Steering Angle and a Couple more (2015 Bentley Flying Spur)
kymapman56
C?ID=413045
Guys, forgive me if I haven't posted this question properly. Replying to this post is the only way I could figure out hour to access "Go Advanced" in order to post my scan. I have a 2015 Bentley Flying Spur that I just rebuilt from a total. All body work is done and it' stunning but I still have several electronic/mechanical gremlins I need to sort out. My scan is posted below. I first think I need to reset my Steering Angle Setting. I think it's contributing to ABS, stability control and possibly suspension problems. Can anybody point me in the right direction for a "how to" on resetting my SAS? Also, I have no backup camera function. I'm guessing it's because of a male plug I still have dangling behind the rear bumper. I know this isn't a Bentley forum, but does anybody know where the female side of this plug is? Here's the Autoscan and I still don't think I did the pasting correctly....
Thursday,13,August,2020,19:58:48:24849
VIN: SCBEC9ZA7FC042611   License Plate:
Mileage: 13670km-8494mi   Repair Order: Aug 13 2020 20:00
Chassis Type: ZA-BY62 (3W0)
Scan: 01 02 03 05 06 07 08 09 11 31 13 15 16 17 19 23 28 2E 34 36
          37 38 46 47 48 53 56 5D 65 66 68 6C 6D 71 76 77
VIN: SCBEC9ZA7FC042611   Mileage: 13670km-8494miles
11-Engine II -- Status: Malfunction 0010
31-Engine other -- Status: Malfunction 0010
38-Roof Electronics -- Status: OK 0000
48-Seat, Rear, DS -- Status: OK 0000
5D-Operations -- Status: Malfunction 0010
66-Seat, Rear -- Status: OK 0000
68-Wiper Electr. -- Status: OK 0000
71-Battery Charger -- Status: Malfunction 0010
Address 01: Engine (J623-CVAA)       Labels: None
   Part No SW: 07C 906 023 AA    HW: 07C 907 309
   Component: ME17.1.6      H16 0301
   Revision: MHH16---    Serial number: VWX3Z0N7008660
   Coding: 0D2A0032436E00020003
   Shop #: WSC 00083 790 00199
   ASAM Dataset: EV_ECM60TMP11107C906023AA 001002
   ROD: EV_ECM60TMP07C906023AC.rod
   VCID: 6099A4A6BAC5B21B323-8034
4327 - Function Restriction due to Faults in Other Modules
          U1113 00 [047] - -
                    Mileage: 13670 km
                    Date: 2020.08.12
                    Time: 00:13:38
                    Engine speed: 592.00 /min
                    Normed load value: 17.3 %
                    Coolant temperature: 93 °C
                    Intake air temperature: 51 °C
                    Voltage terminal 30: 14.135 V
16672 - Please Check DTC Memory of ECU Number 2
          P1923 00 [047] - -
                    Mileage: 13670 km
                    Date: 2020.08.12
                    Time: 00:13:39
                    Engine speed: 596.00 /min
                    Voltage terminal 30: 14.088 V
Readiness: 1110 1101
Address 02: Auto Trans (J217)       Labels:* None
   Part No SW: 4W0 927 158 D    HW: 0CU 927 760 A
   Component: OBL 60 MPIRdW H16 0001
   Revision: --H16---    Serial number: VWX3Z0N7008660
   Shop #: WSC 00083 790 00191
   ASAM Dataset: EV_TCMAL450211 002010
   ROD: EV_TCMAL450211_BY62.rod
   VCID: 3FDB47DA67FBADE36B9-806A
Address 03: ABS Brakes        Labels: None
   VCID: 55F78572FD4747B3515-8000
No Faults Found
   Part No SW: 3D0 909 137 G    HW: 3D0 909 137 G
   Component: C0 Kessy            6850
   Revision: 00H24072    Serial number: VWX3Z0N7008660
   Coding: 0405741
   Shop #: WSC 00083 790 00188
   VCID: 2B03038A8F432143D71-807E
00181 - Access/Start Authorization Antenna (in Rear bumper) (R136)
                    Fault Frequency: 0
                    Reset counter: 241
                    Date: 2064.00.00
                    Time: 00:00:14
   Part No SW: 4W0 959 760 A    HW: 4W0 959 760
   Component: MEM-BFS       H04 0700
   Revision: AA000000    Serial number: 00000105175888
   Coding: D0081F0085070090090001010101002100012727000000
   Shop #: WSC 00083 790 00242
   VCID: 40D944261AC5D21B123-8014
Address 07: Control Head        Labels: 3D0-907-048.clb
   Part No SW: 3D0 907 048     HW: 3D0 907 048
   Component: J127 KBT vorn       0100
   Revision: ABH23001    Serial number: VWZ6Z7P0143059
   VCID: 6393ABAAA713A9032F1-8036
   Part No: 3W5 907 040 K
   Component: Climatronic BY621   3030
   Coding: 0000101
   VCID: 3E253ADE6C31A4EB60F-806A
Address 09: Cent. Elect.        Labels:. 3D0-937-049-V2.clb
   Part No SW: 3D0 937 049 Q    HW: 3D0 937 049 Q
   Component: J519                7700
