Audi a4 saloon guage always showing temp high
Wmwizkid
India
C?ID=374582
hello dear wizards
i have a audi a4 2012 the problem is that the car shows temperature 90deg even after disconnecting the coolant sensor. as a result the fan stays on all the time. i cant get 5v ref on the coolant sensor or the ecu on relavant points. please help me diagnose this one
  Monday,10,August,2020,14:43:10:02918
VCDS Version: 20.4.2.0 (x64)  HEX-NET CB: 0.4513.4
Chassis Type: 8K-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 36 42 44 46 52 53 56 5F 62 6C
          72
VIN: WAUZFC8K7DY700468   Mileage: 65200km-40513miles
Address 01: Engine (J623-CMFA)       Labels: None
   Part No SW: 03L 906 018 LP    HW: 03L 906 018 JL
   Component: R4 2.0l TDI   H24 9979
   Revision: 45H24---
   Coding: 0A034012242400080000
   Shop #: WSC 57310 002 1048576
   ASAM Dataset: EV_ECM20TDI01103L906018LP 003006
   ROD: EV_ECM20TDI01103L906018LP.rod
   VCID: 834618DC0A1EFE9E8E-80D6
          U1113 00 [039] - -
                    Mileage: 65207 km
                    Date: 2020.08.10
                    Time: 13:04:38
                    Engine speed: 0.00 /min
                    Coolant temperature: 150 °C
                    Intake air temperature: 130 °C
                    Ambient air pressure: 930 mbar
                    Voltage terminal 30: 11.740 V
                    Cruise Control System (CCS): switch position-Bits 0-7: 129
                    Cruise Control System (CCS): status-Bits 0-7: 47
                    Cruise control switch-off: irreversible-Bits 0-7: 255
                    Cruise control switch-off: reversible-Bits 0-7: 255
                    Cruise Control System: specified speed: 0.00 km/h
                    Cruise control switch-off: irreversible w. brake intervention-Bits 0-7: 0
4821 - Engine Coolant Temp. Sensor (G62)
          P0117 00 [039] - Signal too Low
                    Mileage: 65207 km
                    Date: 2020.08.10
                    Time: 13:04:38
                    Coolant temperature at radiator outlet: actual value: 150.0 °C
                    Heat delivery temperature in cooling system: -273.1 °C
                    Outside air temperature: 30.0 °C
                    Fuel consumption: 0.00 l/h
                    Fuel temperature: 136.7 °C
                    Engine oil temperature: 54.9 °C
5268 - Sensor 1 for Exhaust Temp Bank 1 (G235)
          P0545 00 [036] - Short to Ground
                    Mileage: 65207 km
                    Date: 2020.08.10
                    Time: 13:01:46
                    Voltage terminal 30: 12.700 V
                    Exh.gas temp.sen 1: 950.5 °C
                    Exh.gas temp.sen 2: -0.0 °C
                    Exh.gas temp.sen 3: 637.2 °C
                    Exh.gas temp.sen 4: 630.1 °C
                    Shut-off timer: last engine shut-off time: 3 s
Address 02: Auto Trans (J217)       Labels:| 0AW-927-156.clb
   Part No SW: 8K2 927 155 G    HW: 0AW 927 156 K
   Component: 0AW 20TDI RdW H04 0003
   Revision: --H04---    Serial number: 0000000997
   Shop #: WSC 90001 000 00000
   ASAM Dataset: EV_TCMVL381 A02431
   ROD: EV_TCMVL381.rod
   VCID: B93ABA343852744E94-80EC
2223 - Load Signal
          P1857 00 [047] - Error Message from ECU
                    Mileage: 65207 km
                    Date: 2020.08.10
                    Time: 13:04:38
                    Engine speed: 100.00 /min
                    Transmission input speed: 1 /min
                    Transmission output speed: 1 /min
                    Engine torque: -40 Nm
                    Transmission fluid temperature: 45 °C
                    Accelerator position: 0.0 %
                    Clutch status: 1
                    Occurrence_counter_over_length_of_life: 29
   Part No SW: 8K0 907 379 CH    HW: 8K0 907 379 CH
   Component: ESP8 front    H09 0100
   Coding: 171D58
   Shop #: WSC 90001 123 12345
   VCID: 814A12D41802EC8E9C-80D4
