PLEASE HELP with 2013 facelift A4 coding fix, post Bi-Xenon conversion.
   #21
George Ab
C?ID=232965
Interesting project. I completed something similar. My methodology was to first get the schematics of the stock with upgrade HID system, then integrating my hardware and the cabling I purchased to make sure it matches. Then I took the scans and coding of the modules from stock upgrade HID system and compared my coding and made changes to those channels that were different. Then I worked each problem as it came up. This is the DIY of my project. http://www.golfmk7.com/forums/showthread.php?t=29237
milkatrek
Poland
C?ID=147536
any chance to someone resolve my problem ??
this fault automaticaly exist if I change coding in byte 31 from 00 to 01 (xenon)
   #23
m87a
Bosnia and Herzegovina
C?ID=156900
try byte 31 hex 02
also for drl check byte 02
   #24
milkatrek
Poland
C?ID=147536
I trying byte31
01 xenon
02 afs
my drl working 100%
paulkf
Romania
C?ID=345147
Hi. I have the same problem as milkatrek after retrofitting a 2013 A4 B8.5 from halogen to bixenon headlamps.
The error reported by the VCDS on 09-Cent. Elect. is ,,01312 - Powertrain Data Bus 004 - No Signal/Communication", and the ,,Range control defective" message on DIS. The headlights are performing the auto-leveling test after deleting de 09-Cent. Elect. error, but after turning on the engine, the auto-leveling test isn't performed.
Chassis Type: 8K-AU48 (8R0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 42 44 46 47 52 53 56 5F 62
          6C 72
VIN: WAUZZZ8K2EA005884   Mileage: 198440km-123304miles
Address 01: Engine (J623-CGLC)       Labels:. 03L-906-018-CGL.clb
   Part No SW: 03L 906 018 JJ    HW: 03L 906 018 JL
   Component: R4 2.0l TDI   H25 9978
   Revision: 45H25---
   Coding: 12034012232401080000
   Shop #: WSC 42803 002 1048576
   ASAM Dataset: EV_ECM20TDI01103L906018JJ 003010
   ROD: EV_ECM20TDI01103L906018JJ.rod
   VCID: 7BB60FD9F2BC7797F2-802E
Address 02: Auto Trans (J217)       Labels:| 0AW-927-156.clb
   Part No SW: 8K5 927 155 L    HW: 0AW 927 156 K
   Component: 0AW 20TDI RdW H05 0001
   Revision: --H05---    Serial number: 0000001112
   Coding: 000002
   Shop #: WSC 06325 000 00000
   ASAM Dataset: EV_TCMVL381 A02433
   ROD: EV_TCMVL381.rod
   VCID: 41CABD31D0D0DD47E8-8014
Address 03: ABS Brakes (J104)       Labels:. 8K0-907-379-V2.clb
   Part No SW: 8K0 907 379 CE    HW: 8K0 907 379 CE
   Component: ESP8 front    H09 0050
   Coding: 175DC401
   Shop #: WSC 43270 003 104857
   VCID: 7EB006CDE9AE62BFD5-802A
   Part No SW: 8K0 907 064 GC    HW: 8K0 907 064 FC
   Component: BCM2 2.0      H12 0633
   Coding: 01A24000000000000000
   VCID: 77BE13E9C69453F796-8022
   Subsystem 1 - Part No SW: 8K0 959 754 H    HW: 8K0 959 754 H
   Serial number: 0813000071481013
   Part No SW: 8K1 820 043 AG    HW: 8K1 820 043 AG
   Component: KLIMA 1 ZONE  H02 0123
   Revision: A1000000    Serial number: 01240520131385
   Coding: 342002E000
   VCID: 6D923181B4C8E9277C-8038
   Part No SW: 8K0 907 063 DD    HW: 8K0 907 063 DD
   Revision: 04016001    Serial number: 00000047305501
   Coding: 290000318134AFE00381000300001F1F439C470826080201000004004001020000000000000000
   VCID: 74A424E5D7E238EFB3-8020
   Subsystem 1 - Part No SW: 8K1 955 119 B    HW: 8K1 955 119 B  Labels: 1KX-955-119.CLB
   Component: MITSUBA160513  H18 0461
   Serial number: 13051307025350
   Coding: 004577
   Serial number: 21336368
   Coding: 02005D
   Component: E1 - LDS  H03 0031
