Abs coding Golf 6 need if possible (ESP MK60EC1)
ikara
Croatia
C?ID=302492
I change module because operation fault.Ori was 1K0907397BC 18 digit code (have it),new module is 1K0907397BK 19 digit,depend of your calc what data you need? I try with avdi but not succes.
ikara
Croatia
C?ID=302492
tomorrow i will post full scan,ori was 1K0907379CD Long Coding 113B200D092300FF880E04ED901F00423400,need coding for other unit 1K0907379BK 19 digit,
Boki Ar
Arandjelovac, Serbia
C?ID=57300
OK, You need 19 Bytes, Long Coding.
I searched the examples I have, also the VIS database found only one such example. Without an AScan file, it will be difficult to figure out.
If you want, you can contact me. Viber, Skype ...
ikara
Croatia
C?ID=302492
Here is LOG,
Tuesday,11,August,2020,08:00:57:04922
VCDS Version: 20.4.2.0  HEX-NET CB: 0.4513.4
VIN: WVWZZZ1KZ9W415396   License Plate: IM449BE
Mileage: 143280km-89030mi   Repair Order:
Chassis Type: 1K-VW36 (1K0)
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 56 62 72
VIN: WVWZZZ1KZ9W415396   Mileage: 143280km-89030miles
25-Immobilizer -- Status: Sporadic communication error 1000
Address 01: Engine (CBD)       Labels: 03L-906-022-CBA.clb
   Part No SW: 03L 906 022 MC    HW: 03L 906 022 G
   Component: R4 2.0l TDI 0000SG  9979
   Revision: 13H01---    Serial number:
   Coding: 0000071
   Shop #: WSC 21959 133 65834
   VCID: F2A88419EDBC9B1695-80A6
7 Faults Found:
009298 - Diesel Particle Filter; Differential Pressure Sensor
               P2452 - 000 - Elect. Malfunction
                    Mileage: 143285 km
                    Date: 2015.01.02
                    Time: 21:09:16
                    Voltage: 11.93 V
                    Pressure: 0 mbar
                    Pressure: 0 mbar
                    (no units): 0.0
                    Temperature: 29.7°C
009258 - Exhaust Gas Temperature Sensor; B1 S3
               P242A - 000 - Malfunction
                    Mileage: 143285 km
                    Date: 2015.01.02
                    Time: 21:09:16
                    Voltage: 11.86 V
                    Temperature: 28.8°C
                    Temperature: 18.0°C
                    Temperature: 930.0°C
009326 - Exhaust Gas Temperature Sensor 4 Bank 1
               P246E - 000 - Electrical Malfunction
                    Mileage: 143285 km
                    Date: 2015.01.02
                    Time: 21:09:16
                    Voltage: 11.86 V
                    Temperature: 28.8°C
                    Temperature: 18.0°C
               P242A - 000 - Malfunction - MIL ON
                    Fault Status: 11100000
                    Mileage: 143285 km
                    Date: 2015.01.02
                    Time: 21:09:21
                    Voltage: 11.86 V
                    Temperature: 28.8°C
                    Temperature: 18.0°C
               P246E - 000 - Electrical Malfunction - MIL ON
                    Mileage: 143285 km
                    Date: 2015.01.02
                    Time: 21:09:21
                    Voltage: 11.86 V
                    Temperature: 28.8°C
                    Temperature: 18.0°C
004374 - Oxygen (Lambda) Sensor Heating; B1 S1
               P1116 - 000 - Open Circuit
                    Mileage: 143285 km
                    Date: 2015.01.02
                    Time: 21:09:22
                    Voltage: 11.86 V
                    Voltage: 11.86 V
                    Voltage: 11.86 V
                    Voltage: 11.86 V
049441 - No Communication with ABS Brake Control Module
               U0121 - 000 -  - Intermittent
                    Temperature: 29.7°C
                    Voltage: 12.01 V
                    Bin. Bits: 00000000
                    Torque: 108.0 Nm
                    Temperature: 31.5°C
   Part No SW: 1K0 907 379 BK    HW: 1K0 907 379 BK
   Revision: 00H31001
   Shop #: WSC 35110 377 08192
   VCID: FCB4AA217FF8DD66CF-80A8
                    Reset counter: 119
                    Date: 2015.01.02
                    Time: 23:49:21
                    Count: 3
                    Count: 20992
                    Count: 195
                    Count: 41984
                    Fault Status: 01100101
                    Reset counter: 119
                    Mileage: 143285 km
                    Date: 2015.01.02
                    Time: 23:48:02
                    Count: 3
                    Count: 20480
                    Count: 279
                    Count: 41984
                    Count: 9728
                    Reset counter: 119
                    Mileage: 143285 km
                    Date: 2015.01.02
                    Time: 23:48:02
                    Count: 3
                    Count: 20480
                    Count: 295
                    Count: 41984
                    Count: 9728
                    Reset counter: 119
                    Mileage: 143285 km
                    Date: 2015.01.02
                    Time: 23:48:02
                    Count: 3
                    Count: 20480
                    Count: 270
                    Count: 41984
                    Count: 9728
   Part No SW: 5K0 907 044 AK    HW: 5K0 907 044 AK
   Component: Climatronic   130 0303
   Coding: 0000000000
   ASAM Dataset: EV_Climatronic A01001
   VCID: F4A482015FA8952687-80A0
13701392 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Bremsensteuergerät - kein Signal/Kommunikation]
                    Reset counter: 159
                    Mileage: 143285 km
                    Date: 2020.08.11
                    Time: 21:12:09