   Revision: -4007---    Serial number: --------------
   Coding: 40820000AB2A11C02508030000000000
   VCID: 38292CC64E159ADBAA3-806C
Address 11: Engine II (J624)       Labels: None
   ASAM Dataset: EV_ECM60TMP21107C906023AA 001002
   ROD: EV_ECM60TMP07C906023AA.rod
14629 - Fuel Pump Control Module
          P025C 00 [175] - Short to Ground
                    Mileage: 13670 km
                    Date: 2020.08.12
                    Time: 00:13:39
                    Engine speed: 600.50 /min
                    Normed load value: 16.9 %
                    Intake air temperature: 50 °C
                    Voltage terminal 30: 14.041 V
Address 13: Auto Dist. Reg        Labels: None
   Part No SW: 4W0 907 567 A    HW: 4W0 907 567 A
   Component: AC201  NAR BY681   00941
   Revision: 00041000    Serial number: 00000000632573
   Coding: 0020681
   Shop #: WSC 00083 790 00202
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 100
                    Mileage: 13670 km
                    Date: 2020.08.12
                    Time: 00:37:34
                    Count: 4
                    Reset counter: 100
                    Mileage: 13670 km
                    Date: 2020.08.12
                    Time: 00:37:34
                    Count: 38
   Part No SW: 3W3 959 655 A    HW: 3W3 959 655 A
   Component: VW10Airbag22M H01 0003
   Revision: --------    Serial number: 003FW0000AW6
   Coding: 00000000000000000000000000000000324D
   ASAM Dataset: EV_AirbaVW10BPABY62X 001002
   ROD: EV_AirbaVW10BPABY62X.rod
   VCID: 45D755320527F733215-8010
   Subsystem 1 - Part No SW: 4W0 959 339 A    HW: 4W0 959 339 A
   Component: BF-Gewichtss.  H03 0201
   Serial number: 5850000R145090AU4B
   Serial number: 3572DRB40000F6E1225V
   Serial number: 3582DRB40000F72079B
   Serial number: 35128RB40000719A993N
   Serial number: 35228RB40000719BE95W
   Serial number: 35547RB400007223790A
   Serial number: 35647RB40000721CEFB0
Address 16: Steering wheel        Labels: 7L6-953-549.lbl
   Part No: 7L6 953 549 K
   Component: J527                3601
   Coding: 0000042
   Shop #: WSC 00083 790 00244
   VCID: 47CB5F3A33EBE523D39-8012
Address 17: Instruments        Labels: 3Wx-920-xxx-17.lbl
   Part No SW: 3W0 920 851 R    HW: 3W0 920 851 R
   Component: J285 KOMBI-INST.    5555
   Revision: KPH10V04
   Coding: 0034214
   Shop #: WSC 05514 002 1048576
   VCID: 45D7553209A7F733215-8010
Address 19: CAN Gateway        Labels: None
   Part No SW: 3W0 909 901     HW: 3W0 920 851 R
   Component: J533  GW-K-CAN TP20 5555
   Revision: KPH10V04
   Coding: DFFBFFFFEB551702
   VCID: 76B5E2FE04C12CAB78F-8022
Address 23: Brake Booster        Labels: None
   Part No: 3W0 907 563 B
   Component: BREMSBOOSTER    007 0430
   Revision: 00007000    Serial number: 00000000030921
   VCID: 3A2D36CE701988CB5C7-806E
Address 28: HVAC, Rear (J524)       Labels: None
   Part No SW: 4W0 035 008     HW: 4W0 035 008
   Component: CLIMATE ECU   H06 0062
   Revision: P0H06004    Serial number: 51400095212001
   Coding: 00000000010102
   VCID: 6B83C38A43C3E143971-803E
   Subsystem 1 - Part No SW: 4W0 907 042 A    HW: 4W0 907 042
   Component: RBM-BY621  H09 0055
   Serial number: WA108623000007669040
04062 - Remote Display and Operating Unit 1 -- Software Version
                    Reset counter: 100
                    Mileage: 13670 km
                    Date: 2020.08.12
                    Time: 00:32:16
   Revision: A1001003    Serial number: 7666318783
   Coding: 030100
   VCID: 2B03038A83032143D71-807E
Address 34: Level Control        Labels: None
   Part No: 4W0 907 553
   Component: LUFTFDR.-CDC- 3C3V0 7705
   Coding: 0005541
   VCID: 78A9ECC60E955ADB6A3-802C
   Component: MEM-FS        H04 0700
   Revision: AA000000    Serial number: 00000105174410
   Coding: D0081F0085870090090001010101012100012727000000
   Shop #: WSC 00083 790 00236
Address 37: Navigation (J0506)       Labels: None
   Part No SW: 3W0 035 017 Q    HW: 3W0 035 017 Q
   Component: RNS-MID       H23 0584
   Revision: AB001001    Serial number: VWZ6Z7P0143059
   Coding: 04010002000000044000
   VCID: 3B2333CA7363B1C3471-806E
   Subsystem 1 - Part No: 3W0 919 859 BN
   Component: NAR V4  7963
Address 38: Roof Electronics        Labels: None
   Part No: 3W0 907 135 H
   Component: Dachmodul           0910
   Coding: 0020493
   VCID: 3B2333CA7F23B1C3471-806E
Address 46: Central Conv.
