Thursday,23,July,2020,14:54:20:41284
VCDS Version: 20.4.1.0 (x64) HEX-V2 CB: 0.4513.4
VIN: TMBME7NU9L5036946 License Plate: LCY
Mileage: 461km-286mi Repair Order:
Chassis Type: NU-SK37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 17 19 22 2B 3C 42 44 47 4B 52
5F 6D A5 A9 BB BC CA D6 D7
VIN: TMBME7NU9L5036946 Mileage: 461km-286miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-DKZA) Labels: None
Part No SW: 81A 907 115 A HW: 06K 907 309 B
Component: R4 2.0l TFSI H61 0002
Revision: O1H61000
Coding: 042540322466050B34100000000000000000000000000000
Shop #: WSC 00033 790 00063
ASAM Dataset: EV_ECM20TFS01181A907115A 001004
ROD: EV_ECM20TFS011_VW37.rod
VCID: 221DED054445E55B65F-8076
17165 - Databus
U1123 00 [040] - Received Error Message
Mileage: 10 km
Date: 2020.06.16
Time: 04:27:11
Engine speed: 0.00 /min
Coolant temperature: 28 °C
Intake air temperature: 17 °C
Voltage terminal 30: 11.820 V
Unlearning counter according OBD: 21
ACC variants-Bits 0-7: 2
CCS Switch-Bits 0-7: 2
Cruise control switch actuation-Bits 0-7: 32
Cruise control switch actuation-Bits 0-7: 128
ACC variants (coding)-Bits 0-7: 3
17166 - Cruise Control Switch (E45)
P0568 00 [040] - Implausible Signal
Fault Frequency: 11
Mileage: 10 km
Date: 2020.06.16
Time: 04:25:47
Voltage terminal 30: 11.860 V
Cruise control switch actuation-Bits 0-7: 33
Part No SW: 0GC 300 013 N HW: 0GC 927 711 H
Component: GSG DQ381 H06 2405
Revision: 00H06V11
ROD: EV_TCMDQ381061.rod
VCID: 2F3B143107975833FA1-807A
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 5Q0 614 517 DP HW: 5Q0 614 517 BS
Component: ESC H82 0113
Revision: 00000000 Serial number: 60350000000132
Coding: 1F078AA1A02324724780070462C929F8510524E2E0469475384150B8F2A94A0B00400C6212120B095A35351919323200
ASAM Dataset: EV_Brake1UDSContiMK100IPB 049012
ROD: EV_Brake1UDSContiMK100IPB_049_SK37.rod
VCID: 025D8D85E485055B45F-8056
Part No SW: 3Q0 959 435 N HW: 3Q0 959 435 N
Component: VWKESSYMQB 037 1307
Revision: 00037000 Serial number: 0541952777
Coding: 032C0C0723
ROD: EV_KessyHellaMQBAB.rod
VCID: 45D75699B52BF26320D-8010
Subsystem 1 - Part No SW: 3G0 962 243 B HW: 3G0 962 243 B
Component: GEB.F.Heckoef H17 0904
Serial number: 58694671
Part No SW: 565 907 044 CL HW: 565 907 044 CL
Component: Climatronic H04 2202
Revision: 00001K00
Coding: 0611000400010401110500080010102A
Shop #: WSC 00033 790 00119
ASAM Dataset: EV_ACClimaBHBVW37X 006150
ROD: EV_ACClimaBHBVW37X_006_SK37.rod
VCID: 678BBC11EFE7C073F21-8032
Air quality sensor:
Subsystem 3 - Part No SW: 5Q0 907 659 C HW: 5Q0 907 659 C
Component: G238 _AQS H31 0120
Serial number: 105364114
Part No SW: 5Q0 937 084 DH HW: 5Q0 937 084 CG
Component: BCM MQBAB H H42 0312
Serial number: 02002004901022
ASAM Dataset: EV_BCMMQB 020001
