- May 24, 2020
- 9
- 4
- Brisbane, Australia
- C?ID=405269
Hi! Would somebody can help to share how VCDS can set the inner DRL led on?
Thanks!
Ivan
Thanks!
Ivan
But that there is a TiguanEDIT: arrh........ I found your auto-scan here. As I suspected - the car is replete with LCM s !!!
Hi all! My car is MY20 Golf with R line package. I am not sure there is inner DRL light or not but I saw some video with same model has.
Saturday,08,August,2020,10:50:24:00429
VIN: WVWZZZAUZLW126371 License Plate: 668ZYE
Mileage: 24km-14mi Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 2B 36 3C 42 44 47 4B 52 5F
A5 D6 D7
VIN: WVWZZZAUZLW126371 Mileage: 24km-14miles
Address 01: Engine (J623-CZDA) Labels:. 04E-907-309-V1.clb
Part No SW: 04E 906 027 HD HW: 04E 907 309 BH
Component: R4 1.4l TFS H26 3742
Revision: R7H26---
Coding: 0125003224641D083000
ASAM Dataset: EV_ECM14TFS01104E906027HD 001007
ROD: EV_ECM14TFS01104E906027HD.rod
VCID: 6D87CCEDBD11E4B3895-8038
CAN Converter 01:
Address 02: Auto Trans (J743) Labels: 0CW-927-769.clb
Part No SW: 0CW 300 050 G HW: 0AM 927 769 E
Component: GSG DQ200G2_M H05 1905
Revision: 00005009 Serial number: CU502003145385
ROD: EV_TCMDQ200021_VW31.rod
VCID: 392F28BDB9D9881355D-806C
Part No SW: 5Q0 614 517 DL HW: 5Q0 614 517 BP
Component: ESC H35 0113
Revision: 00000000 Serial number: 60720000001953
Coding: 01FA8AA190222172477A060760C42980510984E26006947338225038D2A24B0B0000000012121212B835351919323200
ASAM Dataset: EV_Brake1UDSContiMK100IPB 049012
ROD: EV_Brake1UDSContiMK100IPB_049_VW27.rod
VCID: 7EA5FBA1E0776F2B20F-802A
Part No SW: 3Q0 959 435 N HW: 3Q0 959 435 N
Component: VWKESSYMQB 037 1307
Revision: 00037000 Serial number: 0544657645
Coding: 132C0C0723
ROD: EV_KessyHellaMQBAB.rod
VCID: 45D7544DC521FCF3215-8010
Part No SW: 5G0 907 044 FQ HW: 5G0 907 044 FQ
Component: Climatronic H04 2401
Revision: 00001K10
Coding: 001200142001000D110500001010142A
ASAM Dataset: EV_ACClimaBHBVW37X 006151
VCID: 7BA3F2B5F3657A03071-802E
Geber f黵 K鋖temitteldruck/K鋖temitteltemperatur:
Air quality sensor:
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 5Q0 937 084 DG HW: 5Q0 937 084 CF
Component: BCM MQBAB M+ H42 0312
Serial number: 02002007700978
ASAM Dataset: EV_BCMMQB 020001
ROD: EV_BCMBOSCH_020.rod
VCID: 005985599A8319DB523-8054
Subsystem 1 - Part No SW: 5G2 955 119 A HW: 5G2 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 200205 042 0551
Serial number: 200226160315
Subsystem 2 - Part No SW: 5Q0 955 547 C HW: 5Q0 955 547 C Labels: 5Q0-955-547.CLB
Component: RLHS 054 0206
Serial number: SBY20M04D27H17M08S35
Coding: 0008DD
Sun Roof:
Subsystem 3 - Part No SW: 8V3 959 591 A HW: 8V3 959 591 A
Component: J245 PS73.404 H04 0005
Serial number: 0000FST002HM3CK00000
Coding: 181901
Steering Column Switch:
