2019 Tiguan VCD Info System Adjustments Help
djdracine
C?ID=331013
Does anyone know how to change the Phone Favorites to show more then just four?
Also is there a away to have the phone text messages show and play MMS messages (group) messages. Currently the info system does not even recognize there is a new message if its from a group text message. Is there a fix for that as well?
Thank you
Do we have an Auto-Scan from this vehicle somewhere? They do not all have the same infotainment system.
djdracine
C?ID=331013
Auto Scan
This morning something odd also happen, the screen appears to be stuck on welcome to Volkswagen and does not operate.
Sunday,16,August,2020,09:01:21:18517
VIN: 3VV3B7AX1KM040651   License Plate:
Mileage: 15876km-9864mi   Repair Order:
Chassis Type: AX-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 2B 3C 42 44 52 5F 6C 6D 75
          CA
VIN: 3VV3B7AX1KM040651   Mileage: 15876km-9864miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-DGUA)       Labels:. 06L-907-115-V1.clb
   Part No SW: 83A 907 115     HW: 06L 907 309 B
   Component: R4 2.0l TFSI  H31 0003
   Revision: 1DH31000
   Coding: 012A00122464012FB4000000000000000000000000000000
   Shop #: WSC 00066 790 00200
   ASAM Dataset: EV_ECM20TFS01183A907115 001005
   ROD: EV_ECM20TFS01183A907115.rod
   VCID: 6393524A6BD13D432F1-8036
Readiness: 1110 1101
   Part No SW: 09G 927 158 DS    HW: 09G 927 158
   Component: AISIN AQ8     206 3550
   Coding: 0002000100000000000000000000000000000000
   Shop #: WSC 00066 790 00438
   ROD: EV_TCMAQ450031_VW37.rod
   VCID: 074B66DABFA9B163139-8052
   Part No SW: 5Q0 614 517 DE    HW: 5Q0 614 517 AD
   Component: ESC           H25 0524
   Revision: 00000000    Serial number: 52638000000004
   Coding: 0BFA6BA454241B6CC57D0205A2C449D0D62AD8A34045927038415058C282420B002764121A1C230A35351919323200
   Shop #: WSC 01383 790 50316
   ROD: EV_Brake1UDSContiMK100IPB_037_VW37.rod
   VCID: 77AB161ACF49C1E3639-8022
   Part No SW: 3Q0 959 435 L    HW: 3Q0 959 435 L
   Component: VWKESSYMQB    037 1204
   Revision: 00037000    Serial number: 0491998968
   Coding: 132C0C0723
   ASAM Dataset: EV_KessyHellaMQBAB 004046
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 43D3B2CACB115D430F1-8016
Address 08: Auto HVAC (E87)       Labels:| 3V0-907-044.clb
   Part No SW: 5NN 907 044 F    HW: 5NN 907 044 F
   Component: AC Automat    H35 4401
   Revision: 20K03000    Serial number: 00000D00251148
   Coding: 00020024200118001005010012111406
   ASAM Dataset: EV_ACClimaPrehVW37X 002025
   VCID: 4FFB8EFA1759A9239B9-801A
   Part No SW: 5Q0 937 087 BB    HW: 5Q0 937 087 BB
   Component: BCM PQ37BOSCH 036 0265
   Revision: --------    Serial number: C864031018002T
   ASAM Dataset: EV_BodyContrModul1UDSBosc 019001
   ROD: EV_BCMBOSCH_019.rod
   VCID: 7CA10936F66FE2BB0EB-8028
   Subsystem 1 - Part No SW: 5NN 955 119     HW: 5NN 955 119   Labels: 1KX-955-119.CLB
   Component: 326 LL 181001  034 0373
   Serial number: 18093021005840
   Subsystem 2 - Part No SW: 8U0 955 559     HW: 8U0 955 559   Labels: 8U0-955-559.CLB
   Component: G355_FeuchteS  H07 0002
   Serial number: 72291641
   Steering Column Switch:
   Subsystem 3 - Part No SW: 5Q1 953 521 M    HW: 5Q1 953 569
   Component: Lenks.Modul  H03 0170
   Serial number: 0300021120180C201262
   Part No SW: 5QA 919 294 C    HW: 5QA 919 294
   Component: PDC 8 KanalH07 0050
   Serial number: 000137088R18303
   Coding: 0471155811
   ASAM Dataset: EV_EPHVA18AU3700000 009039
   VCID: 4CC199F6E64F923BFEB-8018
   Component: ACCCONTIMQB   H02 0233
   Coding: 3200000158FF8728749C8145304097
   VCID: 3E25C33EA0F330AB60F-806A
   Part No SW: 5Q0 959 655 AG    HW: 5Q0 959 655 AG
   Component: AirbagVW21    005 0338
   Serial number: 003NUM0CB2M$
   Coding: 8CCCFC00000000005000001AC20800000065
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002160
   VCID: 05576CD285A5A373615-8050
   Occupant Detection:
   Serial number: IBH00000000000AE9834
   Coding: 303351
   Subsystem 2 - Part No SW: -----------    HW: 480 001 408 18
   Serial number: 3570000000099B18833O
   Subsystem 3 - Part No SW: -----------    HW: 480 001 408 18
   Serial number: 35800000000D9695133M
   Subsystem 4 - Part No SW: -----------    HW: 480 401 607 18
   Component: SideSensor_Dr  004 6149
   Serial number: 35100010A2B6FB54A39A
   Subsystem 5 - Part No SW: -----------    HW: 480 401 607 18
   Component: SideSensor_Pr  004 6149
