Greetings,
By all accounts of my research, my 2005 A4 uses the CAN Bus however I get the "Function not supported by the gateway" message when running Auto-detect under Auto-Scan. The scan works if I manually select my chassis, so this is not a complaint per se, just a curiosity question. I am using HEX-V2 and VCDS 20.4.2. Could there be another reason the CAN gateway isn't recognized?
Also, here are the results of my first full scan. Thank you in advance for any help and advice.
Tuesday,18,August,2020,17:44:24:39111
VCDS Version: 20.4.2.0 (x64) HEX-V2 CB: 0.4513.4
VIN: WAUDG68E25A453163 License Plate:
67 69 75 76 77
VIN: WAUDG68E25A453163 Mileage: 166190km-103265miles
Address 01: Engine (AUK) Labels:. 06E-910-559-BKH.clb
Part No SW: 8E0 910 559 D HW: 8E0 907 559 A
Component: 3.2l V6 FSI 0050
Revision: --H16--- Serial number:
Coding: 01040106190F0120
Shop #: WSC 06335 000 00000
VCID: 2E050C9DCC1EC90BF0F-807A
18502 - Intake Manifold Tuning Valve (Bank 1)
P2070 - 006 - Stuck Open
18339 - Coolant Fan Control Module (J293)
P1931 - 007 - Malfunction
18438 - Intake Manifold Flap; Bank 1
P2006 - 006 - Stuck Closed - MIL ON
18439 - Intake Manifold Flap; Bank 2
P2007 - 006 - Stuck Closed - MIL ON
Readiness: 0010 0101
Part No SW: 8E1 910 156 B HW: 09L 927 156
Component: AG6 09L 3,2 FSI USA 0020
Revision: --H01--- Serial number: 0084713
VCID: 2615F4BDE4EE814B08F-8072
Address 03: ABS Brakes Labels: 8E0-910-517.clb
Part No SW: 8E0 910 517 C HW: 8E0 614 517 BB
Component: ESP8 quattro H04 0180
Coding: 0004532
VCID: 270BF9B9E3E49843339-8072
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 AL
Component: A4 Klimaautomat 2728
Coding: 00000
VCID: 6B83C5893A9C7C23971-5184
01312 - Powertrain Data Bus
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 J
Component: int. Lastmodul USA 0303
Coding: 01023
Shop #: WSC 65536
VCID: 392F2FC100401EB355D-4B00
37-00 - Faulty
Address 0F: Digital Radio Labels: 8E0-035-593-XM.lbl
Part No: 8E0 035 593 E
Component: SDAR XM 0080
VCID: 2B030589FA2CBC23D71-508A
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 H HW: 8E0 959 655 H
Component: Airbag 9.41 H10 3230
Revision: 91H10323 Serial number: 0036N0004FY%
Coding: 0032607
VCID: 3C2136D50A622B9B4EB-8068
Subsystem 1 - Part No: 8E0 910 339 B
Component: BF-Gewichtsens. 02 0070
Serial number: 6332DRB401114DA2F
Coding: 00032607
Subsystem 2 - Serial number: 6342DRB40135D32FQ
Subsystem 3 - Serial number: 6352ARB4003E18C4O
Subsystem 4 - Serial number: 6362ARB4003E125DL
Subsystem 5 - Serial number: 63729RB4003D97F9$
Subsystem 6 - Serial number: 63829RB4003E3FBC%
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 Q
Component: Lenksáulenmodul 0601
Coding: 02041
Shop #: WSC 06335
VCID: 41DF4721689046731DD-4B00
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 981 N HW: 8E0 920 981 N
Component: KOMBI+WFS 4 H12 0040
Revision: 0040 Serial number: 00000000000000
Coding: 0021261
Shop #: WSC 05152 444 83926
VCID: 38292AC53E4A07BBAA3-5184
Address 25: Immobilizer Labels: 8E0-920-9xx-8EC.lbl
Coding: 0021261
Address 36: Seat Mem. Drvr Labels: 8E0-959-760.lbl
Part No: 8E0 959 760
Component: Sitzmemory R2 F 0305
Coding: 00002
VCID: 71BFD7E1188096F3ADD-4B3C
01447 - Sensor for Driver Seat; Height Adjust (G231)
36-00 - Open Circuit
Address 46: Central Conv. Labels:. 8E0-959-433-MAX.clb
Part No: 8E0 959 433 BT
Component: Komfortgerát T7B 3132
Coding: 11836
Shop #: WSC 06335
VCID: 04518E353702935B76B-4B00
Subsystem 1 - Part No: 8E1959801F
Component: Tõrsteuer.FS BRM 0305
Subsystem 2 - Part No: 8E1959802E
Component: Tõrsteuer.BF BRM 0205
Subsystem 3 - Part No: 8E0959801A
Component: Tõrsteuer.HL BRM 0205
Subsystem 4 - Part No: 8E0959802A
Component: Tõrsteuer.HR BRM 0205
Part No SW: 4F0 910 357 C HW: 4F0 907 357 C
Component: AFS 1 H01 0020
Coding: 0000019
Shop #: WSC 05152 444 64193
Subsystem 1 - Part No: 8E0 941 329
Component: AFS-Modul links H02 0020
Subsystem 2 - Part No: 8E0 941 329
Component: AFS-Modul rechtsH05 0030
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 8E0 035 195 H
Component: symphony II PM6 0410
Coding: 01005
Shop #: WSC 70656
VCID: 2C010695FF22BB1BDEB-508A
End------(Elapsed Time: 04:47, VBatt start/end: 13.4V/13.3V, udsna)--------
