VW Sharan 7n.
Mark G
C?ID=37801
Hi all, I'm wondering if any 1 would have an abs module code. Some 1 has changed it now tyre pressure light is showing.. Thanks
Larry Manton
C?ID=112505
Please post a scan of the unit, for further review.
But, tire pressure coincides with wheel speed, hence might post ABS issue when there is actually none.
Also, when weather gets extremely hot or cold, any tire that is right in the boundary of being out of spec will now be out of spec, and post a code when in fact just make sure all are equal, just a thought. Cheaper than buying ABS modules and tire sensors.
Larry
Mark G
C?ID=37801
Sunday,23,August,2020,09:27:10:24344
VCDS Version: 20.4.2.0  HEX-NET CB: 0.4513.4
VIN: WVWZZZ7NZCV025404   License Plate: MICK TP FAULT
Mileage: 194690km-120974mi   Repair Order:
Chassis Type: 7N-VW36 (7N0)
Scan: 01 03 08 09 10 15 16 17 18 19 25 2E 37 42 44 46 4C 4F 52 53
          56 61 62 72
VIN: WVWZZZ7NZCV025404   Mileage: 194690km-120974miles
4C-Tire Pressure II -- Status: Not registered 0001
   Part No SW: 03L 906 018 HH    HW: 03L 907 309 Q
   Component: R4 2.0l TDI   H26 9981
   Revision: 44H26---    Serial number:
   Coding: 0019001A042501080000
   Shop #: WSC 45464 002 1048576
   ASAM Dataset: EV_ECM20TDI01103L906018HH 003016
   ROD: EV_ECM20TDI01103L906018F_VW36.rod
   VCID: F7BE657E4E92DC3EA2-80A2
Address 03: ABS Brakes        Labels: 7N0-614-109.clb
   Part No SW: 7N0 614 109 N    HW: 7N0 614 109 N
   Component: J104   C3 450M VDEF 0021
   Revision: --H07---    Serial number: 00000004991313
   Coding: 0019991
   VCID: B83CA642CB0C13466B-80EC
02757 - Learning Tire Pressures
                    Reset counter: 239
                    Mileage: 194697 km
                    Date: 2015.01.13
                    Time: 16:23:12
                    Hex Value: 0x0000
                    Bin. Bits: 00000000 00000000
                    Voltage: 14.00 V
                    Bin. Bits: 00011111
                    Count: 194
                    Hex Value: 0x0000
03159 - TPMS Functionality in ESP
                    Reset counter: 239
                    Mileage: 194697 km
                    Date: 2015.01.13
                    Time: 16:24:11
                    Hex Value: 0x0000
                    Voltage: 13.00 V
                    Bin. Bits: 00011111
                    Count: 190
                    Hex Value: 0x0000
   Part No SW: 5K0 907 044 FL    HW: 5K0 907 044 FL
   Component: Clima-Sharan  H18 0204
   Revision: 00001003
   Coding: 0200104409
   Shop #: WSC 00020 999 00000
   VCID: FAB87C4A7D80C156DD-80AE
          B10AB F0 [009] - Too Low
                    Reset counter: 239
                    Mileage: 194697 km
                    Date: 2020.08.22
                    Time: 16:23:12
   Part No SW: 5K0 937 086 M    HW: 5K0 937 086 M
   Component: BCM PQ35 M    021 0064
   Revision: BC021001
   Coding: 40180A3B8125F1C0400800C0740081E443511308436D2D626480C72000C1
   Shop #: WSC 00020 790 12345
   VCID: BE30B05A29282D76A1-80EA
   Subsystem 1 - Part No SW: 7N2 955 119 A    HW: 7N2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS    111028  31  0032
   Serial number:         111102183417
   Coding: 004DBD
   Subsystem 2 - Part No SW: 7N0 955 559     HW: 7N0 955 559   Labels: 7N0-955-559.CLB
   Component: RLFS  021 0022
   Serial number: Y11M11D02h09m54s04S1
   Coding: 0280BB
   Subsystem 3 - Part No: 7N0 951 171
