I am getting a reoccurring fault in my CAN Gateway and I cannot seem to figure it out and neither can the dealership. Unfortunately my debug file from my previous tweaks went MIA during an update so I am flying blind. Can anyone help steer me in the right direction?
Sunday,16,August,2020,16:02:44:58097
VIN: WVWWA7AU2KW108802 License Plate:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 03 05 08 09 10 13 14 15 17 19 22 29 2B 39 3C 42 44 47 4B
52 5F 75 A5 A9 D6 D7
VIN: WVWWA7AU2KW108802 Mileage: 29797km-18514miles
Address 01: Engine (J623-DLRA) Labels:. 06K-907-425-V1.clb
Part No SW: 8V0 906 259 Q HW: 06K 907 425 J
Component: R4 2.0l TFSI H13 0002
Revision: --H13---
Coding: 091900122446000E3004
ASAM Dataset: EV_ECM20TFS0208V0906259Q 001003
ROD: EV_ECM20TFS0208V0906259Q.rod
VCID: 4EC56FA790590A6B90F-801A
21388 - Valve for Exhaust Flap 1 (N321)
P3019 00 [047] - Open Circuit
Mileage: 29697 km
Date: 2020.08.15
Time: 10:49:08
Engine speed: 3560.25 /min
Normed load value: 7.8 %
Vehicle speed: 72 km/h
Coolant temperature: 98 °C
Intake air temperature: 37 °C
Voltage terminal 30: 13.847 V
Engine: operating status: PL
STATE_LS_SAE[1]: OL_INTR
T_AST_SAE: 0 s
MAP_MES_SAE: 32 kPa
Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.963 V
FAC_TPS_1_SAE: 17.187500 %
FUP_H_SAE: 8420.0 kPa
21399 - Valve for Exhaust Flap 2 (N322)
P3023 00 [047] - Open Circuit
Mileage: 29697 km
Date: 2020.08.15
Time: 10:49:08
T_AST_SAE: 0 s
MAP_MES_SAE: 32 kPa
18931 - Oxygen (Lambda) Sensor B1 S2
P013E 00 [096] - Response too Slow Rich to Lean
Mileage: 29733 km
Date: 2020.08.16
Time: 05:31:20
Engine speed: 2815.75 /min
Normed load value: 28.2 %
Vehicle speed: 119 km/h
Coolant temperature: 97 °C
Intake air temperature: 22 °C
Voltage terminal 30: 14.082 V
STATE_LS_SAE[1]: CL
VLS_DOWN_SAE[1]: 0.770 V
LAMB_DELTA_I_LAM_ADJ[1]: 0.00018
Lambda probe correction: duty cycle offset: bank 1: 0.00018
Lambda probe heater: resistance: bank 1: probe 2: 403 Ohm
TEG_DYN_LS_DOWN[0]: 673.2250 °C
Part No SW: 5Q0 614 517 DS HW: 5Q0 614 517 BN
Component: ESC H35 0108
Revision: 00000000 Serial number: 62618000000153
Coding: 01FA6BA150200974457F030060C56980D60A90A2C0069637344050D4D0A84B0B0000000012121212B835351919323200
ROD: EV_Brake1UDSContiMK100IPB_038.rod
VCID: 0557908B05AF0933615-8050
Part No SW: 3Q0 959 435 L HW: 3Q0 959 435 L
Component: VWKESSYMQB 037 1204
Revision: 00037000 Serial number: 0504490121
Coding: 132C0C0623
ASAM Dataset: EV_KessyHellaMQBAB 004046
ROD: EV_KessyHellaMQBAB.rod
VCID: 43D34E934B1BF7030F1-8016
Part No SW: 5G0 907 044 CF HW: 5G0 907 044 CF
Component: Climatronic H04 1801
Revision: 00001K08
Coding: 0002000420010000010500001211140A
VCID: 6D87C82B3D1FD173895-8038
Air quality sensor:
Part No SW: 5Q0 937 085 BT HW: 5Q0 937 085 BG
Component: BCM MQBAB HNA H38 0273
Serial number: 9327004302ÿÿÿÿ
ROD: EV_BCMBOSCH_019.rod
VCID: 0C41A5AF26C5787B3EB-8058
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 181208 043 0551
Serial number: 190108101416
Component: RLHS 052 0107
Serial number: SAY19M01D23H11M10S40
Coding: 00A8DD
