No communication
bobfish45
England
C?ID=373148
After removing and replacing injectors on my 2.0 audi a6 c6 tdi, engine code BRE, I connected my hex v2 only to see the message,"no communication with gateway installation," can anyone help? Thanks, Rod.
Santos
Can you connect to any other module? What happens when you click [Options] [Test]? What version of VCDS do you have installed?
South Molton, UK
Do you have the ignition turned on?
South Molton, UK
Yes Dave. It turned out that a pin was bent over on the injector loom, obviously clumsy fitting:rolleyes:
Glad you solved it - I had to ask about the ignition, you would probably be surprised how many people do a scan with the ignition off :facepalm:
