MK7.5 Golf Dual daytime driving light
ivanyeung
Brisbane, Australia
C?ID=405269
Hi! Would somebody can help to share how VCDS can set the inner DRL led on?
Thanks!
Ivan
Moving to Tweaks.
Are you sure the headlights in your car have an "inner DRL"? I'm not sure about the 7.5, but on the 7, only the 'R' got headlights with inner LED DRLs.
TBAx
C?ID=287144
Uwe is correct. This also applies to the 7.5.
ivanyeung
Brisbane, Australia
C?ID=405269
Hi all! My car is MY20 Golf with R line package. I am not sure there is inner DRL light or not but I saw some video with same model has.
DV52
C?ID=194404
^ ^^ivan: Hi.
Assuming of course that your MY20 vehicle isn't impacted by SFD (or any other miscreant protocol that seems to be inflicted on later model VAG vehicles) and quite separate to the matters raised by Uwe/TBAx - the other issue in your question is can anything related to headlight fittings be changed (at all) on a car that almost certainly controls this equipment via Light Control modules (LCM)
But, without an autoscan of the car in question- it really is all just conjecture rather than informed discussion. IMO, of course!;)
EDIT: arrh........ I found your auto-scan here. As I suspected - the car is replete with LCM s !!!
TBAx
C?ID=287144
„R line“ is unfortunately not the same as „R“. To my knowledge hardware needs to be replaced. The only chance I see is when the car has DLA, but that’s just me guessing.
ivanyeung
Brisbane, Australia
C?ID=405269
Hi all,
here is the first scan of my GOLF
Saturday,08,August,2020,10:50:24:00429
VCDS Version: 20.4.2.0 (x64)  HEX-V2 CB: 0.4513.4
VIN: WVWZZZAUZLW126371   License Plate: 668ZYE
Mileage: 24km-14mi   Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 2B 36 3C 42 44 47 4B 52 5F
          A5 D6 D7
VIN: WVWZZZAUZLW126371   Mileage: 24km-14miles
Address 01: Engine (J623-CZDA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 027 HD    HW: 04E 907 309 BH
   Component: R4 1.4l TFS   H26 3742
   Revision: R7H26---
   Coding: 0125003224641D083000
   ASAM Dataset: EV_ECM14TFS01104E906027HD 001007
   ROD: EV_ECM14TFS01104E906027HD.rod
   VCID: 6D87CCEDBD11E4B3895-8038
   CAN Converter 01:
   Part No SW: 0CW 300 050 G    HW: 0AM 927 769 E
   Component: GSG DQ200G2_M H05 1905
   Revision: 00005009    Serial number: CU502003145385
   ROD: EV_TCMDQ200021_VW31.rod
   VCID: 392F28BDB9D9881355D-806C
   Part No SW: 5Q0 614 517 DL    HW: 5Q0 614 517 BP
   Component: ESC           H35 0113
   Revision: 00000000    Serial number: 60720000001953
   Coding: 01FA8AA190222172477A060760C42980510984E26006947338225038D2A24B0B0000000012121212B835351919323200
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 049012
   ROD: EV_Brake1UDSContiMK100IPB_049_VW27.rod
   VCID: 7EA5FBA1E0776F2B20F-802A
   Part No SW: 3Q0 959 435 N    HW: 3Q0 959 435 N
   Component: VWKESSYMQB    037 1307
   Revision: 00037000    Serial number: 0544657645
   Coding: 132C0C0723
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 45D7544DC521FCF3215-8010
   Part No SW: 5G0 907 044 FQ    HW: 5G0 907 044 FQ
   Component: Climatronic   H04 2401
   Revision: 00001K10
   Coding: 001200142001000D110500001010142A
   ASAM Dataset: EV_ACClimaBHBVW37X 006151
   VCID: 7BA3F2B5F3657A03071-802E
   Geber f黵 K鋖temitteldruck/K鋖temitteltemperatur:
   Air quality sensor:
   Part No SW: 5Q0 937 084 DG    HW: 5Q0 937 084 CF