ROD: EV_BCMBOSCH_020.rod
VCID: 015F8289E1831E435C5-8054
Subsystem 1 - Part No SW: 81A 955 555 A HW: 81A 955 555
Serial number: 24338724X81A955555A0
Coding: 80006E
Subsystem 2 - Part No SW: 5Q0 951 177 HW: 5Q0 951 172
Serial number: 000000000ZY200200D5C
Subsystem 3 - Part No SW: 5Q0 951 605 B HW: 5Q0 951 605 B
Component: Sirene, DWA 004 0007
Serial number: 00000000000000916303
Steering Column Switch:
Subsystem 4 - Part No SW: 5Q1 953 521 AG HW: 5Q1 953 569 A
Component: Lenks.Modul H13 0170
Serial number: 0100160220200C205938
797955 - Steering Column Control Module
B105D 07 [008] - Mechanical Failure
[Schaltermodul Lenksäule (SMLS)->mechanischer Fehler]
Fault Frequency: 9
Reset counter: 43
Mileage: 10 km
Date: 2020.06.16
Time: 04:29:38
Part No SW: 5QA 919 298 H HW: 5QA 919 298 A
Component: PLA 3.0 12K H08 0061
Serial number: 000150057220044
Coding: 0371167851
ASAM Dataset: EV_EPHVA2CAU3700000 009048
VCID: 55F786D9458B42E350D-8000
Part No SW: 2Q0 907 572 R HW: 2Q0 907 572 B
Component: ACCCONTIMQB H03 0372
Coding: 320467D35CFF8428749C814530308700000000000000000004
ROD: EV_ACCMRRCONTIVW376_003_SK37.rod
VCID: 43D34881BB1FCC530E9-8016
2068 - Databus
[FAULT_TSK_IRREV_FAIL]
Fault Frequency: 30
Reset counter: 43
Mileage: 10 km
Date: 2020.06.16
Time: 04:26:07
Voltage terminal 15: 11.8 V
Control Module temperature: 28 °C
Vehicle speed: 0.00 m/s
Longitudinal acceleration: 0.00 m/s²
Adaptive distance regulation: status: ACC_irreversible error
1116 - Databus
[FAULT_TSK_CODING_IN_PLAUS_PHASE_FAIL]
Mileage: 10 km
Date: 2020.06.16
Time: 04:30:05
Control Module temperature: 30 °C
2127 - Databus
[FAULT_OP_FAIL]
Reset counter: 43
Mileage: 10 km
Date: 2020.06.16
Time: 04:27:11
Control Module temperature: 31 °C
Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb
Part No SW: 5Q0 907 376 B HW: 5Q0 907 376 A
Serial number: 02022041350446
ROD: EV_DRCONTITEMIC_VW37.rod
VCID: 38292F6DF2D99F8BABB-806C
Part No SW: 3Q0 959 655 CM HW: 3Q0 959 655 CM
Component: Airbag VW21 006 0720
Revision: -------- Serial number: 003Z2P198MQ2
Coding: 98CCC0C0000000005C540000008800000065
ROD: EV_AirbaVW21TS6VW48X.rod
VCID: 0B43A0A1D3CF4413369-805E
Subsystem 1 - Part No SW: ----------- HW: 454 001 301 20
Serial number: 357000000000EC10A44H
Subsystem 2 - Part No SW: ----------- HW: 454 001 401 20
Serial number: 35800000000A58C0A44Q
Subsystem 3 - Part No SW: ----------- HW: 454 801 501 20
Serial number: 351005540B81A000000A
Subsystem 4 - Part No SW: ----------- HW: 454 801 501 20
Serial number: 35200324DB81A000000J
Subsystem 5 - Part No SW: ----------- HW: 454 801 312 19
Serial number: 35500F9A5A21A000000W
Part No SW: 565 920 790 C HW: 565 920 790 C
Component: KOMBI 503 4194
Coding: 24AC0A1EFF880008018D630B1001000080000000
ASAM Dataset: EV_DashBoardVDDMQBA0 001042