   Serial number: 00000000001605130337
   Subsystem 4 - Part No SW: 4G0 907 658 A    HW: 4G0 907 658 A
   Component: Humidity_Sens  H03 0002
   Serial number: DE884DA6000000000001
   Part No SW: 8K0 919 475 AA    HW: 8P0 919 475 N
   Component: PARKHILFE 8K  H01 0081
   Revision: 11001001    Serial number: 12531119208920
   Coding: 300103
   VCID: 78BC10D5CB8A5C8F9F-802C
   Part No SW: 8K0 959 655 N    HW: 8K0 959 655 N
   Serial number: 003KFD9ACBV
   Coding: 30514435363030303030554A304C384B3053
   Shop #: WSC 21397 001 1048576
   VCID: 48DCA015F3EAEC0F2F-801C
   Serial number: 6334MSME7A010F7FS
   Serial number: 6344MSME79450F51K
   Serial number: 6352QSME663125549
   Serial number: 6362QSME563108427
   Serial number: 63732SME6731054AZ
   Serial number: 63832SME6531484A+
   Part No SW: 8R0 953 568 Q    HW: 8R0 953 568 Q
   Component: Lenks.Modul   H02 0171
   Revision: 00000000    Serial number: 20130527000080
   Coding: 000017
   VCID: 4FEE8B091E843B376E-801A
   Part No SW: 8K0 920 932     HW: 8K0 920 932
   Component: KOMBIINSTR.   H35 0563
   Revision: 00400000    Serial number: WWD617F5E
   Coding: 138F100003010008000000
   VCID: 6C943C858FD2E02F6B-8038
   Part No SW: 8R0 907 468 N    HW: 8R0 907 468 C
   Component: GW-BEM 4CAN-M H11 0056
   Revision: 1Y070028    Serial number: 2841Y135150298
   Coding: 80CF07FF00
   Shop #: WSC 06325 123 12345
   VCID: 4AD89A1DE5E61E1F39-801E
   Serial number: 5422970503
   Serial number: 13143000800021200181
   Part No SW: 8K0 959 793 S    HW: 8K0 959 793 Q
   Component: TSG FA        H02 0506
   Revision:             Serial number: 0000061664162
   Coding: 011E02204800410001
   VCID: 50EC887503BA24CF77-8004
   Component: RCEPS         H37 0507
   Revision: 00001000    Serial number: 0013492476
   Coding: 100000000001
   Shop #: WSC 06324 000 00000
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 3424E4E59F6278EF73-8060
   Revision: 00002001    Serial number: 0305712450
   Coding: 011E062820B900008120023680000047
03389 - Data Set Implausible
                    Reset counter: 139
                    Mileage: 198442 km
                    Date: 2020.02.14
                    Time: 15:11:25
   Revision: 00005001    Serial number: 94813031596305
   VCID: 2D12F181744829273C-8078
   Part No SW: 8K0 959 792 S    HW: 8K0 959 792 Q
   Component: TSG BF        H02 0506
   Revision:             Serial number: 0000061668416
   Coding: 011E02204C00410001
   Part No SW: 8K0 907 801 M    HW: 8K0 907 801 J
   Component: EPB-4         H01 0004
   Revision: --------    Serial number: 10000000216048
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 393AD5D1B8008587A0-806C
   Part No SW: 4G0 035 056 J    HW: 4G0 035 056
   Component: Radio U STD   H60 0133
   Revision: AB001007    Serial number: 229ET0D7700602
   Coding: 010003010000000001
   VCID: 281C00955BAA0C0FCF-807C
   Part No SW: 8R2 035 666 L    HW: 8R2 035 666 C
   Component: H-BN-EU       H46 1036
   Revision: --------    Serial number: 206IZ0D7536611
   Coding: 0F0100010006E1EF05808B5E00000403040000000000000000
   Shop #: WSC 06335 123 12345
   VCID: 42C8B23DDDD6C65FF1-8016
   Subsystem 1 - Part No: 8R0 060 884 GA
   Component: EUR 2019  2802
   Subsystem 2 - Part No SW: 8F0 919 604     HW: 8F0 919 604
   Component: DU7 High  H43 0098
   Serial number: 9466KX0A0256431
   Subsystem 3 - Part No SW: 8T0 919 611 L    HW: 8T0 919 611 C
   Serial number: 00000002160950
   Component: CD-Database  5298
                    Reset counter: 139
