Did I brick my B8?
ES803313
C?ID=242285
Hello everyone,
I'm still familiarizing myself with this Ross-Tech stuff. Have had it for a while but thankfully haven't had much need for it until recently. I'll try to give a little bit of background on the car.
2009 Audi S5 (B8/8T) that I bought back in 2013 with 65k miles on it. At that time I had to do some carbon cleaning on the intake valves and put new injectors in it. After that it was just the common maintenance items and I really fell in love with this car. About a year ago I installed air ride. It would be good to note that I have also installed KW active suspension damper modules (keeps the lights off on the dash). I don't believe it's interfering with the issues you'll read about soon but I also want to make sure we're all looking on the same page here.
Fast forward to the past month or so. Haven't been driving the car a ton due to COVID-19 and my work flexibility has given me the opportunity to work from home. Pair that with a newly acquired Range Rover Classic, this car doesn't really get the daily duty anymore. I believe this 'sitting around' has caused me more harm than good. I recently had to chase an electrical issue which would keep my radiator fans on non-stop; even after the car was shut off. More on that can be found over at A5OC: 2009 S5 Cooling Fan Running Non-Stop - Draining Battery.
Since I've repaired this, things really haven't worked out for me. I was able to drive maybe 20 miles before issues started to crop up. While I was driving, I heard a bunch of clicking accompanied by my dashboard needles sweeping (sounded like relays ticking on and off, on and off). Once the dash came back online I was greeted by a significant number of warnings. EPC, parking brake malfunction, headlight range malfunction, etc. Time to bust out the VCDS, I say... I've ran many scans so I'll try to talk through what happened between them but ultimately my car WILL NO LONGER START. More on that soon. I've had a similar issue in the past where it ended up being a dead battery. Took mine out to have it checked at the local auto parts store and it checked out okay.
Okay, so first scan with all this mess:
Thursday,30,July,2020,15:24:07:03605
VCDS Version: 20.4.1.0 (x64)
VIN: WAURV78T19A055187   License Plate: 20200730
Mileage: 235880km-146569mi   Repair Order:
Chassis Type: 8T-AU48 (8T0)
Scan: 01 03 05 06 07 08 09 0E 0F 10 14 15 16 17 19 1B 1E 36 37 3C
          42 46 47 52 53 55 56 65 67 6C 77
VIN: WAURV78T19A055187   Mileage: 235880km-146569miles
Address 01: Engine (J623-CAUB)       Labels:. 079-907-560-CAU.clb
   Part No SW: 8T0 907 560 S    HW: 8T0 907 560
   Component: 4.2l V8/4V    H10 0004
   Revision: 76H10---
   Coding: 01140009180F0120
   Shop #: WSC 63089 001 1048576
   VCID: 4A9B5F42E5B11CD695-801E
               P1653 - 001 -  - Intermittent
                    Fault Status: 00100001
                    Mileage: 235884 km
                    Date: 2008.05.27
                    Time: 01:37:43
                    Temperature: 95.0°C
                    Temperature: 63.0°C
                    Absolute Pres.: 980.0 mbar
                    Voltage: 12.192 V
               P1653 - 008 -  - Intermittent
                    Mileage: 235884 km
                    Date: 2008.05.27
                    Time: 01:37:43
                    Temperature: 95.0°C
                    Temperature: 63.0°C
                    Voltage: 12.192 V
049456 - Steering Effort Control Module
               U0130 - 008 - No Communications - Intermittent
                    Mileage: 235884 km
                    Date: 2008.05.27
                    Time: 02:06:25
                    RPM: 593 /min
                    Load: 21.2 %
                    Temperature: 101.0°C
