2007 Audi Q7 4L Battery drain gremlins
mattlambie
C?ID=204737
Hi all.
Had these for years now and finally decided to hunt out a battery drain on the old girl!
The boot latch I think I can figure out with a spare latch but the radio.... Don't fancy ripping out the head lining as I have been reading about. Any tips?
01699 - Motor for Central Locking; Hatch/Trunk (V53)
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 107
Mileage: 148039 km
Date: 2018.08.02
Time: 18:16:30
00856 - Radio Antenna
Fault Frequency: 29
Reset counter: 112
Mileage: 151323 km
Date: 2018.11.21
Time: 06:50:44
South Molton, UK
It would be a great help if you only started one thread on the problems with your Q7 AND posted a full unedited VCDS Auto-Scan - see my sig for a link to a How-To
To be fair, he is asking about two different problems in the two threads he's started.
FWIW, I don't think the Radio Antenna fault will cause battery drain, however, I could see the Hatch Motor fault as a possibility.
The following thread may also be useful:
https://forums.ross-tech.com/showthread.php?9468
mattlambie
C?ID=204737
thank you all for the link on draw testing.
Sadly I just tested the fuse panels on both sides and every fuse is showing continuity as 0.01 :confused:
Is that all the fuses or are there more panels hidden away?
@PetrolDave: Hoping to get a laptop on it this weekend for a full scan to post.
mattlambie
C?ID=204737
OK so think I might have found a culprit and most likely my own handy work!
Part No SW: 4E0 910 541 T HW: 4E0 035 541 P
Component: TUNER EU/US/RDW H42 0630
Revision: 00000000 Serial number: 388G0067537926
Coding: 0000001
Shop #: WSC 31414 790 00001
VCID: 316922F8A884070EB4-8065
Fault Frequency: 44
Reset counter: 139
Mileage: 151323 km
Date: 2018.11.21
Time: 06:50:44
I think this is related to the dension I installed years ago and thatit is staying on perm rather than switched live. Disconnected and need to try a code clear to test out.
Tuesday,25,August,2020,21:49:55:44381
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(VMWare)
VCDS Version 20.4.1.0 (x64)
VIN: WAUZZZ4L67D031758   License Plate: AFTERABS
Chassis Type: 4L (4L0)
Scan: 01 02 03 05 06 07 08 09 0E 15 16 17 18 19 34 36 37 42 46 47
          4F 52 55 56 61 62 69 6D 6F 72 76
VIN: WAUZZZ4L67D031758   Mileage: 165610km-102905miles
Address 01: Engine        Labels: 059-907-401-ASB.clb
   Part No SW: 4L0 910 401 M    HW: 4L0 907 401
   Component: 3.0L V6TDI  G001AG  0030
   Revision: --H03---    Serial number:
   Coding: 0011775
   Shop #: WSC 00164 210 89795
   VCID: 2C57338C8FA66AE687-8079
Address 02: Auto Trans        Labels: 09D-927-750.clb
   Part No SW: 09D 927 750 FK    HW: 09D 927 750 FK
   Component: AL 750 6A           0940
   Revision: 00H52000    Serial number:
   Coding: 0012898
   VCID: 7CF7C3CC3F463A6657-8029
Address 03: ABS Brakes        Labels:. 4L0-910-517-V1.clb
   Part No SW: 4L0 910 517 A    HW: 4L0 614 517 A
   Component: ESP ALLRAD MK25E1   0130
   Revision: 00H21001
   Coding: 0038017
   VCID: 285FCF9C9B5E46C663-807D
   Part No SW: 4F0 910 852     HW: 4F0 905 852 B
   Component: FBSAUDIC6 ELV   H31 0220
   Revision: 31050601    Serial number: 10601000473569
   Coding: 0000147
   VCID: 63C598B0A2F8E59E76-8037
   Subsystem 1 - Part No: 4F0 910 131 E
   Component: FBSAUDIC6 EZS   H45 0080
   Subsystem 2 - Part No: 4F0 910 220 D
   Component: FBSAUDIC6 IDG   H01 0040
Address 06: Seat Mem. Pass        Labels: None
   Part No SW: 4F0 910 760     HW: 4L0 959 760
   Component: Sitzmemory BFS  H01 0100
   Revision: 00000000    Serial number: 00000000896401