Address 47: Sound System        Labels: None
   Part No SW: 4W0 035 465     HW: 4W0 035 465
   Component: DSP 10 Kanal        0010
   Revision: 00H08001    Serial number: 75824013012004
   VCID: 72BDDEEE68A9308B547-8026
Address 48: Seat, Rear, DS
Address 53: Parking Brake (J540)       Labels: None
   Part No SW: 4W0 907 801     HW: 4W0 907 801
   Component: EPB-4         H01 0002
   Revision: --------    Serial number: 00000000001559
   ASAM Dataset: EV_BY62XParkiBrake 001008
   ROD: EV_BY62XParkiBrake.rod
   VCID: 74B1D8F61E3D3EBB46B-8020
Address 56: Radio (J0506)       Labels: None
Address 5D: Operations
Address 65: Tire Pressure        Labels: Redir Fail!
   Part No SW: 3W7 907 273 D    HW: 3W7 907 273 D
   Component: J0502 RDK           0007
   Revision:   004007    Serial number: 00000600001530
   Coding: 0000E03175CA4286EB75B9FD52EB0097FC004B6E4B6E4B6E4B6E4B64
   Shop #: WSC 00083 790 00213
   VCID: 41DF41221DCFDB131DD-8014
Address 66: Seat, Rear (J877)       Labels: None
   Component: MEM-BFS-Fond  H04 0700
   Revision: AA000000    Serial number: 00000105175214
   Coding: C0081E8085810000090021000001000000002727000000
   Shop #: WSC 00083 790 00190
Address 68: Wiper Electr.        Labels: 3Wx-955-023.clb
   Part No: 3W5 955 023 M
   Component: Wischermodul       ª0401
   Shop #: WSC 00000 725 65552
   VCID: 44D1483602DDCE3B36B-8010
Address 6C: Back-up Cam.        Labels: None
   Part No SW: 4W0 907 441     HW: 4W0 907 441
   Revision: 00H13000    Serial number: 525 PA8J450365
   Coding: 2020003
   VCID: 74B1D8F612BD3EBB46B-8020
                    Reset counter: 100
                    Mileage: 13670 km
                    Date: 2020.08.12
                    Time: 00:30:08
                        Reverse OFF
                    Count: 3
Address 6D: Trunk Elect.        Labels: None
   Part No SW: 4W0 959 107 A    HW: 4W0 959 107 A
   Shop #: WSC 09592 002 1048576
   ASAM Dataset: EV_HDSGBY621 001002
   ROD: EV_HDSGBY621.rod
   VCID: 3B2333CA73E3B1C3471-806E
Address 71: Battery Charger (J367)       Labels:* None
   Part No SW: 3W3 915 181 B    HW: 3W3 915 181 B
   Component: EMM Batt Man  H05 0570
   Serial number: 0000000001
   Coding: 5E0100
   ASAM Dataset: EV_BatteChargVaria1 002019
   ROD: EV_BatteChargVaria1_002.rod
   VCID: 38292CC642D59ADBAA3-806C
   Subsystem 1 - Part No SW: 8K0 915 181 C    HW: 8K0 915 181 C
   Component: J367-BDM  H07 0141
   Serial number: 41134808581041236367
13705472 - Databus
          [DTC_TIMEOUT_ESP]
                    Reset counter: 140
                    Mileage: 13670 km
                    Date: 2020.08.12
                    Time: 00:37:32
   Part No SW: 3W0 919 283 G    HW: 3W0 919 283 E
   Component: J446  ST Parkhilfe  0111
   Revision: 11H02001    Serial number: 58131416000857
   Coding: 0300066
Address 77: Telephone (J412)       Labels:| 3C8-035-730-A.clb
   Part No SW: 3D0 035 730 D    HW: 3D0 035 730 D
   Component: Telefon       024 0982
   Revision: --------    Serial number: 35502105144334
   Coding: 020106010100010000000001
   ASAM Dataset: EV_UHVPremi 002709
   ROD: EV_UHVPremi.rod
   VCID: 1D67DD52CD37DFF3595-8048
End----------(Elapsed Time: 03:00, VBatt start/end: 14.3V/14.2V)-----------
Hi and welcome.
I've split this into its own thread.
Looks like the ABS didn't read properly in that scan. What happens when you access it directly?