   Component: DWA-Sensor 00  002 0205
Address 10: Park/Steer Assist (J446)       Labels:| 1Q0-919-475.clb
   Part No SW: 7N0 919 475 A    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0012
   Revision: --------    Serial number: 28261130700253
   Coding: 108002
   Shop #: WSC 00078 790 12345
   ASAM Dataset: EV_EPHVA18VW4280000 001005
   ROD: EV_EPHVA18VW4280000.rod
   VCID: B93AA34638060A4E94-80EC
   Part No SW: 7N0 959 655 B    HW: 7N0 959 655 B
   Component: VW10Airbag01K H09 0013
   Serial number: 003GFPNJ2S8A
   Coding: 00314B
   ASAM Dataset: EV_AirbaVW10TS6VW428 A01004
   ROD: EV_AirbaVW10TS6VW428.rod
   VCID: BE30B05A21282D76A1-80EA
   Serial number: 3493ETS60A6200B14DDR
   Serial number: 3503ETS60ECF80A14DD6
   Serial number: 3513ETS60542206149D6
   Serial number: 3523ETS603AC2EB149D/
   Serial number: 35540TS60535FF314DDS
   Part No SW: 5K0 953 569 AL    HW: 5K0 953 569 AL
   Revision: --X01---    Serial number: 20190822100024
   Coding: 108A240000
   ASAM Dataset: EV_SMLSNGVOLWS A01004
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 824804AA1550899685-80D6
   Serial number: 10000000000000035163
   Coding: E20000
   Part No SW: 7N0 920 970 E    HW: 7N0 920 970 E
   Coding: 441F01
   Shop #: WSC 00020 999 12345
   VCID: B522AF76141EEE2E70-80E0
   Part No: 7N0 963 271 C
   Component: Zuheizer        051 2730
   Revision: 00051000    Serial number: 09022126000000
   Coding: 0000041
   Shop #: WSC 00020 790 00000
   VCID: B4249272D764F72647-80E0
   Part No SW: 7N0 907 530 P    HW: 1K0 907 951
   Component: J533  Gateway H40 1623
   Revision:   H40       Serial number: 311011F2000146
   Coding: 468203
   Shop #: WSC 12345 288 14403
   VCID: BD32B756242E366EB8-80E8
                    Mileage: 194697 km
                    Date: 2015.01.13
                    Time: 16:23:12
   VCID: EA984C0A0D2071D62D-80BE
   Revision: A1001003    Serial number: 7661181937
   Coding: 020000
   VCID: A91A7306C0A6BACEE4-80FC
   Part No SW: 3C0 035 279 G    HW: 3C0 035 279 G
   Component: RNS315-EU   H35 0263
   Serial number: VWZAZ2L3852401
   Coding: 0400040104000D0000069002
   ASAM Dataset: EV_RNS315EUV2UDS A01004
   ROD: EV_RNS315EUV2UDS.rod
   VCID: A71E753EDEB28CBEF2-80F2
   Component: EUR_W_0038  0038
1048642 - Internal Control Module Memory Check Sum Error
          B2000 42 [009] - General memory failure
          [ECU defect data memory failure]
                    Mileage: 148688 km
                    Date: 2018.09.29
                    Time: 21:33:29
   Part No SW: 7N0 959 793 D    HW: 7N0 959 793
   Component: TSG FA        H04 0400
   Revision:             Serial number: 0000121806666
   Coding: 011406208001411011
   VCID: C3C6C1AE42CA409ECE-8096
   Part No: 7N0 909 144 R
   Component: EPS_ZFLS Kl. 275    3501
   Revision: 00H20000
   VCID: C2C8C4AA9DD04996C5-8096
   Component: EZE_2         H40 1623
   Coding: 050B0500
   VCID: EFAE5D1E3EC294FE7A-80BA
   Component: J245EE20SKB13  H03 0220
   Component: J394EE20SKB13  H03 0220
   Part No SW: 7N0 959 792 D    HW: 7N0 959 792
   Component: TSG BF        H04 0400
   Revision:             Serial number: 0000121564547
   VCID: C2C8C4AA5DD04996C5-8096
   Part No SW: 3AA 907 801 G    HW: 3AA 907 801 G
   Component: J540 EPB4  VW-64783 0009
   Revision:   H19       Serial number: 00000000376537
   Coding: 0024167
   VCID: B522AF76DC1EEE2E70-80E0
   Component: Batt.regelung H40 1623
   Coding: 030F185A