                    Temperature: 63.0°C
                    Voltage: 13.843 V
               P1602 - 002 - Voltage too Low
                    Fault Status: 01100010
                    Temperature: -40.0°C
                    Absolute Pres.: 0.0 mbar
                    Voltage: 0.000 V
Readiness: 0110 1101
   Part No SW: 8K0 907 379 AH    HW: 8K0 907 379 AH
   Component: ESP8 quattro  H04 0230
   Coding: 112500
   Shop #: WSC 06325 000 00000
   VCID: 7F0D3E96EEF3697E72-802A
03110 - Active Steering Control Module (J792)
                    Fault Status: 00101101
                    Reset counter: 190
                    Mileage: 235884 km
                    Date: 2008.05.27
                    Time: 01:33:25
                    Hex Value: 0x0000
                    Hex Value: 0x0782
                    Hex Value: 0x0029
                    Hex Value: 0x3398
                    Hex Value: 0x00FF
                    Reset counter: 190
                    Mileage: 235884 km
                    Date: 2008.05.27
                    Time: 02:06:26
                    Hex Value: 0x0000
                    Hex Value: 0x4282
                    Hex Value: 0x0028
                    Hex Value: 0x85AD
                    Hex Value: 0x00FF
   Part No SW: 8K0 907 064 AG    HW: 8K0 907 064 AG
   Component: BCM2 1.1      H80 0145
   Coding: 0F0000
   VCID: 75E1DCBEDCCF232E28-8020
   Component: J764 ELV MLB  H36 0042
   Serial number: 0209000020338015
Address 06: Seat Mem. Pass (J521)       Labels:. 8T0-959-760.clb
   Part No SW: 8T0 959 760 B    HW: 8T0 959 760 B
   Component: MEM-BFS       H09 0043
   Revision: AA000000    Serial number: 00001001261350
   Coding: 00017025002C00000000
   VCID: 428B7762DD81C4965D-8016
Address 07: Control Head        Labels: 8T0-035-7xx-07-H.clb
   Part No SW: 8T0 035 729 M    HW: 4E0 035 729 A
   Component: Interfacebox    H43 4610
   Revision: 00000000    Serial number: 340DF097520630
   Coding: 0025003
   VCID: 43857266029BCD9E56-8016
   Subsystem 1 - Part No: 8T0 919 609 D
   Component: E0380 BedienteilH08 0100
   Subsystem 2 - Serial number: 00000000270959
   Subsystem 3 - Serial number: 0115.04.090000000100010413ÿ
   Subsystem 4 - Serial number: 010413ÿ
   Part No SW: 8T1 820 043 AC    HW: 8T1 820 043 AC
   Component: KLIMA 3 ZONEN H06 0150
   Revision: C1000000    Serial number: 01220420090892
   Coding: 48022000
   VCID: 72EBE7A2ADA134160D-8026
                    Fault Status: 01101000
                    Reset counter: 150
                    Mileage: 235884 km
                    Date: 2008.05.27
                    Time: 00:01:28
   Component: BCM1 1.0      H26 0253
   Revision: 05026001    Serial number: 00000000363346
   Coding: 26001091063CAF311E00080300003D3D0F9C93C800010161000000
   VCID: 306F2DAA632D4606BB-8064
   Subsystem 1 - Part No SW: 8T1 955 119 C    HW: 8J1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 160708  H13 0040
   Serial number: SWFBIE 0000624
   Coding: 00FD11
   Component: RLS  H04 0003
   Serial number: 10453890
   Coding: 02532C
   Subsystem 3 - Part No SW: 8K0 941 531 AC    HW: 8K0 941 531 AC
   Component: E1 - LDS  H07 0090
   Serial number: 00000000001103090173
   Subsystem 4 - Part No SW: 8K0 907 410 B    HW: 8K0 907 410 B
   Component: HOMELINK  H01 0010
                    Reset counter: 190
                    Mileage: 235884 km
                    Date: 2008.05.27
                    Time: 02:06:00
   Part No SW: 8T1 035 110 C    HW: 8T1 035 110 C
   Component: MP3-Changer     H43 0390
   Revision: 00043003    Serial number: AUZ5ZBI8792955
   VCID: 2A5B3FC285F13CD675-807E
Address 0F: Digital Radio        Labels: 4E0-910-593-SIR.lbl
   Part No SW: 4E0 910 593 M    HW: 4E0 035 593 F
