car will start but shuts of like its starving for gas. also how come in my auto scan it's showing just about everything malfunctioned.. i just got the car so i am eager to gegt it going.. and last thing is in the diagnostic procedures it doesn't show my engine code.. so what am i to do?? thanks
Saturday,08,August,2020,19:42:46:01276
VCDS Version: 20.4.2.0 HEX-V2 CB: 0.4513.4
VIN: WVWNL73C39E524948 License Plate:
Chassis Type: 3C-VW46 (3C0)
Scan: 01 03 08 09 0F 15 16 17 19 1C 25 36 42 44 46 52 53 56 62 65
72
VIN: WVWNL73C39E524948 Mileage: 164280km-102078miles
09-Cent. Elect. -- Status: Malfunction 1010
1C-Position Sensing -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 1010
62-Door, Rear Left -- Status: Malfunction 1010
Address 01: Engine (CCT) Labels:. 06J-906-026-CCT.clb
Part No SW: 06J 906 026 AF HW: 06J 906 026 AF
Component: MED17.5 TFSI 2,0 3318
Revision: AAH03--- Serial number: VWZCZ000000000
Coding: 0404010A18070160
Shop #: WSC 05314 000 00000
VCID: 6E85CBFC6C974ABBB0F-803A
8 Faults Found:
000568 - Manifold Pressure / Boost Sensor (G31)
P0238 - 000 - Signal too High - MIL ON
Fault Status: 11100000
Mileage: 164284 km
Date: 2014.12.28
Time: 00:36:22
Load: 0.0 %
Temperature: 39.0°C
Temperature: 28.0°C
Absolute Pres.: 980.0 mbar
Voltage: 11.811 V
000112 - Sensor for Ambient Air Temperature (G17)
P0070 - 000 - Malfunction - MIL ON
Mileage: 164284 km
Date: 2014.12.28
Time: 00:36:23
Load: 0.0 %
Temperature: 39.0°C
Temperature: 28.0°C
Voltage: 11.811 V
008581 - Engine Coolant Temp Sensor on Radiator Outlet (G83)
P2185 - 000 - Signal too High - Intermittent
Mileage: 164285 km
Date: 2014.12.28
Time: 00:05:34
Load: 0.0 %
Temperature: 34.0°C
Temperature: 22.0°C
Voltage: 12.700 V
001674 - ECM Power Relay Load Circuit
P068A - 000 - Opens Too Early - Intermittent
Date: 2047.15.31
Time: 31:63:63
Load: 0.0 %
Temperature: 25.0°C
Temperature: 23.0°C
Voltage: 9.779 V
001379 - System Voltage
P0563 - 000 - Too High
Mileage: 164285 km
Date: 2014.12.28
Time: 00:04:49
Load: 0.0 %
Temperature: 32.0°C
Temperature: 36.0°C
Voltage: 17.399 V
Mileage: 164285 km
Date: 2014.12.28
Time: 00:04:49
Load: 0.0 %
Temperature: 32.0°C
Temperature: 36.0°C
Voltage: 17.399 V
001299 - Incorrect Immobilizer Key
P0513 - 000 - - Intermittent
Mileage: 164285 km
Date: 2014.12.28
Time: 00:00:45
RPM: 2266 /min
Load: 76.8 %
Temperature: 32.0°C
Temperature: 30.0°C
Voltage: 12.446 V
008852 - Fuel Pressure Regulator Valve (N276)
P2294 - 000 - Open Circuit - Intermittent
Mileage: 164285 km
Date: 2014.12.30
Time: 00:58:37
Load: 0.0 %
Temperature: 30.0°C
Temperature: 30.0°C
Voltage: 12.065 V
Readiness: 0110 0101
Address 03: ABS Brakes Labels:. 3C0-614-109-C4.clb
Part No SW: 3C0 614 109 P HW: 3C0 614 109 P
Component: J104 C4 440 V2 0011
Revision: --025--- Serial number: 00000786092998
Coding: 0000373
Shop #: WSC 05311 000 00000
VCID: 2B0302E89F057F93D71-807E
Fault Status: 00101101
Fault Frequency: 206
Reset counter: 2
Mileage: 164275 km
Date: 2014.12.20
Time: 12:58:50
Hex Value: 0x0000
Voltage: 12.25 V
Bin. Bits: 00011110
Count: 217
Hex Value: 0x0000
Reset counter: 2
Mileage: 164275 km
Date: 2014.12.20
