ECU swap
Martymc1
C?ID=107715
Hi, was trying to put a used ECU into a mk2 Leon. I’ve followed the procedure given on rosstech site. When I put in the pin for the replacement ECU into login and then go to channel 50 in adaptions and put in the pin from the old ECU the one that’s stored in the clocks for the IMMO it says done. Then I turn off for 2 mins but when I turn car on it is still in safe mode. Anyone know what’s wrong thanks
Martymc1
C?ID=107715
Thanks for replies. Il do a scan tomorrow. Just ECU being changed as suspected fault in original ECU. Car wasn’t starting and showing fault for injectors. Then sometimes would start and run for 10 mins and cut out. Changed injector loom and made no difference.
NostraJackAss
Funny question?
Did you isolate each consumer while trying too & by merely unplugging to see if it wakes up?
Did you trace the entire track yet using WD and of each consumer?
Martymc1
C?ID=107715
scan
this is scan with original ECU
Sunday,16,August,2020,11:21:56:48937
VCDS Version: 20.4.2.0 (x64)
VIN: VSSZZZ1PZ8R069057   License Plate: LEON ORIG ECU
Mileage: 324400km-201572mi   Repair Order:
Chassis Type: 1P (1K0)
VIN: VSSZZZ1PZ8R069057   Mileage: 324400km-201572miles
Address 01: Engine        Labels: 03G-906-016-BKC.clb
   Part No SW: 03G 906 021 SC    HW: 03G 906 021 AN
   Component: R4 1,9L EDC  000SG  1438
   Revision: --H07---    Serial number: XXXXXXXXXXXXXX
   Coding: 0050071
   Shop #: WSC 04941 785 00200
   VCID: 72E0CFE46D10081615-8026
005731 - Control Circuit for PD Injectors
               P1663 - 000 - Short to Plus - Intermittent
                    Fault Status: 00110000
                    Mileage: 324400 km
                    Time: 01:26:04
                    RPM: 882 /min
                    Voltage: 13.83 V
                    Bin. Bits: 11000100
                    Temperature: 25.2°C
                    Bin. Bits: 01010000
001025 - EGR System
               P0401 - 000 - Insufficient Flow
                    Fault Status: 01110000
                    Mileage: 324400 km
                    Time: 01:26:57
                    RPM: 1386 /min
                    Load: 12.2 %
                    Duty Cycle: 14.6 %
                    Duty Cycle: 100.2 %
                    Mass Air / Rev.: 230.0 mg/str
                    Mass Air / Rev.: 470.0 mg/str
005658 - Glowplug for Cylinder 1 (Q10)
               P161A - 000 - Open Circuit
                    Mileage: 324400 km
                    Time: 20:04:19
                    Voltage: 11.63 V
                    Bin. Bits: 11000100
                    Temperature: 14.4°C
                    Bin. Bits: 00110000
005659 - Glowplug for Cylinder 2 (Q11)
               P161B - 000 - Open Circuit
                    Mileage: 324400 km
                    Time: 20:04:19
                    Voltage: 11.63 V
                    Bin. Bits: 11000100
                    Temperature: 14.4°C
                    Bin. Bits: 00110000
005661 - Glowplug for Cylinder 4 (Q13)
               P161D - 000 - Open Circuit
                    Mileage: 324400 km
                    Time: 20:04:19
                    Voltage: 11.63 V
                    Bin. Bits: 11000100
                    Temperature: 14.4°C
                    Bin. Bits: 00110000
   Part No: 1K0 907 379 P
   Coding: 0017025
   VCID: 3F8656D06EC2957E2A-806A
57344 - Unknown Error Code
            Unknown - 015 -  - MIL ON
   Part No: 5P0 820 047 K
   Component: Climatic PQ35   012 0505
   VCID: 356A34F85CFE5F2EF0-8060
00229 - Refrigerant Pressure
   Part No SW: 3C0 937 049 AH    HW: 3C0 937 049 AH
   Revision: 00H54000    Serial number: 00000005270990
   Coding: 00880F2F00041000431D00000000000000007B075C400000000000000000
   Shop #: WSC 18434 020 328969
   VCID: 6FE6C6907E2225FEFA-803A
   Subsystem 1 - Part No: 1P0 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer 101207 022  0601
   Coding: 00056208
   Shop #: WSC 18434
                    Fault Status: 00101100
                    Fault Frequency: 101
                    Reset counter: 235
                    Mileage: 319388 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 12.15 V
                    Fault Status: 01101100
                    Reset counter: 195
                    Mileage: 313468 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 12.40 V
                    Reset counter: 235
                    Mileage: 324436 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 6.80 V
00154 - Windshield Wiper Motor;  Passenger Side (V217)
                    Reset counter: 235
                    Mileage: 324436 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 9.05 V
02383 - Windshield Wiper Motor Function Restricted due to Under-Voltage
                    Reset counter: 235
                    Mileage: 324436 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 9.05 V
   Component: J234__A03 VW10 HI   1815
   Revision: 19013000    Serial number: 0039DPQRENQ.