   Coding: 0078944
   VCID: 61C992B8B8E4F78E64-8035
Address 07: Control Head        Labels: 4L0-910-7xx-07-H.clb
   Part No SW: 4L1 910 732 G    HW: 4E0 035 729
   Component: Interfacebox    H43 5570
   Revision: 00000000    Serial number: 386FQ067515205
   Coding: 0002302
   VCID: 2E533984B9BA18F6A9-807B
   Subsystem 1 - Part No: 4L0 910 609
   Component: E0380 BedienteilH02 0060
   Subsystem 2 - Serial number: 00000000454180
   Subsystem 3 - Serial number: 0126.06.060000000100011216ÿ
   Subsystem 4 - Serial number: 011216ÿ
   Part No SW: 4L0 910 043     HW: 4L0 820 043 E
   Component: KLIMABETAETIGUNGH05 0040
   Revision: 00---008    Serial number: 00000000049321
   Coding: 0001046
                    Reset counter: 179
                    Mileage: 165607 km
                    Date: 2006.03.15
                    Time: 12:25:39
                    Temperature: 42.0°C
                    Temperature: 27.0°C
                    Temperature: 20.0°C
                    RPM: 800 /min
                    Absolute Pres.: 1.0 bar
                    Current: 0.015 A
                    Temperature: 17.0°C
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 139
                    Mileage: 165607 km
                    Date: 2006.03.15
                    Time: 12:25:39
                    Temperature: 17.0°C
   Part No SW: 4F0 910 279 K    HW: 4F0 907 279
   Component: ILM Fahrer      H17 0240
   Coding: 0012121
   Subsystem 1 - Part No: 4L2 910 113   Labels: 1KX-955-119.CLB
   Component: Wischer AU716   H07 0030
   Coding: 00064792
   Shop #: WSC 31414
   Subsystem 2 - Part No: 4E0 910 557 A  Labels: 8K0-955-559.CLB
   Component: REGENLICHTSENSORH12 0090
   Coding: 00150059
   Shop #: WSC 31414
   Part No SW: 4L0 910 111 A    HW: 4L0 035 111
   Component: CD-Changer      H41 0100
   Revision: 00000000    Serial number: AUZ5ZBF3026358
   VCID: 1E33E944C91A887619-804B
   Part No SW: 4L0 910 655 B    HW: 4L0 959 655
   Component: 30 AIRBAG AUDI8RH38 0120
   Revision: 05H38000    Serial number: 0037GD06C93Q
   Coding: 0013104
   Subsystem 1 - Serial number: 6332QSME112D1A25A
   Subsystem 2 - Serial number: 6342QSME112D1877G
   Subsystem 3 - Serial number: 6352QSME11393A47F
   Subsystem 4 - Serial number: 6362QSME0E52412FL
   Subsystem 5 - Serial number: 63734SME1162350FY
   Subsystem 6 - Serial number: 63834SME11784A05
   Part No SW: 4F0 910 549     HW: 4F0 953 549 A
   Component: Lenksäulenmodul H08 0230
   Revision: 00H08000    Serial number: 90026061810395
   Coding: 0102142
   VCID: 66C381A451CA90B691-8033
   Component: Lenkradmodul    H07 0090
Address 17: Instruments        Labels: 4L0-910-xxx-17.lbl
   Part No SW: 4F0 910 930 C    HW: 4L0 920 980 G
   Component: KOMBIINSTR. M73 H17 0110
   Revision: 00300000    Serial number: 5HJ55KH76
   Coding: 2593403
   Shop #: WSC 55809 123 104857
   VCID: 2345D8B0E278A59E36-8077
Address 18: Aux. Heat        Labels: 4L0-910-105.lbl
   Part No SW: 4L0 910 105     HW: 4L0 815 071 C
   Component: Heizgeraet      H07 0060
   Revision: 0000000E    Serial number: 00000009011043
   Coding: 0000021
   VCID: 60CF97BCB3EEFE866B-8035
Address 19: CAN Gateway        Labels:. 4L0-910-468.clb
   Part No SW: 4L0 910 468     HW: 4L0 907 468
   Component: J533__Gateway   H06 0040
   Revision: 00H06000    Serial number: 0900B067068015
   Coding: F7DBBF7F302202
   Shop #: WSC 00164 210 89663
   VCID: 6CD7F38C4F26AAE6C7-8039
Address 34: Level Control        Labels: 4L0-910-553.lbl
   Part No SW: 4L0 910 553 B    HW: 4L0 907 553
   Component: LUFTFDR.-CDC    H03 7550