ROD: EV_DashBoardVDDMQBA0_VW37.rod
VCID: 1E65D9F5703DC1BB417-804A
Part No SW: 3Q0 907 530 AC HW: 3Q0 907 530 C
Component: GW MQB High 521 5388
Serial number: 24022010520457
Coding: 030100047F085900A90322FA9E0F00010001070000000000000000000000
Shop #: WSC 00033 790 00114
ROD: EV_GatewNF_VW37.rod
VCID: 70B9D74DDA2907CBA3B-8024
Component: 4-01-13-01-04
Subsystem 2 - Part No SW: 3V0 919 719 F HW: 3V0 919 719 F
Component: E221__MFL-PR6 H03 0180
Serial number: 000000000D2511170220
Subsystem 3 - Part No SW: 5Q0 915 181 J HW: 5Q0 915 181 J
Component: J367-BDMConti H03 1051
Serial number: 75886003002002190D72
8531970 - Quiescent Current
U1406 00 [008] - Too High
[Ruhestrom oberer Grenzwert überschritten]
Reset counter: 62
Mileage: 314 km
Date: 2020.07.04
Time: 23:03:11
Supply voltage: Terminal 30: 12.4 V
Terminal 15: OFF
Part No SW: 0CQ 907 554 J HW: 0CQ 525 130
Component: Haldex4Motion H55 7084
Serial number: HA1-00008.01.20
Coding: 0001
VCID: 4CC163BD9641032BFF3-8018
Part No SW: 3Q0 905 861 B HW: 3Q0 905 861 B
Component: ELV-MQBB H05 0020
Serial number: 20000020731001
Coding: 0800000000000000
ROD: EV_ELVMarqMQBA0_AU37.rod
VCID: 33331841EBBF7CD39E9-8066
Address 3C: Lane Change (J1086) Labels:* None
Part No SW: 2Q0 907 686 B HW: 2Q0 907 686 B
Component: HRE3_Kl15_Mst H06 0150
Serial number: 00000540349141
Coding: 92954640
ASAM Dataset: EV_HREntryHellaGen3Kl15 002001
ROD: EV_HREntryHellaGen3Kl15.rod
VCID: 392F2A69C9D38683545-806C
Address 42: Door Elect, Driver (J386) Labels:* Redir Fail!
Part No SW: 5Q4 959 593 K HW: 5Q4 959 593 K
Component: TSG FS 007 0485
Serial number: 0000405313494
Coding: 00158820D001020000001100
VCID: 4DC76EB96D5B0A23E8D-8018
Part No SW: 3Q0 909 144 M HW: 3Q0 909 144 L
Component: EPS_MQB_ZFLS 507 5082
Coding: 93170000
ROD: EV_SteerAssisMQB_015.rod
VCID: 3C21337DC6E1B3AB4F3-8068
Address 47: Sound System (J525) Labels:| 81A-035-466.clb
Part No SW: 81A 035 223 HW: 81A 035 223
Component: MIB2_amp_P_SK H10 0410
Revision: 00000001 Serial number: SKZ8Z1KJE09H865
Coding: 0323060000AA002AAA0000000000
ASAM Dataset: EV_AMPMst16C4Gen2ALPI 001001
ROD: EV_AMPMst16C4Gen2ALPI.rod
VCID: 59EF8AE929936683745-800C
0522 - Front Left Treble Speaker
B1061 13 [008] - Open Circuit
[Tieftonlautsprecher Kanal 3: Unterbrechung (DC-Diagnose)]
Reset counter: 62
Mileage: 314 km
Date: 2020.07.04
Time: 13:23:42
Voltage terminal 30: 12.0 V
Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V2.clb
Part No SW: 3Q0 907 338 E HW: 3Q0 907 338 E
Component: FCM MQB Low 003 0367
Serial number: 17022010523938
Coding: 000000070900057606003D01190000000000000000000000000000000000
ROD: EV_MultiModulContiVW48X_003_VW27.rod
VCID: 372B2C51FFC790F3A21-8062
Address 52: Door Elect, Pass. (J387) Labels:* Redir Fail!