Subsystem 4 - Part No SW: 5Q1 953 507 M HW: 5Q1 953 549
Component: J527 SMLS MQB 004 0070
Serial number: 00000029022004220265
Part No SW: 5QA 919 298 H HW: 5QA 919 298 A
Component: PLA 3.0 12K H08 0061
Serial number: 000150057620093
Coding: 0371167851
ASAM Dataset: EV_EPHVA2CAU3700000 009048
VCID: 55F7840D35814C73515-8000
Address 13: Auto Dist. Reg (J428) Labels:| 3Q0-907-572.clb
Part No SW: 5Q0 907 572 P HW: 3QF 907 572 A
Coding: 330067C15DFFC728949C810580400600000000000000000004
VCID: 44D14949CE1BC5FB36B-8010
Part No SW: 5Q0 959 655 BT HW: 5Q0 959 655 BT
Component: AirbagVW21 008 0403
Serial number: 003FNR67GB5R
Coding: 98CCC000000000005C000000008800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002164
VCID: 1373BA15FBF59243FF1-8046
Belt Pretensioner left:
Component: BeltPretRevFL H37 0350
Serial number: 34169677E13032030994
Coding: 333135
Belt Pretensioner right:
Component: BeltPretRevFR H37 0350
Serial number: 34169676E16032030515
Coding: 333135
Subsystem 3 - Part No SW: ----------- HW: 480 002 004 20
Serial number: 357000000006E718C74V
Subsystem 4 - Part No SW: ----------- HW: 480 002 004 20
Serial number: 35800000000E5A9D774%
Subsystem 5 - Part No SW: ----------- HW: 480 400 903 20
Component: SideSensor_Dr 005 6149
Serial number: 3510001B6F2A1A03570.
Subsystem 6 - Part No SW: ----------- HW: 480 400 904 20
Component: SideSensor_Pr 004 6149
Serial number: 35200011C63731C1240K
Subsystem 7 - Part No SW: ----------- HW: 480 401 203 20
Component: FrontSensor_D 004 6149
Serial number: 35500010862F843301F-
Part No SW: 5G1 920 791 B HW: 5G1 920 791 B
Component: KOMBI 404 4191
Coding: 27A401186F88000801886B0B5401000080000000
VCID: 2B0302F543852A83D71-807E
Part No SW: 3Q0 907 530 AC HW: 3Q0 907 530 C
Component: GW MQB High 521 5388
Serial number: 13032010520669
Coding: 030100347F085708FB00025C1C0F00010001070000000000000000000000
ROD: EV_GatewNF_VW37.rod
VCID: 70B9D599AA23095BA23-8024
Component: 4-00-03-00-04
Subsystem 2 - Part No SW: 5G0 959 442 AE HW: 5G0 959 442 AE Labels: 3C8-959-537.CLB
Component: E221__MFL-MD9 H12 0052
Serial number: 29200000169010100057
Coding: 2DFFFF
Subsystem 3 - Part No SW: 5Q0 915 181 K HW: 5Q0 915 181 K
Serial number: 9956404205
Part No SW: 2Q0 905 861 A HW: 2Q0 905 861 A
Component: ELV-MQBB H08 0021
Serial number: 20000051615006
Coding: 0800000000000000
ROD: EV_ELVMarqMQBA0_VW37.rod
VCID: 313F109D61A94053EDD-8064
Address 36: Seat Mem. Drvr (J810) Labels:* None
Part No SW: 5Q0 959 760 E HW: 5Q0 959 760 E
Component: Sitzmemory H09 0026
Serial number: Y0007TBD38833
Coding: 0014000000000500018280808080000000008181000000F400
ASAM Dataset: EV_SeatMemorDriveSide 002022
VCID: 3FDB46A5A7FDA6236B9-806A
Address 3C: Lane Change (J1086) Labels:| 5Q0-907-686.clb
Part No SW: 5Q0 907 686 C HW: 5Q0 907 686 C
Component: HRE_Master H12 0081
