Vw Golf R 2016 missing message codes no l
Galee
U.K.
C?ID=207647
Hello all members I have here a 2016 Vw Golf R DSG which is a bit poorly at the moment. Not much previous info is know as the veichle has come from auction. When i first got it none of the steering controls or flappy paddles worked. I changed the steering clock spring that solved a lot of issues but I have this missing message code in loads of modules. Also I have noticed when i get it out the car it say to moved selecter to park but is already in park. The vehicle will not also will unlock and the boot but will not lock with the remote and the stop start does not work I assume that is because of the faulty radar cruise.Any help or advice apperciated.
Galee
Wednesday,12,August,2020,06:44:34:07703
VCDS Version: 20.4.2.0 (x64)  HEX-NET CB: 0.4513.4
VIN: WVWZZZAUZGW210559   License Plate: GOLF R 1
Mileage: 76009km-47229mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 22 2B 42 44 52 55 5F A9
VIN: WVWZZZAUZGW210559   Mileage: 76009km-47229miles
Address 01: Engine (J623-CJXC)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 F    HW: 06K 907 425 B
   Revision: --H13---
   Coding: 091D00122466050B3004
   ASAM Dataset: EV_ECM20TFS0205G0906259F 001004
   ROD: EV_ECM20TFS0205G0906259F.rod
   VCID: 312A1A4860374D0EAC-8064
15100 - MAP/MAF <-> Throttle Position Correlation
          P0068 00 [101] - -
                    Mileage: 76009 km
                    Date: 2020.08.11
                    Time: 10:18:14
                    Engine speed: 730.25 /min
                    Normed load value: 30.2 %
                    Coolant temperature: 68 °C
                    Intake air temperature: 48 °C
                    Voltage terminal 30: 14.355 V
                    Engine: operating status: IS
                    STATE_LS_SAE[1]: CL
                    T_AST_SAE: 22 s
                    MAP_MES_SAE: 45 kPa
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.978 V
                    FAC_TPS_1_SAE: 10.937500 %
                    FAC_LAM_LIM[1]: 1.653 %
26372 - Leak in Air Intake System
          P2279 00 [096] - -
                    Mileage: 76009 km
                    Date: 2020.08.11
                    Time: 10:18:14
                    STATE_LS_SAE[1]: CL
                    T_AST_SAE: 22 s
                    MAP_MES_SAE: 45 kPa
                    FUP_H_SAE: 15400.0 kPa
22008 - No Communications with Cruise Control (Front) Distance Sensor
          U0235 00 [039] - -
                    Mileage: 76009 km
                    Date: 2020.08.11
                    Time: 10:10:11
                    Engine speed: 0.00 /min
                    Coolant temperature: 75 °C
                    Intake air temperature: 43 °C
                    Voltage terminal 30: 12.031 V
                    Engine: operating status: ES
                    High-pressure system: status: VCV_OPEN
                    TEMP_CAT_UP_1_SAE: 253.6 °C
                    T_ES: 15 min
                    Cruise control switch actuation-Main switch: not activated
                    Cruise control switch actuation-Setting: not activated
                    Cruise control switch actuation-Activation: not activated
                    Cruise control switch actuation-Accelerate: not activated
                    Cruise control switch actuation-Decelerate: not activated
                    Cruise control switch actuation-Cancel: not activated
                    Cruise control switch actuation-Main switch hardware: not activated
                    Cruise control switch actuation-Limit button: not activated
                    Cruise control switch actuation-Main switch CAN: not activated
                    Cruise control switch actuation-Large increment: not activated
Readiness: 1010 0001
   Part No SW: 0D9 300 012     HW: 02E 927 770 AQ
   Component: DQ250-6A MQB  H53 4911
   Revision: 06253104    Serial number: TFK01511040364
   Shop #: WSC 04742 780 00200
   ROD: EV_TCMDQ250021.rod
   VCID: 53E670C03AEB5F1EFE-8006
   Revision: 00000000    Serial number: 63355000002193
   Coding: 01FA93A15421296C077C070541CC6980C92A94E0E08296F718425078C208
   VCID: 7AB8FD64FDC14E565D-802E
8192 - Databus
          [FCAN: ACC_07 message is not received]
                    Reset counter: 48
                    Date: 2020.08.11
                    Time: 10:19:02
   Revision: 00021000    Serial number: 0387409362