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 233
                    Mileage: 65207 km
                    Date: 2020.08.10
                    Time: 13:04:37
                    Hex Value: 0x00C0
                    Hex Value: 0x0782
                    Hex Value: 0x000B
                    Hex Value: 0x4691
                    Hex Value: 0x0000
   Part No SW: 8K0 907 064 FR    HW: 8K0 907 064 FR
   Component: BCM2 2.0      H10 0602
   Coding: 01910000000000000000
   VCID: 854206C40C2AC0AEA0-80D0
   Subsystem 1 - Part No SW: 8T0 959 754     HW: 8T0 959 754
   Component: FBSAUDIB8 IDG  H60 0072
   Serial number: 0812000043977014
   Part No SW: 8K2 820 043 AC    HW: 8K2 820 043 AC
   Revision: D0000000    Serial number: 01030420120217
   Coding: 340462E000
   VCID: EA98557805740FD62D-80BE
                    Fault Status: 01101000
                    Reset counter: 233
                    Mileage: 65207 km
                    Date: 2020.08.10
                    Time: 13:04:38
   Part No SW: 8K0 907 063 DG    HW: 8K0 907 063 AG
   Component: BCM1 1.0      H14 0103
   Revision: 07014001    Serial number: 00000397580002
   Coding: 260000108034AFC00081400000001D0D0F1D430823090201000008000401020100000034000000
   Shop #: WSC 61394 002 1048576
   VCID: F7BE7C0C46C6A23EA2-80A2
   Subsystem 1 - Part No SW: 8K2 955 119 A    HW: 8T2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 280312  H06 0070
   Serial number: SWF12030280312
   Coding: 00FD11
   Serial number: 20190018
   Coding: 02005D
   Component: E1 - LDS  H03 0031
   Serial number: 00000000002103123665
   Component: AQ_Hum_Sensor  H02 0002
   Serial number: 6208CF16000000000001
                    Fault Status: 01101100
                    Reset counter: 233
                    Mileage: 65207 km
                    Date: 2020.08.10
                    Time: 13:01:44
00003 - Control Module
                    Fault Status: 00111110
                    Mileage: 31691 km
                    Date: 2018.04.19
                    Time: 21:34:38
   Part No SW: 8K0 959 655 N    HW: 8K0 959 655 N
   Serial number: 003KFD926DB6
   Coding: 30544435363030303030554A3052384B3053
   Shop #: WSC 02787 002 1048576
   VCID: C8DCCFF073B81DC61B-809C
   Serial number: 6334MSME6D404433A
   Serial number: 6344MSME6D4610206
   Serial number: 6352QSME131019664
   Serial number: 6362QSME7D105264G
   Serial number: 63732SME7E0F175CH
   Serial number: 63832SME3B0F0A747
   Part No SW: 8R0 953 568 Q    HW: 8R0 953 568 Q
   Component: Lenks.Modul   H02 0171
   Revision: 00000000    Serial number: 20120411000914
   Coding: 000016
   VCID: CFEEE4EC9ED6CAFE5A-809A
   Component: E221 - MFL  H03 0003
   Part No SW: 8K0 920 931 C    HW: 8K0 920 931 C
   Component: KOMBIINSTR.   H35 0540
   Revision: 00000000    Serial number: NTD70524D
   Coding: 3326080003010008010000
   VCID: AE109968F91CA3F631-80FA
   Part No SW: 8R0 907 468 C    HW: 8R0 907 468 C
   Component: GW-BEM 4CAN-M H10 0025
   Revision: 1Y030014    Serial number: 1441Y1222902D4
   Coding: 00C303FF00
   VCID: BFCED42C2E765A7EAA-80EA
   Serial number: 1496267101
                    Reset counter: 18
                    Mileage: 65207 km
                    Date: 2020.08.10
                    Time: 13:37:50
                    Bin. Bits:    00000
                    Voltage: 12.20 V
                    Count: 7
                    Bin. Bits:    10000
                    Time: 0.40 s
   Component: MEM-FS        H06 0076
   Revision: AA000000    Serial number: 00000025630124
   Coding: 00781300000000000000
   VCID: BB36A03C3A6E465E86-80EE
   Part No SW: 8T0 959 793 G    HW: 8T0 959 793 G
   Component: TSG FA        H09 0302
   Coding: 011C02205E01410001
   VCID: CDD2FEE494DAF8EE28-8098
   Component: RCEPS         H39 0507
   Revision: 00001000    Serial number: 0003115627
   Coding: 100000010001
   Shop #: WSC 00070 000 00000
   ROD: EV_RCEPSAU48X_008.rod
   VCID: B4248B001F30892647-80E0