Time: 12:58:50
Hex Value: 0x0000
Voltage: 12.25 V
Bin. Bits: 00011110
Count: 217
Hex Value: 0x0000
Reset counter: 2
Mileage: 164275 km
Date: 2014.12.20
Time: 12:58:50
Part No SW: 3C8 907 336 E HW: 3C8 907 336 E
Component: Climatic 120 0102
Revision: 00003001
Coding: 0000000000
ASAM Dataset: EV_Climatic A01001
ROD: EV_ClimaBasis_VW46.rod
VCID: 2F3B16F8A79D03B3FB9-807A
9 Faults Found:
13701376 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Motorsteuergerät - kein Signal/Kommunikation]
Reset counter: 49
Mileage: 164285 km
Date: 2020.08.07
Time: 00:00:18
13701408 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Diagnoseinterface für Datenbus - kein Signal/Kommunikation]
Reset counter: 49
13701424 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Steuergerät für Bordnetz - kein Signal/Kommunikation]
Reset counter: 49
13701936 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
[Steuergerät für Bordnetz - bitte Fehlerspeicher auslesen]
Reset counter: 49
Mileage: 164284 km
Date: 2020.08.05
Time: 22:28:25
13701456 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Steuergerät im Schalttafeleinsatz - kein Signal/Kommunikation]
Reset counter: 49
13701968 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
[Steuergerät im Schalttafeleinsatz - bitte Fehlerspeicher auslesen]
Fault Frequency: 89
Reset counter: 9
Mileage: 164275 km
Date: 2020.07.28
Time: 00:12:01
13701488 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Türsteuergerät Fahrerseite - kein Signal/Kommunikation]
Reset counter: 48
Mileage: 164275 km
Date: 2020.07.31
Time: 03:34:32
13701520 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Türsteuergerät hinten links - kein Signal/Kommunikation]
Reset counter: 48
Mileage: 164275 km
Date: 2020.07.31
Time: 03:34:32
13636096 - Supply voltage
U1012 00 [008] - Voltage too High
[Versorgungsspannung - oberer Grenzwert überschritten]
Reset counter: 49
Mileage: 164285 km
Date: 2020.08.06
Time: 00:05:53
Revision: 00H54000 Serial number: 00000008816018
Coding: F1848F8B40041A0047970F00170000000028FF475C40017C170000000000
Shop #: WSC 05124 000 00000
VCID: 33331A88473527539F1-8066
Subsystem 1 - Part No: 3C8 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 170708 022 0602
Coding: 00046997
Shop #: WSC 05124
Component: RLS 120908 054 0402
Coding: 00209133
Shop #: WSC 05124
10 Faults Found:
Fault Status: 01101100
Reset counter: 9
Voltage: 9.55 V
Fault Status: 01111100
Reset counter: 9
Voltage: 9.50 V
Reset counter: 9
Voltage: 9.45 V
Reset counter: 9
Voltage: 9.40 V
00532 - Supply Voltage B+
Fault Status: 00100001
Reset counter: 42
Mileage: 164275 km
Voltage: 15.65 V
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 9
Mileage: 164275 km
Voltage: 9.35 V
Reset counter: 9
Mileage: 164275 km
Voltage: 9.35 V
Reset counter: 9
Mileage: 164275 km
Voltage: 9.30 V
Reset counter: 9
Mileage: 164275 km
Voltage: 9.30 V
02386 - Rain / Light Recognition Sensor Function restriction due to Over-Voltage
Reset counter: 42
Mileage: 164275 km
Voltage: 15.45 V
Revision: 00000000 Serial number: AUZ4Z7H0410055
Coding: 0000000
Fault Frequency: 7
Reset counter: 49
