T6 charging module? BATTERY NOT CHARGING
invernesspl
C?ID=345478
Hi,
I have just picked up a 2016 T6. The van has been parked up for several months and the battery was completely dead. It jump starts first time, but even after leaving the engine run, the engine dies when jump cables removed. I put a multi-meter on the battery and confirmed there was only 11.6V when engine running, so it is not charging.
I then replaced the battery with a new one, it starts and runs fine, but again it is still not charging.
When I go in to the central electrics there is a fault saying charging circuit module has no signal?
Is there a possibility there is something simple such a fuse blown?
Full code below is from before I replaced the battery with a new one, so many of the faults were down to the battery problem. It is the charging fault I'm trying to diagnose.
Any help would be much appreciated.
on: 00001002
   Coding: 0000000003
   Shop #: WSC 02737 790 50316
   ROD: EV_ClimaT5Basis.rod
   VCID: 73B3DCA41B3F25935E9-8026
13701456 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Steuergerät im Schalttafeleinsatz - kein Signal/Kommunikation]
                    Reset counter: 83
                    Mileage: 34913 km
                    Date: 2020.08.19
                    Time: 00:38:31
   Part No SW: 7E0 937 090 B    HW: 7E0 937 090
   Component: BCM PQ25 Max4 H81 0744
   Revision: B9081001    Serial number: 0982 200160355
   Coding: E0A4303A0A212031002009742C2B8C540F00708F60464D60320400220800
   Shop #: WSC 02737 534 188775
   VCID: 2A0D01C08CF5245B2DF-807E
   Subsystem 1 - Part No SW: 7E0 959 801 P    HW: 7E0 959 801 P
   Component: J386__TSG_FT  003 0653
   Serial number: KU0KU019071662016989
   Coding: 1400B0
   Subsystem 2 - Part No SW: 7E0 959 802 P    HW: 7E0 959 802 P
   Component: J387__TSG_BT  003 0653
   Serial number: KU0KU020071662028142
   Coding: 0400A0
03303 - Response Closing Status of Rear Left Door
                    Reset counter: 65
                    Mileage: 34532 km
                    Date: 2019.06.04
                    Time: 23:43:51
                    Reset counter: 83
                    Reset counter: 83
01598 - Drive Battery Voltage
                    Reset counter: 83
                    Mileage: 34913 km
                    Date: 2020.08.19
                    Time: 00:01:56
   Part No SW: 7E0 959 655 G    HW: 7E0 959 655 G
   Component: VW10Airbag021 H08 0018
   Revision: --------    Serial number: 003V3001GEM4
   Coding: 000000000000000000000000000000003231
   Shop #: WSC 02734 790 50316
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 3A2D31807CD594DB5DF-806E
12670208 - Databus
          [Kombi1-3 Time Out Error]
                    Reset counter: 83
                    Mileage: 34913 km
                    Date: 2020.08.19
                    Time: 00:38:31
12674816 - Databus
          [VIN Time Out Error]
                    Reset counter: 83
                    Mileage: 34913 km
                    Date: 2020.08.19
                    Time: 00:38:31
   Part No SW: 7E0 920 960 S    HW: 7E0 920 960 S
   Coding: 450B010300
   ROD: EV_Kombi_UDS_VDD_RM09_005_VW31.rod
   VCID: 392F2E8C79D39FC3545-806C
9453074 - Fuel Level Sensor 1
          B103E 1B [008] - Resistance Too High
                    Reset counter: 83
9453330 - Outside temperature sensor
          B103F 1B [008] - Resistance Too High
                    Reset counter: 83
9453842 - Oil Level Thermal Sensor
          B1041 35 [008] - Signal high time > maximum
                    Reset counter: 83
12605440 - Databus
          U1201 00 [008] - No Communications
                    Reset counter: 83
   Part No SW: 7E0 909 901     HW: 7E0 937 090
   Component: GW-K-CAN TP20 H81 0744
   Revision: B9081001
   Coding: 042305
   VCID: 6889BBC85279D64BFBB-803C
                    Reset counter: 83
                    Mileage: 34913 km
                    Date: 2020.08.19
                    Time: 00:38:31
   Component: IMMO          H03 1104
   VCID: 6A8DC1C04CF5E45BEDF-803E
13762816 - Databus
                    Reset counter: 83
   Part No SW: 1K8 035 150 L    HW: 1K8 035 150 L
   Component: MU-E-D-ER     055 7067
   Serial number: 07061600011928
   Coding: 065700003C00000041111101008000001F0000C60000010001
   ROD: EV_MUEnt4CGen2LGE_VW32.rod
   VCID: 2E050DD0B09D487BF17-807A
6706 - Databus
          [Instrument cluster: no communication]
                    Mileage: 34913 km
                    Date: 2020.08.19
                    Time: 00:38:30
                    Voltage terminal 30: 11.5 V
                    Network diagnosis-Status: Not available
6714 - Databus
          [VIN: no communication]
                    Mileage: 34913 km
                    Date: 2020.08.19
                    Time: 00:38:30
   Part No SW: 7E0 907 534     HW: 7E0 937 090
   Component: Batt.regelung H81 0744
   Coding: 030B1A73
   Shop #: WSC 02739 790 00000
   Subsystem 1 - Part No SW: 7E0 915 181 K    HW: 7E0 915 181 K
   Serial number: 75410903001607160349
                    Fault Status: 00100011
                    Reset counter: 84
                    Mileage: 34913 km
                    Date: 2020.08.19