Steering Column Switch:
Subsystem 3 - Part No SW: 5Q1 953 507 M HW: 5Q1 953 549
Component: J527 SMLS MQB 004 0060
Serial number: 00000011011904400187
Part No SW: 5QA 919 294 C HW: 5QA 919 294
Component: PDC 8 KanalH07 0050
Serial number: 000308418019012
Coding: 0471155801
ASAM Dataset: EV_EPHVA18AU3700000 009039
VCID: 4CC165AF6645387BFEB-8018
Address 13: Auto Dist. Reg (J428) Labels:| 3Q0-907-572.clb
Part No SW: 5Q0 907 572 P HW: 3QF 907 572 A
Coding: 2B0000C159FFC728949C810560401600000000000000000004
VCID: 44D14D8F4E15F03B36B-8010
Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb
Part No SW: 5Q0 907 376 B HW: 5Q0 907 376 A
Serial number: 10011941350223
ROD: EV_DRCONTITEMIC_VW37.rod
VCID: 3829297F02DDA4DBAA3-806C
Part No SW: 5Q0 959 655 J HW: 5Q0 959 655 J
Component: AirbagVW20 010 0830
Serial number: 003GCR0AUEP8
VCID: 47CB5A837F23DB23D39-8012
Occupant Detection:
Component: BF-Gewichtss. H13 0022
Serial number: IBH00000000000AVPG98
Coding: 303344
Subsystem 2 - Part No SW: ----------- HW: 480 001 701 19
Serial number: 35700000000C0C55D73T
Subsystem 3 - Part No SW: ----------- HW: 480 001 501 19
Serial number: 35800000000BF391343M
Subsystem 4 - Part No SW: ----------- HW: 480 401 801 19
Component: SideSensor_Dr 004 6149
Serial number: 3510001122B72277042E
Subsystem 5 - Part No SW: ----------- HW: 480 402 301 19
Component: SideSensor_Pr 004 6149
Serial number: 35200010A2BFA0C5044+
Subsystem 6 - Part No SW: ----------- HW: 480 401 601 19
Component: FrontSensor_D 004 6149
Serial number: 3550001102B7C81654D+
Front Sensor Passenger:
Subsystem 7 - Part No SW: ----------- HW: 480 401 601 19
Component: FrontSensor_P 004 6149
Serial number: 3560001102B7C815C6C6
Part No SW: 5G1 920 891 B HW: 5G1 920 891 B
Component: KOMBI 402 4191
Coding: 0BBD30127F88CF0502886B0B4401000080000000
VCID: 2C01052FC685187BDEB-8078
Part No SW: 3Q0 907 530 AA HW: 3Q0 907 530 C
Component: GW MQB High 442 4366
Revision: -------- Serial number: 0008936547
Coding: 0101000838085900FB00823A880F00000001070000000000000000000000
ROD: EV_GatewNF_VW37.rod
VCID: 6E85CF2730192A6BB0F-803A
Component: 0-00-00-00-00
Subsystem 2 - Part No SW: 5G0 959 442 AE HW: 5G0 959 442 AE Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H11 0052
Serial number: 29180002995650038507
Coding: 2CFFFF
66304 - Databus
U1124 00 [009] - Additional Installations Detected
[Mehrverbau CAN]
Fault Frequency: 50
Reset counter: 180
Supply voltage: Terminal 30: 12.2 V
Terminal 15: OFF
Part No SW: 0CQ 907 554 J HW: 0CQ 525 130
Component: Haldex4Motion H55 7084
Serial number: HA1-00029.11.18
Coding: 0001
Address 29: Left Light (J1018) Labels: 8V0-907-399.clb
Part No SW: 8V0 907 399 D HW: 8V0 907 399 D
Component: LCM_MLBevoH08 0014
Part No SW: 2Q0 905 861 A HW: 2Q0 905 861 A
Component: ELV-MQBB H08 0021
Serial number: 18000410777003
ROD: EV_ELVMarqMQBA0_VW37.rod
VCID: 313F145BE1A77593EDD-8064
Address 39: Right Light (J1023) Labels: 8V0-907-399.clb
Address 3C: Lane Change (J1086) Labels:| 5Q0-907-686.clb
Part No SW: 5Q0 907 686 C HW: 5Q0 907 686 C
Component: HRE_Master H12 0081
