Audi a1 2011
Gapel3
Australia
C?ID=313356
SOME ONE REPLACED CLOCK SPRING WITHOUT WITHOUT PROPERLY CODING...INSTALL NEW CLOCK SPRING BUT STILL DOESNT COMMUNICATE WITH STEERING ANGLE SENSOR. 5K0 953 569AL ANY ONE CAN GIVE ME RIGHT LONG CODING FOR IT.
Gapel3
Australia
C?ID=313356
Thursday,20,August,2020,16:19:38:39620
VCDS Version: 20.4.1.0 (x64)  HEX-NET CB: 0.4508.4
VIN: WAUZZZ8X8CB011952   License Plate: CTU17D
Mileage: 110000km-68350mi   Repair Order:
Chassis Type: 8X-AU21 (8U0)
Scan: 01 03 05 08 09 10 15 16 17 19 25 2B 42 44 46 52 56 5F
VIN: WAUZZZ8X8CB011952   Mileage: 110000km-68350miles
04-Steering Angle -- Status: Sporadic communication error 1000
Address 01: Engine (J623-CAXA)       Labels:. 03C-906-016-CAX2.clb
   Part No SW: 03C 997 016 K    HW: 03C 906 016 BG
   Component: 1.4l R4/4V TS H08 2467
   Revision: LEH08---    Serial number:
   Coding: 00190032002401000000
   Shop #: WSC 58015 000 1048576
   ASAM Dataset: EV_ECM14TFS01103C997016K 001002
   ROD: EV_ECM14TFS01103C997016K.rod
   VCID: B12A4F91E0B31E0E34-80E4
7249 - No Communications with Steering Angle Sender (G85)
          U0126 00 [040] - -
                    Mileage: 110005 km
                    Date: 2020.08.20
                    Time: 15:12:37
                    Engine speed: 730.00 /min
                    Normed load value: 16.5 %
                    Coolant temperature: 82 °C
                    Intake air temperature: 45 °C
                    Voltage terminal 30: 14.465 V
                    Generator power: 0 W
                    CAN TimeOut meter - gateway-Bits 0-7: 0
                    CAN TimeOut meter - battery manager-Bits 0-7: 0
4714 - Steering Column Control Module
          U0212 00 [047] - No Communications
                    Mileage: 110005 km
                    Date: 2020.08.20
                    Time: 15:20:27
                    Engine speed: 0.00 /min
                    Coolant temperature: 91 °C
                    Intake air temperature: 48 °C
                    Voltage terminal 30: 12.486 V
Readiness: 0110 0101
   Part No SW: 6R0 907 379 BB    HW: 6R0 907 379 AH
   Component: ESP8.2i front H07 0001
   Revision: --------
   Coding: 330448E9236E00B3CC2E12E7C4D300910C00
   Shop #: WSC 00046 000 00000
   VCID: FF4E59A96A67387EF2-80AA
                    Fault Frequency: 8
                    Reset counter: 116
                    Mileage: 110005 km
                    Date: 2020.08.20
                    Time: 14:12:10
                    Hex Value: 0x0007
                    Hex Value: 0x0002
                    Hex Value: 0x30AE
                    Hex Value: 0x1B9D
                    Hex Value: 0x00FF
                    Hex Value: 0x7F7F
                    Hex Value: 0x7F00
                    Fault Frequency: 8
                    Reset counter: 116
                    Mileage: 110005 km
                    Date: 2020.08.20
                    Time: 14:12:10
                    Hex Value: 0x0007
                    Hex Value: 0x0002
                    Hex Value: 0x30AE
                    Hex Value: 0x1B9D
                    Hex Value: 0x00FF
                    Hex Value: 0x7F7F
                    Hex Value: 0x7F00
   Part No SW: 5K0 959 434 A    HW: 5K0 959 434 A
   Component: VWKESSYPQ35GP 085 0802
   Revision: 00085000    Serial number: 0146983423
   Coding: 010E0E
   ASAM Dataset: EV_KESSY_PQ35GP A01018
   ROD: EV_KESSY_PQ35GP.rod
   VCID: B32645991AAF2C1E46-80E6
Address 08: Auto HVAC (J255)       Labels:* None
   Part No SW: 8X0 820 043 A    HW: 8X0 820 043 A
   Component: Klima 1 Zone  H12 0063
   Serial number: 00000000061393
   Coding: 6420680000
   Shop #: WSC 00046 790 00000
   ASAM Dataset: EV_AirCondiFrontAU210 006031
   ROD: EV_AirCondiFrontAU210_006.rod
   VCID: B228409DE5B525164D-80E6
   Part No SW: 8X0 907 063 G    HW: 8X0 907 063 G
   Component: BCM PQ35  M   110 0653
   Revision: 00110 AD
   Coding: 4E000A2FA8051A00201840E02100015451FB6C0A01EF49B2DC088783E045
   VCID: C0CC1A5553198786CB-8094
   Subsystem 1 - Part No SW: 8K0 955 559     HW: 8K0 955 559
   Component: RLS  H04 0003
   Serial number: 11497765
   Coding: 02562D
                    Reset counter: 116
                    Mileage: 110005 km
                    Date: 2020.08.20
                    Time: 15:12:33
                    Voltage: 14.35 V