Mileage: 164285 km
Date: 2014.12.28
Time: 00:00:07
Voltage: 15.50 V
Reset counter: 49
Mileage: 164285 km
Date: 2014.12.28
Time: 00:00:45
Voltage: 18.50 V
Part No SW: 5N0 959 655 HW: 5N0 959 655
Component: J234__313 VW10 HI 1815
Revision: 19013000 Serial number: 0039BPHY4NGD
Coding: 0012595
VCID: 7AADF7AC20DF161B1C7-802E
Subsystem 1 - Part No: 3C8 959 339
Component: BF-Gewichtsens. 001 0003
Subsystem 2 - Serial number: 00000000001Q7T
Subsystem 3 - Serial number: 0011.06.080000100000650273ÿ†63
Subsystem 4 - Serial number: 650273ÿ†6333FTS605812478 ÿ†63
Subsystem 5 - Serial number: 12478 ÿ†6343FTS606552478 ÿ†63
Subsystem 6 - Serial number: 52478 ÿ†6353ETS64V1KUVNH ÿ†63
Subsystem 7 - Serial number: KUVNH ÿ†6363ETS68N3OUVNH ÿ†00
Subsystem 8 - Serial number: OUVNH ÿ†00000000000000000ÿ†63
Subsystem 9 - Serial number: 000000ÿ†6384CTS6BR7VUVNR ÿ
Subsystem 10 - Serial number: VUVNR ÿ
01738 - Crash Sensor for Front Airbag; Drivers Side (G283)
007 - Short to Ground - Intermittent - MIL ON
Fault Status: 10100111
Fault Frequency: 19
Reset counter: 44
Mileage: 164275 km
Date: 2014.12.21
Time: 12:37:39
008 - Implausible Signal - Intermittent - MIL ON
Fault Status: 10101000
Fault Frequency: 14
Reset counter: 42
Mileage: 164275 km
Date: 2014.12.21
Time: 12:37:20
Fault Status: 11101010
Fault Frequency: 27
Reset counter: 42
Mileage: 164275 km
Date: 2014.12.19
Time: 00:12:03
Address 16: Steering wheel Labels: 3C0-953-549-SW25.lbl
Part No SW: 3C0 953 549 AK HW: 3C0 953 549 AK
Component: J0527 0025
Revision: 00030000 Serial number: 3C5953507CP
Coding: 0000511
VCID: 75B7E49009C17963715-8020
Subsystem 1 - Part No: 3C8 959 537 Labels: 3C8-959-537.CLB
Component: E221__MFL-TAP H2ÿ 0021
Coding: 00000226
Part No SW: 3C8 920 970 B HW: 3C8 920 970 B
Component: KOMBI H19 0023
Coding: 240F00
Shop #: WSC 05311 115 00000
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04020
ROD: EV_Kombi_UDS_VDD_RM09_004_VW46.rod
VCID: 2B0302E893857F93D71-807E
9453330 - Outside temperature sensor
B103F 1B [009] - Resistance Too High
Reset counter: 2
Mileage: 164275 km
Date: 2020.07.28
Time: 00:12:00
12648448 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Steuergerät für Motor: keine Kommunikation]
Fault Frequency: 7
Reset counter: 49
Mileage: 164285 km
Date: 2020.08.07
Time: 00:00:15
12664832 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Steuergerät für BCM / Bordnetz / el. ZE: keine Kommunikation]
Reset counter: 49
Mileage: 164285 km
Date: 2020.08.08
Time: 00:56:58
13893888 - Function Restricted due to Excessive Voltage
U1401 00 [008] - -
Reset counter: 49
Mileage: 164285 km
Date: 2020.08.06
Time: 11:07:28
Address 19: CAN Gateway Labels:. 3C0-907-530-V2.clb
Part No SW: 3C0 907 530 H HW: 3C0 907 951
Component: J533__Gateway H13 0142
Revision: H13 Serial number: 2600
Coding: F980FF07001302F100
VCID: 2615F3DC84E742FB08F-8072
Reset counter: 49
Mileage: 164275 km
Date: 2014.12.19
Time: 01:53:45
Reset counter: 48
Mileage: 164275 km
Date: 2014.12.22
Time: 03:34:33
Reset counter: 48
Mileage: 164275 km
Date: 2014.12.22
Time: 03:34:33
Reset counter: 49
Mileage: 164285 km
Date: 2014.12.29
Time: 00:00:17
