drval85
Hi,
New user here! My name is Dan. I bought a 2009 VW GTI a year ago and installed a euro switch with auto position (but no rain/light sensor). It worked like this:
Off - DRLs (set as fogs)
Auto- low beams only- NO city lights or side markers (like when xenons are set as DRLs)
Parking- city lights and side markers on (Pull for fogs)
On- city lights, side markers and low beams on (Pull for fogs)
Lights off when key was removed from ignition at any position except parking.
I recently had my instrument cluster changed. Now, city lights stay on at all positions. I assumed it was set to Scandinavian DRLs, but it wasn’t. Also, the country code was set at 0.
If anyone can help me go back to the above settings, it would be greatly appreciated. Other than the settings above and the lights turning off when the key is removed, I am completely open to changing other settings- country code, coming home, leaving home etc. are not a concern.
I assume it's some combination of country code, CH/LH settings, DRL, and the assistance driving light settings.
Thanks!
Dan V
VCDS Version: Release 14.10.1
Data version: 20150130
Monday,23,February,2015,15:15:00:27490
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 55 56 65
VIN: WVWEV71K09W031131 Mileage: 84890km-52748miles
Address 01: Engine (CCT) Labels: 06J-906-026-CCT.clb
Part No SW: 1K0 907 115 AE HW: 1K0 907 115 AA
Component: 2.0l R4/4V TFSI 0030
Revision: AAH03--- Serial number: VWX7Z0H53N58R1
Coding: 0403010A18070160
Shop #: WSC 01279 785 00200
VCID: 69F76FE240128069D9E-803C
Address 03: ABS Brakes (-----) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AN HW: 1K0 907 379 AN
Component: ESP MK60EC1 H45 0107
Revision: 00H45001
Coding: 113B600D492500FB880C06E7921A00413000
Shop #: WSC 63470 001 1048576
VCID: 7EDD2CBEE99C17D11CC-802B
Part No SW: 1K0 820 047 JT HW: 1K0 820 047 JT
Component: Climatic PQ35 143 1515
Revision: 00143034 Serial number: 00000000000000
VCID: 7F23D1BA2E961ED917A-802A
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C8 937 049 E HW: 3C8 937 049 E
Revision: 00H54000 Serial number: 00000008520456
Coding: B78D8F214004150047140000001400000019770B5C000100000000000000
Shop #: WSC 44637 001 104857
VCID: 334BCD8A525E0AB9A32-8066
Component: Wischer 020608 021 0501
Coding: 00038805
Shop #: WSC 44637
Address 0F: Digital Radio Labels: 8E0-035-593-SIR.lbl
Part No SW: 8E0 035 593 M HW: 8E0 035 593 M
Component: SDAR SIRIUS H07 0150
Revision: 00000000 Serial number: AUZ4Z7H0341173
Coding: 0000000
Reset counter: 108
Mileage: 84535 km
Time: 09:07:25
Part No SW: 1K0 909 605 AB HW: 1K0 909 605 AB
Component: 6K AIRBAG VW8R 034 8000
Revision: 05034000 Serial number: 003B6D0BCE2T
Coding: 0013899
Shop #: WSC 01269 785 00200
VCID: 6CF916F64FE09541A28-8039
Subsystem 1 - Part No: 1K0 959 339 G
Component: BF-Gewichtsens. 007 0007
Subsystem 2 - Serial number: 6332MSME3D7506409
Subsystem 3 - Serial number: 6342MSME32062750/
Subsystem 4 - Serial number: 6352QSME6F662229P
Subsystem 5 - Serial number: 6362QSME736116035
Subsystem 6 - Serial number: 63727SME167D4D138
Subsystem 7 - Serial number: 63827SME167D53769
Part No SW: 1K0 953 549 BP HW: 1K0 953 549 BP
Component: J0527 752 0101
Coding: 0002022
VCID: 012757425862682961E-8054
Component: E0221 002 0010
Part No SW: 1K6 920 974 HX HW: 1K6 920 974 HX
Component: KOMBIINSTRUMENT VDD 2416
Revision: V0005000 Serial number: VWX7Z0H53N58R1
Coding: 0005103
Shop #: WSC 08272 444 12594
VCID: 11076702080218A9F1E-8044
Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 Q HW: 1K0 907 951
Component: J533 Gateway H07 0062
Revision: H07 01 Serial number: 040608F1000771
Coding: E9811F070013020000
VCID: 354FF3925C2A14898D6-8060
Part No SW: 1K6 919 879 HW: 1K6 919 879
Component: Kompass 001 0003
Revision: 00001000 Serial number: 1225223T3AVG03
VCID: 7DDF2BB2249A0CC9056-8028
Component: IMMO VDD 2416
Shop #: WSC 59975 001 1048576
Part No SW: 1K0 959 701 M HW: 1K0 959 701 M
Component: Tuer-SG 006 1207
Coding: 0001077
VCID: 3851FAA64B38E9E1960-806D
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.074 H08 1901
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 CT HW: 1K0 959 433 CT
Component: KSG PQ35 RDK 052 0221
Revision: 00052000 Serial number: 00000000000000
Coding: 12900E885103403F7F04058FB0080A04889C00
VCID: 04295E5647707D014A8-8051
Part No SW: 1K0 959 702 M HW: 1K0 959 702 M
Coding: 0001076
VCID: 3957FFA27032F0E969E-806C
Address 55: Headlight Range Labels: 1T0-907-357.lbl
Part No: 1T0 907 357
Component: Dynamische LWR 0003
Coding: 0000003
VCID: 74C90E9617D04D817A8-8021
Part No SW: 1K0 035 180 L HW: 1K0 035 180 L
Component: Radio PM6 019 0037
Revision: 00019000 Serial number: VWZ5Z7H2236096
Coding: 0040401
VCID: 29772FE28092406919E-807C
Component: RDK 0450
Coding: 0100101
End-------------------------(Elapsed Time: 01:16)--------------------------
Thanks!
Dan V