   Component: SDAR SIRIUS     H07 0160
   Revision: 00000000    Serial number: AUZ4Z7I0534212
   Coding: 0000100
   VCID: 316928AEA8274F0EB4-8064
                    Reset counter: 151
                    Mileage: 235884 km
                    Date: 2008.05.27
                    Time: 01:15:44
   Part No SW: 8K0 919 475 F    HW: 8K0 919 475
   Component: PARKHILFE 4K  H06 0040
   Revision: 11001001    Serial number: 40140911303983
   Coding: 200002
   VCID: 3C77099ABF65B26617-8068
Address 14: Susp. Elect. (J250)       Labels: None
   Part No SW: 8K0 907 364 A    HW: 8K0 907 364
   Component: DAEMPFUNGS-SG H08 0050
   Revision: 00000000    Serial number: 06040900270001
   Coding: 050181
   VCID: 316928AE68274F0EB4-8064
                    Reset counter: 191
                    Mileage: 235884 km
                    Date: 2008.05.27
                    Time: 02:06:25
                    Bin. Bits: 00000000 00000000
                    Bin. Bits: 00000000 00000001
   Part No SW: 8K0 959 655 F    HW: 8K0 959 655 F
   Component: AirbagVW-AU10 H27 0410
   Serial number: 0039KD151TFA
   Coding: 303333334330303030304A55304C38543053
   VCID: 408F7D6ADB8DD6864B-8014
   Subsystem 1 - Part No SW: 8K0 959 339     HW: 8K0 959 339
   Component: BF-Gewichtss.  H01 0050
   Serial number: 5810000R0900003687
   Serial number: 6334MSME465371425
   Serial number: 6344MSME466454227
   Serial number: 6352QSME542719128
   Serial number: 6362QSME3C220C2CN
   Serial number: 63732SME61124A12Q
   Serial number: 63832SME6B125010Q
   Part No SW: 8K0 953 568 G    HW: 8K0 953 568 G
   Revision: --------    Serial number: 90315IDF0002M
   Coding: 000016
   VCID: 3E730392A979A07639-806A
   Part No SW: 8T0 920 981 E    HW: 8T0 920 981 E
   Component: KOMBIINSTR.   H32 0224
   Revision: 00200000    Serial number: 9D9207E49
   Coding: 8B1501003B00D705020000
                    Reset counter: 191
                    Mileage: 235884 km
                    Date: 2008.05.27
                    Time: 02:06:26
   Part No SW: 8T0 907 468 Q    HW: 8T0 907 468 L
   Component: GW-BEM 5CAN-M H10 0095
   Revision: FB600048    Serial number: 4800F094178073
   Coding: 000303
   VCID: 4FAD4E561ED339FEC2-801A
   Component: J367-BDM  H06 0160
   Serial number: 19074B19310309
   Part No SW: 8K0 907 144 C    HW: 8K0 907 144 C
   Component: DYNAMIKLENK.  H06 0500
   Revision: 50001005    Serial number: --------------
   Coding: 840000
   Shop #: WSC 06324 000 00000
   VCID: 2F6D2ED67E1359FEA2-807A
Address 1E: Media Player 2 (R199)       Labels:. 4E0-035-785.lbl
   Part No SW: 4E0 035 785 F    HW: 4E0 035 785 C
   Component: SG ext.Player H20 0850
   Revision: 00000000
   Coding: 020000
   VCID: 2B553AC64A0B25DE8E-807E
   Component: MEM-FS        H09 0043
   Revision: AA000000    Serial number: 00001001261167
   Coding: 00197B25002C00000000
   Part No SW: 4E0 910 888 M    HW: 4E0 919 887 M
   Component: MNS US          H52 1100
   Revision: 00000000    Serial number: 341DQ097525815
   Shop #: WSC 06342 000 00000
   VCID: 387F158A4B5D9E46F3-806C
   Part No SW: 8K0 907 566 B    HW: 4L0 907 566 B
   Revision: 00H01000    Serial number: 6PZ 009 014-13
   Coding: 0000004
   VCID: 36631BB241496836E1-8062
   Subsystem 1 - Part No: 8K0 907 568 B
   Subsystem 2 - Serial number: 6PZ 009 014-33
   Subsystem 3 - Serial number: 5F24.03.0900H010003CD10273ÿ
   Subsystem 4 - Serial number: D10273ÿ
   Part No SW: 8K0 959 793 D    HW: 8K0 959 793 D
   Revision:             Serial number: 0000008793444
   Coding: 011C13224E00120102
   VCID: 4189786ED887DF8E44-8014
   Revision: 00002001    Serial number: 0117677757
   Coding: 0106069A007A444500B000
   Component: GTO BF  H06 0050
   Serial number: 00000000000000132775
   Subsystem 3 - Part No SW: 8R0 959 591     HW: 8R0 959 591