   Component: BCM MQBAB M+  H42 0312
   Serial number: 02002007700978
   ASAM Dataset: EV_BCMMQB 020001
   ROD: EV_BCMBOSCH_020.rod
   VCID: 005985599A8319DB523-8054
   Subsystem 1 - Part No SW: 5G2 955 119 A    HW: 5G2 955 119 A  Labels: 5QX-955-119-V1.CLB
   Component: WWS    200205  042  0551
   Serial number:         200226160315
   Component: RLHS  054  0206
   Serial number: SBY20M04D27H17M08S35
   Coding: 0008DD
   Sun Roof:
   Subsystem 3 - Part No SW: 8V3 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS73.404  H04  0005
   Serial number: 0000FST002HM3CK00000
   Coding: 181901
   Steering Column Switch:
   Subsystem 4 - Part No SW: 5Q1 953 507 M    HW: 5Q1 953 549
   Component: J527 SMLS MQB  004  0070
   Serial number: 00000029022004220265
   Part No SW: 5QA 919 298 H    HW: 5QA 919 298 A
   Component: PLA 3.0 12K   H08 0061
   Serial number: 000150057620093
   Coding: 0371167851
   ASAM Dataset: EV_EPHVA2CAU3700000 009048
   VCID: 55F7840D35814C73515-8000
   Part No SW: 5Q0 907 572 P    HW: 3QF 907 572 A
   Coding: 330067C15DFFC728949C810580400600000000000000000004
   VCID: 44D14949CE1BC5FB36B-8010
   Part No SW: 5Q0 959 655 BT    HW: 5Q0 959 655 BT
   Component: AirbagVW21    008 0403
   Serial number: 003FNR67GB5R
   Coding: 98CCC000000000005C000000008800000065
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002164
   VCID: 1373BA15FBF59243FF1-8046
   Belt Pretensioner left:
   Component: BeltPretRevFL  H37 0350
   Serial number: 34169677E13032030994
   Coding: 333135
   Belt Pretensioner right:
   Component: BeltPretRevFR  H37 0350
   Serial number: 34169676E16032030515
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 002 004 20
   Serial number: 357000000006E718C74V
   Subsystem 4 - Part No SW: -----------    HW: 480 002 004 20
   Serial number: 35800000000E5A9D774%
   Subsystem 5 - Part No SW: -----------    HW: 480 400 903 20
   Component: SideSensor_Dr  005 6149
   Serial number: 3510001B6F2A1A03570.
   Subsystem 6 - Part No SW: -----------    HW: 480 400 904 20
   Component: SideSensor_Pr  004 6149
   Serial number: 35200011C63731C1240K
   Subsystem 7 - Part No SW: -----------    HW: 480 401 203 20
   Component: FrontSensor_D  004 6149
   Serial number: 35500010862F843301F-
   Part No SW: 5G1 920 791 B    HW: 5G1 920 791 B
   Component: KOMBI         404 4191
   Coding: 27A401186F88000801886B0B5401000080000000
   VCID: 2B0302F543852A83D71-807E
   Component: GW MQB High   521 5388
   Serial number: 13032010520669
   Coding: 030100347F085708FB00025C1C0F00010001070000000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 70B9D599AA23095BA23-8024
   Component: 4-00-03-00-04
   Subsystem 2 - Part No SW: 5G0 959 442 AE    HW: 5G0 959 442 AE  Labels: 3C8-959-537.CLB
   Component: E221__MFL-MD9  H12 0052
   Serial number: 29200000169010100057
   Coding: 2DFFFF
   Serial number: 9956404205
   Part No SW: 2Q0 905 861 A    HW: 2Q0 905 861 A
   Component: ELV-MQBB      H08 0021
   Serial number: 20000051615006
   Coding: 0800000000000000
   ROD: EV_ELVMarqMQBA0_VW37.rod
   VCID: 313F109D61A94053EDD-8064
Address 36: Seat Mem. Drvr (J810)       Labels:* None
   Part No SW: 5Q0 959 760 E    HW: 5Q0 959 760 E
   Component: Sitzmemory    H09 0026
   Serial number: Y0007TBD38833
   Coding: 0014000000000500018280808080000000008181000000F400