Serial number: 0504192659
Coding: 02011103
ROD: EV_HREntryHella_VW37.rod
VCID: 3D27386B2DFF81F3795-8068
Lane Change Assistant 2:
Subsystem 1 - Part No SW: 5Q0 907 685 C HW: 5Q0 907 685 C
Component: HRE_Slave H12 0081
Serial number: 0503894530
Coding: 020111
Part No SW: 5Q0 959 593 F HW: 5Q0 959 593 F
Component: TSG FS001 0287
Serial number: YE007SA310659
Coding: 003E13208000040000000000
Subsystem 1 - Part No SW: 5Q0 959 811 D HW: 5Q0 959 811 D Labels: 5QX-959-81X-V1.CLB
Component: FOND_FHSG_DRV 006 0007
Serial number: 00000000000026599671
Coding: 111000
Part No SW: 3Q0 909 144 M HW: 3Q0 909 144 L
Component: EPS_MQB_ZFLS 507 5082
Coding: 910A0000
ROD: EV_SteerAssisMQB_015.rod
VCID: 3C21356F36E588FB4EB-8068
Address 47: Sound System (J525) Labels:| 5Q0-035-456.clb
Part No SW: 5Q0 035 456 A HW: 5Q0 035 456 A
Component: MIB2_lite_amp H40 0200
Revision: 00000001 Serial number: VWZ8Z1JMD040LNT
Coding: 2200000000AAAAAA000000000000
ROD: EV_AMPMst12C1Gen2ALPI.rod
VCID: 2E050F27F0996A6BF0F-807A
Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V2.clb
Part No SW: 3Q0 907 338 C HW: 3Q0 907 338 C
Component: FCM MQB Low 002 0345
Serial number: 08011910802065
Coding: 000000050900161206710F01020000000000000000000000000000000000
ASAM Dataset: EV_MultiModulContiVW48X 002006
ROD: EV_MultiModulContiVW48X_002_VW37.rod
VCID: 3537204B15CF59B3B15-8060
Part No SW: 5Q0 959 592 F HW: 5Q0 959 592 F
Component: TSG BFS001 0287
Serial number: YE007RLE1018B
Subsystem 1 - Part No SW: 5Q0 959 812 D HW: 5Q0 959 812 D Labels: 5QX-959-81X-V1.CLB
Component: FOND_FHSG_PSG 006 0007
Serial number: 00000000000026714801
Coding: 091000
Part No SW: 3Q0 035 876 B HW: 3Q0 035 876 B
Component: MU-S-NS-US 851 0867
Coding: 027310020000000041220002001808009F0507F401200405C6
ROD: EV_MUStd4CDELP_VW37.rod
VCID: 33331E531BBB47839F1-8066
Subsystem 1 - Part No SW: 5G6 919 605 D HW: 5G6 919 605 D
Component: ABT_Std-2_Nav H52 8130
Serial number: VWZ6ZJV1745975
Subsystem 2 - Part No SW: 3G0 919 866 BP HW: -----------
Component: NAR 2018 --- 0715
Address 75: Telematics (J949) Labels:| 5QE-035-285.clb
Part No SW: 5QE 035 285 A HW: 5QE 035 285 A
Component: OCULowMQBUS 009 0570
Coding: 02730002C2821A017F1E06020000
ROD: EV_OCULowMQB.rod
9458451 - Cellular Antenna
B1053 13 [008] - Open Circuit
[GSM antenna open load]
Fault Frequency: 20
Mileage: 28954 km
Date: 2020.08.05
Time: 17:15:13
Part No SW: 3Q0 980 654 H HW: 3Q0 980 654 A
Component: MQB_B_MFK H09 0272
Serial number: 11091815P13111
Coding: 0003070000000201002213548150490084000E200120
Part No SW: 5G0 907 159 D HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0001
Serial number: 181115202292
VCID: 2F3B1223F7936363FB9-807A
Part No SW: 7P5 941 572 A HW: 7P5 941 572 A
Component: LED1L H06 0002
ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
ROD: EV_LEDMinMaxL_KEBODAVW481.rod
VCID: 392F2C7B39D7BDD355D-806C
Component: LED1R H06 0002
ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
ROD: EV_LEDMinMaxRKEBODVW481.rod
End----------(Elapsed Time: 01:45, VBatt start/end: 12.2V/12.1V)-----------