   Component: J245EE16SKB10  H01 0180
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 151
                    Mileage: 235884 km
                    Date: 2008.05.27
                    Time: 01:55:03
   Part No SW: 8T0 035 223 T    HW: 8T0 035 223 F
   Component: DSP Prem      H14 0400
   Revision: 00H14003    Serial number: 34814004703101
   Coding: 030101
   Shop #: WSC 12336 024 394758
   VCID: 3F8D7E96AE73A97E32-806A
00422 - Rear Right DSP Midrange Speaker (R106)
                    Reset counter: 151
                    Mileage: 235884 km
                    Date: 2008.05.27
                    Time: 01:15:39
                    Voltage: 12.20 V
                    Temperature: 23.0°C
                    Temperature: 24.0°C
                    Bin. Bits: 01000000
   Part No SW: 8K0 959 792 D    HW: 8K0 959 792 D
   Revision:             Serial number: 0000008803772
   VCID: 408F7D6AD38DD6864B-8014
   Part No SW: 8K0 907 801 G    HW: 8K0 907 801 G
   Component: EPB Audi B8   H08 0080
   Revision: 00000003    Serial number: 10000000222380
   VCID: 336522A6923B7D1EC6-8066
02435 - Supply Voltage for Control Module for Right Channel
                    Fault Status: 00101001
                    Reset counter: 190
                    Mileage: 235884 km
                    Date: 2008.05.27
                    Time: 02:16:45
                    Voltage: 13.30 V
                    Count: 17
                    Hex Value: 0x02E1
                    Hex Value: 0x0021
                    Hex Value: 0x0808
Address 55: Headlight Range        Labels: 8T0-907-357.clb
   Part No SW: 8H0 907 357 A    HW: 8H0 907 357
   Coding: 0000018
   VCID: 306F2DAAA32D4606BB-8064
   Subsystem 1 - Part No: 7L6 941 329 C
   Component: AFS-Modul links H01 0004
   Subsystem 2 - Part No: 7L6 941 329 C
   Component: AFS-Modul rechtsH01 0004
00471 - Control Module for Elect. Regulated Dampers (J250)
                    Reset counter: 191
                    Mileage: 235884 km
                    Date: 2008.05.27
                    Time: 01:55:02
                    Reset counter: 191
                    Mileage: 235884 km
                    Date: 2008.05.27
                    Time: 02:06:25
   Part No SW: 4E0 910 541 T    HW: 4F0 035 541 N
   Component: TUNER EU/US/RDW H42 0630
   Revision: 00000000    Serial number: 357DJ097532011
   Coding: 0000002
Address 65: Tire Pressure (J502)       Labels: 8K0-907-273.clb
   Part No SW: 8K0 907 273 A    HW: 8K0 907 273 A
   Component: J502-RDK      H03 0250
   Revision: 00001001    Serial number: 13374795152427
   Coding: 0CD154
   Part No SW: 4E0 910 754 Q    HW: 4E0 035 753 A
   Component: SDS 3501 US     H46 0630
   Revision: 00000000    Serial number: 00000904030025
   VCID: 346721BA57357A26DF-8060
   Part No SW: 8T0 907 441 B    HW: 4L0 907 441 A
   Component: J772__Rearview      0070
   Revision: --H12---    Serial number: 525PA8-J9290T6
   Coding: 1001008
   VCID: 377D16B64643913EFA-8062
                    Reset counter: 191
                    Mileage: 235884 km
                    Date: 2008.05.27
                    Time: 02:06:25
                        Reverse OFF
                    Count: 5
   Part No SW: 4F0 910 336 H    HW: 4E0 862 335
   Component: Handyvorb2      H20 1130
   Revision: 00000000    Serial number: 00000005085102
   Coding: 0010900
   VCID: 285FC5CA9BFD0EC663-807C
End-------------------------(Elapsed Time: 04:12)--------------------------
After getting this scan I started looking into things as they are sorted by fault priority. We can see our first priority is:
Reset counter: 190
Mileage: 235884 km
Date: 2008.05.27
Time: 02:16:45
Voltage: 13.30 V
Count: 17
Hex Value: 0x02E1
Hex Value: 0x0021
Hex Value: 0x0808