Part No SW: 5Q4 959 592 K HW: 5Q4 959 592 K
Component: TSG BFS 007 0485
Serial number: 0000405284813
Coding: 00158020D001020000001100
Part No SW: 565 035 019 E HW: 565 035 019
Component: MU-H-LND-RW H55 1440
Serial number: A890K0KP000105
Coding: 032306080000000001510202008908312F0108F601208400FF
VCID: 176BCCD19F07B0F3821-8042
Subsystem 1 - Part No SW: 565 919 606 D HW: 565 919 606 D
Component: ABT_High-2 H53 9130
Serial number: SKZ6ZHX0535905
Subsystem 2 - Part No SW: V03 959 806 GS HW: -----------
Component: ROW 2020/2021 --- 0088
Compact Disc Database:
Component: Gracenote2 --- 4013
B201A 00 [009] - -
Fault Frequency: 15
Reset counter: 22
Mileage: 170 km
Date: 2020.06.30
Time: 22:08:04
Voltage terminal 30: 12.8 V
Status_Software_Version_Management-module_name: MDUK621/Main
6667 - Optical Data Bus for Information Electronics 1
U10CA 00 [008] - Intermittent Disruption
[Optical data bus: sporadic open circuit in central processor]
Reset counter: 48
Mileage: 170 km
Date: 2020.06.30
Time: 22:07:40
Temperature of MOST transceiver-max.value: -50 °C
Temperature of MOST transceiver-min.value: -3 °C
Temperature of MOST transceiver-Current: 45 °C
6678 - Digital sound System control module
U106A 00 [008] - No Communication
[Control module for sound system: no communication]
Reset counter: 48
Mileage: 170 km
Date: 2020.06.30
Time: 21:30:22
Voltage terminal 30: 12.6 V
Part No SW: 5Q0 959 107 S HW: 5Q0 959 107 J
Component: HDSG-Modul H13 0271
Revision: -------- Serial number: A2-C737-6291-8
Coding: 1808
VCID: 48C95FAD8239EF0BDBB-801C
Part No SW: 3Q0 980 654 L HW: 3Q0 980 654 A
Component: MQB_B_MFK H13 0610
Serial number: 18022015P11412
Coding: 020307080000010100022346C150A90088000E20000000
ROD: EV_MFKBoschMQBB_002.rod
VCID: 40D9478DAA09D74B13B-8014
Address A9: Struct. Borne Sound (J869) Labels: None
Part No SW: 57A 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0001
Serial number: 191017201308
VCID: 6C81C33DF601E32B9F3-8038
Part No SW: 8W0 959 595 M HW: 8W0 959 595 J
Component: TSG HFS 010 0384
Serial number: 0000405598586
Coding: 000080200001020000001100
VCID: 56F581D5588D49FB597-8002
Component: TSG HBFS 010 0384
Serial number: 0000405803949
ROD: EV_DCU2RearPasseMAXHCONT_AU49.rod
Part No SW: 4K0 907 594 AC HW: 4K0 907 594
Component: SAD_STG_1 006 0002
Coding: 508040632602
ROD: EV_SunRoofCONTIAU736_009_VW37.rod
VCID: 75B7E659A54B22E370D-8020
Address D6: Light Ctrl Left 2 (A31) Labels: 7P5-941-591.clb
Part No SW: 7P5 941 591 AJ HW: 7P5 941 591 A
Component: LED1L H07 0011
ROD: EV_LED_PLUS_L_KEBODAVW416_VW37.rod
VCID: 04518B9DFE910B6B773-8050
Address D7: Light Ctrl Right 2 (A27) Labels: 7P5-941-591.clb
Component: LED1R H07 0011
ROD: EV_LED_PLUS_R_KEBODAVW416_VW41.rod
End----------(Elapsed Time: 02:11, VBatt start/end: 14.9V/14.9V)-----------