Serial number: 0540381239
Coding: 02011203
ROD: EV_HREntryHella_VW37.rod
VCID: 3D273CADADF1B433795-8068
Lane Change Assistant 2:
Subsystem 1 - Part No SW: 5Q0 907 685 C HW: 5Q0 907 685 C
Component: HRE_Slave H12 0081
Serial number: 0540240233
Coding: 020112
Part No SW: 5Q0 959 593 K HW: 5Q0 959 593 F
Component: TSG FS002 0330
Serial number: YE007TB43092D
Coding: 003B1320D201048000001000
VCID: 49CF587DE9391893C5D-801C
Subsystem 1 - Part No SW: 5Q0 959 408 HW: 5Q0 959 164
Component: FOND_FHSG_DRV 007 0010
Serial number: 00000000000039680001
Coding: 0D0000
Part No SW: 3Q0 909 144 M HW: 3Q0 909 144 L
Component: EPS_MQB_ZFLS 507 5082
Coding: 931F0000
ROD: EV_SteerAssisMQB_015.rod
VCID: 3C2131A9B6EBBD3B4EB-8068
Address 47: Sound System (J525) Labels:| 5Q0-035-456.clb
Part No SW: 5Q0 035 456 A HW: 5Q0 035 456 A
Component: MIB2_lite_amp H40 0200
Revision: 00000001 Serial number: VWZ8Z1KMD07D8Z2
Coding: 12000000008AAA8A000000000000
ASAM Dataset: EV_AMPMst11CGen2ALPI 001003
ROD: EV_AMPMst11CGen2ALPI.rod
VCID: 2E050BE170975FABF0F-807A
Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V2.clb
Part No SW: 3Q0 907 338 E HW: 3Q0 907 338 E
Component: FCM MQB Low 003 0367
Serial number: 12032010520784
Coding: 000000070900164E01000101020000000000000000000000000000000000
ROD: EV_MultiModulContiVW48X_003_VW27.rod
VCID: 372B2E858FCD9E63A39-8062
Address 52: Door Elect, Pass. (J387) Labels:* Redir Fail!
Part No SW: 5Q0 959 592 K HW: 5Q0 959 592 F
Component: TSG BFS002 0330
Serial number: YE007TB409286
Coding: 003B1120DE01048000001000
VCID: 48C95D79F233E19BDA3-801C
Subsystem 1 - Part No SW: 5Q0 959 407 HW: 5Q0 959 163
Component: FOND_FHSG_PSG 007 0010
Serial number: 00000000000039659122
Coding: 150000
Part No SW: 5NA 035 045 F HW: 5NA 035 045
Component: MU-H-N-RW H55 1367
Serial number: A849B0LP002470
Coding: 027310080000000041510002000808001F0106F601200402DF
VCID: 3B2332B5B3E5BA03471-806E
Subsystem 1 - Part No SW: 5G6 919 606 HW: 5G6 919 606
Component: ABT_High-2 H61 9214
Serial number: VWZ6ZJX0780327
Subsystem 2 - Part No SW: V03 959 806 FQ HW: -----------
Component: ROW 2019/2020 --- 0079
Compact Disc Database:
Component: Gracenote2 --- 4013
Part No SW: 3Q0 980 654 L HW: 3Q0 980 654 A
Component: MQB_B_MFK H13 0610
Serial number: 16032012K23913
Coding: 000307000000010100022354C150A90088000E20002000
ROD: EV_MFKBoschMQBB_002.rod
VCID: 40D94559DA03D9DB123-8014
Address D6: Light Ctrl Left 2 (A31) Labels: 7P5-941-591.clb
Part No SW: 7P5 941 591 AJ HW: 7P5 941 591 A
Component: LED1L H07 0011
ROD: EV_LED_PLUS_L_KEBODAVW416_VW37.rod
VCID: 045189498E9B05FB76B-8050
Address D7: Light Ctrl Right 2 (A27) Labels: 7P5-941-591.clb
Component: LED1R H07 0011
End----------(Elapsed Time: 01:47, VBatt start/end: 12.3V/12.2V)-----------
Uwe is correct. This also applies to the 7.5.