   Serial number: 35200010A2B6FB535362
   Subsystem 6 - Part No SW: -----------    HW: 480 402 509 18
   Component: FrontSensor_D  003 6149
   Serial number: 3550001A12BC7D92459D
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 402 509 18
   Component: FrontSensor_P  003 6149
   Serial number: 3560001A12BC7D9226DH
   Part No SW: 5NA 920 891 C    HW: 5NA 920 891 C
   Component: KOMBI         403 4191
   Coding: 0BA4011A2788CF0502886A0954010000A0000000
   VCID: 44D1B1D6CE1F5A7B36B-8010
   Part No SW: 3Q0 907 530 Q    HW: 3Q0 907 530 C
   Component: GW MQB High   518 5344
   Serial number: 14101800841660
   Coding: 030100347F085900FA000258180F00010001070000000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 3D27C432ADF52BB3795-8068
   Component: 1-00-0d-00-04
   Subsystem 2 - Part No SW: 5NA 959 442 B    HW: 5NA 959 442 B
   Component: E221__MFL-TAT  H06 0025
   Serial number: 2391811491000682FJ2B
   Coding: 2C0000
   Serial number: 1450946100
   Serial number: 18000290606015
   Coding: 0800000000000000
   ROD: EV_ELVMarqMQBA0_VW37.rod
   VCID: 3333E20A9BB1EDC39F1-8066
   Serial number: 0492349935
   Coding: 02011103
   ROD: EV_HREntryHella_VW37.rod
   Lane Change Assistant 2:
   Component: HRE_Slave  H12 0081
   Serial number: 0492020758
   Coding: 020111
   Part No SW: 5Q4 959 393 M    HW: 5Q4 959 393 F
   Component: TSG FS        006 0247
   Serial number: 50038830003221
   Coding: 00301B200000048000000000
   VCID: 4DC794F21D559B33E95-8018
   Subsystem 1 - Part No SW: 5Q4 959 811 G    HW: 5Q4 959 811 G
   Component: Fond FHSG DRV  010 0004
   Serial number: 00000000000001044574
   Coding: 011000
   Part No SW: 5QM 909 144 B    HW: 5QM 909 144 B
   Component: EPS_MQB_ZFLS  173 1081
   Coding: 011F0000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 50F98D860A67B6DB823-8004
   Part No SW: 5Q4 959 392 M    HW: 5Q4 959 392 F
   Component: TSG BFS       006 0247
   Serial number: 54038829404475
   Coding: 003013200000048000000000
   Subsystem 1 - Part No SW: 5Q4 959 812 G    HW: 5Q4 959 812 G
   Component: Fond FHSG PSG  010 0004
   Serial number: 00000000000001018242
   Coding: 091000
   Part No SW: 3Q0 035 876 B    HW: 3Q0 035 876 B
   Component: MU-S-NS-US    853 0890
   Coding: 02730602BE00000051220001001808001F0500E401200405C6
   Shop #: WSC 00066 790 00326
   ROD: EV_MUStd4CDELP_VW37.rod
   Subsystem 1 - Part No SW: 5G6 919 605 D    HW: 5G6 919 605 D
   Component: ABT_Std-2_Nav  252 8130
   Serial number: VWZ6ZMV2875610
   Subsystem 2 - Part No SW: 5NA 919 866 E    HW: -----------
   Component: NAR 2018/19  --- 0810
          B11CF 53 [009] - Deactivated
                    Reset counter: 231
                    Mileage: 15876 km
                    Date: 2020.08.16
                    Time: 08:57:30
                    Voltage terminal 30: 14.2 V
                    SDARS_tuner_status_2-Satellite radio antenna status: Electrical OK
                    SDARS_tuner_status_2-Audio Signal: Not available
                    SDARS_tuner_status_2-Antenna current: 111 mA
                    SDARS_tuner_status_2-Reception quality: No_signal
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 07
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 07
   Coding: 0123060122002017300040
   VCID: 392FD022B9DD179355D-806C
   Part No SW: 5Q0 959 107 P    HW: 5Q0 959 107 J
   Component: HDSG-Modul    H13 0266
   Revision: --------    Serial number: A2-C758-8680-2
   Coding: 0A08
   VCID: 45D7ACD2C5256373215-8010
   Component: OCULowMQBUS   009 0570
   Coding: 02230602C2823A017F1E06000000
   ROD: EV_OCULowMQB.rod
   Part No SW: 4M0 907 594 J    HW: 4M0 907 594
   Component: SAD_STG_1     014 0005
   Coding: 00804073260C
   ROD: EV_SunRoofCONTIAU736_006.rod
End----------(Elapsed Time: 01:33, VBatt start/end: 13.1V/13.2V)-----------
djdracine: Hi.
I don't believe that it's possible to increase the phone favorites beyond 4.
For the SMS text message question, it's normally a setting on the phone itself that enables this function. Try this (the exact process depends on the phone manufacturer):
On the mobile ->In Settings -> Bluetooth -> select the Tiggy connection and ensure that "Show Notifications" is turned on.
For the frozen infotainment screen, try re-setting the hex5F unit; with the (frozen) screen turned-on, hold down the ON/OFF button until the screen turns-off, then turns-on again
