ABS coding (2008 Passat)
Mohammad
Palestine
C?ID=383900
could you please help me coding ABS for vw Passat 2009 CBAB engine
we changed ECU +lock steering +immobilizer
old vin is :WVWZZZ3CZAP006653
NEW vin : WVWZZZ3CZ8P126531
Thursday,20,August,2020,13:22:22:06524
VIN: WVWZZZ3CZ8P126531   License Plate: 00000000
Mileage: 289420km-179837mi   Repair Order:
Chassis Type: 3C-VW46 (3C0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 37 42 44 46 52 53 56 62 72
VIN: WVWZZZ3CZ8P126531   Mileage: 289420km-179837miles
Address 01: Engine (CBA)       Labels: 03L-906-022-CBA.clb
   Part No SW: 03L 906 022 CL    HW: 03L 907 309
   Component: R4 2,0L EDC G000AG  3107
   Revision: --H01---    Serial number: VWZCZ000000000
   Coding: 0000078
   Shop #: WSC 83968 922 673350
   VCID: 71BE2F43FDA88D43ADD-8024
7 Faults Found:
               U1017 - 000 -
                    Mileage: 289423 km
                    Date: 2015.01.11
                    Time: 18:48:01
                    RPM: 782 /min
                    Voltage: 13.60 V
                    Bin. Bits: 11101110
                    Bin. Bits: 00000000
                    (no units): 0.0
009263 - Diesel Particulate Filter (Bank 1)
               P242F - 000 - Restricted/Clogged - MIL ON
                    Fault Status: 11100000
                    Mileage: 289423 km
                    Date: 2015.01.11
                    Time: 18:48:02
                    RPM: 782 /min
                    Pressure: 118 mbar
                    Hex Value: 0xFF01
                    Temperature: 90.0°C
                    (no units): 45.9
               U1017 - 000 -  - MIL ON
                    Mileage: 289423 km
                    Date: 2015.01.11
                    Time: 18:48:03
                    RPM: 782 /min
                    Voltage: 13.53 V
                    Torque: 0.0 Nm
                    Hex Value: 0xFF00
                    Bin. Bits: 11101110
               U1017 - 000 -
                    Mileage: 289423 km
                    Date: 2015.01.11
                    Time: 18:48:03
                    RPM: 782 /min
                    Voltage: 13.38 V
                    Bin. Bits: 11101110
                    Bin. Bits: 00000000
                    (no units): 0.0
000406 - Engine Oil Temp. Sensor (G8)
               P0196 - 000 - Implausible Signal - Intermittent
                    Mileage: 289424 km
                    Date: 2015.01.11
                    Time: 20:47:40
                    RPM: 782 /min
                    Content: 0.0 mm
                    Content: 29.0 mm
                    Temperature: 88.2°C
                    Temperature: 64.8°C
                    Temperature: 92.7°C
001137 - Exhaust Pressure Sensor 1
               P0471 - 000 - Implausible Signal
                    Mileage: 289424 km
                    Date: 2015.01.11
                    Time: 20:55:08
                    Voltage: 13.07 V
                    Pressure: 113 mbar
                    Pressure: 64 mbar
                    Hex Value: 0xFF01
                    Temperature: 54.9°C
                    Mileage: 289424 km
                    Date: 2015.01.11
                    Time: 22:16:30
                    Content: 0.0 mm
                    Content: 0.0 mm
                    Temperature: 82.8°C
                    Temperature: 71.1°C
                    Temperature: 97.2°C
Readiness: 1 1 0 0 1
   Part No SW: 02E 300 050 D    HW: 02E 927 770 AD
   Component: GSG DSG         082 1404
   Revision: 04808020    Serial number: 00000807081540
   Shop #: WSC 00900 730 13594
   VCID: 137245CBA7741F53FF1-8046
Address 03: ABS Brakes        Labels:. 3C0-614-109-C4.clb
   Part No SW: 3C0 614 109 AF    HW: 3C0 614 109 AF
   Component: J104    C4 440 V2   0015
   Revision: --025---    Serial number: 00000795243863
   Coding: 0010000