   ASAM Dataset: EV_SeatMemorDriveSide 002022
   VCID: 3FDB46A5A7FDA6236B9-806A
   Component: HRE_Master    H12 0081
   Serial number: 0540381239
   Coding: 02011203
   ROD: EV_HREntryHella_VW37.rod
   VCID: 3D273CADADF1B433795-8068
   Component: HRE_Slave  H12 0081
   Serial number: 0540240233
   Coding: 020112
   Part No SW: 5Q0 959 593 K    HW: 5Q0 959 593 F
   Component: TSG FS002 0330
   Serial number: YE007TB43092D
   Coding: 003B1320D201048000001000
   ROD: EV_DCU2DriveSideMAXHKLO.rod
   VCID: 49CF587DE9391893C5D-801C
   Subsystem 1 - Part No SW: 5Q0 959 408     HW: 5Q0 959 164
   Component: FOND_FHSG_DRV  007 0010
   Serial number: 00000000000039680001
   Coding: 0D0000
   Part No SW: 3Q0 909 144 M    HW: 3Q0 909 144 L
   Component: EPS_MQB_ZFLS  507 5082
   Coding: 931F0000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 3C2131A9B6EBBD3B4EB-8068
Address 47: Sound System (J525)       Labels:| 5Q0-035-456.clb
   Part No SW: 5Q0 035 456 A    HW: 5Q0 035 456 A
   Component: MIB2_lite_amp H40 0200
   Revision: 00000001    Serial number: VWZ8Z1KMD07D8Z2
   Coding: 12000000008AAA8A000000000000
   ASAM Dataset: EV_AMPMst11CGen2ALPI 001003
   ROD: EV_AMPMst11CGen2ALPI.rod
   VCID: 2E050BE170975FABF0F-807A
Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V2.clb
   Part No SW: 3Q0 907 338 E    HW: 3Q0 907 338 E
   Component: FCM MQB Low   003 0367
   Serial number: 12032010520784
   Coding: 000000070900164E01000101020000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 003003
   ROD: EV_MultiModulContiVW48X_003_VW27.rod
   VCID: 372B2E858FCD9E63A39-8062
Address 52: Door Elect, Pass. (J387)       Labels:* Redir Fail!
   Part No SW: 5Q0 959 592 K    HW: 5Q0 959 592 F
   Component: TSG BFS002 0330
   Serial number: YE007TB409286
   Coding: 003B1120DE01048000001000
   ROD: EV_DCU2PasseSideMAXHKLO.rod
   VCID: 48C95D79F233E19BDA3-801C
   Subsystem 1 - Part No SW: 5Q0 959 407     HW: 5Q0 959 163
   Component: FOND_FHSG_PSG  007 0010
   Serial number: 00000000000039659122
   Coding: 150000
   Part No SW: 5NA 035 045 F    HW: 5NA 035 045
   Component: MU-H-N-RW     H55 1367
   Serial number: A849B0LP002470
   Coding: 027310080000000041510002000808001F0106F601200402DF
   VCID: 3B2332B5B3E5BA03471-806E
   Subsystem 1 - Part No SW: 5G6 919 606     HW: 5G6 919 606
   Component: ABT_High-2  H61 9214
   Serial number: VWZ6ZJX0780327
   Subsystem 2 - Part No SW: V03 959 806 FQ    HW: -----------
   Component: ROW 2019/2020  --- 0079
   Component: Gracenote2  --- 4013
   Part No SW: 3Q0 980 654 L    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H13 0610
   Serial number: 16032012K23913
   Coding: 000307000000010100022354C150A90088000E20002000
   ROD: EV_MFKBoschMQBB_002.rod
   VCID: 40D94559DA03D9DB123-8014
Address D6: Light Ctrl Left 2 (A31)       Labels: 7P5-941-591.clb
   Part No SW: 7P5 941 591 AJ    HW: 7P5 941 591 A
   Component: LED1L         H07 0011
   ROD: EV_LED_PLUS_L_KEBODAVW416_VW37.rod
   VCID: 045189498E9B05FB76B-8050
Address D7: Light Ctrl Right 2 (A27)       Labels: 7P5-941-591.clb
   Component: LED1R         H07 0011
End----------(Elapsed Time: 01:47, VBatt start/end: 12.3V/12.2V)-----------
hadez16
C?ID=289891
Dual DRL:
MK7: Golf R headlights
MK7.5: Golf R, or DLA/ALS Headlights, or any exotic international market car (near east...) (from german perspective)
