Audi A6 ABS unit Coding
SolexPower
Sweden
C?ID=256475
Hello helping a friend to replace ABS unit with a used one and exactly the same part number and it had software coding 00000 i login with 07495 and enter code 07395 (workshop 12345) the software code is still 00000. i have tested every guide i can find and change part to another used one with no luck. please help me.
the car is
Audi A6 (4B)
1LA brakes
6 cyl gasoline
Manual transmission
Friday,14,August,2020,12:15:11:52766
VCDS Version: 20.4.2.0 (x64)
VIN: WAUZZZ4B62N143678   License Plate: TMH635
Chassis Type: 4B (4B - Audi A6/S6/RS6/allroad C5 (1998 > 2005))
          75 76 77
Address 01: Engine        Labels: 078-907-551-AZA.lbl
   Part No: 4B0 907 551 M
   Component: 2.7l V6/5VT     G   0002
   Coding: 10712
   Shop #: WSC 02325
   VCID: 2E6B4F1CEAD95BF6B1-FFFE
   WAUZZZ4B62N143678     AUZ5Z0B4038094
18057 - Powertrain Data Bus
            P1649 - 35-10 - Missing Message from ABS Controller - Intermittent
18010 - Power Supply Terminal 30
            P1602 - 35-10 - Voltage too Low - Intermittent
Readiness: 0010 0101
Address 03: ABS Brakes        Labels: 4B0-614-517.lbl
   Part No: 4B0 614 517 H
   Component: ABS/ESP allrad      1328
   Coding: 00000
   VCID: 267BB73CC22913B649-FFFE
            35-00 - -
            57-00 - Electric Circuit Failure
            66-10 - Not Matched - Intermittent
Address 08: Auto HVAC        Labels: 4B0-820-043-MY2.lbl
   Part No: 4B0 820 043 AB
   Component: A6-Klimavollautomat 0105
   Coding: 00000
   Shop #: WSC 02325
   VCID: 5A83D3CCC6D167563D-FFFE
Address 15: Airbags        Labels: 4B0-959-655-AI84.lbl
   Part No: 4B0 959 655 M
   Component: Airbag 8.4E         5003
   Coding: 0001406
   Shop #: WSC 02325 785 00200
   VCID: 3A43734C769187561D-FFFE
Address 17: Instruments        Labels: 4B0-920-xxx-17.lbl
   Part No: 4B0 920 901 A
   Component: KOMBI+WEGFAHRS. M73 D04
   Coding: 00164
   VCID: 1C0F95D48C65D966EF-FFFE
No Faults Found
Address 35: Centr. Locks        Labels:. 4B0-962-258.clb
   Part No: 4B0 962 258 D
   Component: Zentralverriegelung D35
   Coding: 06721
   Shop #: WSC 02325
   VCID: 2A63430CD63137D66D-FFFE
9 Faults Found:
01366 - Opened Due to Crash Signal
            35-00 - -
00955 - Key 1
            09-10 - Adaptation Limit Surpassed - Intermittent
00956 - Key 2
01559 - Drivers Door
            58-10 - Can't Lock - Intermittent
01561 - Rear left door
            59-10 - Can't Unlock - Intermittent
01562 - Rear right door
            60-10 - Won't Safe - Intermittent
            61-10 - Won't De-Safe - Intermittent
Address 55: Headlight Range        Labels: 4Z7-907-357.lbl
   Part No: 4Z7 907 357
   Component: dynamische LWR       D07
   Coding: 00050
   Shop #: WSC 02325
   VCID: 043FCDB414D501A637-FFFE
   Part No: 4B0 035 186 G
   Component: concert II  GRO    0008
   Coding: 00001
   Shop #: WSC 02325
   VCID: 247FAD34B415E1A657-FFFE
00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier
End-------------------------(Elapsed Time: 09:16)--------------------------
SolexPower
Sweden
C?ID=256475
Thank you but I have followed that guid and it didn’t help.
Jacek
Poland
C?ID=360566
You can't have any faults for coding, and you need to fix it: "01435 - Brake pressure sensor 1 (G201) 57-00 - Electric circuit failure"
NEtech
Denmark
C?ID=56995
^Exactly, you need to perform Basic Setting, before removing Ignition, after Coding saved.
Why 07395 for Coding ?
Check link, 06395
SolexPower
Sweden
C?ID=256475
We have fixed that error now still no luck.
SolexPower
Sweden
C?ID=256475
Check link, 06395
There it was in my word blindness i missed that the numbers changed for model in coding section. Thanks for your help every one..
