HVAC Adaptation failed >> 01087 - Basic Setting Not Performed
Guray
C?ID=328540
Hi all,
This is my first problem encounter with HVAC module and I will really appreciate your help here.
1:> Very short history for a background
Everything started with error codes
And ended up with 2 AC pipes been changed
2:> Then another problem manifested itself >> Basic settings not performed.
a) Here my own garage is asking about 20 hours of labor to take dash board totally out in order to access unit itself
b) Official Audi Reading performed diagnostics, same results here as well, asking 3K GBP to remove dashboard and access the air_distribution_hoising
3:> Activity in question
Performing basic settings adaptation procedure ended up in failure. Have a video captured during adaptation and key point captured as still images following
Basic transcript/key moments are
a) Basic settings adaptation started (On/OFF/Next)
b) 00:45.57 sec>>Flaps started to move and make noise (first still image)
c) 01:17.47 sec >> learn/adap switched to <0.00V> <Not Occup.> <0.0%> and <11.70V> (second still image)
d) 01:17.57 sec >> switched to <Aborted> <N/A> <N/A> <11.70V> (thurd still image)
e) 01:17.70 sec >> Switched to <N/A> <N/A> <N/A> <N/A> (fourth still image)
4:> Questions
a) Are those basic settings importable ? Assuming I have them as binary file, can it be uploaded to controller using VCDS or been manually populated ?
b) Any way (using VCDS) to disable 'perform basic settings adaptation' routine been a show_stopper for A/C compressor to work properly ?
c) Any means to 'reset' OR 'reboot' controller and force it back to normal ? Some suggest to disconnect battery and wait for 10 mins ?
5:> The Bottom line
In the most AirCon requiring time of the year, it is quite annoying to not have A/C working and I will appreciate any shape or form of Your help to get this done.
Many thanks in advance, stay safe,
Guray
P.S: Scan outputs and visuals >> https://1drv.ms/u/s!AhOrIZkYCeGQgel2TRPHh3D18D2hCA?e=PuWeQ0
From your scan at the above link:
   Part No SW: 4L0 910 043     HW: 4L0 820 043 F
   Component: KLIMABETAETIGUNGH05 0040
   Revision: 00---007    Serial number: 00000000016908
   Coding: 0131094
   Shop #: WSC 31414 790 00001
   VCID: 619F58039D4D40433C5-8034
00710 - Defroster Flap Positioning Motor (V107)
            003 - Mechanical Failure
                    Fault Status: 01100011
                    Reset counter: 12
                    Mileage: 246343 km
                    Date: 2020.08.07
                    Time: 15:55:09
                    Voltage: 13.10 V
                    Temperature: 33.0°C
                    (no units): 75.0
                    (no units): 187.0
                    Temperature: 31.0°C
02380 - Positioning Motor for Right Side Vent (V300)
                    Reset counter: 12
                    Mileage: 246343 km
                    Date: 2020.08.07
                    Time: 15:55:09
                    Voltage: 13.10 V
                    Temperature: 33.0°C
                    (no units): 190.0
                    (no units): 125.0
                    Temperature: 31.0°C
00714 - Centre Right Vent Positioning Motor (V111)
                    Fault Status: 00100011
                    Reset counter: 52
                    Mileage: 246343 km
                    Date: 2020.08.07
                    Time: 15:55:09
                    Voltage: 13.10 V
                    Temperature: 33.0°C
                    (no units): 130.0
                    (no units): 75.0
                    Temperature: 31.0°C
                    Fault Status: 01100101
                    Reset counter: 12
                    Mileage: 245088 km
                    Date: 2020.07.22
                    Time: 12:23:41
You need to fix the hard faults with the positioning motors before Basic Settings will run successfully.
However, I do not think any of these faults would prevent the A/C Compressor from running.
PS: No, Basic Settings are not "importable". I do not think a cold boot will help, but it certainly doesn't cost much to try.
Guray
C?ID=328540
Appreciate Your reply Uwe, thanks for that,
Indeed, accessing flap motors to service them is 'biggest' problem I have as dashboard removal is quite costly endeavour, for money asked by official Audi service, I can buy a small hatchback :-(. I've checked again with my VCDS, looking at measuring blocks and compressor shut-off codes seems to be '2', '12, '0' and '0'. From info available on internet I've found that
2 Compressoroff (basic setting not performed or not performed without error.)
and
12 Compressor off (request from the engine control unit, via data bus.
So, my next steps seems to be dashboard removal and replacement of V107, V300 and V111 flap servo motors.
Thanks again for Your help, Regards,
Guray
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
Like UWE said , Inside flap will not stop Compressor from running, so you have different problem.
On My Mk5 fresh air flap was making terrible noise , never was able to close before I chnage it, but never stop Compressor form running.
And why would they chnage A/C pipe, High Pressure sensor should be replaceable by it self .
