I did a some work on the car during previous weeks: replaced battery, replaced front brake discs and pads (rear i will do one of these days), replaced petrol and LPG injectors (so no more hard starting in warm condition now, no more petrol smell while hot starting and no more problems with bad exhaust gas values: it is now simply running great), ... so a lot of things have been disconnected and a lot of DTC's have been stored.
Auto scan was completed succesfully after these works, but offcourse it was full of stored DTC's so i cleared them and made a new one today after approx. 260 KMs (approx. 175 miles) of driving: plse see below.
Offcourse this 17y old car still has some issues (f.e. further tweaking of LPG corrections, ...), but most important for now is a binding/shaking feeling in slow, hard cornering in high gear (driving forward or backward), much better or even abcent in low gear.
Following 2004 VW tech bulletin (nr. 04-02) i think that i should consult VW to check software in Transfer Box control module ...
Some extra info on scan: rear seats and safety belts where removed bij previous owner to make room for a large LPG tank: i don't need them, being single, but this perhaps explains some issues on the scan. I will adress to them later, most important remaining problem now is the "binding": any questions or suggestions would be very welcome
Saturday,22,August,2020,16:21:46:30525
VCDS Version: 20.4.2.0 (x64) HEX-V2 CB: 0.4526.4
VIN: WVGZZZ7LZ3D006640 License Plate:
Chassis Type: 7L (7L - VW Touareg (2003 > 11/2006))
Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
VIN: WVGZZZ7LZ3D006640 Mileage: 178910km-111169miles
Address 01: Engine Labels: 022-906-032-BMX.lbl
Part No SW: 022 906 032 BE HW:
Component: MOTRONIC ME7.1.1G 0008
Coding: 0000133
Shop #: WSC 02402 202 05928
VCID: 4FFA8B451BCA5FA39B9-5184
17560 - Long Term Fuel Trim Additive Air; Bank 1; Range 2
P1152 - 001 - System too Lean - Intermittent
Readiness: 0000 0001
Address 02: Auto Trans Labels: 09D-927-750.clb
Part No: 09D 927 750 A
Component: AL 600 6Q 0360
Coding: 0004136
VCID: 2C00FCC94A1C44BBDEB-5160
Address 03: ABS Brakes Labels: 7L0-907-379-MK25.lbl
Part No: 7L0 907 379 A
Component: ESP ALLRAD MK25 0105
Coding: 0014337
Shop #: WSC 31414 000 00000
VCID: 372AD3A5835AF763A39-5184
Address 05: Acc/Start Auth. Labels: 3D0-909-13x-05.lbl
Part No SW: 3D0 909 131 T HW: 5WK 470 21
Component: Kessy 6120
Coding: 0000232
VCID: 323CE2B16838124B947-5184
Component: ELV XXXX
Address 08: Auto HVAC Labels: 7L6-907-040.clb
Part No: 7L6 907 040 D
Component: CLIMAtronic R/L 0302
Coding: 0001020
VCID: 313EEDBD6D3E2953EDD-5184
02100 - Footwell Flap Motor (V261)
Address 09: Cent. Elect. Labels:. 7Lx-937-049-V1.clb
Part No: 7L6 937 049 K
Component: 2701
Coding: 0100452
VCID: 44D0B469C28CACFB36B-5184
Address 15: Airbags Labels: 3D0-909-601.lbl
Part No: 3D0 909 601 B
Component: 4 Airbag 8.4E+ H07 0641
Coding: 0008244
VCID: 221C12F138D882CB647-5184
01739 - Crash Sensor for Front Airbag; Pass. Side (G284)
00654 - Seat Belt Tensioner Igniter; Driver Side (N153)
01212 - Belt Tensioner Igniter; Rear Passenger Side (N197)
002 - Lower Limit Exceeded - MIL ON
01211 - Belt Tensioner Igniter; Rear Driver Side (N196)
011 - Open Circuit - MIL ON
Address 16: Steering wheel Labels: 7L6-953-549.lbl
Part No: 7L6 953 549 B
Component: Lenksäulenmodul 3201
Coding: 0000011
VCID: 3E24C681AC60C62B60F-5184
Address 17: Instruments Labels: 7L6-920-xxx-7LA.lbl
Part No: 7L6 920 880
Component: KOMBIINSTRUMENT RB4 2601
Coding: 0007111
VCID: 74B024A9D2AC5C7B46B-5184
Part No: 6N0 909 901
Component: Gateway K<>CAN 0101
Coding: 0000006
VCID: 70B828B9A6B4605BA23-5184
Address 22: AWD Labels: None
Part No: 0AD 927 755 BE
Component: TRANSFERCASE 0122
VCID: 7F5AFB85EBEA0F232B9-5184
Address 46: Central Conv. Labels: 7L0-959-933.lbl
Part No: 7L0 959 933 C
Component: 4L HSG 3214
Coding: 0000065
Shop #: WSC 03816 202 82061
VCID: 3C20CC89BA7CD43B4EB-4B1E
Subsystem 1 - Part No: 7L0 959 701
Component: Tuersteuergeraet FS 0101
Subsystem 2 - Part No: 7L0 959 702
Component: Tuersteuergeraet BF 0101
Subsystem 3 - Part No: 7L0 959 703
Component: Tuersteuergeraet HL 0101
Subsystem 4 - Part No: 7L0 959 704 B
Subsystem 5 - Part No: 7L0 907 719
Component: Neigungssensor 0018
Subsystem 6 - Part No: 7L6 951 171
Component: A Innenraumsensor 0019
Address 68: Wiper Electr. Labels: 7L0-955-119-V1.clb
Part No: 7L0 955 119 F
Component: Front Wiper 2416
Coding: 0000255
End----------(Elapsed Time: 08:58, VBatt start/end: 14.0V/13.9V)-----------
