Need of abs code
Kristian Hasa
Albania
C?ID=309376
Hello. A client brought a audi a4 he changed some type of module and now the abs doesnt have a code in. Can anybody help me, I need the code of the abs. Thanks.
Here is the autoscan
Thursday,13,August,2020,09:39:47:50280
VCDS Version: 19.6.2.0 (x64)
VIN: WAUZZZ8EX3A381501   License Plate:
          67 69 75 76 77
VIN: WAUZZZ8EX3A381501   Mileage: 318320km-197794miles
Address 01: Engine        Labels: 038-906-019-AVF.lbl
   Part No: 038 906 019 JT
   Component: 1,9l R4 EDC G000SG  1572
   Coding: 00002
   Shop #: WSC 63251
   VCID: 72A802973C6B49DFA1-4B3C
   WAUZZZ8EX3A381501     AUZ6Z0C0096916
17552 - Mass Air Flow Sensor (G70)
            P1144 - 35-00 - Open or Short to Ground
17996 - Engine Mount Solenoid Valves (N144/N145)
            P1588 - 35-10 - Open Circuit - Intermittent
Readiness: 0 0 X X X
Address 03: ABS Brakes        Labels: 8E0-614-517.lbl
   Part No: 8E0 614 517
   Component: ABS/ESP front       3429
   Coding: 00000
   VCID: 658269CBFDA5AE6734-51F2
            35-00 - -
   Part No: 8E0 820 043 AA
   Component:   A4 Klimaautomat   1119
   Coding: 00000
   Shop #: WSC 63251
   VCID: 608C78DFE287CB4FC7-5160
Address 15: Airbags        Labels: 8E0-959-655-84.lbl
   Part No: 8E0 959 655 B
   Component: Airbag 8.4EP        2000
   Coding: 0011602
   Shop #: WSC 63251 000 00000
   VCID: 3620FE87408315FF4D-5184
01217 - Side Airbag Igniter; Driver Side (N199)
            002 - Lower Limit Exceeded - MIL ON
Address 17: Instruments        Labels: 8E0-920-9xx-8E2.lbl
   Part No: 8E0 920 900 MX
   Component: KOMBI+WEGFAHRS. RB8 D42
   Coding: 00100
   Shop #: WSC 00001
   VCID: 06404E4720E3457F9D-5184
Address 45: Inter. Monitor        Labels: 8E0-951-177.lbl
   Part No: 8E0 951 177
   Component: Innenraumueberw.   0604
   Coding: 00001
   VCID: 6B961FF31B41981762-5118
Address 46: Central Conv.        Labels:. 8Z0-959-433.lbl
   Part No: 8Z0 959 433 AC
   Component: Komfortgerát TA5    1310
   Coding: 06720
   Shop #: WSC 02138
   VCID: 075E434327E95C77E6-4B1E
   Subsystem 1 - Part No: 8E1959801B
   Component: Tõrsteuer.FS BRM 0003
   Subsystem 2 - Part No: 8E1959802B
   Component: Tõrsteuer.BF BRM 0003
01561 - Rear left door
            59-00 - Can't Unlock
            61-00 - Won't De-Safe
01562 - Rear right door
            62-10 - No or Incorrect Adjustment - Intermittent
            80-00 - Single-Wire Operation
Address 76: Park Assist        Labels: 8Z0-919-283.lbl
   Part No: 8Z0 919 283 A
   Component: Parkingsyst. A4 RDW D09
   Coding: 10004
   Shop #: WSC 00186
   VCID: 43C697535051B057FA-5160
01546 - Sensor for Parking Aid; Rear Mid-Left (G204)
            30-00 - Open or Short to Plus
End-------------(Elapsed Time: 08:14, VBatt start/end: 13.7V)--------------
ai_Ingo
Germany (Auto-Intern)
C?ID=56975
Hi, According to my research, the login code should be 09555. After entering the login you can enter the coding. This should be 04255 like Boki Ar said. It is important not to close the control unit after coding, but to adjust the steering angle sensor directly. Otherwise the coding is not accepted.
C18,Note #1: Coding is accepted after a specific Login has been carried out.
C19,Note #2: Special Coding 04499 is used for BFB Engine with 1LT Brakes and Multitronic.
C20,Note #3: After successful Coding the Steering Angle Sensor Alignment needs to be carried out.