   Coding: 030C0C
   VCID: 3A383D64BD418E561D-806E
   Part No SW: 5G0 907 044 BD    HW: 5G0 907 044 BD
   Revision: 00001K08
   Coding: 00120004200100011005000000101002
   ROD: EV_ACClimaBHBVW37X_004_VW37.rod
   VCID: 6A98CD248D61FED6AD-803E
   Air quality sensor:
262914 - Refrigerant Pressure
          B10AB F0 [009] - Too Low
                    Reset counter: 48
                    Mileage: 76009 km
                    Date: 2020.08.11
                    Time: 10:11:05
                    Outside air temperature: 26.5 °C
                    Engine speed: 0 /min
                    Temperature after evaporator: 25.7 °C
                    System run time-Terminal 15 on: 255 s
   Part No SW: 5Q0 937 084 AS    HW: 5Q0 937 084 AN
   Serial number: 01061533702574
   Coding: 03051A46C24122F30BA44080B10C07281800000000000000000000000000
   Shop #: WSC 53545 001 1048576
   ROD: EV_BCMBOSCH_015.rod
   VCID: 095A92A8A82755CE44-805C
   Component: WWS    151108  042 0551
   Serial number:         151113073038
   Component: RLHS  037 0059
   Serial number: S4Y15M12D12H10M08S51
   Coding: 90A8DD
   Serial number: 000000000ZY153082B3L
   Component: Sirene, DWA  005 0312
   Serial number: 00000000000033961309
   Revision: --------    Serial number: 39391534300106
   Coding: 0071051011
   VCID: 43C64080CA8BCF9E4E-8016
   Part No SW: 5Q0 907 572 D    HW: 5Q0 907 572 D
   Component: ACC Bosch MQB H04 0303
   Serial number: 22051477030246
   Coding: 001C1300FE0739
   VCID: 383C276C834D9C46EB-806C
1037 - Databus
          [FAULT_CIS_QDCACC_FAIL]
                    Reset counter: 48
                    Mileage: 76009 km
                    Date: 2020.08.11
                    Time: 10:11:36
                    Control Module temperature: 41 °C
                    Voltage terminal 15: 12.0 V
                    Vehicle speed: 0.00 m/s
                    Acceleration: 0.00 m/s²
1039 - Databus
          [FAULT_CIS_QDISACC_FAIL]
                    Reset counter: 48
                    Mileage: 76009 km
                    Date: 2020.08.11
                    Time: 10:11:36
1807 - No Enable Indentifications Active
          B2032 00 [009] - -
          [FAULT_SWAP_NO_FSID_ACTIVE]
                    Reset counter: 49
                    Mileage: 76009 km
                    Date: 2020.08.11
                    Time: 10:11:35
   Part No SW: 5Q0 959 655 AA    HW: 5Q0 959 655 AA
   Component: AirbagVW20    015 0388
   Serial number: 003MLR1AUTCQ
   VCID: 7F4E0C70E6E36B7E6A-802A
   Belt Pretensioner left:
   Serial number: 34169677B25041440516
   Coding: 333135
   Belt Pretensioner right:
   Serial number: 34169676B29041470063
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 001 911 15
   Serial number: 357670000001B001C71I
   Subsystem 4 - Part No SW: -----------    HW: 480 000 809 15
   Serial number: 35867000000C6D05361W
   Subsystem 5 - Part No SW: -----------    HW: 480 402 411 15
   Serial number: 3516502C11E34434708/
   Subsystem 6 - Part No SW: -----------    HW: 480 402 511 15
   Serial number: 3526502B31DBD61581AK
   Subsystem 7 - Part No SW: -----------    HW: 480 402 105 14
   Serial number: 3556502C1157E9E20319
   Part No SW: 5Q0 953 549 E    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 01081904720076
   Coding: 0600
   Shop #: WSC 30686 003 104857
   VCID: 3E303174A169A27621-806A
   Part No SW: 5G1 920 958 A    HW: 5G1 920 958 A
   Component: KOMBI         302 6420
   Coding: 27AD08182F80260001886A011400000000000000
   VCID: 2F2E1C3076035BFEBA-807A
   Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1244
   Revision: --------    Serial number: 0004284970
   Coding: 030100043F085900FB00027E1C0F00010001050000000000000000000000
   ROD: EV_GatewLear_013.rod
   VCID: 79BAE268F8C7454E54-802C
   Subsystem 2 - Part No SW: 5G0 959 442 N    HW: 5G0 959 442 N  Labels: 3C8-959-537.CLB
   Serial number: 29150002320460085474
   Coding: 2DFFFF
   Serial number: 9569118603
   Serial number: HA1-00011.11.15
   Coding: 0001
   VCID: 4AD86DA4EDA11ED68D-801E
   Revision: 00000000    Serial number: 15000256845010
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 3424135C9F257826C7-8060
13637389 - Function Restriction due to Implausible Message(s)
          U1112 00 [009] - -
          [Invalid SMLS_P_verriegelt]
                    Reset counter: 48
                    Mileage: 76009 km
                    Date: 2020.08.11
                    Time: 10:12:22