   Revision: 00002001    Serial number: 0173858679
   Coding: 011A062000B901848020013280000000
   Subsystem 3 - Part No SW: 8K0 959 591 B    HW: 8K0 959 591
   Component: J245 PS050  H08 0043
   Part No SW: 8T0 959 792 G    HW: 8T0 959 792 G
   Component: TSG BF        H09 0302
   VCID: CCD4F3E06FC0F1E63F-8098
   Part No SW: 8K0 907 801 J    HW: 8K0 907 801 J
   Component: EPB-4         H01 0001
   Revision: --------    Serial number: 30000000008957
   ROD: EV_ParkiBrake_AU48.rod
   VCID: B620B108094C9B3679-80E2
464384 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
          [FC_SIGNAL_MO_QBIT_MOTORMOMENTE_QBIT]
                    Reset counter: 233
                    Mileage: 65207 km
                    Date: 2020.08.10
                    Time: 13:04:37
                    Voltage terminal 30: 11.7 V
                    Internal Fault ID: 188
                    Function light in parking brake button: OFF
                    Red operating lamp: OFF
                    Red warning lamp: OFF
                    Green operating lamp: OFF
                    Yellow warning lamp: OFF
                    Terminal 15 status: On
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
                    ACC requested apply: not active
                    Auto Adjust: not active
                    Internal Parking Brake state: static
                    Status ParkingBrake left: Open
                    Status ParkingBrake right: Open
   Part No SW: 4G0 035 056 E    HW: 4G0 035 056
   Component: Radio U STD   H60 0093
   Revision: AB001007    Serial number: 230CL0C2505328
   Coding: 070003020100000001
   VCID: A306785CA2DE1E9EAE-80F6
   Part No SW: 8R2 035 754 A    HW: 8R2 035 754
   Component: H-BN-RW       H43 0467
   Revision: --------    Serial number: 070DS0C7506065
   Coding: 0F0001000006A1EF41808B4E00000403FC0000020000000000
   VCID: B522B6041C4A902E70-80E0
   Subsystem 1 - Part No: 8R0 060 884 AJ
   Component: ROW 2012  0403
   Subsystem 2 - Part No SW: 8R0 919 604     HW: 8R0 919 604
   Component: DU7 High  H41 0104
   Serial number: A130D30CS141475
   Subsystem 3 - Part No SW: 8T0 919 611 K    HW: 8T0 919 611 B
   Serial number: 00000001388864
   Subsystem 4 - Part No: 8R0 060 961 C
   Component: CD-Database  3638
   Part No SW: 8T0 959 795 H    HW: 8T0 959 795 H
   Component: TSG HL        H07 0302
   Coding: 010C02204001210001
   VCID: D0ECE79083E8D50643-8084
   Part No SW: 8T0 907 441 D    HW: 8T0 907 441 D
   Component: J772__Rearview      0140
   Revision: --H06---    Serial number: 525PA8-J2193UT
   Coding: 1020006
   VCID: B93ABA34F052744E94-80EC
   Component: TSG HR        H07 0302
End----(Elapsed Time: 01:52, VBatt start/end: 12.0V/11.9V. VIgn 11.9V)-----
Jef
HQ
Unplug the smaller T60 connector from the ECM. Unplug the coolant temp sensor, G62. Run a jumper wire across terminals /1 and /2 to short the two wires together. Now ohm test T60/54 and T60/43 and make sure you get a dead short reading. Pull the jumper wire out of the connector for the G62 and ohm test again T60/54 and T60/43, you should have an open circuit. I'd also ohm test T60/54 and T60/43 to ground and make sure that is open circuit
Wmwizkid
India
C?ID=374582
Did this this test passed still no 5v on sensor
South Molton, UK
If you look at the WD is there more than one fuse supplying power to the ECU? If so then check ALL of them.
Wmwizkid
India
C?ID=374582
All fuses checked even chked voltages on ecu but still no 5v coming from ecu to temperature sensors.
Jef
HQ
IF.... if the ECM is bad, that will need to go through the dealer network to match up a replacement. Having said that, for testing purposes you can plug up another ECM and see if the coolant temp sensor issue goes away. I don't know how things roll in India, but over there, dealers more or less won't bother with used ECMs since the factory scan tool doesn't seem to be able to match up good used ECMs 98% of the time.
