2013 Volkswagen Passat - Vehicle not starting when the vehicle is warm
NitrousOxide
Jamaica
C?ID=269481
Someone had asked me to look at their 2013 Passat. The issue with it is that the car doesn't start whenever the car is parked out in the sun or recently running. The dashboard displays "immobilizer active". If the car is left in the shade for a few hours or hasn't been running for a few hours (and not eposed to sunlight, then the car may start and run without issue. The car will stay running once started if left in the sun and will drive to the destination without an issue. The issue will resurface once attempting to restart the hot vehicle. This issue happens with both genuine keys that the car came with.
I've placed an AutoScan below for your perusal.
Sunday,09,August,2020,20:48:03:39976VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 20.4.2.0 (x64)
Dealer/Shop Name: Matthew Taylor
VIN: WVWZZZ3CZDP008334   License Plate:
Chassis Type: 3C-VW46 (7N0)
Scan: 01 02 03 08 09 10 14 15 16 17 19 25 2E 42 44 46 4C 4F 52 53
          56 61 62 72 77
VIN: WVWZZZ3CZDP008334   Mileage: 72710km-45179miles
Address 01: Engine (CCZ)       Labels:. 06J-907-115-CCZ.clb
   Part No SW: 06J 906 027 M    HW: 06J 907 309 B
   Component: MED17.5.2        03 8324
   Revision: PAH04---    Serial number: VWZCZ000000000
   Coding: 040400101C070160
   Shop #: WSC 00028 028 00001
   VCID: 354FD8585CDD5E2EF0-8060
000604 - Fuel Pump Control Module
               P025C - 000 - Short to Ground - Intermittent
                    Temperature: -40.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 12.192 V
005488 - Engine Start Blocked by Immobilizer
               P1570 - 000 -  - Intermittent
                    Fault Frequency: 33
                    Mileage: 69953 km
                    Date: 2014.10.27
                    Time: 00:19:31
                    RPM: 1307 /min
                    Load: 11.0 %
                    Temperature: 96.0°C
                    Temperature: 45.0°C
                    Voltage: 12.192 V
Readiness: 0000 0001
   Part No SW: 02E 300 058 N    HW: 02E 927 770 AL
   Component: GSG DSG AG6     512 3501
   Revision: 05551213    Serial number: 00001205241579
   VCID: 256F0818EC7D2EAE40-8070
   Part No SW: 3AA 614 109 BK    HW: 3AA 614 109 BK
   Component: J104   C2 450M VDF6 0024
   Revision: --H07---    Serial number: 00000005896729
   Coding: 0001929
   VCID: 77D3125006516C3E22-8022
   Part No SW: 3AA 907 044 AG    HW: 3AA 907 044 AG
   Component: Climatronic   H03 0303
   Revision: 00001K02
   Coding: 0014004802
   Shop #: WSC 00028 028 00020
   VCID: 75CF1858D45D1E2E30-8020
13701936 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
                    Reset counter: 251
                    Mileage: 71894 km
                    Date: 2020.07.24
                    Time: 20:34:43
Address 09: Cent. Elect.        Labels: None
   VCID: 558F78D8BC9D7E2E10-8000
Address 10: Park/Steer Assist (J446)       Labels:| 3AE-919-475.clb
   Part No SW: 3AE 919 475 B    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0016
   Revision: --------    Serial number: 28261216701352
   Coding: 108101
   ASAM Dataset: EV_EPHVA18VW47X0000 001005
   ROD: EV_EPHVA18VW47X0000.rod
   VCID: 3E5DC774A1EB9D7621-806A
Address 14: Susp. Elect. (J250)       Labels:. 3C0-907-376.clb
   Part No SW: 3C0 907 376 A    HW: 3C0 907 376
   Component: DAEMPFUNGS-SG H07 0071
   Revision: 00000000    Serial number: 11061200550002
   Coding: 010180
   VCID: 2773021056713CBE72-8072
   Component: J234__108 VW10 HI   2118
   Revision: 24017000    Serial number: 003L7PCHFSUT
   Coding: 0012344
   VCID: 7CD90D7C3F774F664F-8028
   Subsystem 1 - Serial number: 6332MTS664221482
   Subsystem 2 - Serial number: 6342MTS665481492
   Subsystem 3 - Serial number: 6351HTS67DSS4BKR
   Subsystem 4 - Serial number: 6361HTS60UOS3BKR
01228 - Airbag Cut-Off Switch for Passenger Side (E224)
            008 - Implausible Signal - Intermittent - MIL ON
                    Fault Status: 10101000
                    Mileage: 70226 km
                    Date: 2014.11.04
                    Time: 06:45:26
Address 16: Steering wheel (J527)       Labels:| 3C0-953-569.clb
   Part No SW: 3C5 953 501 BG    HW: 5K0 953 569 T
   Revision: FF010041    Serial number: 20120618301859
   Coding: 098A250000
   VCID: 6BFB3E208219D8DED6-803E
   Component: E221__MFL-TK6  H07 0022
   Coding: E20000
   Part No SW: 3AA 920 870 H    HW: 3AA 920 870 H
   Component: KOMBI         H05 0705
   Coding: 160F01
   VCID: 3753D2508ED1AC3EE2-8062
   Part No SW: 7N0 907 530 T    HW: 7N0 907 530 K
   Component: J533  Gateway H40 1632
   Revision:   H40       Serial number: 160612F2002526
   Coding: 461007
   VCID: 41A7BC88D815E28E5C-8014
                    Reset counter: 26
   Part No SW: 3AA 959 433     HW: 3AA 959 433
   Component:    IMMO         043 0400
   Revision: 00043000    Serial number: VWZCZ000000000
   VCID: 76CD1F54015B153639-8022
01176 - Key
                    Fault Status: 01101000
                    Fault Frequency: 82