Reset counter: 49
Mileage: 164285 km
Date: 2014.12.30
Time: 00:57:02
Part No SW: 3C8 919 965 HW: 3C8 919 965
Component: Kompass 001 0001
Revision: 00001000 Serial number: 1614128T01P102
Reset counter: 49
Mileage: 164285 km
Date: 2014.12.30
Time: 00:57:04
Part No SW: 3C0 959 433 AK HW: 3C0 959 433 AK
Component: IMMO 051 0383
Revision: 00051000 Serial number: VWZCZ000000000
Shop #: WSC 21316 002 1048576
VCID: 73B3DA8807B567535F1-8026
Component: ELV 029 0380
3C0905861J ELV 029 0380
02828 - Enabling Steering Column Lock from Diagnostic Interface
Reset counter: 49
Mileage: 164285 km
Date: 2014.12.30
Time: 00:57:01
02861 - Electronic Steering Column Lock Check Sum Error
Reset counter: 49
Mileage: 164285 km
Date: 2014.12.28
Time: 00:00:40
02812 - Supply Voltage (Terminal 30) for Electronic Steering Column Lock
Reset counter: 49
Mileage: 164285 km
Date: 2014.12.28
Time: 00:00:52
Address 36: Seat Mem. Drvr Labels: 3C0-959-760.lbl
Part No SW: 3C8 959 760 HW: 3C8 959 760
Component: J810 0801
Revision: 00002000 Serial number: 00000000000000
Coding: 0000001
VCID: 72BDDF8C78AF6E5B547-8026
Reset counter: 49
Mileage: 164285 km
Date: 2014.12.28
Time: 00:05:47
Reset counter: 49
Mileage: 164285 km
Date: 2014.12.30
Time: 00:57:01
Part No SW: 1T0 959 701 L HW: 1K0 959 793 P
Component: J386 TUER-SG FT 1533
Revision: 71009005 Serial number: 00000547188806
Coding: 0001463
VCID: 40D9454406838CCB123-8014
Fault Status: 01100101
Reset counter: 9
Mileage: 164275 km
Date: 2014.12.19
Time: 00:11:58
00131 - Outside Door Handle Illumination/mirror Light Driver Side
Fault Status: 00101100
Fault Frequency: 12
Reset counter: 48
Mileage: 164279 km
Date: 2014.12.22
Time: 23:20:10
01734 - Potentiometer for Mirror Adj. Horizontal; Drivers Side
Reset counter: 48
Mileage: 164279 km
Date: 2014.12.22
Time: 23:20:11
01736 - Potentiometer for Mirror Adj. Vertical; Drivers Side
Reset counter: 48
Mileage: 164279 km
Date: 2014.12.22
Time: 23:20:11
Fault Frequency: 8
Reset counter: 49
Reset counter: 49
Part No SW: 5N1 909 144 G HW: 5N1 909 148 F
Component: J500__APA-BS KL.074 0401
Revision: 1AH02234 Serial number: 00081830023902
Coding: 0000258
VCID: 3635239C5447327BB8F-8062
00003 - Control Module
Fault Status: 11101100
Reset counter: 2
Term 15 On
(no units): 14.0
Voltage: 11.00 V
Fault Status: 11100101
Reset counter: 9
(no units): 14.0
Steering Angle: 0.00°
Not OK
(no units): 6
01288 - Terminal 30; Steering Assist
Fault Status: 00101011
Fault Priority: 9
Reset counter: 49
Mileage: 164275 km
Term 15 On
(no units): 14.0
Voltage: 10.00 V
Component: KSG PQ46 RDK 051 0221
Coding: 13910F8001862E521204141FF08A8F0E085C01
Shop #: WSC 77129 444 25114
Reset counter: 49
Reset counter: 48
Mileage: 164275 km
Date: 2014.12.22
Time: 03:34:34
Reset counter: 48
Mileage: 164275 km
Date: 2014.12.22
Time: 03:34:34
Reset counter: 49
Reset counter: 49
Reset counter: 49
Part No SW: 1T0 959 702 L HW: 1K0 959 792 P
Component: J387 TUER-SG BT 1533
Revision: 71009005 Serial number: 00000780688811
Coding: 0001462
VCID: 41DF40400D8985C31DD-8014
Reset counter: 9
00936 - Electric Window Switch in Front Passenger Door (E107).