Okay, so I am still able to start the car at this time. Since I saved the log, I cleared my codes and start this rig up. Pull on the parking brake lever (which I used all the time since it's a manual) and boom, errors triggered on the dash. Unfortunately for me, it's late. We'll try again the next day.
2 days later I want to do some output tests. So I jump into the parking brake module (address 53). Sure enough, I get errors when I try to actuate the RH parking brake. Current measures 0 on that channel (I think it's a calculated value if I remember correctly). Auto-scan supports these findings, as well:
Saturday,01,August,2020,11:27:07:03605
VIN: WAURV78T19A055187   License Plate: (1)20200801
   Revision: 76H10---
   Coding: 112500
   Coding: 0F0000
   Coding: 0025003
   Coding: 48022000
                    Reset counter: 150
                    Mileage: 235884 km
                    Date: 2008.05.27
                    Time: 00:12:37
   Coding: 00FD11
   Coding: 02532C
   Coding: 0000100
                    Reset counter: 150
                    Mileage: 235884 km
                    Date: 2008.05.27
                    Time: 00:12:47
   Coding: 200002
   Coding: 050181
   Coding: 000016
   Coding: 000303
   Coding: 840000
   Revision: 00000000
   Coding: 020000
   Coding: 0000004
                    Reset counter: 150
                    Mileage: 235884 km
                    Date: 2008.05.27
                    Time: 00:12:37
   Coding: 030101
            009 - Open or Short to Ground - MIL ON
                    Fault Status: 11101001
                    Reset counter: 150
                    Mileage: 235884 km
                    Date: 2008.05.27
                    Time: 00:12:54
                    Voltage: 13.20 V
                    Count: 17
                    Hex Value: 0x02E0
                    Hex Value: 0x0001
                    Hex Value: 0x0808
   Coding: 0000018
   Coding: 0000002
   Coding: 0CD154
   Coding: 1001008
   Coding: 0010900
End-------------------------(Elapsed Time: 04:05)--------------------------
So I set off to chase wires seeing how I was battling corrosion on those cooling fans recently. A lot easier to work with than I was anticipating. Parking brake wires are well protected outside of the car and the run comes up and in to the trunk (er, boot?) and to the control module on the RH side behind a carpet panel. Sweet. Measure wires for continuity and visible check tells me the wiring is good. No water or anything in the compartment. A real head scratcher here. Plug everything back in and start the car to see if maybe unplugging and plugging back in has some miraculous fixt (it worked for those Nintendo games, right?!). Well, at this time the car turned on and then I had no control over it. Couldn't push any buttons to turn it off. I think I did a scan while the car was on and acting up:
Sunday,02,August,2020,14:24:31:03605
VCDS Version: 20.4.2.0 (x64)
VIN: WAURV78T19A055187   License Plate: 20200802
05-Acc/Start Auth. -- Status: Cannot be reached 1100
0E-Media Player 1 -- Status: Malfunction 0010
14-Susp. Elect. -- Status: Cannot be reached 1100
46-Central Conv. -- Status: Cannot be reached 1100
65-Tire Pressure -- Status: Cannot be reached 1100
67-Voice Control -- Status: Malfunction 0010
   Revision: 76H10---
   VCID: 4A9B5F42E5B11CD68D-801E
                    Voltage: 0.000 V
049473 - Body Control Module (Central Electric 2)
               U0141 - 008 - No Communications
                    Mileage: 235884 km
                    Date: 2008.05.27
                    Time: 00:06:21
                    RPM: 697 /min
                    Load: 22.0 %
                    Temperature: 45.0°C
                    Temperature: 30.0°C
                    Absolute Pres.: 970.0 mbar