   Shop #: WSC 00046 000 00000
   VCID: 629C500F284E26DB247-8036
7 Faults Found:
                    Reset counter: 41
                    Mileage: 289424 km
                    Date: 2015.01.11
                    Time: 22:26:47
                    Hex Value: 0x0000
                    Voltage: 12.50 V
                    Bin. Bits: 00011110
                    Count: 150
                    Hex Value: 0x0000
03201 - Adaptation Overboost
                    Reset counter: 41
                    Mileage: 289424 km
                    Date: 2015.01.11
                    Time: 22:26:47
                    Reset counter: 41
                    Mileage: 289424 km
                    Date: 2015.01.11
                    Time: 22:26:47
                    Reset counter: 41
                    Mileage: 289424 km
                    Date: 2015.01.11
                    Time: 22:26:47
                    Reset counter: 41
                    Mileage: 289424 km
                    Date: 2015.01.11
                    Time: 22:26:47
                    Reset counter: 41
                    Mileage: 289424 km
                    Date: 2015.01.11
                    Time: 22:26:47
                    Reset counter: 41
                    Mileage: 289424 km
                    Date: 2015.01.11
                    Time: 22:26:47
Address 08: Auto HVAC        Labels: 3C0-907-044.lbl
   Part No SW: 3C0 907 044 DG    HW: 3C0 907 044 DG
   Component: ClimatronicPQ46 133 0909
   Revision: 00133025    Serial number: 00000000000000
   VCID: 698E4723D5787583E5D-803C
   Revision: 00H54000    Serial number: 00000006056625
   Coding: E1800F0700041A00470A00000F00000000095D435C000120000000000000
   Shop #: WSC 00028 028 00001
   VCID: 3332E54BC734FF539F1-8066
   Subsystem 1 - Part No: 3C1 955 419 A  Labels: 1KX-955-119.CLB
   Component: Wischer 150509 004  0206
   Coding: 00046997
   Shop #: WSC 00028
   Component: RLS     220609 054  0402
   Coding: 00208936
   Shop #: WSC 00028
Address 10: Park/Steer Assist (J446)       Labels:. 3C8-919-475.clb
   Part No SW: 3C8 919 475 A    HW: 3C8 919 475
   Component: PARKHILFE 8K  H07 0009
   Revision: --------    Serial number: 08740915501288
   Coding: 100102
   VCID: 323CE04F342EF65B947-8066
   Part No SW: 5N0 959 655 J    HW: 5N0 959 655 J
   Component: J234__00H VW10 HI   1916
   Revision: 20013000    Serial number: 003E2PBL6KJZ
   Coding: 0012360
   VCID: 44D0B697929A48EB36B-8010
   Subsystem 1 - Serial number: 6332MTS635431319
   Subsystem 2 - Serial number: 6342MTS616381339
   Subsystem 3 - Serial number: 6351HTS6M45LU8KR
   Subsystem 4 - Serial number: 6361HTS6G7L626KR
Address 16: Steering wheel        Labels: 3C0-953-549-SW25.lbl
   Part No SW: 3C0 953 549 AJ    HW: 3C0 953 549 AJ
   Component: J0527               0030
   Revision: 00032000    Serial number: 3C5953507CN
   Coding: 0001511
   VCID: 74B0265782BAB86B46B-8020
   Subsystem 1 - Part No: 3C8 959 537 B  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAP   H4ÿ 0021
   Coding: 00000226
   Part No SW: 3C0 920 872 B    HW: 3C0 920 872 B
   Component: KOMBI         H02 0206
   Coding: 160F00
   Shop #: WSC 00028 790 00207
   VCID: 241016177E5A68EB16B-8070
9453865 - Oil Level Thermal Sensor
          B1041 29 [009] - Signal Implausible
                    Reset counter: 41
                    Mileage: 289424 km
                    Date: 2020.08.20
                    Time: 22:26:46
Address 19: CAN Gateway        Labels:. 3C0-907-530-V3.clb
   Part No SW: 3C0 907 530 L    HW: 3C0 907 951
   Component: J533__Gateway   H13 0152
   Revision:   H13       Serial number: 3300P09609008A
   Coding: FDA07F06400202001002
   VCID: 2A0CF82F10FEBE9B2C7-807E
   Part No SW: 3C0 959 433 R    HW: 3C0 959 433 R
   Component:    IMMO         042 0383
   Shop #: WSC 06402 785 00200