   Revision: --H03001    Serial number: 15.1528-0095.2
   Coding: 0015510
   Shop #: WSC 12268 000 1048576
   VCID: 2959CA9880547FCE7C-807D
   Component: Sitzmemory FS   H01 0100
   Coding: 0074850
   Part No SW: 4E0 910 888 P    HW: 4E0 919 887 D
   Component: MNS ECE         H48 1060
   Revision: 00000000    Serial number: 399F1067529682
   VCID: 3B7500D07AC8FD5E1E-806F
Address 42: Door Elect, Driver        Labels: 4L0-910-793-42.lbl
   Part No SW: 4L0 910 793 B    HW: 4L0 959 793 B
   Component: TSG FA          H12 0130
   Revision: 00000000    Serial number: x9w
   Coding: 0002779
   VCID: 2F6D2480BEB011FEA2-807B
   Part No SW: 4L0 910 289 D    HW: 4L0 907 289 A
   Component: Komfortgeraet   H05 0020
   Revision: 0020 ---    Serial number: 01015932160000
   Coding: 7348475
   Subsystem 2 - Part No: 4F0 910 177
   Component: Innenraumueberw.H01 0020
                    Reset counter: 138
Address 47: Sound System        Labels: 4L0-910-223-BO.lbl
   Part No SW: 4L0 910 223 G    HW: 4L0 035 223 D
   Component: DSP-High AU716  H02 0150
   Revision: PROD_01     Serial number: 00000000005650
   Coding: 0000013
   VCID: 285FCF9C9B5E46C663-FFFF
No Faults Found
   Part No SW: 4F0 910 280     HW: 4F0 907 280 E
   Component: ILM Beifahrer   H10 0080
   Revision:             Serial number: 00000000003905
   Coding: 0011101
   VCID: 5EB3A944899AC87659-800B
Address 52: Door Elect, Pass.        Labels: 4L0-910-793-52.lbl
   Part No SW: 4L0 910 793 B    HW: 4L0 959 792 B
   Component: TSG BF          H12 0130
   Revision: 00000000    Serial number: ‘yx
   Coding: 0002779
   Part No: 8P0 907 357 F
   Coding: 0000008
   VCID: 3D710EC864DCF36E20-8069
   Coding: 0000001
                    Fault Frequency: 44
                    Reset counter: 139
                    Mileage: 151323 km
                    Date: 2018.11.21
                    Time: 06:50:44
Address 61: Battery Regul.        Labels: 4F0-910-181.lbl
   Part No SW: 4L0 910 181     HW: 4L0 915 181
   Component: J0644 BEM       H12 0530
   Revision: --------    Serial number: 00000000027332
   Shop #: WSC 00137 210 103752
   VCID: 64C79BACA7F6E2A68F-8031
   Subsystem 1 - Part No: 402 092 316 2
   Component: von VA0  320514E1IT
   Coding: 343032303932333136322056413033323035313445314954
Address 62: Door, Rear Left        Labels: 4L0-910-795.lbl
   Part No SW: 4L0 910 795 B    HW: 4L0 959 795 B
   Component: TSG HL          H21 0050
   Coding: 0002058
Address 69: Trailer (J345)       Labels:. 4E0-907-383.clb
   Part No SW: 4E0 907 383 J    HW: 4E0 907 383 J
   Revision: 2A001001    Serial number: 00000194546809
   Coding: 0100000000000000
   VCID: 316922F86884070EB4-8065
Address 6D: Trunk Elect.        Labels: None
   Part No SW: 4L0 910 945     HW: 4L0 827 851 C
   Component: ValeoHeckdeckel H28 0290
   Revision: --H28001    Serial number: E5030000B
   Shop #: WSC 00137 210 91082
   Subsystem 3 - Serial number: RD12.11.10--H28001001C0099ÿ
   Subsystem 4 - Serial number: 1C0099ÿ
   Part No SW: 4L0 910 290     HW: 4L0 907 290
   Component: ILM HINTEN 2    H05 0040
   Revision: AAH05044    Serial number: 001762299-----
   Coding: 0000001
   VCID: 65C186A8ACCC9BAE98-8031
Address 72: Door, Rear Right        Labels: 4L0-910-795.lbl
   Part No SW: 4L0 910 795 B    HW: 4L0 959 794 B
   Component: TSG HR          H21 0050
   Coding: 0002058
   Part No SW: 4F0 910 283 G    HW: 4F0 919 283 G
   Component: Parkhilfe 8-Kan H12 0060
   Revision: 00H12000    Serial number: 06320617204197
   Coding: 0211146
End-------------------------(Elapsed Time: 03:16)--------------------------