                    Reset counter: 245
                    Mileage: 69970 km
                    Date: 2014.10.27
                    Time: 23:01:51
02811 - Control Module for Electronic Steering Column Lock (J764)
            014 - Defective
                    Fault Status: 01101110
                    Fault Frequency: 78
                    Reset counter: 245
                    Mileage: 70012 km
                    Date: 2014.10.30
                    Time: 00:11:18
02815 - Steering Column Lock; Supply Voltage for Locking Motor
            006 - Short to Plus - Intermittent
                    Fault Status: 00100110
                    Fault Frequency: 13
                    Reset counter: 29
                    Mileage: 70012 km
                    Date: 2014.10.30
                    Time: 00:19:09
   Component: SG EXT.PLAYER H18 0530
   Revision: A1001003    Serial number: 7662863366
   Coding: 010100
   VCID: 2A75FB24456301D66D-807E
   Part No SW: 3AA 959 701 A    HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0534
   Revision: 12110009    Serial number: 0005157179
   Coding: 0002FF
   VCID: 354FD85894DD5E2EF0-8060
   Slave Driver:
   Subsystem 1 - Part No SW: 3AA 959 704 B    HW: 3C8 959 795   Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  004 0502
   Serial number: 00000002974954
   Coding: 0102D8
66304 - Switch for Drivers Side Window Regulator
          B11F0 29 [008] - Signal Implausible
                    Reset counter: 26
                    Mileage: 72552 km
                    Date: 2020.08.06
                    Time: 03:12:56
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 205    3305
   Revision: 00H22000
   VCID: 3753D25046D1AC3EE2-8062
00750 - Warning Lamp
                    Fault Status: 00101101
                    Mileage: 71023 km
                    Date: 2014.11.25
                    Time: 00:00:25
                    Voltage: 9.38 V
                        PD
                    Temperature: 34.0°C
   Component:    KSG PQ47 ELV 043 0634
   Coding: 01910A0002860E763404941570085FCE105801
   Component: Neigungssensor  004 0611
                    Reset counter: 251
                    Mileage: 71894 km
                    Date: 2014.12.15
                    Time: 20:34:36
   Part No SW: 7N0 907 532     HW: 7N0 907 530 K
   Component: EZE_2         H40 1632
   Coding: 00000008
   VCID: 6FC32A30BE0124FEFA-803A
   Subsystem 1 - Part No SW: 3AA 919 204 A    HW: 3AA 919 204 A
   Component: Analoguhr  004 0004
   Part No SW: 3AA 959 702 A    HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0534
   Revision: 14110009    Serial number: 0005172214
   Coding: 0002FE
   Shop #: WSC 46069 002 1048576
   VCID: 364DDF5489DB5536F9-8062
   Slave Passenger:
   Subsystem 1 - Part No SW: 3AA 959 703 B    HW: 3C8 959 794   Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  004 0502
   Serial number: 00000002970488
   Coding: 0102D8
   Revision:   H19       Serial number: 00000000264097
   Coding: 0022157
   VCID: 364DDF5441DB5536F9-8062
                    Fault Frequency: 112
                    Reset counter: 27
                    Mileage: 65594 km
                    Date: 2014.06.25
                    Time: 11:17:37
                    Voltage: 12.80 V
                    Count: 10
                    Speed: 16.0 km/h
                    Hex Value: 0x1260
                    Hex Value: 0x0014
                    Hex Value: 0x0101
Address 56: Radio (J0503)       Labels:. 5M0-035-1xx-56.clb
   Part No SW: 5K0 035 190 B    HW: 5K0 035 190 B
   Component: Radio RCD510  005 0234
   Revision: 00000001    Serial number: VWZ1Z3M7246423
   Coding: 01000410040010
   VCID: 2469151C2747D7A657-8070
   Part No SW: 7N0 907 534     HW: 7N0 907 530 K
   Component: Batt.regelung H40 1632
   Coding: 03260859
   VCID: 71C72C48A835320EEC-8024
   Component: J367-BDM  H07 0180
   Serial number: 00000000008900566795
   Part No SW: 7P6 035 730 K    HW: 7P6 035 730 K
   Revision: 1B001001    Serial number: 00007662846461
   Coding: 0A00000000010100
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA_002.rod
   VCID: 3A55CB64BDC3B1561D-806E
End-------------------------(Elapsed Time: 05:59)--------------------------
siLc
Tallinn, Estonia
C?ID=330192
            014 - Defective
                    Fault Frequency: 78
                    Reset counter: 245
                    Mileage: 70012 km
                    Date: 2014.10.30
                    Time: 00:11:18
                    Fault Frequency: 13
                    Reset counter: 29
                    Mileage: 70012 km
                    Date: 2014.10.30
                    Time: 00:19:09
The steering column lock doesn't seem to like the high temperature. On the Passat B6/B7 it's a part of the immobilizer - when there's a problem with it, the immo will not allow the engine to be started. AFAIK changing the steering column lock is a dealer job. This can also be done at a suitable independent garage which has access to the VW "mothership".