Reset counter: 49
Mileage: 164284 km
Date: 2014.12.27
Time: 22:04:21
Fault Frequency: 7
Reset counter: 49
Reset counter: 49
Reset counter: 48
Mileage: 164275 km
Date: 2014.12.22
Time: 03:34:35
Address 53: Parking Brake Labels: 5N0-907-801.clb
Part No SW: 3C8 907 801 A HW: 3C8 907 801 A
Component: J540 EPB3 VW-10498 0003
Revision: 009 Serial number: 00000000126382
Coding: 0000057
VCID: 2809FDE48EF3548B3A3-807C
00576 - Terminal 15
Reset counter: 49
Mileage: 164285 km
Date: 2014.12.30
Time: 00:56:60
Voltage: 11.80 V
Count: 54
Hex Value: 0x1160
Hex Value: 0x0001
Hex Value: 0x0101
03182 - Clutch Position Sensor (G476)
Fault Status: 00101010
Reset counter: 49
Voltage: 12.30 V
Count: 57
Hex Value: 0x1270
Hex Value: 0x0001
Hex Value: 0x0101
Fault Frequency: 11
Reset counter: 49
Mileage: 164285 km
Date: 2014.12.29
Time: 00:00:19
Voltage: 12.40 V
Count: 73
Hex Value: 0x1270
Hex Value: 0x0001
Hex Value: 0x0101
02845 - Function Display in Instrument Cluster (!)
Fault Status: 00100111
Fault Frequency: 8
Reset counter: 49
Mileage: 164275 km
Date: 2014.12.19
Time: 00:27:32
Voltage: 10.10 V
Count: 78
Hex Value: 0x1171
Hex Value: 0x0001
Hex Value: 0x1010
Address 56: Radio Labels: None
Part No SW: 3C8 035 180 A HW: 3C8 035 180 A
Component: Radio PM6 024 0046
Revision: 00024000 Serial number: VWZ5Z7H2257775
Coding: 0040401
VCID: 2019E5C4E6C3ACCB723-8074
Fault Status: 00110100
Reset counter: 49
Fault Frequency: 7
Reset counter: 49
Mileage: 164275 km
Date: 2014.12.19
Time: 00:27:36
Part No SW: 3C8 959 703 B HW: 1K0 959 795 Q
Component: J388 TUER-SG HL 0309
Revision: 43004101 Serial number: 00000000564583
Coding: 0001168
VCID: 313F1080BD291543EDD-8064
Reset counter: 9
Mileage: 164275 km
Date: 2014.12.19
Time: 00:11:58
02071 - Local Databus
Reset counter: 48
Mileage: 164279 km
Date: 2014.12.22
Time: 23:20:10
Component: RDK 0450
Coding: 0100101
Shop #: WSC 05311 000 08193
00667 - Ambient Temperature Signal
Fault Status: 01111000
Reset counter: 2
Mileage: 164275 km
Date: 2014.12.19
Time: 00:12:02
Part No SW: 3C8 959 704 B HW: 1K0 959 794 Q
Component: J388 TUER-SG HR 0309
Revision: 43004101 Serial number: 00000000584567
Coding: 0001168
VCID: 323D1F8CB82F2E5B947-8066
00935 - Electric Window Motor; Rear Right (V27)
Reset counter: 9
Mileage: 164275 km
Date: 2014.12.19
Time: 00:12:01
End----------(Elapsed Time: 01:44, VBatt start/end: 12.1V/12.1V)-----------