                    Time: 00:02:29
02252 - Generator
                    Reset counter: 44
                    Mileage: 34913 km
                    Date: 2020.08.19
                    Time: 00:01:03
End----(Elapsed Time: 01:10, VBatt start/end: 11.7V/11.7V. VIgn 11.6V)-----
invernesspl
C?ID=345478
Just re scanned to give more detail and went in to each fault module as below:
Engine:
Wednesday,19,August,2020,20:25:05:41168
VCDS Version: Release 20.4.1 (x64) Running on Windows 8.1 x64
                Address 01: Engine       Labels: 04L-907-309-V2.clb
Control Module Part Number: 04L 906 056 KA    HW: 04L 907 445
  Component and/or Version: R4 2.0l TDI   H02 4047
           Software Coding: 00114014430401090000
            Work Shop Code: WSC 00000 790 50316
              ASAM Dataset: EV_ECM20TDI03004L906056KA 004003 (VN75)
                       ROD: EV_ECM20TDI03004L906056JS_004.rod
                      VCID: 76B5E5B0084D30BB797-8022
25796 - Body Control Module (Central Electric)
          U0140 00 [039] - No Communications
                    Mileage: 35051 km
                    Date: 2031.01.22
                    Time: 02:14:10
                    Engine speed: 827.00 /min
                    Normed load value: 22.0 %
                    Coolant temperature: 75 °C
                    Intake air temperature: 40 °C
                    Voltage terminal 30: 11.382 V
                    Accelerator pedal travel: raw value: 0.00 %
                    CAN status - engine control module: 0
                    Cruise Control System (CCS): status: main switch off
                    selected gear: Shifting process active
Readiness: N/A
BATTERY REGULATOR:
BATTERY REGULATOR – Status malfunction
Wednesday,19,August,2020,20:19:11:41168
                Address 61: Battery Regul.       Labels: 1K0-907-534.clb
Control Module Part Number: 7E0 907 534     HW: 7E0 937 090
  Component and/or Version: Batt.regelung H81 0744
           Software Coding: 030B1A73
            Work Shop Code: WSC 02739 790 00000
02252 - Generator
                    Reset counter: 44
                    Mileage: 34913 km
                    Date: 2020.08.19
                    Time: 00:01:00
iichel
Eindhoven, NB, NL
C?ID=284912
Looks like the alternaternator is offline/dead.
invernesspl
C?ID=345478
I know thats not unheard of, but the van is quite new and only 20K miles on the clock, so I'm thinking unlikely its the alternator, more likely wiring or a module etc??
Gone But Not Forgotten
Are you going too trace the LIN current track & with load light to alternator and BCM/Gateway/BDM isolated directly & as per WD or overlay to test?
Data BUS too?
Scan is not complete.......
iichel
Eindhoven, NB, NL
C?ID=284912
Yes, it is possible that the LIN wire is somehow disconnected (corrosion, broken wire). Did you have a look at the fuse for the alternator?
Or, als Jack is suggesting, trace the LIN connection.
IIRC, an 'uncontrolled' LIN generator will still give out decent voltages.
IIRC2, a broken LIN alternator fuse will not result in an 'unreachable' error for the battery regulator.
That's why I'm suspecting the alternator itself instead of the wiring.
invernesspl
C?ID=345478
Data BUS too?
I would investigate further the possiility there is a damaged cable, but i'm currently in London and have to get the van back to Wales! Was hoping there may be some things I can try at the side of the road.
Does anyone know if the charging module is affected by any fuses perhaps?
invernesspl
C?ID=345478
Right ok. I've only ever had T5's before so haven't located the alternator fuse yet. (wasn't sure if there was one) Is this located underneath the battery as in the older T5's?
iichel
Eindhoven, NB, NL
C?ID=284912
It should be a rather thick black cable near the battery fuse compartment.
invernesspl
C?ID=345478
A bit more info.
I have just discovered that the instrument cluster has been removed at some point, and badly refitted. This van was bought through an insurance company so there is every chance it was Stolen / recovered.
Is there anything in or behind the instrument cluster that could affect the charging circuit? I'm guessing the thieves needed access to the instrument cluster in order to steal the van?
iichel
Eindhoven, NB, NL
C?ID=284912
I don't think so. The battery regulator is integrated into the BCM and from there there is a wire directly to the LIN generator.
dnoermann
C?ID=358118
All the Big Fuses are in the Fuse box under the Battery.
You need to get the Battery Holder out, than you can open the big plastic box.
There are a lot Fuses and one for the Alternator, it is a 225A Fuse in Position SA1.
You can look there, but it looks more like the Alternator is missing, not Connected or defect.
Since the Battery Regulator inside BCM is only complaining about no connection to generator, we can rule out LIN Bus error/defect in BCM, because on the same LIN Bus the Battery Shunt is connected and that one looks like it is working.
I would assume that when LIN Bus cable to Generator is only missing, that Generator will work in "Safe Emergency" Mode bringing 13.8V allways.
But since you get no Voltage @all i would assume the Generator is defect ...