   VCID: 392ED763E558050355D-806C
   Component:    ELV          027 0380
   3C0905861G     ELV          027 0380
Address 37: Navigation (J794)       Labels:| 3C0-035-270.clb
   Part No SW: 3C0 035 270     HW: 3C0 035 270
   Component: RNS310        H12 0212
   Serial number: VWZ1Z2I8037086
   Coding: 000004010400000000000000
   Shop #: WSC 00028 028 00022
   ASAM Dataset: VW_RNS310 A02007
   ROD: EV_VWRNS310UDS.rod
   VCID: 57EA71DB7F8CF373439-8002
   Part No SW: 1K0 959 701 AS    HW: 1K0 959 793 P
   Component: J386  TUER-SG FT    1501
   Revision: 71009005    Serial number: 00000638198616
   Coding: 0004279
   VCID: 7F5AF97BBBFCEB332B9-802A
   Part No SW: 5N1 909 144 K    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.148 0703
   Revision: 1AH03256    Serial number: 00082990047702
   Coding: 0000258
   VCID: 3A2CC86FE05E0E1B5C7-806E
02546 - Steering Limit Stop
                    Fault Status: 11100101
                    Reset counter: 41
                    Mileage: 289424 km
                    Date: 2015.01.11
                    Time: 22:26:47
                    (no units): 4.0
                    Voltage: 12.60 V
                    Reset counter: 41
                    Mileage: 289424 km
                    Date: 2015.01.11
                    Time: 22:26:47
                    (no units): 4.0
                    Steering Angle: 0.00°
                        Not OK
                    (no units): 14
   Component:    KSG PQ46 ELV 042 0472
   Coding: 00910A0001860E763004941570084F0B6078A1
   Part No SW: 1K0 959 702 AS    HW: 1K0 959 792 P
   Component: J387  TUER-SG BT    1501
   Revision: 71009005    Serial number: 00000667498611
   Coding: 0004278
   VCID: 00587A87C60294CB523-8054
   Part No SW: 3C8 907 801 C    HW: 3C8 907 801 C
   Component: J540 EPB3  VW-13618 0005
   Revision:   010       Serial number: 00000000025016
   Coding: 0010000
            000 - - - MIL ON
                    Fault Status: 11110000
                    Reset counter: 21
                    Mileage: 289019 km
                    Date: 2014.12.29
                    Time: 02:36:15
                    Voltage: 13.20 V
                    Count: 43
                    Hex Value: 0x1240
                    Hex Value: 0x0001
                    Hex Value: 0x0101
                    Fault Status: 11111101
                    Reset counter: 41
                    Mileage: 289424 km
                    Date: 2015.01.11
                    Time: 22:26:47
                    Voltage: 12.20 V
                    Count: 71
                    Hex Value: 0x1251
                    Hex Value: 0x0001
                    Hex Value: 0x1010
            000 - - - MIL ON
                    Reset counter: 21
                    Mileage: 289019 km
                    Date: 2014.12.29
                    Time: 02:35:17
                    Voltage: 13.30 V
                    Count: 100
                    Hex Value: 0x1240
                    Hex Value: 0x0001
                    Hex Value: 0x0101
                    Fault Status: 11110101
                    Reset counter: 21
                    Mileage: 289019 km
                    Date: 2014.12.29
                    Time: 02:24:26
                    Voltage: 13.20 V
                    Count: 101
                    Hex Value: 0x1250
                    Hex Value: 0x0001
                    Hex Value: 0x0101
   Part No SW: 1K0 959 703 AB    HW: 1K0 959 795 L
   Component: J388   TUER-SG HL   0308
   Revision: 41004101    Serial number: 00000000966738
   Coding: 0000144
   VCID: 70B82A47F6A2844BA23-8024
   Part No SW: 1K0 959 704 AB    HW: 1K0 959 794 L
   Component: J389   TUER-SG HR   0308
   Revision: 41004101    Serial number: 00000000964720
   Coding: 0000144
End----------(Elapsed Time: 01:19, VBatt start/end: 12.6V/12.6V)-----------