                    Mileage: 198442 km
                    Date: 2020.02.14
                    Time: 15:11:30
                    Text: DU9466,Front,M,0,0,6
                    Reset counter: 139
                    Mileage: 198442 km
                    Date: 2020.02.14
                    Time: 15:11:28
                    Voltage: 12.10 V
                    Bin. Bits:      010
03623 - Invalid Security/Release Code
                    Reset counter: 139
                    Mileage: 198442 km
                    Date: 2020.02.14
                    Time: 15:11:29
                    Hex Value: 0x0004
                    Hex Value: 0x000B
                    Count: 6
   Component: TSG HL        H01 0506
   Revision:             Serial number: 0000062125334
   Coding: 010C02204000210001
   VCID: 46C0AE2DF1FEFA7FDD-8012
   Part No SW: 8T0 907 441 B    HW: 4L0 907 441 A
   Component: J772__Rearview      0070
   Revision: --H12---    Serial number: 525PA8-J8791UC
   Coding: 1020007
   Shop #: WSC 20599 142 86696
   VCID: 373ED3E9461493F756-8062
03006 - Back-up Camera System not calibrated
                    Reset counter: 139
   Component: TSG HR        H01 0506
   Revision:             Serial number: 0000062125371
End----------(Elapsed Time: 01:50, VBatt start/end: 12.3V/12.3V)-----------
And this is the log after retrofitting the headlights to bixenon and the 09-Central Electrics module from DD to DH
Scan: 01 02 03 05 08 09 10 15 16 17 19 3C 42 44 46 47 52 53 56 5F
          62 6C 6D 72
VIN: WAUZZZ8K2EA005884   Mileage: 199470km-123944miles
   Revision: 45H25---
   Coding: 000002
   Coding: 175D8C01
   Part No SW: 8K0 907 064 KJ    HW: 8K0 907 064 KJ
   Component: BCM2 2.0      H15 0711
   Coding: 05220000000000000000
   VCID: 0248723D9D56065FB1-8056
   Coding: 342002E000
   Part No SW: 8K0 907 063 DH    HW: 8K0 907 063 DH
   Revision: 08016001    Serial number: 00000980423901
   Coding: 260000118134AFE00381400300001D0D439C070826090201000004004000020100000010000000
   Coding: 004577
   Coding: 02005D
                    Reset counter: 55
                    Mileage: 199475 km
                    Date: 2020.03.16
                    Time: 18:38:51
   Coding: 300103
   Coding: 000017
   Part No SW: 8R0 907 468 P    HW: 8R0 907 468 D
   Component: GW-BEM 5CAN-M H11 0060
   Revision: 1Z120030    Serial number: 3041Z1413003F1
   Coding: 80CF07FF00
   VCID: 4CD49C05EF92002F0B-8018
   Part No SW: 8K0 907 566 H    HW: 4L0 907 566 B
   Component: J0769_SWA_MasterH01 0010
   Revision: 00H01000    Serial number: 6PZ 009 014-82
   Coding: 0000102
   VCID: 3C34CCC57F32B0AFBB-8068
   Subsystem 1 - Part No: 8K0 907 568 H
   Component: J0770_SWA_Slave_H01 0010
   Subsystem 2 - Serial number: 6PZ 009 014-92
   Subsystem 3 - Serial number: 5F07.08.0900H010003C320316˙
   Subsystem 4 - Serial number: 320316˙
   Component: TSG FA        H02 0511
   Revision:             Serial number: 0000156597510
   Coding: 011D12205C00410001
   Coding: 100000010001
   Shop #: WSC 06324 123 12345
   Revision: 00002001    Serial number: 0516224809
   Coding: 011E0E2020BD30818120023680000000
   Component: TSG BF        H02 0510
   Revision:             Serial number: 0000144379375
   Coding: 011D12205400410001
   VCID: 4ED0960D198E323F65-801A
   Part No SW: 8R1 035 666 L    HW: 8R1 035 666 H
   Component: H-BN-EU       H48 1036
   Revision: --------    Serial number: 514J.0E7500735
   Coding: 0F0100010006E1EF15808B5E00000403040000000000000000
   VCID: 41CABD31D8D0DD47E8-8014