                    Voltage: 14.478 V
                    Mileage: 235884 km
                    Date: 2008.05.27
                    Time: 00:06:31
                    RPM: 705 /min
                    Load: 22.3 %
                    Temperature: 46.0°C
                    Temperature: 30.0°C
                    Voltage: 14.097 V
   Coding: 112500
   VCID: 7F0D3E96EEF3697E6A-802A
   VCID: 428B7762DD81C49645-8016
                    Reset counter: 150
                    Mileage: 235884 km
                    Date: 2008.05.27
                    Time: 00:06:21
   Coding: 0025003
   VCID: 43857266029BCD9E4E-8016
                    Reset counter: 150
                    Mileage: 235884 km
                    Date: 2008.05.27
                    Time: 00:06:40
                    Reset counter: 150
                    Mileage: 235884 km
                    Date: 2008.05.27
                    Time: 00:06:40
                    Reset counter: 150
                    Mileage: 235884 km
                    Date: 2008.05.27
                    Time: 00:06:33
                    Bin. Bits: 00100000 10000000
   Coding: 48022000
   VCID: 72EBE7A2ADA1341615-8026
                    Reset counter: 150
                    Mileage: 235884 km
                    Date: 2008.05.27
                    Time: 00:12:37
   VCID: 306F2DAA632D4606A3-8064
   Coding: 00FD11
   Coding: 02532C
                    Reset counter: 150
                    Mileage: 235884 km
                    Date: 2008.05.27
                    Time: 00:06:00
                    Reset counter: 190
                    Mileage: 235884 km
                    Date: 2008.05.27
                    Time: 00:06:00
                    Reset counter: 150
                    Mileage: 235884 km
                    Date: 2008.05.27
                    Time: 00:06:00
   VCID: 2A5B3FC285F13CD66D-807E
                    Reset counter: 150
                    Mileage: 235884 km
                    Date: 2008.05.27
                    Time: 00:06:52
   Coding: 0000100
   VCID: 316928AEA8274F0EAC-8064
                    Reset counter: 150
                    Mileage: 235884 km
                    Date: 2008.05.27
                    Time: 00:12:47
   Coding: 200002
   VCID: 3C77099ABF65B2660F-8068
                    Reset counter: 150
                    Mileage: 235884 km
                    Date: 2008.05.27
                    Time: 00:06:21
                    Temperature: 25.0°C
   VCID: 408F7D6ADB8DD68653-8014
   Coding: 000016
   VCID: 3E730392A979A07621-806A
                    Reset counter: 150
                    Mileage: 235884 km
                    Date: 2008.05.27
                    Time: 00:06:21
                    Reset counter: 150
                    Mileage: 235884 km
                    Date: 2008.05.27
                    Time: 00:06:31
                    Reset counter: 150
                    Mileage: 235884 km
                    Date: 2008.05.27
                    Time: 00:06:33
                    Reset counter: 150
                    Mileage: 235884 km
                    Date: 2008.05.27
                    Time: 00:06:36
   Coding: 000303
   VCID: 4FAD4E561ED339FEDA-801A
                    Reset counter: 150
                    Mileage: 235884 km
                    Date: 2008.05.27
                    Time: 00:06:21
00456 - Control Module for Access and Start Control (J518)
                    Reset counter: 150
                    Mileage: 235884 km
                    Date: 2008.05.27
                    Time: 00:06:32
                    Reset counter: 150
                    Mileage: 235884 km
                    Date: 2008.05.27
                    Time: 00:06:32
                    Reset counter: 150
