Audi A3 DSG 0AM P17BF fault adaptation error
ricky
C?ID=396939
Hi, I replaced the accumulator on a dsg gearbox, however when I try to do the basic setting thourgh channel 60 I get : 255 6 0 in addition to these fault codes :
Saturday,15,August,2020,13:48:16:01758
VCDS Version: 20.4.1.0 (x64)  HEX-V2 CB: 0.4508.4
VIN: WAUZZZ8P8BA017030   License Plate: AUDI A3
                Address 02: Auto Trans  (0AM 300 058 S)
13:48:08 Group 060
  255
  6
                Address 02: Auto Trans       Labels: 0AM-927-769.CLB
Control Module Part Number: 0AM 300 058 S    HW: 0AM 927 769 D
  Component and/or Version: GSG DSG AG7     403 5220
           Software Coding: 0000020
            Work Shop Code: WSC 38529 001 1048576
                      VCID: 41DF43793D89A7E31C5-8014
001836 - Gear 1
               P072C - 008 - Not Selectable - MIL ON
                    Fault Status: 11101000
                    Mileage: 135062 km
                    Date: 2020.08.12
                    Time: 03:04:33
006293 - Functional Restriction due to Pressure Drop
               P1895 - 000 -  - Intermittent
                    Reset counter: 5
                    Mileage: 135062 km
                    Date: 2020.08.12
                    Time: 03:10:46
001836 - Gear 1
                    Mileage: 135062 km
                    Date: 2020.08.12
                    Time: 03:04:33
                    Reset counter: 5
                    Mileage: 135062 km
                    Date: 2020.08.12
                    Time: 03:10:46
Thanks in advance for your help.
ricky
C?ID=396939
Hi, thanks for your reply, would you know what's the procedure to adapt the nominal measurement ?
NEtech
Denmark
C?ID=56995
First, when removing, use Basic Setting MWB 062 and installing should be in manual, available from erwin.
ricky
C?ID=396939
Will try this tommorow,
Thank you
Golftwincharged
Guyana
C?ID=320847
yeah, you have an incorrect installation with this, make sure you neutralise the gear selectors in its correct N position, the mechatronic must measure 25mm on each selector push forks, when installation is completed make sure the push rods for the clutch fork to be in aligned properly, once that is completed basic settings will go through.
ricky
C?ID=396939
Will try this many thanks for your help.
ricky
C?ID=396939
Hi, after trying the above the first attempt at basic setting worked, however the car is very jerky between 1st and second gear. Tried basic setting and getting 255 18 0 . I also get P175D P175E P189B.
Can anyone help with this ? thank you
siLc
Tallinn, Estonia
C?ID=330192
But does the new accumulator actually hold the needed pressure of 45-60bar? You can check this in the TCM's measuring blocks. Please post a new scan of the current faults.
ricky
C?ID=396939
Hi, these are the pressure values :
Wednesday,16,September,2020,20:08:27:01758
VIN:    License Plate: A3AUDI
20:08:21 Group 030: Hydraulic Pump (V401)
  60.00 bar  pressure supply  S1 (V401)
  42.00 bar  pressure supply  S2 (V401)
  50.12 bar  pressure supply  (actual value - V401)
  2672  pressure supply  AD (actual value - V401)
And these are the fault codes :
                      VCID: 41DF43793D89A7E31DD-8014
006299 - Clutch 2
               P189B - 000 - Clearance too Small - Intermittent
                    Reset counter: 10
                    Mileage: 135065 km
                    Date: 2020.08.17
                    Time: 00:31:17
005982 - Clutch 1 Closes Unintentionally
               P175E - 000 -  - Intermittent
                    Mileage: 135069 km
                    Date: 2020.08.17
                    Time: 01:14:50
005981 - Clutch 1 Opens Unintentionally
               P175D - 000 -  - Intermittent - MIL ON
                    Fault Status: 10100000
                    Fault Frequency: 9
                    Mileage: 135070 km
                    Date: 2020.08.17
                    Time: 01:18:13
               P175D - 001 -  - Intermittent - MIL ON
                    Fault Frequency: 9
                    Mileage: 135070 km
                    Date: 2020.08.17
                    Time: 01:18:13
Thank you !
ricky
C?ID=396939
Hi, replaced the valves related to clutch solenoid as suggested, however I get the following fault when trying do basic setting. 255 | 101 | 0. Help would be very appreciated.
Thanks in advance.