                        Term 50 On
Address 10: Park/Steer Assist (J446)       Labels:| 8X0-919-475.clb
   Part No SW: 8X0 919 475 F    HW: 8X0 919 475
   Component: PARKHILFE 4K  H03 0032
   Revision: 11001001    Serial number: 37001113901003
   ASAM Dataset: EV_EPHVA14AU21X0000 002004
   ROD: EV_EPHVA14AU21X0000_002.rod
   VCID: C9DA0771682346CE1C-809C
   Part No SW: 8X0 959 655 A    HW: 8X0 959 655 A
   Component: Airbag10.41   H04 0008
   Revision: --------    Serial number: 003JJ002H9J2
   Coding: 30314539303330303037554A305238583053
   ASAM Dataset: EV_Airba1041BPAAU210 001015
   ROD: EV_Airba1041BPAAU210.rod
   VCID: C8DC02757329BFC603-809C
   Serial number: 3554VRB40530I3GU8113
   Serial number: 3575HRB404R0INGS2P7E
   Serial number: 3585HRB40570ISD48GOV
   Rear Impact Crash Sensor:
   Serial number: 3515ZRB40670GR36DPP4
   Part No SW: 5K0 953 569 AL    HW: 5K0 953 569 AL
   Revision: --X01---    Serial number: 20191120200466
   Coding: 1184004000
   Shop #: WSC 01286 386 08256
   VCID: 8248D05D159555969D-80D6
   Subsystem 1 - Part No SW: 4G0 951 528 C    HW: 4G0 951 528 C
   Component: E221 - MFL  H07 0009
   Serial number: 25 05 2011  B0019240
1140738 - Steering angle sensor
                    Reset counter: 76
                    Mileage: 110006 km
                    Date: 2020.08.20
                    Time: 16:10:45
                    UBat: 12.40 V
                    MC1 interner Fehlercode: 0
                    MC2 interner Fehlercode: 0
   Part No SW: 8X0 920 930 C    HW: 8X0 920 930 C
   Component: KOMBI_MEDIUM  H02 0179
   Coding: 71DE00
   ASAM Dataset: EV_Kombi_UDS_VDD_AU10 A04390
   VCID: BA3868BD3DC5DD5685-80EE
   Part No SW: 8U0 907 468 C    HW: 8U0 907 468 C
   Component: GAT 4CAN 2L M H10 0043
   Revision: 1R050020    Serial number: 2041R1152980C4
   Coding: FBCF0064010301010153
   VCID: C2C8105D5D159596DD-8096
   Subsystem 1 - Part No SW: 8X0 959 591     HW: 4H0 959 591
   Component: J245 PS70.017  H07 0006
   Serial number:     WOO12380873
   Coding: 001E00
   Subsystem 2 - Part No SW: 8K0 915 181 H    HW: 8K0 915 181 H
   Component: J367-BDM  H07 0171
   Serial number: 00000000007100178796
   Subsystem 3 - Part No SW: 8K0 959 663     HW: 8K0 959 663
   Serial number: 11172001862011200181
                    Reset counter: 116
                    Mileage: 110005 km
                    Date: 2020.08.20
                    Time: 15:12:34
                    Bin. Bits:    11111
                    Voltage: 14.50 V
                    Count: 6
                    Bin. Bits:    10000
                    Time: 25.40 s
   Component: IMMO          H02 0179
   Coding: 000007
   ASAM Dataset: EV_Immo_UDS_VDD_AU10 A04110
   ROD: EV_Immo_UDS_VDD_AU10.rod
   Part No SW: 5K0 905 861 A    HW: 5K0 905 861 A
   Component: ELV-PQ35      H20 0230
   Revision: 00000000    Serial number: 11000132621005
   Coding: 4100000000000000
   ROD: EV_ELVMarquMPVW36X_VW31.rod
   VCID: AE1054EDF18D01F629-80FA
   Part No SW: 8X0 959 793 D    HW: 8X0 959 793 D
   Component: TSG FA        H09 0409
   Coding: 011E12200101000100
   VCID: CED0346D994D61F649-809A
   Part No: 6R0 423 156 B
   Coding: 11251
   Shop #: WSC 00046
   VCID: AF2E49E96A8708FE22-80FA
   Part No SW: 8X0 959 792 D    HW: 8X0 959 792 D
   Component: TSG BF        H09 0409
   VCID: CDD23361944B5AEE30-8098
   Part No SW: 4G1 035 053 C    HW: 4G1 035 053
   Component: Radio U Basic H41 0079
   Revision: AB001007    Serial number: 049FQ0BB004221
   Coding: 040005020100000002
   VCID: 9F0EB9298E27987E92-80CA
   Part No SW: 8X0 035 754 C    HW: 8X0 035 754
   Component: H-BN-RW       H52 0386
   Revision: --------    Serial number: 437GP0B7505010
   Coding: 0C0A01020008C0E90100032600000001F40000020000000000
   VCID: BB366DB93AFFE45E9E-80EE
   Subsystem 1 - Part No: 8R0 060 884 AE
   Component: ROW 2011  0301
   Subsystem 2 - Part No SW: 8X0 919 604     HW: 8X0 919 604
   Component: DU6 High  H42 0084
   Serial number: 9463FR0B0017275
   Subsystem 3 - Part No: 8R0 060 961 B
   Component: CD-Database  3371
End----------(Elapsed Time: 01:15, VBatt start/end: 12.3V/12.3V)-----------
iichel
Eindhoven, NB, NL
C?ID=284912
Do a basic setting of the G85 and I suspect you're good to go.
Gapel3
Australia
C?ID=313356
Cannot do it...doesn’t letting me do basic setting .error