                    Mileage: 235884 km
                    Date: 2008.05.27
                    Time: 00:06:34
   Coding: 840000
   VCID: 2F6D2ED67E1359FEBA-807A
   Revision: 00000000
   Coding: 020000
   VCID: 2B553AC64A0B25DE96-807E
                    Reset counter: 150
                    Mileage: 235884 km
                    Date: 2008.05.27
                    Time: 00:06:21
   VCID: 387F158A4B5D9E46EB-806C
   Coding: 0000004
   VCID: 36631BB241496836F9-8062
                    Reset counter: 150
                    Mileage: 235884 km
                    Date: 2009.01.01
   Coding: 030101
   VCID: 3F8D7E96AE73A97E2A-806A
                    Reset counter: 150
                    Mileage: 235884 km
                    Date: 2008.05.27
                    Time: 00:00:07
                    Voltage: 12.50 V
                    Temperature: 20.0°C
                    Temperature: 21.0°C
                    Bin. Bits: 00000100
   VCID: 336522A6923B7D1EDE-8066
                    Reset counter: 150
                    Mileage: 235884 km
                    Date: 2008.05.27
                    Time: 00:07:00
                    Voltage: 14.40 V
                    Count: 15
                    Hex Value: 0x02F0
                    Hex Value: 0x0001
                    Hex Value: 0x0801
02433 - Supply Voltage for Right Parking Brake Motor (V283)
            011 - Open Circuit - MIL ON
                    Fault Status: 11101011
                    Reset counter: 150
                    Mileage: 235884 km
                    Date: 2008.05.27
                    Time: 00:07:00
                    Voltage: 14.40 V
                    Count: 29
                    Hex Value: 0x02F0
                    Hex Value: 0x0001
                    Hex Value: 0x0801
                    Fault Status: 11100100
                    Reset counter: 150
                    Mileage: 235884 km
                    Date: 2008.05.27
                    Time: 00:06:31
                    Voltage: 14.40 V
                    Count: 68
                    Hex Value: 0x02E0
                    Hex Value: 0x0001
                    Hex Value: 0x0101
   Coding: 0000018
   VCID: 306F2DAAA32D4606A3-8064
                    Reset counter: 150
                    Mileage: 235884 km
                    Date: 2008.05.27
                    Time: 00:06:19
                    Reset counter: 190
                    Mileage: 235884 km
                    Date: 2008.05.27
                    Time: 00:06:21
                    Reset counter: 150
                    Mileage: 235884 km
                    Date: 2008.05.27
                    Time: 00:06:21
   Coding: 0000002
   VCID: 346721BA57357A26C7-8060
                    Reset counter: 150
                    Mileage: 235884 km
                    Date: 2008.05.27
                    Time: 00:06:37
                    Reset counter: 150
                    Mileage: 235884 km
                    Date: 2008.05.27
                    Time: 00:06:37
   Coding: 0010900
   VCID: 285FC5CA9BFD0EC67B-807C
End-------------------------(Elapsed Time: 03:56)--------------------------
So, how to turn the car off? Well, I disconnected the battery (both terminals) and the car was still running on generator power. Uh,,, okay. Next step I pulled off the cowl under the hood (and other parts) and removed the ECU cover. ECU pulled out (not disconnected, simply making space to access relays). Pulled relays one-by-one until the car shut off. Not sure what relay went where, but I was in a pinch to get this thing turned off. Another late night, so I went inside and ordered a used parking brake module from eBay making sure it matched the part number exactly. And then I waited...