                    Reset counter: 55
                    Mileage: 199475 km
                    Date: 2020.03.16
                    Time: 18:38:55
02612 - Audio Wire Adapter Set
                    Reset counter: 55
                    Mileage: 199475 km
                    Date: 2020.03.16
                    Time: 18:39:03
                    Voltage: 14.60 V
                    Reset counter: 55
                    Mileage: 199475 km
                    Date: 2020.03.16
                    Time: 18:38:54
                    Hex Value: 0x0004
                    Hex Value: 0x000B
                    Count: 6
   Coding: 010C12204000210001
   Coding: 1020007
                    Reset counter: 55
   Part No SW: 8K9 827 851 A    HW: 8K9 827 851 A
   Component: J605  Master  H52 0330
   Revision: --------    Serial number: 8K9827851A
   VCID: 3C34CCC5BF32B0AFBB-8068
   Subsystem 1 - Part No SW: 8K9 827 852 A    HW: 8K9 827 852 A
   Component: J756  Slave  H52 0330
   Serial number: 8K9827852A
End----------(Elapsed Time: 01:52, VBatt start/end: 14.7V/14.8V)-----------
Any help ?
vipers
Bucharest Romania
C?ID=28396
Retrofit bixenon
          6C 72
   Revision: 45H25---
   Coding: 000002
   Coding: 175DC401
   Coding: 342002E000
   Coding: 004577
   Coding: 02005D
   Coding: 300103
   Coding: 000017
   Coding: 80CF07FF00
                    Reset counter: 139
                    Mileage: 198442 km
                    Date: 2020.02.14
                    Time: 15:11:25
                    Reset counter: 139
                    Mileage: 198442 km
                    Date: 2020.02.14
                    Time: 15:11:30
                    Reset counter: 139
                    Mileage: 198442 km
                    Date: 2020.02.14
                    Time: 15:11:28
                    Voltage: 12.10 V
                    Bin. Bits:      010
                    Reset counter: 139
                    Mileage: 198442 km
                    Date: 2020.02.14
                    Time: 15:11:29
                    Hex Value: 0x0004
                    Hex Value: 0x000B
                    Count: 6
   Coding: 1020007
                    Reset counter: 139
          62 6C 6D 72
   Revision: 45H25---
   Coding: 000002
   Coding: 175D8C01
   Coding: 342002E000
   Coding: 004577
   Coding: 02005D
                    Reset counter: 55
                    Mileage: 199475 km
                    Date: 2020.03.16
                    Time: 18:38:51
   Coding: 300103
   Coding: 000017
   Coding: 80CF07FF00
   Coding: 0000102
                    Reset counter: 55
                    Mileage: 199475 km
                    Date: 2020.03.16
                    Time: 18:38:55
                    Reset counter: 55
                    Mileage: 199475 km
                    Date: 2020.03.16
                    Time: 18:39:03
                    Voltage: 14.60 V
                    Reset counter: 55
                    Mileage: 199475 km
                    Date: 2020.03.16
                    Time: 18:38:54
                    Hex Value: 0x0004
                    Hex Value: 0x000B
                    Count: 6
   Coding: 1020007
                    Reset counter: 55
Any help ?
Salut treci pe la noi la viper si rezolvam. Spor
   #28
vastechnics
C?ID=143747
You have to check the adaptions. If you get power train databus most likely car was equipped with AFS. Then its looking for slave units.
For topic starter. Drl can make work by change adaptions
