959 655 N
   Component: AirbagVW20    011 0361
   Serial number: 003M2R07T4KS
   Coding: 98CCC0000C0000005C5400CA00C800000065
   ROD: EV_AirbaVW20SMEVW37X_VW48.rod
   VCID: 4BC36427D34F4823F71-801E
   Subsystem 1 - Part No SW: -----------    HW: 480 001 607 14
   Serial number: 357670000003EAD0001Q
   Subsystem 2 - Part No SW: -----------    HW: 480 001 607 14
   Serial number: 35867000000DDAD0001-
   Subsystem 3 - Part No SW: -----------    HW: 480 402 107 14
   Serial number: 3516502C515F3C34B23C
   Subsystem 4 - Part No SW: -----------    HW: 480 402 107 14
   Serial number: 3526502C515F3C324166
   Subsystem 5 - Part No SW: -----------    HW: 480 401 706 14
   Serial number: 35565029D1697520A136
   Pedestrian Protection Driver:
   Subsystem 6 - Part No SW: -----------    HW: 480 400 807 14
   Component: PedP_Sensor_D  001 6149
   Serial number: 2286502C11656B83C307
   Subsystem 7 - Part No SW: -----------    HW: 480 400 807 14
   Component: PedP_Sensor_P  001 6149
   Serial number: 2296502C11656B8393CH
   Pedestrian Protection Center:
   Subsystem 8 - Part No SW: -----------    HW: 480 400 807 14
   Component: PedP_Sensor_C  001 6149
   Serial number: 23065029B1656B853287
   Part No SW: 8V0 953 521 BM    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 17071408490481
   Coding: A408
   ROD: EV_SMLSKLOMQB_009_AU37.rod
   VCID: 0655951388AD754B68F-8052
   Part No SW: 8V0 920 971 E    HW: 8V0 920 971 E
   Component: KOMBI         H02 4291
   Coding: 27A509002B8026000100EA001000000000000000
   VCID: 3FDB40F797F7E4836B9-806A
   Part No SW: 5Q0 907 530 T    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1188
   Revision: --------    Serial number: 0002290549
   Coding: 030100040F0876005B000248080B00000001010000000000000000000000
   ASAM Dataset: EV_GatewLear 011016
   ROD: EV_GatewLear_011.rod
   VCID: 42DD4903E405896B047-8016
   Subsystem 2 - Part No SW: 8U0 951 528 A    HW: 8U0 951 528 A
   Serial number: 12 07 2014  D0038904
   Serial number: 3110563903
   Serial number: 14071403110089
   Coding: 00108E204001040000001002
   VCID: 40D9430BEA099B7B123-8014
   Component: EPS_MQB_ZFLS  122 1043
   Coding: 8103
   ROD: EV_SteerAssisMQB_010.rod
   VCID: 41DF460FE10392731DD-8014
   Serial number: 12071404080092
   Coding: 001086204C01040000001002
   Coding: 019C000001000000
   VCID: 75B7E2DFE54B6ED3715-8020
Address 5F: Information Electr. (J794)       Labels:| 8V0-035-MIB-STD1.clb
   Part No SW: 8V0 035 874 B    HW: 8V0 035 874 B
   Component: MU-S-ND-ER    041 0420
   Serial number: A7F01907140514
   Coding: 01730301FF0A000021111101000A00002F0004460100010006
   ASAM Dataset: EV_MUStd4CPASE 002018
   ROD: EV_MUStd4CPASE_VW37.rod
   Subsystem 1 - Part No SW: 8V0 919 866 B    HW: -----------
   Component:  ECE 2014  --- 0036
   Subsystem 2 - Part No SW: 8V0 919 603 C    HW: 8V0 919 603 C
   Component: DU Std  H49 0013
   Serial number: AUZ8Z9EY304V8J
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 8V0 919 614 P    HW: 8V0 919 614 P
   Component: ControlUnit_B  H41 0054
   Serial number: C1000007061400020173
   Part No SW: 5Q0 959 595 B    HW: 5Q0 959 595 B
   Component: TSG HFS       020 0025
   Serial number: 11071401100167
   Coding: 000086204001040000001002
   Component: TSG HBFS      020 0025
   Serial number: 11071402090166
End----(Elapsed Time: 01:27, VBatt start/end: 12.3V/11.9V. VIgn 11.9V)-----
Thanks, Kris
   #22
Since you had not posted an Auto-Scan when you originally asked this question, I did not realize you had a diesel engine. The concept of "fuel trim" doesn't apply to diesels.
Gasoline engines control power by controlling airflow using a throttle and then the engine management provides an appropriate amount of fuel, which is "trimmed" based on feedback from various sensors, primarily the oxygen sensor(s) in the exhaust.
Diesel engines do not control power by restricting airflow using a throttle. The control power by controlling the amount of fuel injected. Traditionally, they had completely unrestricted airflow, but this resulted in lots of excess air under part-load conditions and thus high NOx emissions. So what they do now is to substitute oxygen-depleted exhaust gasses for air to try to minimize those NOx emissions, but they still don't trim fuel; instead they effectively trim air.
However, diesels have various other "learned values" that are cleared/reset when you clear fault codes.