   Coding: 0012339
   VCID: 3B7E22C07ADA895E06-806E
   Subsystem 1 - Serial number: 6333FTS656663207
Martymc1
C?ID=107715
this is scan with replacement ECU. not sure how to upload them properly so had to copy and paste
Sunday,16,August,2020,11:29:23:48937
VIN: VSSZZZ1PZ8R069057   License Plate: LEON REPLACEMENT ECU
   Revision: --H11---    Serial number:
   Coding: 0050071
   Shop #: WSC 06401 785 00200
                    Mileage: 324400 km
                    Time: 20:16:01
                    Voltage: 11.86 V
                    Bin. Bits: 11000100
                    Temperature: 14.4°C
                    Bin. Bits: 00110000
                    Mileage: 324400 km
                    Time: 20:16:01
                    Voltage: 11.86 V
                    Bin. Bits: 11000100
                    Temperature: 14.4°C
                    Bin. Bits: 00110000
                    Mileage: 324400 km
                    Time: 20:16:01
                    Voltage: 11.86 V
                    Bin. Bits: 11000100
                    Temperature: 14.4°C
                    Bin. Bits: 00110000
   Coding: 0017025
   Coding: 00056208
   Shop #: WSC 18434
                    Reset counter: 195
                    Mileage: 324400 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 11.60 V
   Coding: 0012339
   Subsystem 2 - Serial number: 6343FTS600043247
   Subsystem 3 - Serial number: 6353ETS6EDE010KH
   Subsystem 4 - Serial number: 6363ETS6OP0510KH
   Part No SW: 1K0 953 549 BM    HW: 1K0 953 549 BM
   Component: J0527           752 0100
   Coding: 0000002
   VCID: 7EF8EBD429485C7661-802A
   Part No: 1P0 920 907 B
   Component: KOMBIINSTRUMENT VO3 0450
   Coding: 0002401
   Shop #: WSC 00581 210 64475
   VCID: 2E581B94B9A86CF6B1-807A
   Part No SW: 1K0 907 530 P    HW: 1K0 907 951
   Component: J533__Gateway   H16 0191
   Revision:   H16       Serial number: 2000K07B160296
   Coding: E9801F060002020203
   VCID: 346C09FC57844626C7-8060
   Component: IMMO            VO3 0450
   Part No SW: 1T0 959 701 F    HW: 1K0 959 793 L
   Component: J386  TUER-SG FT    1130
   Revision: 32008001    Serial number: 00000538678826
   Coding: 0000560
   VCID: 3A7027C475E0B0561D-806E
   Part No: 1K2 909 144 M
   Component: EPS_ZFLS Kl.077 H08 1901
   VCID: 366833F441F85436F9-8062
   Part No: 1K0 959 433 CP
   Coding: 99C000CC7F008505485B861004CC
   Shop #: WSC 64001 476 12192
   VCID: 0004952C53BC2A8613-8054
   Subsystem 5 - Part No: 1P0 951 171
   Component: Innenraumueberw.010 4971
   Coding: 00000000
   Subsystem 6 - Part No: 1K0 951 605 C
   Subsystem 7 - Component:       NGS n.mounted
   Part No SW: 1T0 959 702 F    HW: 1K0 959 792 L
   Component: J387  TUER-SG BT    1130
   Revision: 32008001    Serial number: 00000503078825
   Coding: 0000560
   Part No: 1P2 035 186 A
   Component: Radio BVX           0006
   Coding: 0020414
   VCID: 2B5E12808ABA19DE96-807E
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
I do not think that ECU can be done with VCDS .
Can you go in Advanced ID and post it here ?
Martymc1
C?ID=107715
Yea no problem. Why can it not be done thanks?
Another thing I noticed is it says immobiliser disabled when I check Immo status in adaptions.
Jetta 97
C?ID=81680
Late 2007+ models had different way of programing , VW Called Download .
Post Advanced ID info to see it .
Martymc1
C?ID=107715
When Immobilzer is set to off, 050 adaption is not possible due to flash or eeprom status regardless.
whats my options jack? am i better getting clocks and ecu thats matched or is there anyway i can do it with this one. i have kess as well.
Martymc1
C?ID=107715
Monday,17,August,2020,18:21:46:48937
VIN: License Plate: LEON ADV ID OLD
Address 01: Engine
Control Module Part Number: 03G 906 021 SC
Component and/or Version: R4 1,9L EDC 000SG 1438
Software Coding: 0050071
Work Shop Code: WSC 04941
Advanced Identification
Identification: BPG-810
Revision: --H07---
Date: 01.12.07
Test stand number: 1328
Manufacturer number: 0174
Flash Status
Programming Attempts: 0
Successful Attempts: 0
Programming Status: 00000000
Required Conditions: 00000000
Flash Tool Code: 00000 000 00000
Flash Date: 00.00.00
Software
P0101
HAS9
Misc.
Hardware number: 03G 906 021 AN
Immo Challenge: 94 4F E1 00
Car Info
Chassis Number: XXXXXXXXXXXXXXXXX
VCDS Info:
Readiness: No script available
Monday,17,August,2020,18:19:45:48937
VIN: VSSZZZ1PZAR047747 License Plate: LEON ADV ID NEW/USED
Address 01: Engine
Work Shop Code: WSC 06401
Identification: BPG-658
Revision: --H11---
Date: 06.01.10
Test stand number: 1409
Manufacturer number: 0322
Flash Status
Required Conditions: 00000010
Software
P0101
HAS9
Misc.
Immo Challenge: 40 37 F6 85
Car Info
Chassis Number: VSSZZZ1PZAR047747
VCDS Info:
def something up as the ECU thats was in her is not showing the chassis number in the ID scan. anyone know best way round this thanks for the replies
NostraJackAss
Immobilizer is active on both of those advanced ID's aforementioned in eeprom and you can see the challenge, I suspect the flash is modified or maybe you are not observing 0x01-10-091?
What is the status of the 0x17 & 25 Advanced ID and key status as married or recognized?
You could consider seeing dealer for FaZit session or locksmith?
If you sent me equipment and credentials, I can make it all happen but I am a bit far away.
Martymc1
C?ID=107715
Thanks for all the help folks. I ended up removing the eeprom from the old ECU and putting it into the donor one. Cars starting and driving ok now so far. Only problem I’m having is setting the basic setting for the steering but other than that all’s good. Thanks Martin.
