00975 Z1 Fault Code for Cabriolet
cschmitz20
Verified VCDS-Lite User
C?ID=385099
Anyone have a cabrio that has had to change out the Z1part which is for the rear window heater? ERWIN shows where it generally is but the area is all enclosed by the top and window. I could not fund anywhere in th erwin manual where it says how to remove it and replace. I changed out the fuse and vcds keeps giving me fault code 00975. Its not a huge deal. I dont want to have to take the window out or take the top apart. Thanks.
What is the full text of the fault? Open Circuit? Short to GND? Or...?
cschmitz20
C?ID=385099
Here it is:
- Heated Rear Window (Z1)
31-10 - Open or Short to Ground - Intermittent"
cschmitz20
C?ID=385099
I replaced the fuse and the fuse is good. The light turns on the climate control and stays illuminated but doesnt work and the code shows.
How about a complete Auto-Scan so people can see exactly what kind of Cabrio this is (there are several VAG models that are called "Cabrio") and how it is equipped.
cschmitz20
C?ID=385099
Sorry should have put that itd an 03 audi a4 cabrio 3.0. I did find the part. I to maneuver the top in such a way so.i.could get to it. Its has a small unit attached to a longer wire that goes down and attaches to a post screw. I will post an auto scan in a bit.
cschmitz20
C?ID=385099
VCDS-Lite
Windows Based VAG/VAS Emulator
Version: Release 1.2
Workshop Code: 000 00000
Self-Diagnosis Log
Wednesday, 19 August 2020, 15:15:04:11085
VIN Number: WAUAT48H63K022250 License Plate:
Mileage: Repair Order:
Chassis Type: 8H - Audi Cabrio B6
Scan: 01,02,03,08,09,0F,11,15,16,17,18,26,36,37,45,46,55,56,57,63,65,67,73,75,76,77
Address 01: Engine Labels: 06C-909-559-ASN.LBL
 Controller: 8E0 909 559 E
 Component: 3.0L V6/5V G 0004
 Coding: 0016584
 Shop #: WSC 00672
 VCID: 370183920655
Readiness: 0000 1100
Address 02: Auto Trans Labels: 01J-927-156.LBL
 Controller: 01J 927 156 FE
 Component: V30 01J 3.0l 5V USA 3031
 Coding: 01001
 Shop #: WSC 03213
 VCID: 749B749E57A3
18161 - Tiptronic Switch (F189): Implausible Signal
 P1753 - 35-10 - - - Intermittent
Address 03: ABS Brakes Labels: 8E0-614-517.LBL
 Controller: 8E0 614 517 G
 Component: ABS/ESP front 2328
 Coding: 04499
 Shop #: WSC 00672
 VCID: 2C2BACFECF13
VCDS-Lite
Self-Diagnosis Log
Wednesday, 19 August 2020, 15:15:05:11085
Page 2
Address 08: Auto HVAC Labels: 8E0-820-043.LBL
 Controller: 8E0 820 043 L
 Component: A4 Klimaautomat 1116
 Coding: 00100
 Shop #: WSC 00672
 VCID: 2A27AAE6C5E7
 41-10 - Blocked or No Voltage - Intermittent
00975 - Heated Rear Window (Z1)
 31-00 - Open or Short to Ground
00825 - Drivers Seat Heating Element (Z6)
00826 - Passengers Seat Heating Element (Z8)
 30-00 - Open or Short to Plus
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.LBL
 Controller: 8E0 907 279 E
 Component: int. Lastmodul USA 0305
 Coding: 00013
 Shop #: WSC 00672
 VCID: 341BB49E1723
Address 15: Airbags Labels: 8H0-959-655-84.LBL
 Controller: 8H0 959 655 B
 Component: Airbag 8.4EC 1015
 Coding: 0010105
 Shop #: WSC 00672
 VCID: 390585AA3041
Address 16: Steering wheel Labels: 8E0-953-549.LBL
 Controller: 8E0 953 549 N
 Component: Lenksáulenmodul 0308
 Coding: 02041
 Shop #: WSC 00672
 VCID: 3E0F96B6296F
01304 - Radio
 49-00 - No Communications
VCDS-Lite
Self-Diagnosis Log
Page 3
Address 17: Instruments Labels: 8E0-920-9xx-8E2.LBL
 Controller: 8H0 920 950 E
 Component: KOMBI+WEGFAHRS. RB4 D16
 Coding: 02201
 Shop #: WSC 03213
 VCID: 2E2FA6F6F90F
 WAUAT48H63K022250 AUZ6Z0B0400950
01304 - Radio
Address 26: Auto Roof Labels: 8H0-959-255.LBL
 Controller: 8H0 959 255 B
 Component: VSG B6 CABRIO 7195
 Coding: 0000000
 Shop #: WSC 02101
 VCID: 351D899A1C59
02000 - Switch Position
 Controller: 8H0 959 760
 Component: Sitzmemory EE H04 X013
 Coding: 00002
 Shop #: WSC 00065
 VCID: F49BF49ED7A3
02010 - Left Entry Assistance Control Module (J572)
 79-10 - Please Check Fault Codes - Intermittent
Address 46: Central Conv. Labels: 8E0-959-433-MAX.LBL
 Controller: 8H0 959 433 C
 Component: Komfortgerát T7B 1412
 Coding: 11788
 Shop #: WSC 00672
 VCID: 341BB49E1723
00955 - Key 1
VCDS-Lite
Self-Diagnosis Log
Page 4
Address 55: Xenon Range Labels: 4Z7-907-357.LBL
 Controller: 4Z7 907 357
 Component: dynamische LWR D09
 Coding: 00070
 Shop #: WSC 00672
 VCID: 047B245E0703
Address 63: Entry Assist,D Labels: None
 Controller: 8H0 959 760 A
 Component: EasyEntry F M H11 X023
 Coding: 00006
 Shop #: WSC 00065
 VCID: 351D899A1C59
Address 73: Entry Assist, P Labels: None
 Component: EasyEntry BF H11 X023
 Coding: 00005
 VCID: 351D899A1C59
01900 - Passengers Seat Fore / Aft Adjusting Motor (V31)
 44-00 - Short Circuit
01794 - Control Module - Incorrect Chassis (VIN) Number
 35-00 - -
End --------------------------------------------------------------------------------------------------
Gone But Not Forgotten
Did you measure the value with meter of rear window defrost directly at "posts" isolated & to see if it took a Schmitz or completes a tone? :rolleyes:
Did you unplug those sensors aforementioned in 0x08 such as G65 or other consumers to see if shared using WD in RTFB to observe tracks yet?
Removed from ignore list........temporarily.