Today, I get the part in and before I swap anything out I wanted to get another scan of the car. Unfortunately, the car did not want to talk to me today. I tried to clear codes, access the gateway, etc. No real luck. Here's the scan:
Sunday,09,August,2020,10:40:16:03605
VIN:    License Plate: 20200809
Chassis Type: 8T0
01-Engine -- Status: Cannot be reached 1100
04-Steering Angle -- Status: Cannot be reached 1100
10-Park/Steer Assist -- Status: Cannot be reached 1100
15-Airbags -- Status: Cannot be reached 1100
1B-Active Steering -- Status: Cannot be reached 1100
3C-Lane Change -- Status: Cannot be reached 1100
55-Headlight Range -- Status: Cannot be reached 1100
Address 01: Engine
   Coding: 112500
                    Reset counter: 150
                    Mileage: 235884 km
                    Date: 2008.05.27
                    Time: 00:01:56
   Coding: 0025003
                    Reset counter: 150
                    Mileage: 235884 km
                    Date: 2008.05.27
                    Time: 00:01:55
                    Reset counter: 150
                    Mileage: 235884 km
                    Date: 2008.05.27
                    Time: 00:02:54
                    Bin. Bits: 00100000 00000000
   Coding: 48022000
   Coding: 00FD11
   Coding: 02532C
                    Reset counter: 150
                    Mileage: 235884 km
                    Date: 2008.05.27
                    Time: 00:01:00
   Coding: 0000100
                    Reset counter: 150
                    Mileage: 235884 km
                    Date: 2008.05.27
                    Time: 00:02:06
Address 15: Airbags
   Coding: 000016
                    Reset counter: 150
                    Mileage: 235884 km
                    Date: 2008.05.27
                    Time: 00:01:55
   Coding: 000303
                    Reset counter: 150
                    Mileage: 235884 km
                    Date: 2008.05.27
                    Time: 00:01:58
                    Reset counter: 150
                    Mileage: 235884 km
                    Date: 2008.05.27
                    Time: 00:01:58
                    Reset counter: 150
                    Mileage: 235884 km
                    Date: 2008.05.27
                    Time: 00:02:01
                    Reset counter: 150
                    Mileage: 235884 km
                    Date: 2008.05.27
                    Time: 00:02:43
01312 - Powertrain Data Bus
                    Reset counter: 150
                    Mileage: 235884 km
                    Date: 2008.05.27
                    Time: 00:02:44
   Revision: 00000000
   Coding: 020000
                    Reset counter: 150
                    Mileage: 235884 km
                    Date: 2008.05.27
                    Time: 00:01:56
Address 56: Radio
End-------------------------(Elapsed Time: 03:11)--------------------------
The car was really fighting me today and I noticed only a few modules would even produce codes. I tried to drive into each of those modules to clear but I get nothing. Can't even get the dash to light up anymore. At this point I won't bother swapping in the parking brake module because I won't even know if that works.
So, this is where I'd like to reach out to the forum. I appreciate the time and effort everyone lends to help me out. I am at a loss as to what my next step should be. In the meantime I'll keep searching and reading anything that might shed some light on this.
Thanks again. -Erick
ES803313
C?ID=242285
I should also note that I have the keyless start feature. Whenever I put the key inside the dash slot it locks it in place. Was able to get it to release once in my fiddling but I'm afraid to try it again for fear that the key gets stuck forever!
Seems to me you have various voltage supply problems in this car.
Have you got proper wiring diagrams for it?
If it were mine, and the last scan reflected its current state, I would start at the Kessy module (05 - Acc/Start Auth) and try to figure out why it's not talking now. With it being out of commission, lots of other stuff won't power up either.
ES803313
C?ID=242285
Uwe and Jack,
I appreciate the response. I do have some downloads from Erwin. Used a day subscription to download everything a could find. It has already helped me find out some of these component locations so I can start chasing wires. I'll look for this Kessy module and see what I can find.
Again, I truly appreciate the help here my friends.
ES803313
C?ID=242285
Few things to report. I haven't had much time to work on this thing. I'm mostly able to get into the car at night. Here's the current status of the vehicle:
So far no indications that Kessy is (or ever was) wet. At this time I've decided to get eyes on the wiring harness so I am taking the car apart! Stay tuned.