                    ELV State: 04
                    Information Clamps: 77 60
                    CoCo State: A0 01
                    WFS State: 17 06
                    Vehicle speed: 0.00 km/h
                    Voltage: 68
                    AD-Value H-bridge: 32
                    Clamp15 flip flop: SSTx: button contacts: 06
                    CAN signals: 00
   Serial number: 070715BG706921
   Coding: 003F0220D001048000001000
   Serial number: 00000000000008327986
   Coding: 0D0000
65799 - Door Warning / Entry Lighting
          B1775 01 [009] - Electrical Failure
                    Reset counter: 48
                    Mileage: 76009 km
                    Date: 2020.08.11
                    Time: 10:13:00
   Part No SW: 3Q0 909 144 J    HW: 3Q0 909 144 H
   Component: EPS_MQB_ZFLS  505 5063
   Coding: 8103
   VCID: 393A2268B847854E14-806C
   Serial number: 030915BI30204A
   Coding: 003B0020DE01048000801000
   VCID: 42C84584D591C69645-8016
   Serial number: 00000000000008318852
   Coding: 150000
   Coding: 02AE00000B010200
   VCID: 40CC4F8CDB9DD48653-8014
   Subsystem 1 - Part No SW: 3D0 941 329     HW: 3D0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H05 0012
   Coding: 2E0000
   Subsystem 2 - Part No SW: 3D0 941 329     HW: 3D0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H05 0012
   Coding: 2E0000
   Part No SW: 3G0 035 020 C    HW: 3G0 035 020
   Component: MU-H-ND-EU    H50 0343
   Serial number: A682L0FB007887
   Coding: 02730001FF00000051111101008808001F0207C601200100DF
   VCID: 177EC4D0EE93B33EC2-8042
   Component: ABT_High  H62 0031
   Serial number: VWZ8Z9RU304H9Y
   Subsystem 2 - Part No SW: V03 959 800 QN    HW: -----------
   Component: ECE 2016  --- 0134
   Compact Disc Database:
   Component: Gracenote2  --- 1012
6697 - Databus
          [Airbag: no communication]
                    Reset counter: 89
                    Mileage: 76009 km
                    Date: 2020.08.11
                    Time: 15:08:21
                    Voltage terminal 30: 13.8 V
                    Network diagnosis-Status: Enabled
7173 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [ACC (0x05) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 48
                    Mileage: 76009 km
                    Date: 2020.08.11
                    Time: 10:14:07
                    Voltage terminal 30: 12.1 V
                    BAP-BAP_Function_ID: 02
   Part No SW: 5G0 907 159 D    HW: 4H0 907 159 A
   Serial number: 151114200672
End----------(Elapsed Time: 01:49, VBatt start/end: 12.1V/12.1V)-----------
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
For vehicle history, the overall fault picture kind of implies partial repairs of a front end collision. Or possibly the front fell off. :)
8192 - Databus
          B2032 00 [009] - -
The only current (non-intermittent) missing-message faults are around ACC. You have a front radar installed, I'm guessing a salvage unit swapped in from another vehicle. It's not complaining about component protection faults (meaning someone did half the job with ODIS), but it looks like it doesn't have the feature enable codes to operate in ACC mode instead of just FCW/AEB mode (the other half of the job). The radar is responsible for sending the ACC CAN messages in question, and it may not do so if it's not fully configured for that mode. Unfortunately, restoring FECs has to be done online with the factory database using ODIS.
          U1112 00 [009] - -
This might be related to your shift-to-Park problem. SMLS is "Schaltermodul der Lenksäule", switch module for steering column, "verriegelt" means locked. Might be a problem with swapped steering wheel button/controller components, mismatched coding, or maybe something with brake-shift interlock. My guess is coding of swapped components somewhere.
There does exist a fault code relating to the door warning/entry lighting, but I'm not sure if that would cause a problem with central locking. I'd solve the shift-to-Park problem first, because remote lock and unlock won't work if the car doesn't think it's in Park.
Don't spend any time troubleshooting auto start-stop until all other faults have been resolved. Auto start-stop won't engage unless all involved components are healthy, and that can include ACC if so equipped and configured, because the ACC radar has the authority to prevent stops and request starts.
