DSG 0B5 tranny calibration keeps failing for me, any help is appreciated
ninsei
C?ID=20445
Hi. Been trying and failing for years to do this procedure: http://wiki.ross-tech.com/wiki/index.php/7-Speed_S-Tronic_Direct-Shift_Gearbox_(DSG/0B5)
on my 2010 Audi S4.
On Erase counter for start and stop processes, I get request out of range.
On Clutch valve calibration, I get aborted - safety reasons
Distance senor calibration finishes correctly.
I start the procedure when tranny fluid temp is at 43 deg. I also tried it at 53 deg.
Below is a full autoscan of my car:
Wednesday,12,August,2020,10:02:06:19019
VCDS Version: 20.4.2.0 (x64)
VIN: WAUBxxxxxxxx   License Plate:
Mileage: 142840km-88756mi   Repair Order:
Chassis Type: FL-AU48 (8T0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 42 46 52 53 55 56 5F 62 6C
          72
VIN: WAUB   Mileage: 142840km-88756miles
Address 01: Engine (J623-CCBA)       Labels:. 06E-907-551-CAK.clb
   Part No SW: 8K0 907 551 D    HW: 8K0 907 551 A
   Component: 3.0T SIMOS84  H06 0003
   Revision: --H06---
   Coding: 0104000A240F0128
   Shop #: WSC 06325 000 00000
   ASAM Dataset: EV_ECM30TFS0218K0907551D 001003
   ROD: EV_ECM30TFS0218K0907551D.rod
   VCID: 326BDE3965652A16D5-8066
Readiness: 0010 1101
   Part No SW: 8K1 927 156 AD    HW: 0B5 927 156 E
   Component: 0B5 30TFSINAR H04 0002
   Revision: --H04---    Serial number: 0000001150
   Shop #: WSC 04742 780 00200
   ASAM Dataset: EV_TCMDL501 A02044
   ROD: EV_TCMDL501.rod
   VCID: 77FD2F2DCE870F3E22-8022
   Part No SW: 8K0 907 379 CA    HW: 8K0 907 379 AN
   Component: ESP8 quattro  H04 0010
   Coding: 294D18
   Shop #: WSC 06325 123 12345
   VCID: 7AFB3619F59512565D-802E
   Part No SW: 8K0 907 064 DG    HW: 8K0 907 064 DG
   Component: BCM2 1.1      H02 0321
   Coding: 090100
   VCID: 78FF2C11CB9900462B-802C
   Subsystem 1 - Part No SW: 8T0 959 754 AD    HW: 8T0 959 754 AD
   Serial number: 0509000018032018
   Component: J764 ELV MLB  H36 0042
   Serial number: 0209000037036009
   Component: KLIMA 3 ZONEN H08 0160
   Revision: C1000000    Serial number: 01130620090592
   Coding: 66102000
   VCID: 000F44F19349488613-8054
   Component: BCM1 1.0      H25 0380
   Revision: 10025001    Serial number: 00000000286641
   Coding: 26001091043CAF010000080300003D0D4F1C520800010161000000
   VCID: 3C77F001BF21EC660F-8068
   Component: WWS 150609  H06 0070
   Serial number: SWF09060150101
   Coding: 00FD11
   Component: RLS  H04 0003
   Serial number: 10506930
   Coding: 025028
   Component: E1 - LDS  H08 0090
   Serial number: 00000000000406091607
   Subsystem 4 - Part No SW: 8K0 907 410 B    HW: 8K0 907 410 B
   Component: HOMELINK  H01 0010
   Part No SW: 8K0 919 475 H    HW: 8K0 919 475
   Component: PARKHILFE 4K  H06 0050
   Revision: 11001001    Serial number: 39940916408926
   Coding: 20010D
   VCID: 3E73FA09A93DFE7621-806A
01543 - Parking Aid Warning Chime (H15)
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 134
                    Mileage: 142848 km
                    Date: 2020.08.12
                    Time: 09:42:43
                    Temperature: 27.0°C
   Part No SW: 8K0 959 655 H    HW: 8K0 959 655 H
   Component: AirbagVW-AU10 H37 0520
   Serial number: 003EGD022PLA
   Coding: 303836354230303030304A55304C384B3053
   VCID: 428B8EF9D5C59A9645-8016
   Subsystem 1 - Part No SW: 8K0 959 339 B    HW: 8K0 959 339 B
   Serial number: 5810000R09000047UW
   Serial number: 6334MSME48534A33D
   Serial number: 6344MSME4930747EM
   Serial number: 6352QSME412F430CI
   Serial number: 6362QSME51304F1CJ
   Serial number: 63732SME41270016K