   VCID: F1AA5B6628F6820E6C-80A4
   Component: J367-BDM  H07 0180
   Serial number: 00000000008900957410
Address 62: Door, Rear Left (J388)       Labels:. 7N0-959-794.clb
   Part No SW: 7N0 959 794 E    HW: 7N0 959 795 A
   Component: TSG HL        H03 0400
   Revision:             Serial number: 0000121697192
   Coding: 010004200001411001
   VCID: C5C2DFB64CFE7EAEE0-8090
   Component: TSG HR        H03 0400
   Revision:             Serial number: 0000121697195
End----------(Elapsed Time: 02:29, VBatt start/end: 12.1V/12.1V)-----------
Mark G
C?ID=37801
Any 1 any idea of the proper coding for this abs pump, plz
Hi Mark,
I looked over the 03-ABS coding and believe it is configured correctly but this VIN doesn't show a PR-Code for TPMS type (i.e. 7K0, 7K6, etc) so I cannot confirm it was factory equipped. Due to the coding of address 17-Instruments I suspect indirect 7K6 indirect TPMS was factory enabled.
This RHD CFFB / Manual trans Sharan Blue Motion has a GVL which includes 4C-Tire Pressure II -- Status: OK 0000:
https://forums.ross-tech.com/showth...2-0-BlueMotion&p=109514&viewfull=1#post109514
I suspect someone tinkered with the 19-CAN Gateway [Installation List] function. Please connect to 19, click [Installation List], tick the 4C box and [Save coding]. After doing so inflate the tires properly, reset the indirect TPMS via the button or MFA/cluster menu and try driving the vehicle. If it wont' learn the TPMS values something may be wrong with the wheel speed sensors, wheel bearings, etc. That may be why someone attempted to disable it in the installation list.
P.S. I just checked the PR-Codes on the other Sharan and it did NOT have a 7K? code either. I'm thinking the lack of PR code may be normal and they may all have indirect TPMS?
Mark G
C?ID=37801
Hey Dana thanks. Yes I've changed the coding in 17 the dash to code out the light so it won't be flashing. Also have ticked the 4c box in installation list in 19 can, still no joy. 😭. When I got the car nothing was working on it like parking sensors, blue tooth, esp, abs etc, so I copied codes from a seat alhambra, I can't get my hands on another sharan atm.
Gone But Not Forgotten
Try this yet in ABS Coding: 0019223?
Hi guys,
Mark did you try enabling indirect TPMS in all of the modules at the same time and resetting the system yet? I believe doing so would involve coding:
03 to 0019991
17 to 441F01
19 to 468003 -and- making sure that 4C-Tire Pressure II is registered​
I would imagine a key cycle would be needed before some fault codes clear and you might want to reset TPMS big hammer style in 03 via Basic Settings 042 (rather than MFA or button).
Some vehicles require a test drive before TPMS DTCs will clear, which gives the ABS module time to check plausibility of the speed sensor data, and other models will reset at a stand-still. Either way, a scan in that condition might shed light.
If you still have the goofy TPMS DTCs we might want to check an Adaptation function map from 03. Channel 005 has some interesting notes in the label file and I think 2 = Tire Pressure Management System (TPMS) Plus active (7N0-614-109-* from SW 0020>) would apply.
I think you'll have wrong hand drive codes with Jack's coding but we don't have much on the C3 modules so please report back on his coding suggestion if you test it.
0019223 | 4B17
0019991 | 4E17
Mark G
C?ID=37801
Ill try this when I get the vehicle back. Thanks Dana