13701936 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [Steuergerät für Bordnetz - bitte Fehlerspeicher auslesen]
                    Reset counter: 159
                    Mileage: 143285 km
                    Date: 2020.08.11
                    Time: 00:01:16
13701456 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Steuergerät im Schalttafeleinsatz - kein Signal/Kommunikation]
                    Reset counter: 159
9481988 - Air Quality Sensor
          B10AF 04 [008] - Internal System Fault
                    Reset counter: 159
                    Mileage: 119851 km
                    Date: 2019.03.27
                    Time: 09:47:09
   Part No SW: 1K0 937 086     HW: 1K0 937 086
   Component: BCM PQ35  M   020 0358
   Revision: 00020000
   Coding: 40180A3A98251AC040080080540081E445510088736D8D60648000000000
   VCID: ED929765348244EE48-80B8
   Component: Wischer 09100  21  0501
   Coding: 009795
   Component: RLS 231008 05  54  0402
   Coding: 0330AD
01800 - Light Switch (E1)
                    Reset counter: 159
                    Mileage: 143285 km
                        Term 15 Off
                    Voltage: 12.35 V
                        Term 50 Off
                    Reset counter: 159
                    Mileage: 143285 km
                    Date: 2015.01.02
                    Time: 00:01:10
                    Voltage: 12.00 V
                        Term 50 Off
                    Fault Frequency: 13
                    Reset counter: 119
                    Mileage: 143285 km
                    Date: 2015.01.02
                    Time: 00:02:06
                    Voltage: 11.95 V
                        Term 50 Off
                    Reset counter: 159
                    Mileage: 143285 km
                    Date: 2015.01.02
                    Time: 21:12:08
                    Voltage: 12.00 V
                        Term 50 Off
Address 10: Park/Steer Assist (J446)       Labels:. 3C8-919-475.clb
   Part No SW: 5K0 919 475     HW: 5K0 919 475
   Component: PARKHILFE 8K  H07 0002
   Revision: --------    Serial number: 60640825303325
   Coding: 100001
   VCID: F3A6811D52A6921E9E-80A6
                    Reset counter: 159
                    Mileage: 143285 km
                    Date: 2015.01.02
                    Time: 21:12:08
                    Temperature: 30.0°C
   Part No SW: 5K0 959 655     HW: 5K0 959 655
   Component: AirbagVW10    020 0507
   Serial number: 003C2D040KR
   Coding: 00003135
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01003
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: F7BEB50D4EDEFE3EA2-80A2
   Component: S.Sens.Fahr.V  U01 ----
   Serial number: 11543442ZZZZZZZZZZZZ
   Component: S.Sens.Beif.V  U01 ----
   Serial number: 0E2A3442ZZZZZZZZZZZZ
   Serial number: 0E110D60ZZZZZZZZZZZZ
   Serial number: 28140F0EZZZZZZZZZZZZ
12656896 - No Communication with ABS Brake Control Module
          U0121 00 [008] - -
          [Lost Communication With Vehicle Dynamics Control Module]
                    Reset counter: 159
                    Mileage: 143285 km
                    Date: 2020.08.11
                    Time: 21:12:07
   Part No SW: 1K0 953 549 CQ    HW: 1K0 953 549 CQ
   Component: J0527           853 0111
   Coding: 0000004
   VCID: 8346D1DDC206A29E8E-80D6
   Part No SW: 5K0 920 870 C    HW: 5K0 920 870 C
   Component: KOMBI         H21 0028
   Coding: 170F00
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04020
   VCID: AD125765FC0284EE08-80F8
12656896 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Steuergerät für Bremse: keine Kommunikation]
                    Reset counter: 159
   Part No SW: 1K0 907 530 S    HW: 1K0 907 951
   Component: J533__Gateway   H16 0210
   Revision:   H16       Serial number: 3400K089030836
   Coding: E9A07F06000202000002
   VCID: B73E750DC65E3E3E62-80E2
                    Reset counter: 159
                    Reset counter: 159
                    Mileage: 143285 km
                    Date: 2015.01.02
                    Time: 21:12:06
   Component: IMMO          H21 0028
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03002
   Part No SW: 1K0 959 701 AN    HW: 1K0 959 701 AN
   Component: Tuer-SG         008 2015
   Coding: 0004278
   VCID: FAB8AC39B5CCE356DD-80AE
   Part No: 1K0 909 144 C
   Component: EPS_ZFLS Kl. 69     2301
   Revision: 00H15000
   Shop #: WSC 01324 785 00200
   VCID: AA185C7905EC93D6ED-80FE
                    Reset counter: 169
                    Mileage: 143285 km
                    Date: 2015.01.02
                    Time: 21:12:08
                    Voltage: 11.88 V
                        DU
                    Temperature: 30.0°C
                    Speed: 50.0 km/h
                    Speed: 50.0 km/h
   Part No SW: 1K0 959 702 AN    HW: 1K0 959 702 AN
   Coding: 0004534
   VCID: FBB6A93DBAF6DA5EC6-80AE
Address 56: Radio (J0503)       Labels:. 5M0-035-1xx-56.clb
   Part No SW: 3C8 035 195     HW: 3C8 035 195
   Component: Radio RCD510  036 0130
   Revision: 00000001    Serial number: VWZ1Z3H3348221
   Coding: 0500040004
   Shop #: WSC 00028 028 00001
   VCID: E582EF45EC727CAE00-80B0
00625 - Vehicle Speed Signal
                    Reset counter: 159
                    Mileage: 143285 km
                    Date: 2015.01.02
                    Time: 21:12:12
   Part No SW: 1K0 959 703 AL    HW: 1K0 959 703 AL
   Component: Tuer-SG         007 2009
   Coding: 0000144
   Shop #: WSC 01357 011 1012552
   Part No SW: 1K0 959 704 AL    HW: 1K0 959 704 AL
   Coding: 0000144
End----(Elapsed Time: 01:12, VBatt start/end: 11.8V/11.7V. VIgn 11.8V)-----