   Serial number: 63832SME54302F34-
   Revision: --------    Serial number: 90315IF9000FX
   Coding: 000036
   VCID: 3D71FD05A43BE56E38-8068
   Part No SW: 8K0 920 980 Q    HW: 8K0 920 980 Q
   Component: KOMBIINSTR.   H04 0253
   Revision: 00100000    Serial number: BY020AC69
   Coding: 8B1709000300D705020000
   VCID: 408F84F1D3C9888653-8014
   Part No SW: 8T0 907 468 T    HW: 8T0 907 468 K
   Component: GW-BEM 4CAN-M H09 0101
   Revision: EB700052    Serial number: 5200E095278163
   Coding: 00C303
   VCID: 52ABBEB90DA50A16F5-8006
   Component: J367-BDM  H06 0160
   Serial number: 1907DB75140509
   Part No SW: 8K0 959 793 H    HW: 8K0 959 793 D
   Component: TSG FA        H11 0306
   Revision:             Serial number: 0000008948033
   Coding: 011C03204000410001
   VCID: 458195E5CCEBADAE60-8010
   Revision: 00002001    Serial number: 0119049461
   Coding: 0106063A007A440400B0010000000000
   Shop #: WSC 06342 123 12345
   Component: GTO BF  H06 0050
   Serial number: 00000000000000143938
   Subsystem 3 - Part No SW: 8K0 959 591 A    HW: 8K0 959 591
   Component: J245 PS037  H06 0041
   Part No SW: 8K0 959 792 H    HW: 8K0 959 792 D
   Revision:             Serial number: 0000008936464
   Coding: 011C03205000410001
   VCID: 448788E1C7D194A677-8010
   Component: EPB Audi B8   H09 0090
   Revision: 00000003    Serial number: 00000000391164
   VCID: 3467D82197712426C7-8060
   Part No: 8K5 907 357
   Coding: 0000004
   Shop #: WSC 06324 000 00000
   VCID: 77FD2F2D06870F3E22-8022
   Part No SW: 4F0 035 082 A    HW: 4F0 035 082
   Component: Radio U SIRIU H45 0021
   Revision: AB001007    Serial number: 335FS097516611
   Coding: 020000020100000001
   VCID: 1D311D8504FB856E18-8048
   Part No SW: 8T1 035 664 A    HW: 8T1 035 664 A
   Component: H-BN-NA       H41 0042
   Revision: --------    Serial number: 490FU097509024
   Coding: 010200000206E1EF01000F0E000000030000
   VCID: 3663E229810D3636F9-8062
   Subsystem 1 - Part No: 8R0 060 884 F
   Component: NAR 2009/2010  5304
   Component: DU7 High  H43 0306
   Serial number: 9356FM091013904
   Subsystem 3 - Part No SW: 8T0 919 609 F    HW: 8T0 919 609 F
   Serial number: 00000001113632
   Component: CD-Database  1293
   Part No SW: 8K0 959 795 C    HW: 8K0 959 795 C
   Revision:             Serial number: 0000101305912
   Coding: 010C03204000210001
   VCID: 428B8EF9DDC59A9645-8016
   Part No SW: 8T0 907 441 B    HW: 4L0 907 441 A
   Component: J772__Rearview      0070
   Revision: --H12---    Serial number: 525PA8-J939118
   Coding: 1000006
   VCID: 377DEF2D4607CF3EE2-8062
   Revision:             Serial number: 0000101305918
End-------------------------(Elapsed Time: 03:38)--------------------------
Your transmission has software version 0002:
   Component: 0B5 30TFSINAR H04 [COLOR="#0000FF"][B]0002[/B][/COLOR]
There appear to be three newer versions for it: 0003, 0004, and 0006:
https://vag-flashinfo.de/index.php?partno=8K1+927+156+AD&as=
No guarantees that getting it updated will resolve this, but if it were mine, I would certainly try it.
ninsei
C?ID=20445
Thanks for the reply. Forgot to mention that i currently have the GIAC TCU and ECU tune. That said, I've also tried and failed to do this calibration many times, with the stock ECU and TCU SW. I've saved VCDS logs pre GIAC tune and here's the TCU info pre GIAC, which also failed in the same way when doing this calibration procedure:
Address 02: Auto Trans (J217) Labels: 0B5-927-156.clb
Part No SW: 8K0 927 156 M HW: 0B5 927 156 D
Component: 0B5 30TFSINAR H02 0003
Revision: --H02--- Serial number: 0000000921
ASAM Dataset: EV_TCMDL501 A02035
